how to set RSA private key into SE050
7,480 次查看
yang_lee
Hi everone, now I want to set RSA private key into SE050 but this function return fail: sss_key_store_set_key(). Is there a problem with the way I pass parameters to that function? Please help me.
My code below:
sss_status_t ex_sss_entry_user_set_privKey(ex_sss_boot_ctx_t *pCtx, uint32_t objectID, uint8_t *key_inject, size_t keyLen,)
  sss_status_t status = kStatus_SSS_Success;
    /* Policies for key */
    const sss_policy_u key_withPol = {
        .type = KPolicy_Asym_Key,
        /*Authentication object based on SE05X_AUTH*/
        .auth_obj_id = objectID,
        .policy = {
            /*Asymmetric key policy*/
            .asymmkey = {
                /*Policy for sign*/
                .can_Sign = 1,
                /*Policy for verify*/
                .can_Verify = 1,
                /*Policy for encrypt*/
                .can_Encrypt = 1,
                /*Policy for decrypt*/
                .can_Decrypt = 1,
                /*Policy for Key Derivation*/
                .can_KD = 1,
                /*Policy for wrapped object*/
                .can_Wrap = 1,
                /*Policy to re-write object*/
                .can_Write = 1,
                /*Policy for reading object*/
                .can_Read = 1,
                /*Policy to use object for attestation*/
                .can_Attest = 1,
    /* Common rules */
    const sss_policy_u common = {
        .type = KPolicy_Common,
        .policy = {
        .common = {
        /*Secure Messaging*/
        .req_Sm = 0,
        /*Policy to Delete object*/
        .can_Delete = 1,
        /*Forbid all operations on object*/
        .forbid_All = 0,
    /* create policy set */
    sss_policy_t policy_for_ec_key = {
        .nPolicies = 2,
        .policies = { &key_withPol, &common }
#ifdef GET_FREE_MEM
  sss_se05x_session_t *pSession = (sss_se05x_session_t *)&pCtx->session;
  uint16_t free_mem = 0;
#endif
  /* initialize keyObject with key store */
  status = sss_key_object_init(&key_object, &pCtx->ks);
  if (status != kStatus_SSS_Success)
    return status;  /* return error if can't initialize keyObject */
/* allocate/pre-provision memory for new key */
  status = sss_key_object_allocate_handle(&key_object,
                                          objectID,
                                          kSSS_KeyPart_Private,
                                          kSSS_CipherType_RSA_CRT,
                                          keyLen,
                                          kKeyObject_Mode_Persistent);
    return status;
/* moves data[] from memory to the destination key store */
  status = sss_key_store_set_key(&pCtx->ks, &key_object, key_inject, keyLen, keyLen * 8, &policy_for_ec_key, 0);
    return status;
  return status;   /* return successful if save data successfully */
标记 (1)
11 回复数
7,450 次查看
Kan_Li
Hi @yang_lee ,
Which SE05x variant are you playing with? Please kindly clarify.
Kan
7,441 次查看
yang_lee
Hi Kan,
Thanks for reply, I am using SE050C2HQ1 for my product. It seems to support RSA.
In addition, when I use OM-SE051 ARD-E Dev Kit to run seTool to set RSA key (using PlugAndTrust_v04.07.00_20250210), I get an error described as below image:
7,390 次查看
Kan_Li
Hi @yang_lee ,
Please try with RSA RAW instead, the RSA CTR doesn't accept the pri key value, please check the APDU spec for more details.
Kan
7,356 次查看
yang_lee
Hi @Kan_Li ,
I noticed that the code in seTool is using kSSS_CipherType_RSA_CRT.
And I also tried with raw data but still failed. The RSA key that I pass into the ex_sss_entry_user_set_privKey function is attached below:
Is there any problem with this raw key?
7,280 次查看
Kan_Li
Hi @yang_lee ,
How did you generate the RSA Key for SeTool externally?  Actually we have a demo of se05x_Delete_and_test_provision which provides an example for that purpose, please kindly refer to the following for details.
