Failure in Se05x_API_SessionOpen on SE052F (Raspberry Pi I2C Communication Issue)
10,090 次查看
krsuresh
Hi Team,
I am facing an issue while trying to communicate with the SE052F over I2C using the Plug & Trust Nano Package.
According to the AN14277 application note, I configured the SCP03 keys as follows:
ENC Key: 3ae441c747e32ebc16b3bb2d843c6dd8
MAC Key: 6c18f3d08fee1cb96a3c8de5d3538aaa
However, Se05x_API_SessionOpen consistently fails.
System Information
Platform: Raspberry Pi
Package: Plug and Trust Nano Package v1.5.4
Example used: ex_se05x_GetInfo
Log Details:
./ex_se05x_GetInfo
Se05x Getinfo Example !
Plug and Trust nano package - version: 1.5.4
I2C driver supports plain i2c-level commands.
APDU Tx> :00 a4 04 00 0b d2 76 00 00 85 30 4a 43 4f 90 03 00
Failed writing data (nrWritten=-1).
Se05x_API_SessionOpen failedError in Se05x_API_SessionOpen
SE05x Getinfo Example Failed !
I2C Detect details in Raspberry Pi:
flexxon@raspberrypi:~/SE050/NEW-NANO/se052f/nano-package/examples/se05x_GetInfo/linux/build $ i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- 48 -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Sureshkumar R
23 回复数
9,527 次查看
Kan_Li
Hi @krsuresh ,
Since you are testing this on Raspberry Pi , did you also test with the full version of MW? Did it work anyway? Please kindly clarify.
Kan
9,524 次查看
krsuresh
Hi @Kan_Li,
Thanks for the quick response.
I used the following configuration during the simw_top build, and while se05x_GetInfo runs successfully, se05x_Minimal fails; the log is provided below.
PTMW_ Applet = SE05X_C
PTMW_ FIPS = None
PTMW_ SE05X_ Ver = 03_XX
PTMW_SE05X_Auth = PlatfSCP03
PTMW_ SCP = SCP03_SSS
SSSFTR_ SE05X_ RSA = disable/enable
./se05x_GetInfo
Failed to export Enable pin : Invalid argument
Failed to open GPIO value file : No such file or directory
Failed to unexport GPIO : Invalid argument
App :INFO :Running ./se05x_GetInfo
App :INFO :If you want to over-ride the selection, use ENV=EX_SSS_BOOT_SSS_PORT or pass in command line arguments.
App :INFO :PlugAndTrust_v04.07.01_20250519
sss :INFO :atr (Len=35)
01 A0 00 00 03 96 04 03 E8 00 FE 02 0B 03 E8 00
01 00 00 00 00 64 13 88 0A 00 65 53 45 30 35 31
00 00 00
App :WARN :#####################################################
App :INFO :uid (Len=18)
04 00 50 01 39 97 7A C3 BF 57 52 04 26 1F 32 0A
1D 90
00 00 00
sss :INFO :Newer version of Applet Found
sss :INFO :Compiled for 0x70200. Got newer 0x70216
sss :WARN :Communication channel is Plain.
sss :WARN :!!!Not recommended for production use.!!!
