SE050C2HQ1 middle ware integration issue
daisuke2
I am trying to integrate middle ware for SE050C2HQ1 on imx8mp custom board.
I used 'SE-PLUG-TRUST-MW_04.07.01.zip' from nxp portal site and build with cmake flag as bellow
-DCMAKE_BUILD_TYPE=Debug \
-DPTMW_Host=iMXLinux -DPTMW_HostCrypto=OPENSSL -DPTMW_SMCOM=T1oI2C \
-DPTMW_SE05X_Auth=PlatfSCP03 -DPTMW_SCP=SCP03_SSS -DPTMW_Applet=SE05X_A \
-DPTMW_SE05X_Ver=07_02
when i trying to run 'ex_ecc', i am keep getting error like bellow
----log----------------------
App :INFO :Running ex_ecc
App :INFO :Using PortName='/dev/i2c-2' (CLI)
App :INFO :PlugAndTrust_v04.07.01_20250519
App :WARN :Using SCP03 keys from:'/etc/se05x/scp03_keys.bin' (ENV=EX_SSS_BOOT_SCP03_PATH)
App :ERROR:Unknown key type «Í«Í«Í«Í«Í«Í«Í[m
sss :INFO :atr (Len=35)
01 A0 00 00 03 96 04 03 E8 00 FE 02 0B 03 E8 00
01 00 00 00 00 64 13 88 0A 00 65 53 45 30 35 31
00 00 00
sss :INFO :Newer version of Applet Found
sss :INFO :Compiled for 0x70200. Got newer 0x70216
scp :WARN :nxEnsure:'status == kStatus_SSS_Success' failed. At Line:148 Function:nxScp03_AuthenticateChannel
sss :ERROR:Could not set SCP03 Secure Channel
App :ERROR:sss_session_open failed
App :ERROR:ex_sss_session_open Failed
App :ERROR:!ERROR! ret != 0.
I thought that my scp3-key 'scp03_keys.bin'  might be problem, so i tried 'se05x_MandatePlatformSCP' and 'se05x_Delete_and_test_provision'.
But  keep getting "unknown key type" error and fails.
It seems that Applet in SE050C2H is new than "SE-PLUG-TRUST-MW_04.07.01.zip".
Is there any newer "SE-PLUG-TRUST-MW_04.07.xx.zip" available?
Or it could be different issue other than Applet version mismatch ?
Best Regards
daisuke
daisuke2
One correction. I was wrong. Secure IC is SE052F2HN2 not SE050C2HQ1 .
Kan_Li
Hi @daisuke2 ,
Please kindly refer to table 3 in https://www.nxp.com/docs/en/application-note/AN14028.pdf for details regarding the Cmake-settings for SE052F.
Hope that helps,
Kan
daisuke2
Hi Kan,
I fixed the cmake flag  SE05X_C   and define SSS_PFSCP_ENABLE_SE052_B501=1 in header file.
But it still can't establish secure channel.
-----log----------
oot@harmonia-mvp1-dvt-machine:~# se05x_GetInfo /dev/i2c-2
App :INFO :Running se05x_GetInfo
App :INFO :Using default PlatfSCP03 keys. You can use keys from file using ENV=EX_SSS_BOOT_SCP03_PATH
00 00 00
I tried "DPTMW_SE05X_Auth=None". This did not work before, but
Is it possible to control SE052F2HN2  without scp3 secure channel?
Does this applet version mismatch mater at all?
daisuke
Kan_Li
Hi @daisuke2 ,
How did you change the default platformSCP keys for SE052F? It is not in the head file, it is in the fsl_sss_ftr.h.in file including options to select one of the predefined default
Platform SCP keys. This file is located in: simw-top/sss/inc.
Alternatively, you may set up a file to contain the default platformSCP keys for SE052F. Please refer to SE-PLUG-TRUST-MW_04.07.01/simw-top/doc/appendix/platfscp.html for more details.
PlatformSCP is mandatory for SE052F2 as required by FIPS certification.
Does this applet version mismatch mater at all? - I didn't find any mismatch info from the log. what are you referring to?
Kan
daisuke2
Hi Kan,
Ok, let me check the SCP3 key in embedded.
