SE051C2 I2C address change
1,716 次查看
mfgbasti
is it possible to change the default I2C address 0x48 of the SE051?
In https://community.nxp.com/t5/Secure-Authentication/SE050-change-default-I2C-address/m-p/1269078 the solution is a link to the AN13015 which isn't downloadable.
1,706 次查看
Kan_Li
Hi @mfgbasti ,
AN13015 has been moved to docstore/secure file only, as it contains some info under NDA. Please kindly sign NDA with NXP at first and then request it from the doc store/secure file. Please kindly refer to the following for details.
1. How to request NDA online:
2. How to request docs from secure file:
https://www.nxp.com.cn/docs/en/user-guide/nxp-secure-access-rights-registration.pdf
Kan
1,707 次查看
Kan_Li
Hi @mfgbasti ,
Kan