Kan
7,275 次查看
yang_lee
Hi @Kan_Li,
I generated the RSA key by Openssl.
I think I will use it with ECC key instead of RSA key because now I have successfully used it with ECC key. Thanks for your kind support.
Brg.
7,264 次查看
Kan_Li
Hi @yang_lee ,
Thanks for the clarification!
Please kindly have SeTool examples regarding RSA key pair as below:
openssl genpkey -algorithm RSA -out RsaKeyPair2048.pem -pkeyopt rsa_keygen_bits:2048
./seTool setRsaKeyPair 2048 0xF0000211 RsaKeyPair2048.pem none
Hope that helps,
Kan
7,234 次查看
yang_lee
Hi @Kan_Li,
Thanks for suggestions.
I built Plug & Trust MW version 04.07.00 and tried with SE051 but it still fails when using RSA key while succeeds with ECC key. Details are shown in the image below:
Brg.
标记 (1)
7,193 次查看
Kan_Li
Hi @yang_lee ,
Was the RSA key file generated with the following command?
Are you using OM-SE050E-ARD ? Indeed SE050E doesn't support RSA.
Kan
7,152 次查看
yang_lee
Hi @Kan_Li,
1. “Was the RSA key file generated with the following command?”
Yes, the RSA key file was generated using the command:
"openssl genpkey -algorithm RSA -out RsaKeyPair2048.pem -pkeyopt rsa_keygen_bits:2048."
2. “Are you using OM-SE050E-ARD? Indeed SE050E doesn't support RSA.”
No, I am using OM-SE051-ARD (SE051C2HQ1) instead of OM-SE050E-ARD. Actually I have both of these development kits and both build SE-PLUG-TRUST-MW_04.07.00 to run the examples with SE05x. Besides, the product I am developing is using SE050C2HQ1 (for both Android and Bare metal platform), everything seems to work fine except RSA.
Best regard.
6,995 次查看
Kan_Li
Hi @yang_lee ,
Sorry, my bad! Seems this tool has updated its parameters, please use the following command instead.
seTool setRSA 2048 0xF0000211 RsaKeyPair2048.pem none
Please kindly have my result as below:
Kan
%3CLINGO-SUB%20id%3D%22lingo-sub-2194325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E5%9C%A8%20SE050%20%E4%B8%AD%E8%AE%BE%E7%BD%AE%20RSA%20%E7%A7%81%E9%92%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%E7%8E%B0%E5%9C%A8%E6%88%91%E6%83%B3%E5%9C%A8%20SE050%20%E4%B8%AD%E8%AE%BE%E7%BD%AE%20RSA%20%E7%A7%81%E9%92%A5%EF%BC%8C%E4%BD%86%E8%BF%99%E4%B8%AA%E5%87%BD%E6%95%B0%E8%BF%94%E5%9B%9E%E5%A4%B1%E8%B4%A5%EF%BC%9Asss_key_store_set_key()%E3%80%82%20%E6%88%91%E5%90%91%E8%AF%A5%E5%87%BD%E6%95%B0%E4%BC%A0%E9%80%92%E5%8F%82%E6%95%B0%E7%9A%84%E6%96%B9%E5%BC%8F%E6%9C%89%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E8%AF%B7%E5%B8%AE%E5%B8%AE%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CDIV%3Esss_status_t%20ex_sss_entry_user_set_privKey(ex_sss_boot_ctx_t%20*pCtx%2C%20uint32_t%20objectID%2C%20uint8_t%20*key_inject%2C%20size_t%20keyLen%2C)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%20%20sss_status_t%20status%20%3D%20kStatus_SSS_Success%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%2F*%20%E5%85%B3%E9%94%AE%E5%AD%97%E7%9A%84%E6%94%BF%E7%AD%96%20*%2F%3C%2FDIV%3E%3CDIV%3E%20%20%20%20const%20sss_policy_u%20key_withPol%20%3D%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20.type%20%3D%20KPolicy_Asym_Key%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%2F*%20%E5%9F%BA%E4%BA%8E%20SE05X_AUTH%20%E7%9A%84%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%E5%AF%B9%E8%B1%A1*%2F%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20.auth_obj_id%20%3D%20objectID%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20.policy%20%3D%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%2F*%E9%9D%9E%E5%AF%B9%E7%A7%B0%E5%AF%86%E9%92%A5%E7%AD%96%E7%95%A5*%2F%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20.asymmkey%3D%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