Applet version mismatch thing is like
---log-------
00 00 00
daisuke
Kan_Li
Hi @daisuke2 ,
The following is the default platformSCP keys for SE052F, was it the same as yours? please kindly refer to https://www.nxp.com/docs/en/application-note/AN14277.pdf for more details.
Applet version mismatch info like  "sss :INFO :Compiled for 0x70200. Got newer 0x70216" doesn't matter at all.
Kan
daisuke2
Hi Kan,
Tried 10.11 Using own Platform SCP03 Keys.
Looks does not work either. somehow keep getting 'Unknown key type' error when i setup local key file.
---log----
root@harmonia-mvp1-dvt-machine:~# export EX_SSS_BOOT_SCP03_PATH=/etc/se05x/plain_scp.txt
root@harmonia-mvp1-dvt-machine:~# ex_ecc /dev/i2c-2
App :WARN :Using SCP03 keys from:'/etc/se05x/plain_scp.txt' (ENV=EX_SSS_BOOT_SCP03_PATH)
00 00 00
daisuke
%3CLINGO-SUB%20id%3D%22lingo-sub-2197745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3C%2FP%3E%3CP%3EI%20am%20trying%20to%20integrate%20middle%20ware%20for%20SE050C2HQ1%20on%20imx8mp%20custom%20board.%3C%2FP%3E%3CP%3EI%20used%20'SE-PLUG-TRUST-MW_04.07.01.zip'%20from%20nxp%20portal%20site%20and%20build%20with%20cmake%20flag%20as%20bellow%3C%2FP%3E%3CP%3E---------------------------%3C%2FP%3E%3CP%3E-DCMAKE_BUILD_TYPE%3DDebug%20%5C%3CBR%20%2F%3E-DPTMW_Host%3DiMXLinux%26nbsp%3B-DPTMW_HostCrypto%3DOPENSSL%26nbsp%3B-DPTMW_SMCOM%3DT1oI2C%20%5C%3CBR%20%2F%3E-DPTMW_SE05X_Auth%3DPlatfSCP03%26nbsp%3B-DPTMW_SCP%3DSCP03_SSS%26nbsp%3B-DPTMW_Applet%3DSE05X_A%20%5C%3CBR%20%2F%3E-DPTMW_SE05X_Ver%3D07_02%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ewhen%20i%20trying%20to%20run%20'ex_ecc'%2C%20i%20am%20keep%20getting%20error%20like%20bellow%3C%2FP%3E%3CP%3E----log----------------------%3C%2FP%3E%3CP%3EApp%20%3AINFO%20%3ARunning%20ex_ecc%3CBR%20%2F%3EApp%20%3AINFO%20%3AUsing%20PortName%3D'%2Fdev%2Fi2c-2'%20(CLI)%3CBR%20%2F%3EApp%20%3AINFO%20%3APlugAndTrust_v04.07.01_20250519%3CBR%20%2F%3EApp%20%3AWARN%20%3AUsing%20SCP03%20keys%20from%3A'%2Fetc%2Fse05x%2Fscp03_keys.bin'%20(ENV%3DEX_SSS_BOOT_SCP03_PATH)%3CBR%20%2F%3EApp%20%3AERROR%3AUnknown%20key%20type%20%C2%AB%C3%8D%C2%AB%C3%8D%C2%AB%C3%8D%C2%AB%C3%8D%C2%AB%C3%8D%C2%AB%C3%8D%C2%AB%C3%8D%5Bm%3CBR%20%2F%3Esss%20%3AINFO%20%3Aatr%20(Len%3D35)%3CBR%20%2F%3E01%20A0%2000%2000%2003%2096%2004%2003%20E8%2000%20FE%2002%200B%2003%20E8%2000%3CBR%20%2F%3E01%2000%2000%2000%2000%2064%2013%2088%200A%2000%2065%2053%2045%2030%2035%2031%3CBR%20%2F%3E00%2000%2000%3CBR%20%2F%3Esss%20%3AINFO%20%3ANewer%20version%20of%20Applet%20Found%3CBR%20%2F%3Esss%20%3AINFO%20%3ACompiled%20for%200x70200.%20Got%20newer%200x70216%3CBR%20%2F%3Escp%20%3AWARN%20%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%20failed.%20At%20Line%3A148%20Function%3AnxScp03_AuthenticateChannel%3CBR%20%2F%3Esss%20%3AERROR%3ACould%20not%20set%20SCP03%20Secure%20Channel%3CBR%20%2F%3EApp%20%3AERROR%3Asss_session_open%20failed%3CBR%20%2F%3EApp%20%3AERROR%3Aex_sss_session_open%20Failed%3CBR%20%2F%3EApp%20%3AERROR%3A!ERROR!%20ret%20!%3D%200.%3C%2FP%3E%3CP%3E------------------------------------%3C%2FP%3E%3CP%3EI%20thought%20that%20my%20scp3-key%20'scp03_keys.bin'%26nbsp%3B%20might%20be%20problem%2C%20so%20i%20tried%20'se05x_MandatePlatformSCP'%20and%20'se05x_Delete_and_test_provision'.