App :INFO :Applet Major = 7
App :INFO :Applet Minor = 2
App :INFO :Applet patch = 22
App :INFO :AppletConfig = 26F2
App :INFO :With ECDSA_ECDH_ECDHE
App :INFO :WithOut EDDSA
App :INFO :WithOut DH_MONT
App :INFO :With HMAC
App :INFO :With RSA_PLAIN
App :INFO :With RSA_CRT
App :INFO :With AES
App :INFO :WithOut DES
App :INFO :With PBKDF
App :INFO :With TLS
App :INFO :WithOut MIFARE
App :INFO :With I2CM
App :INFO :Internal = FFFF
App :INFO :Tag value - proprietary data 0xFE = 0xFE
App :INFO :Length of following data 0x45 = 0x4F
App :INFO :Tag card identification data (Len=2)
DF 28
App :INFO :Length of card identification data = 0x4C
App :INFO :Tag configuration ID (Must be 0x01) = 0x01
App :INFO :Configuration ID (Len=12)
00 05 B5 01 1B 7D B8 1B 89 99 D0 5D
App :INFO :OEF ID (Len=2)
B5 01
App :INFO :Tag patch ID (Must be 0x02) = 0x02
App :INFO :Patch ID (Len=8)
00 00 00 00 00 00 00 00
App :INFO :Tag platform build ID1 (Must be 0x03) = 0x03
App :INFO :Platform build ID (Len=24)
4A 33 52 36 30 30 30 33 37 33 31 38 31 32 30 30
6D 20 B6 19 7D 63 5E 7C
App :INFO :JCOP Platform ID = J3R6000373181200
App :INFO :Tag FIPS mode (Must be 0x05) = 0x05
App :INFO :FIPS mode var = 0x01
App :INFO :Tag pre-perso state (Must be 0x07) = 0x07
App :INFO :Bit mask of pre-perso state var = 0x00
App :INFO :Tag ROM ID (Must be 0x08) = 0x08
App :INFO :ROM ID (Len=8)
B3 37 5F E9 B5 50 8B C4
App :INFO :Tag JCOP OS Core ID (Must be 0x0A) = 0x0A
App :INFO :JCOP OS Core (Len=8)
55 60 6F D4 BE EC F3 CD
App :INFO :Status Word (SW) (Len=2)
90 00
App :INFO :se05x_GetInfoPlainApplet Example Success !!!...
App :INFO :cplc_data.IC_fabricator (Len=2)
47 90
App :INFO :cplc_data.IC_type1 (Len=2)
D6 00
App :INFO :cplc_data.Operating_system_identifier (Len=2)
47 00
App :INFO :cplc_data.Operating_system_release_date (Len=2)
00 00
App :INFO :cplc_data.Operating_system_release_level (Len=2)
00 00
App :INFO :cplc_data.IC_fabrication_date (Len=2)
41 02
App :INFO :cplc_data.IC_Serial_number (Len=4)
38 51 87 21
App :INFO :cplc_data.IC_Batch_identifier (Len=2)
02 67
App :INFO :cplc_data.IC_module_fabricator (Len=2)
00 00
App :INFO :cplc_data.IC_module_packaging_date (Len=2)
00 00
App :INFO :cplc_data.ICC_manufacturer (Len=2)
00 00
App :INFO :cplc_data.IC_embedding_date (Len=2)
00 00
App :INFO :cplc_data.IC_OS_initializer (Len=2)
19 26
App :INFO :cplc_data.IC_OS_initialization_date (Len=2)
1F 38
App :INFO :cplc_data.IC_OS_initialization_equipment (Len=4)
35 31 38 37
App :INFO :cplc_data.IC_personalizer (Len=2)
00 00
App :INFO :cplc_data.IC_personalization_date (Len=2)
00 00
App :INFO :cplc_data.IC_personalization_equipment_ID (Len=4)
00 00 00 00
App :INFO :cplc_data.SW (Len=2)
90 00
App :INFO :ex_sss Finished
flexxon@raspberrypi:~/SD/simw-top_build/raspbian_native_se050_t1oi2c/bin $ ./se05x_Minimal
App :INFO :Running ./se05x_Minimal
00 00 00
sss :WARN :nxEnsure:'ret == SM_OK' failed. At Line:7839 Function:sss_se05x_TXn
sss :WARN :APDU Transaction Error: Conditions not satisfied (0x6985)
App :ERROR:Se05x_API_GetFreeMemory Failed
App :INFO :mem=0
App :ERROR:se05x_Minimal Example Failed !!!...
App :ERROR:ex_sss_entry Failed
App :ERROR:!ERROR! ret != 0.
Sureshkumar R
9,487 次查看
Kan_Li
Hi @krsuresh ,
Did you really rebuild the MW with the following options?
