PCF7961 Datasheet
10,097件の閲覧回数
ivanadam
I wish to design a project using PCF7961 but I can't find any documentation about its pinout or electrical characteristics. Do I need to buy the datasheet? What do I have to do?
Thanks!
10,080件の閲覧回数
Kan_Li
Hi @ivanadam ,
It is a non mass market product, so you have to sign NDA at first and then request the data sheet from the docstore. You may contact your local Disty for help with the NDA or create a private ticket as described in https://community.nxp.com/t5/Using-Our-Community-Knowledge/How-to-submit-a-new-question-for-NXP-Supp... .  The Disty contact info can be fetched from https://www.nxp.com/support/sample-and-buy/distributor-network:DISTRIBUTORS .
Please refer to the attachment for more details.
Hope that helps,
Kan
4 返答(返信)
10,081件の閲覧回数
Kan_Li
Hi @ivanadam ,
Hope that helps,
Kan
8,395件の閲覧回数
DuanZhiY
Hello, I have already got DocStore account, but I cannot get any searching result when type in PCF7961. Could you please help to check if I miss some application process?
8,388件の閲覧回数
Kan_Li
Hello @DuanZhiY ,
Just let you know the NDA process is much more convenient than before, you may easily have it following the 2 steps as below:
Kan
8,389件の閲覧回数
Kan_Li
Hello @DuanZhiY ,
Most likely it is due to that you don't have enough access right, please kindly contact [email protected] for further assistance. and of course, you have to sign NDA with NXP before the request.
Hope that makes sense,
Kan