%3C%2FP%3E%3CP%3EBut%26nbsp%3B%20keep%20getting%20%22unknown%20key%20type%22%20error%20and%20fails.%3C%2FP%3E%3CP%3EIt%20seems%20that%20Applet%20in%20SE050C2H%20is%20new%20than%20%22SE-PLUG-TRUST-MW_04.07.01.zip%22.%3C%2FP%3E%3CP%3EIs%20there%20any%20newer%20%22SE-PLUG-TRUST-MW_04.07.xx.zip%22%20available%3F%3C%2FP%3E%3CP%3EOr%20it%20could%20be%20different%20issue%20other%20than%20Applet%20version%20mismatch%20%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBest%20Regards%3C%2FP%3E%3CP%3Edaisuke%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2197745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESE050%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2199852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2199852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F200599%22%20target%3D%22_blank%22%3E%40daisuke2%3C%2FA%3E%26nbsp%3B%EF%BC%8C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThe%20following%20is%20the%20default%20platformSCP%20keys%20for%20SE052F%2C%20was%20it%20the%20same%20as%20yours%3F%20please%20kindly%20refer%20to%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14277.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14277.pdf%3C%2FA%3E%26nbsp%3Bfor%20more%20details.%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kan_Li_0-1762414176073.png%22%20style%3D%22width%3A%20645px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1762414176073.png%22%20style%3D%22width%3A%20645px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F364243iF5246D5B23AA22BE%2Fimage-dimensions%2F645x128%3Fv%3Dv2%22%20width%3D%22645%22%20height%3D%22128%22%20role%3D%22button%22%20title%3D%22Kan_Li_0-1762414176073.png%22%20alt%3D%22Kan_Li_0-1762414176073.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EApplet%20version%20mismatch%20info%20like%26nbsp%3B%20%22%3CSPAN%3Esss%20%3AINFO%20%3ACompiled%20for%200x70200.%20Got%20newer%200x70216%3C%2FSPAN%3E%22%20doesn't%20matter%20at%20all.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3CBR%20%2F%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2199036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2199036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Kan%2C%3C%2FP%3E%3CP%3ETried%2010.11%20Using%20own%20Platform%20SCP03%20Keys.%3C%2FP%3E%3CP%3ELooks%20does%20not%20work%20either.%20somehow%20keep%20getting%20'Unknown%20key%20type'%20error%20when%20i%20setup%20local%20key%20file.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E---log----%3C%2FP%3E%3CP%3Eroot%40harmonia-mvp1-dvt-machine%3A~%23%20export%20EX_SSS_BOOT_SCP03_PATH%3D%2Fetc%2Fse05x%2Fplain_scp.txt%3CBR%20%2F%3Eroot%40harmonia-mvp1-dvt-machine%3A~%23%20ex_ecc%20%2Fdev%2Fi2c-2%3CBR%20%2F%3EApp%20%3AINFO%20%3ARunning%20ex_ecc%3CBR%20%2F%3EApp%20%3AINFO%20%3AUsing%20PortName%3D'%2Fdev%2Fi2c-2'%20(CLI)%3CBR%20%2F%3EApp%20%3AINFO%20%3APlugAndTrust_v04.07.01_20250519%3CBR%20%2F%3EApp%20%3AWARN%20%3AUsing%20SCP03%20keys%20from%3A'%2Fetc%2Fse05x%2Fplain_scp.txt'%20(ENV%3DEX_SSS_BOOT_SCP03_PATH)%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3EApp%20%3AERROR%3AUnknown%20key%20type%3C%2FFONT%3E%3CBR%20%2F%3Esss%20%3AINFO%20%3Aatr%20(Len%3D35)%3CBR%20%2F%3E01%20A0%2000%2000%2003%2096%2004%2003%20E8%2000%20FE%2002%200B%2003%20E8%2000%3CBR%20%2F%3E01%2000%2000%2000%2000%2064%2013%2088%200A%2000%2065%2053%2045%2030%2035%2031%3CBR%20%2F%3E00%2000%2000%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3Esss%20%3AINFO%20%3ANewer%20version%20of%20Applet%20Found%3C%2FFONT%3E%3CBR%20%2F%3Esss%20%3AINFO%20%3ACompiled%20for%200x70200.