20%E6%A0%87%E8%AF%86%E6%94%BF%E7%AD%96*%2F%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20.can_Sign%3D%201%2C%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%E9%AA%8C%E8%AF%81%E6%94%BF%E7%AD%96*%2F%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20.can_Verify%3D%201%2C%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%E5%8A%A0%E5%AF%86%E7%AD%96%E7%95%A5*%2F%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20.can_Encrypt%3D%201%2C%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%E8%A7%A3%E5%AF%86%E7%AD%96%E7%95%A5*%2F%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20.can_Decrypt%3D%201%2C%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20%E5%AF%86%E9%92%A5%E8%A1%8D%E7%94%9F%E6%94%BF%E7%AD%96*%2F%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20.can_KD%3D%201%2C%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20%E5%B0%81%E8%A3%85%E5%AF%B9%E8%B1%A1%E7%9A%84%E7%AD%96%E7%95%A5*%2F%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20.can_Wrap%3D%201%2C%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%E9%87%8D%E5%86%99%E5%AF%B9%E8%B1%A1%E7%9A%84%E7%AD%96%E7%95%A5*%2F%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20.can_Write%3D%201%2C%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%E8%AF%BB%E5%8F%96%E5%AF%B9%E8%B1%A1%E7%9A%84%E7%AD%96%E7%95%A5*%2F%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20.can_Read%3D%201%2C%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%E4%BD%BF%E7%94%A8%E5%AF%B9%E8%B1%A1%E8%BF%9B%E8%A1%8C%E9%AA%8C%E8%AF%81%E7%9A%84%E6%94%BF%E7%AD%96*%2F%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20.can_Attest%3D%201%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%7D%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%2F*%20%E9%80%9A%E7%94%A8%E8%A7%84%E5%88%99%20*%2F%3C%2FDIV%3E%3CDIV%3E%20%20%20%20const%20sss_policy_u%20common%20%3D%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20.type%20%3D%20KPolicy_Common%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%2F*%20%E5%9F%BA%E4%BA%8E%20SE05X_AUTH%20%E7%9A%84%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%E5%AF%B9%E8%B1%A1*%2F%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20.auth_obj_id%20%3D%20objectID%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20.policy%20%3D%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20.common%20%3D%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%2F*%E5%AE%89%E5%85%A8%E4%BF%A1%E6%81%AF%E4%BC%A0%E9%80%92*%2F%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20.req_Sm%20%3D%200%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%2F*%E5%88%A0%E9%99%A4%E5%AF%B9%E8%B1%A1%E7%9A%84%E7%AD%96%E7%95%A5*%2F%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20.can_Delete%20%3D%201%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%2F*%E7%A6%81%E6%AD%A2%E5%AF%B9%E5%AF%B9%E8%B1%A1%E8%BF%9B%E8%A1%8C%E4%BB%BB%E4%BD%95%E6%93%8D%E4%BD%9C*%2F%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20.forbid_All%20%3D%200%E3%80%81%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%7D%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%2F*%20%E5%88%9B%E5%BB%BA%E7%AD%96%E7%95%A5%E9%9B%86%20*%2F%3C%2FDIV%3E%3CDIV%3E%20%20%20%20sss_policy_t%20policy_for_ec_key%20%3D%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20.nPolicies%20%3D%202%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20.policies%20%3D%20%7B%20%7B%26amp%3Bkey_withPol%2C%26amp%3Bcommon%20%7D%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%7D%3B%3C%2FDIV%3E%3CDIV%3E%23ifdef%20GET_FREE_MEM%3C%2FDIV%3E%3CDIV%3E%20%20sss_se05x_session_t%20*pSession