Getting error 0x6985 with SE05x
ar01
I'm using the evaluation board for SE052. I'm trying to implement the se052_reset_example but it is not working. The function ex_sss_boot_open works fine and the applet is selected. However, the next command from Se05x_API_GetRandom function returns the error 0x6985.
I've also tried sending different commands after ex_sss_boot_open, like Se05x_API_GetFreeMemory but I received the same 0x6985 error.
Thanks.
Kan_Li
Hi @ar01 ,
Actually the SE052F uses like SE050F a mandated PlatformSCP connection. Did you configure the MW correctly ? Please kindly refer to https://www.nxp.com/webapp/Download?colCode=AN14028 for more details.
Hope that helps,
Kan
Kan_Li
Hi @ar01 ,
Hope that helps,
Kan
ar01
Thanks Kan!, I thought that was disabled by default, I changed the features to include the platform scp and that worked. Have a nice day.
%3CLINGO-SUB%20id%3D%22lingo-sub-1961205%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGetting%20error%200x6985%20with%20SE05x%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1961205%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI'm%20using%20the%20evaluation%20board%20for%20SE052.%20I'm%20trying%20to%20implement%20the%20se052_reset_example%20but%20it%20is%20not%20working.%20The%20function%20ex_sss_boot_open%20works%20fine%20and%20the%20applet%20is%20selected.%20However%2C%20the%20next%20command%20from%20%3CSPAN%3ESe05x_API_GetRandom%20function%20returns%20the%20error%200x6985.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EI've%20also%20tried%20sending%20different%20commands%20after%26nbsp%3Bex_sss_boot_open%2C%20like%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ESe05x_API_GetFreeMemory%26nbsp%3Bbut%20I%20received%20the%20same%200x6985%20error.%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EThanks.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1961205%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESE050%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1962055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Getting%20error%200x6985%20with%20SE05x%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1962055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThanks%20Kan!%2C%20I%20thought%20that%20was%20disabled%20by%20default%2C%20I%20changed%20the%20features%20to%20include%20the%20platform%20scp%20and%20that%20worked.%20Have%20a%20nice%20day.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1961486%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Getting%20error%200x6985%20with%20SE05x%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1961486%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F239453%22%20target%3D%22_blank%22%3E%40ar01%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EActually%26nbsp%3Bthe%20SE052F%20uses%20like%20SE050F%20a%20mandated%20PlatformSCP%20connection.%20Did%20you%20configure%20the%20MW%20correctly%20%3F%20Please%20kindly%20refer%20to%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN14028%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN14028%3C%2FA%3E%26nbsp%3Bfor%20more%20details.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHope%20that%20helps%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3CBR%20%2F%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