From the log, there are some conflicts:
Kan
9,476 次查看
krsuresh
Hi @Kan_Li,
Please find the test result log below. Let me know if you need any additional information for further analysis.
flexxon@raspberrypi:~/SD/simw-top_build/raspbian_native_se050_t1oi2c/bin $ ./se05x_GetInfo
App :INFO :Using default PlatfSCP03 keys. You can use keys from file using ENV=EX_SSS_BOOT_SCP03_PATH
00 00 00
scp :WARN :nxEnsure:'status == kStatus_SSS_Success' failed. At Line:148 Function:nxScp03_AuthenticateChannel
sss :ERROR:Could not set SCP03 Secure Channel
App :ERROR:sss_session_open failed
App :ERROR:ex_sss_session_open Failed
00 00 00
sss :INFO :Compiled for 0x30100. Got newer 0x70216
Sureshkumar R
9,470 次查看
Kan_Li
Hi @krsuresh ,
Thanks for the info! Seems the platformSCP keys used in your test are not for SE052F, would you please configure the keys according to the guide in SE-PLUG-TRUST-MW_04.07.01/simw-top/doc/appendix/platfscp.html?
Hope that helps,
Kan
9,453 次查看
krsuresh
Hi @Kan_Li,
Thanks for the update. Yes, the MW is working fine now after configuring the correct PlatformSCP keys. However, I noticed something unusual: the Plug & Trust Nano package samples are also working now without any code changes, even though they were failing earlier. I’m not able to understand how they started working suddenly. Could you please help clarify what might cause this behavior?
flexxon@raspberrypi:~/SE050/NEW-NANO/se052f/nano-package/examples/se05x_crypto/linux/build $ ./ex_se05x_crypto
Se05x crypto Example !
Establish Secure Channel to SE05x !
Created scp03 Session
Get Version ==>
Applet Version 7.2.22
ex_get_version, PASSED
ex_generate_nist256_key, PASSED
ex_set_get_nist256_key, PASSED
ex_nist256_sign_verify, PASSED
ex_generate_nist384_key, PASSED
ex_set_get_nist384_key, PASSED
ex_nist384_sign_verify, PASSED
ex_set_certificate, PASSED
ex_ecdh, PASSED
ex_aes_ECB_NOPAD, PASSED
ex_aes_CBC_NOPAD, PASSED
ex_aes_CTR, PASSED
ex_nist256_sign_policy, PASSED
ex_read_attst_object, PASSED
Close i2c device 3.
SE05x crypto Example Success !
Sureshkumar R
9,359 次查看
krsuresh
Hi @Kan_Li,
I am testing two new SE052F boards. On the first board, the Plug & Play Nano package sample initially failed, but after running the Middleware sample once with plain_scp.txt, both Middleware and Nano samples started working correctly.
However, when I switch to the second new board and test the Nano package, it fails. After that, when I switch back to the first board, the Nano package also fails again. It seems that running the Middleware sample with plain_scp.txt is required each time to make the Nano package work.
Could you please help clarify why the Plug & Play Nano sample behaves inconsistently when switching between different SE052F boards? Is there any configuration or reinitialization needed for each board before running the Nano package?
Sureshkumar R
9,352 次查看
Kan_Li
Hi @krsuresh ,
How did you connect SE05x with the raspberry board? If you connect them via wires, maybe you can connect the RST pin to VCC directly to avoid the SE hold in reset.
Kan
9,324 次查看
krsuresh
Hi @Kan_Li,
I have tested the setup by connecting the RST pin to VCC as suggested, but the issue still persists. Additionally, I have observed that when I run the Middleware sample first, both the Middleware and the Nano package function correctly. However, after disconnecting and reconnecting the power to the SE052F board, the Nano package fails to work again.
Sureshkumar R
8,745 次查看
Kan_Li
Hi @krsuresh ,
I can reproduce this issue here and checking with the MW team now, will let you know when there is any progress,
Thanks for your patience!
Kan
7,964 次查看
krsuresh
Hi @Kan_Li
Thank you for the update.
Just checking if there is any progress or update from the MW team on this issue.
Please let me know when you have any information.
Sureshkumar R
7,930 次查看
Kan_Li
Hi @krsuresh ,
I am sorry, but so far there is no response from the MW team due to the holidays, while as a quick solution, you may use a longer timer interval as below:
The source file can be found in nano-package-master/lib/platform/linux/ .