%20%3D%20(sss_se05x_session_t%20*)%26amp%3BpCtx-%26gt%3Bsession%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20uint16_t%20free_mem%20%3D%200%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%23endif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20%2F*%20%E4%BD%BF%E7%94%A8%E5%AF%86%E9%92%A5%E5%AD%98%E5%82%A8%E5%88%9D%E5%A7%8B%E5%8C%96%20keyObject%20*%2F%3C%2FDIV%3E%3CDIV%3E%20%20status%20%3D%20sss_key_object_init(%26amp%3Bkey_object%2C%26amp%3BpCtx-%26gt%3Bks)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%E5%A6%82%E6%9E%9C%20(status%20!%3D%20kStatus_SSS_Success)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20return%20status%3B%20%2F*%20%E5%A6%82%E6%9E%9C%E6%97%A0%E6%B3%95%E5%88%9D%E5%A7%8B%E5%8C%96%20keyObject%EF%BC%8C%E5%88%99%E8%BF%94%E5%9B%9E%E9%94%99%E8%AF%AF%20*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F*%20%E4%B8%BA%E6%96%B0%E5%AF%86%E9%92%A5%E5%88%86%E9%85%8D%2F%E9%85%8D%E7%BD%AE%E5%86%85%E5%AD%98%20*%2F%3C%2FDIV%3E%3CDIV%3E%20%20status%20%3D%20sss_key_object_allocate_handle(%26amp%3Bkey_object%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20objectID%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20kSSS_KeyPart_Private%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20kSSS_CipherType_RSA_CRT%E3%80%81%20%20%20%20%20%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20keyLen%E3%80%81%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20kKeyObject_Mode_Persistent%EF%BC%89%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%E5%A6%82%E6%9E%9C%20(status%20!%3D%20kStatus_SSS_Success)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%E8%BF%94%E5%9B%9E%E7%8A%B6%E6%80%81%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F*%20%E5%B0%86%E5%86%85%E5%AD%98%E4%B8%AD%E7%9A%84%E6%95%B0%E6%8D%AE%5B%5D%E7%A7%BB%E8%87%B3%E7%9B%AE%E6%A0%87%E6%8C%89%E9%94%AE%E5%AD%98%E5%82%A8%E5%8C%BA%20*%2F%3C%2FDIV%3E%3CDIV%3E%20%20status%20%3D%20sss_key_store_set_key(%26amp%3BpCtx-%26gt%3Bks%2C%26amp%3Bkey_object%2C%20key_inject%2C%20keyLen%2C%20keyLen%20*%208%2C%26amp%3Bpolicy_for_ec_key%2C%200)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%E5%A6%82%E6%9E%9C%20(status%20!%3D%20kStatus_SSS_Success)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20%E8%BF%94%E5%9B%9E%E7%8A%B6%E6%80%81%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20return%20status%3B%20%2F*%20%E5%A6%82%E6%9E%9C%E6%88%90%E5%8A%9F%E4%BF%9D%E5%AD%98%E6%95%B0%E6%8D%AE%EF%BC%8C%E5%88%99%E8%BF%94%E5%9B%9E%E6%88%90%E5%8A%9F%20*%2F%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2194325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESE050%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2200443%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20how%20to%20set%20RSA%20private%20key%20into%20SE050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2200443%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252826%22%20target%3D%22_blank%22%3E%40yang_lee%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%AF%B9%E4%B8%8D%E8%B5%B7%EF%BC%8C%E6%88%91%E7%9A%84%E9%94%99%EF%BC%81%E8%AF%A5%E5%B7%A5%E5%85%B7%E4%BC%BC%E4%B9%8E%E6%9B%B4%E6%96%B0%E4%BA%86%E5%8F%82%E6%95%B0%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E4%BB%A3%E6%9B%BF%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EseTool%20setRSA%202048%200xF0000211%20RsaKeyPair2048.pem%20none%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E8%AF%B7%E5%B0%86%E6%88%91%E7%9A%84%E7%BB%93%E6%9E%9C%E5%A1%AB%E5%86%99%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kan_Li_0-1762482313155.png%22%20style%3D%22width%3A%20639px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1762482313155.png%22%20style%3D%22width%3A%20639px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F364354i646EB4F61D3333B3%2Fimage-dimensions%2F639x214%3Fv%3Dv2%22%20width%3D%22639%22%20height%3D%22214%22%20role%3D%22button%22%20title%3D%22Kan_Li_0-1762482313155.png%22%20alt%3D%22Kan_Li_0-1762482313155.