%20Got%20newer%200x70216%3CBR%20%2F%3Escp%20%3AWARN%20%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%20failed.%20At%20Line%3A148%20Function%3AnxScp03_AuthenticateChannel%3CBR%20%2F%3Esss%20%3AERROR%3ACould%20not%20set%20SCP03%20Secure%20Channel%3CBR%20%2F%3EApp%20%3AERROR%3Asss_session_open%20failed%3CBR%20%2F%3EApp%20%3AERROR%3Aex_sss_session_open%20Failed%3CBR%20%2F%3EApp%20%3AERROR%3A!ERROR!%20ret%20!%3D%200.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3CP%3Edaisuke%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Kan%2C%3C%2FP%3E%3CP%3EOk%2C%20let%20me%20check%20the%20SCP3%20key%20in%20embedded.%3C%2FP%3E%3CP%3EApplet%20version%20mismatch%20thing%20is%20like%3C%2FP%3E%3CP%3E---log-------%3C%2FP%3E%3CP%3EApp%20%3AINFO%20%3ARunning%20ex_ecc%3CBR%20%2F%3EApp%20%3AINFO%20%3AUsing%20PortName%3D'%2Fdev%2Fi2c-2'%20(CLI)%3CBR%20%2F%3EApp%20%3AINFO%20%3APlugAndTrust_v04.07.01_20250519%3CBR%20%2F%3EApp%20%3AINFO%20%3AUsing%20default%20PlatfSCP03%20keys.%20You%20can%20use%20keys%20from%20file%20using%20ENV%3DEX_SSS_BOOT_SCP03_PATH%3CBR%20%2F%3Esss%20%3AINFO%20%3Aatr%20(Len%3D35)%3CBR%20%2F%3E01%20A0%2000%2000%2003%2096%2004%2003%20E8%2000%20FE%2002%200B%2003%20E8%2000%3CBR%20%2F%3E01%2000%2000%2000%2000%2064%2013%2088%200A%2000%2065%2053%2045%2030%2035%2031%3CBR%20%2F%3E00%2000%2000%3CBR%20%2F%3Esss%20%3AINFO%20%3ANewer%20version%20of%20Applet%20Found%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3Esss%20%3AINFO%20%3ACompiled%20for%200x70200.%20Got%20newer%200x70216%3C%2FFONT%3E%3CBR%20%2F%3Escp%20%3AWARN%20%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%20failed.%20At%20Line%3A148%20Function%3AnxScp03_AuthenticateChannel%3CBR%20%2F%3Esss%20%3AERROR%3ACould%20not%20set%20SCP03%20Secure%20Channel%3CBR%20%2F%3EApp%20%3AERROR%3Asss_session_open%20failed%3CBR%20%2F%3EApp%20%3AERROR%3Aex_sss_session_open%20Failed%3CBR%20%2F%3EApp%20%3AERROR%3A!ERROR!%20ret%20!%3D%200.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3CP%3Edaisuke%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198804%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198804%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F200599%22%20target%3D%22_blank%22%3E%40daisuke2%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHow%20did%20you%20change%20the%20default%20platformSCP%20keys%20for%20SE052F%3F%20It%20is%20not%20in%20the%20head%20file%2C%20it%20is%20in%26nbsp%3Bthe%20fsl_sss_ftr.h.in%20file%20including%20options%20to%20select%20one%20of%20the%20predefined%20default%3CBR%20%2F%3EPlatform%20SCP%20keys.%20This%20file%20is%20located%20in%3A%20simw-top%2Fsss%2Finc.%3CBR%20%2F%3EAlternatively%2C%20you%20may%20set%20up%20a%20file%20to%20contain%20the%20default%20platformSCP%20keys%20for%20SE052F.%20Please%20refer%20to%26nbsp%3BSE-PLUG-TRUST-MW_04.07.01%2Fsimw-top%2Fdoc%2Fappendix%2Fplatfscp.html%20for%20more%20details.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EPlatformSCP%20is%20mandatory%20for%20SE052F2%20as%20required%20by%20FIPS%20certification.