Hope that helps,
Kan
6,831 次查看
krsuresh
Hi @Kan_Li,
As suggested, I increased the timer interval, but I am still facing the same behavior.
Is there any update from the MW team on this issue?
Sureshkumar R
6,075 次查看
Kan_Li
Hi @krsuresh ,
Have you tried a larger value instead? The MW has put this in plan, but the fix I would expect to be the next release.
Kan
5,633 次查看
Ben-FLX
@Kan_Li Do you know of any scheduled release that happens on regular interval in which we can expect this to be made available?
For e.g, within every quarter, or every Q1 & Q3?
If it is not something that is happening soon, then we need to know whether there is any possibility for a off-cycle release such that it does not affect our development activity.
Otherwise, we may have to consider other options such as going back to using SE050 (for our upcoming prototype build) and understand what it takes to migrate to SE052.
5,594 次查看
Kan_Li
Hi @Ben-FLX ,
We could plan for a release on the end of Feb 2026 along with our Main Package Release. Does it align with your timeline?
Kan
5,585 次查看
Ben-FLX
Hi @Kan_Li
Yes, end feb works as long as we are able to execute all supported code/functions supplied by the package using SE052 eval board. Of course, the earlier this package can be made available, the better it is for us.
Lastly, what is a good way for us to be notified when the new package becomes available? I am not sure why I am not receiving email notifications here and I don't see myself refreshing NXP website on a daily basis to check for updates.
5,583 次查看
Kan_Li
Hi @Ben-FLX ,
Thanks for the clarification! I will let the MW team know about this. and for notification, I think you may use the notify function from the github, as shown below:
and anyway, you may reach out to me here at anytime.
Kan
5,275 次查看
Ben-FLX
@Kan_Li Just wondering, any update/news about the planned code release? Is it progressing smoothly?
5,217 次查看
Kan_Li
Hi @Ben-FLX ,
I just checked with the MW team, the fix would be available by Mar 31st. Due to other priorities this is delayed. Sorry for the inconvenience that has caused.
Kan
%3CLINGO-SUB%20id%3D%22lingo-sub-2253656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESE052F%20%E4%B8%8A%20Se05x_API_SessionOpen%20%E5%A4%B1%E8%B4%A5%EF%BC%88Raspberry%20Pi%20I2C%20%E9%80%9A%E4%BF%A1%E9%97%AE%E9%A2%98%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2253656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%9B%A2%E9%98%9F%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20Plug%20%26amp%3B%20Trust%20Nano%20%E8%BD%AF%E4%BB%B6%E5%8C%85%E9%80%9A%E8%BF%87%20I2C%20%E4%B8%8E%20SE052F%20%E9%80%9A%E4%BF%A1%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%E6%A0%B9%E6%8D%AE%20AN14277%20%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%EF%BC%8C%E6%88%91%E6%8C%89%E5%A6%82%E4%B8%8B%E6%96%B9%E5%BC%8F%E9%85%8D%E7%BD%AE%20SCP03%20%E5%AF%86%E9%92%A5%EF%BC%9A%3C%2FP%3E%3CP%3EENC%20Key%EF%BC%9A3ae441c747e32ebc16b3bb2d843c6dd8%3CBR%20%2F%3EMAC%20Key%EF%BC%9A6c18f3d08fee1cb96a3c8de5d3538aaa%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8CSe05x_API_SessionOpen%20%E5%A7%8B%E7%BB%88%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%B3%BB%E7%BB%9F%E4%BF%A1%E6%81%AF%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E5%B9%B3%E5%8F%B0%EF%BC%9A%3C%2FSTRONG%