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2199611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20how%20to%20set%20RSA%20private%20key%20into%20SE050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2199611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%3CSTRONG%3E1.%22RSA%20%E5%AF%86%E9%92%A5%E6%96%87%E4%BB%B6%E6%98%AF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E7%94%9F%E6%88%90%E7%9A%84%E5%90%97%EF%BC%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%E6%98%AF%EF%BC%8CRSA%20%E5%AF%86%E9%92%A5%E6%96%87%E4%BB%B6%E6%98%AF%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E7%94%9F%E6%88%90%E7%9A%84%EF%BC%9A%3CBR%20%2F%3E%22%20openssl%20genpkey%20-algorithm%20RSA%20-out%20RsaKeyPair2048.pem%20-pkeyopt%20rsa_keygen_bits%3A2048%E3%80%82%22%3C%2FP%3E%3CP%3E%3CSTRONG%3E2.%22%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20OM-SE050E-ARD%20%E5%90%97%EF%BC%9F%E4%BA%8B%E5%AE%9E%E4%B8%8A%20SE050E%3C%2FSTRONG%3E%E4%B8%8D%E6%94%AF%E6%8C%81%20RSA%E3%80%82%22%3CBR%20%2F%3E%E4%B8%8D%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20OM-SE051-ARD%20(SE051C2HQ1)%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20OM-SE050E-ARD%E3%80%82%E5%85%B6%E5%AE%9E%E6%88%91%E6%9C%89%E8%BF%99%E4%B8%A4%E4%B8%AA%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%EF%BC%8C%E8%80%8C%E4%B8%94%E9%83%BD%E7%89%88%E6%9C%AC%E4%BA%86%20SE-PLUG-TRUST-MW_04.07.00%20%E6%9D%A5%E4%BD%BF%E7%94%A8%20SE05x%20%E8%BF%90%E8%A1%8C%E7%A4%BA%E4%BE%8B%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E5%BC%80%E5%8F%91%E7%9A%84%E4%BA%A7%E5%93%81%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20SE050C2HQ1%EF%BC%88%E9%80%82%E7%94%A8%E4%BA%8E%20Android%20%E5%92%8C%E8%A3%B8%E6%9C%BA%E5%B9%B3%E5%8F%B0%EF%BC%89%EF%BC%8C%E9%99%A4%E4%BA%86%20RSA%EF%BC%8C%E5%85%B6%E4%BB%96%E4%B8%80%E5%88%87%E4%BC%BC%E4%B9%8E%E9%83%BD%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E9%A2%82%E5%95%86%E7%A5%BA%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198809%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20how%20to%20set%20RSA%20private%20key%20into%20SE050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198809%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252826%22%20target%3D%22_blank%22%3E%40yang_lee%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERSA%20%E5%AF%86%E9%92%A5%E6%96%87%E4%BB%B6%E6%98%AF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E7%94%9F%E6%88%90%E7%9A%84%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CPRE%20class%3D%22bp-text%20bp-text-plain%20hljs%20bp-is-scrollable%22%20tabindex%3D%220%22%3E%3CCODE%20class%3D%22bp-text-code%20txt%22%3Eopenssl%20genpkey%20-algorithm%20RSA%20-out%20RsaKeyPair2048.pem%20-pkeyopt%20rsa_keygen_bits%3A2048%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20OM-SE050E-ARD%20%E5%90%97%EF%BC%9F%E4%BA%8B%E5%AE%9E%E4%B8%8A%EF%BC%8CSE050E%20%E4%B8%8D%E6%94%AF%E6%8C%81%20RSA%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20how%20to%20set%20RSA%20private%20key%20into%20SE050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198195%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%9E%84%E5%BB%BA%E4%BA%86%20Plug%20%26amp%3B%20Trust%20MW%20%E7%89%88%E6%9C%AC%2004.07.00%20%E5%B9%B6%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20SE051%EF%BC%8C%E4%BD%86%E6%98%AF%E4%BD%BF%E7%94%A8%20RSA%20%E5%AF%86%E9%92%A5%E6%97%B6%E5%AE%83%E4%BB%8D%E7%84%B6%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%80%8C%E4%BD%BF%E7%94%A8%20ECC%20%E5%AF%86%E9%92%A5%E5%8D%B4%E6%88%90%E5%8A%9F%E4%BA%86%E3%80%82%E8%AF%A6%E6%83%85%E5%A6%82%E4%B8%8B%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22yang_lee_1-1762248358170.