%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EDoes%20this%20applet%20version%20mismatch%20mater%20at%20all%3F%20-%20I%20didn't%20find%20any%20mismatch%20info%20from%20the%20log.%20what%20are%20you%20referring%20to%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3CBR%20%2F%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198400%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198400%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Kan%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20fixed%20the%20cmake%20flag%26nbsp%3B%20SE05X_C%26nbsp%3B%20%26nbsp%3Band%20define%20SSS_PFSCP_ENABLE_SE052_B501%3D1%20in%20header%20file.%3C%2FP%3E%3CP%3EBut%20it%20still%20can't%20establish%20secure%20channel.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E-----log----------%3C%2FP%3E%3CP%3Eoot%40harmonia-mvp1-dvt-machine%3A~%23%20se05x_GetInfo%20%2Fdev%2Fi2c-2%3CBR%20%2F%3EApp%20%3AINFO%20%3ARunning%20se05x_GetInfo%3CBR%20%2F%3EApp%20%3AINFO%20%3AUsing%20PortName%3D'%2Fdev%2Fi2c-2'%20(CLI)%3CBR%20%2F%3EApp%20%3AINFO%20%3APlugAndTrust_v04.07.01_20250519%3CBR%20%2F%3EApp%20%3AINFO%20%3AUsing%20default%20PlatfSCP03%20keys.%20You%20can%20use%20keys%20from%20file%20using%20ENV%3DEX_SSS_BOOT_SCP03_PATH%3CBR%20%2F%3Esss%20%3AINFO%20%3Aatr%20(Len%3D35)%3CBR%20%2F%3E01%20A0%2000%2000%2003%2096%2004%2003%20E8%2000%20FE%2002%200B%2003%20E8%2000%3CBR%20%2F%3E01%2000%2000%2000%2000%2064%2013%2088%200A%2000%2065%2053%2045%2030%2035%2031%3CBR%20%2F%3E00%2000%2000%3CBR%20%2F%3Escp%20%3AWARN%20%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%20failed.%20At%20Line%3A148%20Function%3AnxScp03_AuthenticateChannel%3CBR%20%2F%3Esss%20%3AERROR%3ACould%20not%20set%20SCP03%20Secure%20Channel%3CBR%20%2F%3EApp%20%3AERROR%3Asss_session_open%20failed%3CBR%20%2F%3EApp%20%3AERROR%3Aex_sss_session_open%20Failed%3CBR%20%2F%3EApp%20%3AERROR%3A!ERROR!%20ret%20!%3D%200.%3C%2FP%3E%3CP%3E--------------------------------%3C%2FP%3E%3CP%3EI%20tried%20%22DPTMW_SE05X_Auth%3DNone%22.%20This%20did%20not%20work%20before%2C%20but%3C%2FP%3E%3CP%3EIs%20it%20possible%20to%20control%20SE052F2HN2%20%26nbsp%3Bwithout%20scp3%20secure%20channel%3F%3C%2FP%3E%3CP%3EDoes%20this%20applet%20version%20mismatch%20mater%20at%20all%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3CP%3Edaisuke%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2197846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F200599%22%20target%3D%22_blank%22%3E%40daisuke2%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EPlease%20kindly%20refer%20to%20table%203%20in%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14028.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14028.pdf%3C%2FA%3E%26nbsp%3Bfor%20details%20regarding%20the%20Cmake-settings%20for%20SE052F.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHope%20that%20helps%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3CBR%20%2F%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2197776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE050C2HQ1%20%20middle%20ware%20integration%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3C%2FP%3E%3CP%3EOne%20correction.%20I%20was%20wrong.%20Secure%20IC%20is%26nbsp%3BSE052F2HN2%20not%26nbsp%3BSE050C2HQ1%20.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
