JCOP modules installation
liran_bh
hi
i installed all jcop tools , activated it , its all working great
but
during the installation process the manual refers to additional jcop modules to install
I cant find the files. all files should be zip files with name starting with jcopx-api-module
where can i find it?
the guide is "getting started with jcop tools" chapter 6.1
thanks
liran
liran_bh
any idea?
Kan_Li
Hi @liran_bh ,
I am checking with the expert regarding your questions, and will let you know when I have any feedback from there.
Thanks for your patience!
Kan
Kan_Li
Hi @liran_bh ,
May I have the version of JCOP you are working with? Is there any snapshot regarding the issue you had during the installation? Thanks for your patience!
Kan
liran_bh
hi
i asked for jcop4 - im not sure that this is the version i got from docstore
the version of the tools is: JCOP-Tools-v53204_RC1
on the installation guide i see a section to install modules (attached screenshot of the files dialog from the manual)
i cant find those modules
while starting a new project i can use only classic java card packages (attached new project dialog)
thanks
liran