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22yang_lee_1-1762248358170.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363906iF84F7EE2F0BB0D9E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22yang_lee_1-1762248358170.png%22%20alt%3D%22yang_lee_1-1762248358170.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBrg.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2197860%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20how%20to%20set%20RSA%20private%20key%20into%20SE050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197860%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252826%22%20target%3D%22_blank%22%3E%40yang_lee%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E6%BE%84%E6%B8%85%EF%BC%81%20%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AF%B7%E5%8F%82%E8%80%83%E4%BB%A5%E4%B8%8B%E6%9C%89%E5%85%B3%20RSA%20%E5%AF%86%E9%92%A5%E5%AF%B9%E7%9A%84%20SeTool%20%E7%A4%BA%E4%BE%8B%EF%BC%9A%3C%2FP%3E%0A%3CPRE%20class%3D%22bp-text%20bp-text-plain%20hljs%20bp-is-scrollable%22%20tabindex%3D%220%22%3E%3CCODE%20class%3D%22bp-text-code%20txt%22%3Eopenssl%20genpkey%20-algorithm%20RSA%20-out%20RsaKeyPair2048.pem%20-pkeyopt%20rsa_keygen_bits%3A2048%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CPRE%20class%3D%22bp-text%20bp-text-plain%20hljs%20bp-is-scrollable%22%20tabindex%3D%220%22%3E%3CCODE%20class%3D%22bp-text-code%20txt%22%3E.%2FseTool%20setRsaKeyPair%202048%200xF0000211%20RsaKeyPair2048.pem%20%E6%97%A0%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E4%BD%A0%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2197337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20how%20to%20set%20RSA%20private%20key%20into%20SE050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E7%94%A8%20Openssl%20%E7%94%9F%E6%88%90%E4%BA%86%20RSA%20%E5%AF%86%E9%92%A5%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E6%88%91%E4%BC%9A%E4%BD%BF%E7%94%A8%20ECC%20%E5%AF%86%E9%92%A5%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20RSA%20%E5%AF%86%E9%92%A5%EF%BC%8C%E5%9B%A0%E4%B8%BA%E7%8E%B0%E5%9C%A8%E6%88%91%E5%B7%B2%E7%BB%8F%E6%88%90%E5%8A%9F%E5%9C%B0%E4%BD%BF%E7%94%A8%E4%BA%86%20ECC%20%E5%AF%86%E9%92%A5%E3%80%82%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%A4%A7%E5%8A%9B%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3EBrg.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2197281%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20how%20to%20set%20RSA%20private%20key%20into%20SE050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197281%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252826%22%20target%3D%22_blank%22%3E%40yang_lee%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E6%98%AF%E5%A6%82%E4%BD%95%E4%BB%8E%E5%A4%96%E9%83%A8%E4%B8%BA%20SeTool%20%E7%94%9F%E6%88%90%20RSA%20%E5%AF%86%E9%92%A5%E7%9A%84%EF%BC%9F%20%E5%AE%9E%E9%99%85%E4%B8%8A%EF%BC%8C%E6%88%91%E4%BB%AC%E6%9C%89%E4%B8%80%E4%B8%AA%20se05x_Delete_and_test_provision%20%E6%BC%94%E7%A4%BA%EF%BC%8C%E6%8F%90%E4%BE%9B%E4%BA%86%E4%B8%80%E4%B8%AA%E8%BF%99%E6%96%B9%E9%9D%A2%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%8C%E8%AF%A6%E6%83%85%E8%AF%B7%E5%8F%82%E8%80%83%E4%B8%8B%E6%96%87%E3%80%82%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorKan_Li_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2196641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20how%20to%20set%20RSA%20private%20key%20into%20SE050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2196641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%20seTool%20%E4%B8%AD%E7%9A%84%E4%BB%A3%E7%A0%81%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20kSSS_CipherType_RSA_CRT%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22yang_lee_0-1761913504498.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22yang_lee_0-1761913504498.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363508i5047F9AF63F5ACFF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22yang_lee_0-1761913504498.png%22%20alt%3D%22yang_lee_0-1761913504498.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E4%B9%9F%E8%AF%95%E8%BF%87%E4%BD%BF%E7%94%A8%E5%8E%9F%E5%A7%8B%E6%95%B0%E6%8D%AE%EF%BC%8C%E4%BD%86%E8%BF%98%E6%98%AF%E5%A4%B1%E8%B4%A5%E4%BA%86%E3%80%82%E6%88%91%E4%BC%A0%E5%85%A5%20ex_sss_entry_user_set_privKey%20%E5%87%BD%E6%95%B0%E7%9A%84%20RSA%20%E5%AF%86%E9%92%A5%E9%99%84%E5%9C%A8%E4%B8%8B%E9%9D%A2%EF%BC%9A%3C%2FP%3E%3CP%3E%E8%BF%99%E4%B8%AA%E5%8E%9F%E5%A7%8B%E5%AF%86%E9%92%A5%E6%9C%89%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20how%20to%20set%20RSA%20private%20key%20into%20SE050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252826%22%20target%3D%22_blank%22%3E%40yang_lee%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AF%B7%E6%94%B9%E7%94%A8%20RSA%20RAW%EF%BC%8CRSA%20CTR%20%E4%B8%8D%E6%8E%A5%E5%8F%97%20pri%20%E5%AF%86%E9%92%A5%E5%80%BC%EF%BC%8C%E8%AF%A6%E6%83%85%E8%AF%B7%E6%9F%A5%E7%9C%8B%20APDU%20%E8%A7%84%E8%8C%83%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20how%20to%20set%20RSA%20private%20key%20into%20SE050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194854%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8CKan%E3%80%81%20%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%8C%E6%88%91%E7%9A%84%E4%BA%A7%E5%93%81%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20SE050C2HQ1%E3%80%82%20%E5%AE%83%E4%BC%BC%E4%B9%8E%E6%94%AF%E6%8C%81%20RSA%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22yang_lee_0-1761720445844.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22yang_lee_0-1761720445844.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363017i35EF00EEFE24E0BE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22yang_lee_0-1761720445844.png%22%20alt%3D%22yang_lee_0-1761720445844.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%20OM-SE051%20ARD-E%20Dev%20Kit%20%E8%BF%90%E8%A1%8C%20seTool%20%E8%AE%BE%E7%BD%AE%20RSA%20%E5%AF%86%E9%92%A5%E6%97%B6%EF%BC%88%E4%BD%BF%E7%94%A8%20PlugAndTrust_v04.07.00_20250210%EF%BC%89%E3%80%81%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E5%A6%82%E4%B8%8B%E5%9B%BE%E6%89%80%E7%A4%BA%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22yang_lee_1-1761720788886.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22yang_lee_1-1761720788886.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363018iC6E2DA9B762BCA05%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22yang_lee_1-1761720788886.png%22%20alt%3D%22yang_lee_1-1761720788886.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20how%20to%20set%20RSA%20private%20key%20into%20SE050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252826%22%20target%3D%22_blank%22%3E%40yang_lee%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%20SE05x%20%E5%8F%98%E4%BD%93%EF%BC%9F%E8%AF%B7%E4%BA%88%E4%BB%A5%E6%BE%84%E6%B8%85%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