3E%E6%A0%91%E8%8E%93%E6%B4%BE%3CBR%20%2F%3E%3CSTRONG%3E%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%9A%3C%2FSTRONG%3E%E5%8D%B3%E6%8F%92%E5%8D%B3%E7%94%A8%E7%BA%B3%E7%B1%B3%E8%BD%AF%E4%BB%B6%E5%8C%85%20v1.5.4%3CBR%20%2F%3E%3CSTRONG%3E%E4%BD%BF%E7%94%A8%E7%A4%BA%E4%BE%8B%EF%BC%9A%3C%2FSTRONG%3Eex_se05x_GetInfo%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CU%3E%3CSTRONG%3E%E6%97%A5%E5%BF%97%E8%AF%A6%E6%83%85%EF%BC%9A%3C%2FSTRONG%3E%3C%2FU%3E%3C%2FP%3E%3CP%3E%E3%80%82%2Fex_se05x_GetInfo%3CBR%20%2F%3ESe05x%20Getinfo%20%E7%A4%BA%E4%BE%8B%EF%BC%81%3CBR%20%2F%3EPlug%20and%20Trust%20nano%20%E8%BD%AF%E4%BB%B6%E5%8C%85%20-%20%E7%89%88%E6%9C%AC%EF%BC%9A1.5.4%3CBR%20%2F%3EI2C%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%94%AF%E6%8C%81%E6%99%AE%E9%80%9A%20i2c%20%E7%BA%A7%E5%91%BD%E4%BB%A4%E3%80%82%3CBR%20%2F%3EAPDU%20Tx%26gt%3B%3A00%20a4%2004%2000%200b%20d2%2076%2000%2000%2085%2030%204a%2043%204f%2090%2003%2000%3CBR%20%2F%3E%E5%86%99%E5%85%A5%E6%95%B0%E6%8D%AE%E5%A4%B1%E8%B4%A5%20(nrWritten%3D-1)%E3%80%82%3CBR%20%2F%3ESe05x_API_SessionOpen%20%E4%B8%AD%E7%9A%84%20failedError%3CBR%20%2F%3ESE05x%20Getinfo%20%E7%A4%BA%E4%BE%8B%E5%A4%B1%E8%B4%A5%20%EF%BC%81%3C%2FP%3E%3CP%3E%3CU%3E%3CSTRONG%3EI2C%20%E5%9C%A8%20Raspberry%20Pi%20%E4%B8%AD%E6%A3%80%E6%B5%8B%E7%BB%86%E8%8A%82%EF%BC%9A%3C%2FSTRONG%3E%3C%2FU%3Ef%20%3CBR%20%2F%3E%20lexxon%20%40raspberrypi%EF%BC%9A~%2Fse050%2Fnew-nano%2Fse052f%2Fnano-package%2Fexamples%2Fse05x_getinfo%2Flinux%2Fbuild%20%24%20i2cdetect-y%201%20%3CBR%20%2F%3E%200%201%202%203%204%205%206%207%208%209%20a%20b%20c%20d%20e%20f%20%3CBR%20%2F%3E%2000%EF%BC%9A-------%3CBR%20%2F%3E%2010%EF%BC%9A-----------------------%3CBR%20%2F%3E%2020%3A------------------------------%3CBR%20%2F%3E%2030%3A------------------------------------------------------------------------------------------------------------------------%3CBR%20%2F%3E%2040%3A----------------48------------%3CBR%20%2F%3E%2050%3A--------------------------------------------60%3A------------------60%3A--------------------60%3A------%3CBR%20%2F%3E--------%3CBR%20%2F%3E%2070%3A------------------%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3ESureshkumar%20R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2253656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESE050%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2254808%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2254808%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F210184%22%20target%3D%22_blank%22%3E%40krsuresh%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%81%E6%82%A8%E5%9C%A8%E6%B5%8B%E8%AF%95%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%9A%84%20platformSCP%20%E5%AF%86%E9%92%A5%E4%BC%BC%E4%B9%8E%E4%B8%8D%E9%80%82%E7%94%A8%E4%BA%8E%20SE052F%EF%BC%8C%E8%AF%B7%E6%8C%89%E7%85%A7%20SE-PLUG-TRUST-MW_04.07.01%2Fsimw-top%2Fdoc%2Fappendix%2Fplatfscp.html%20%E4%B8%AD%E7%9A%84%E6%8C%87%E5%8D%97%E9%85%8D%E7%BD%AE%E5%AF%86%E9%92%A5%E3%80%82%20%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E4%BD%A0%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2254767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2254767%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F210184%22%20target%3D%22_blank%22%3E%40krsuresh%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%A0%E7%9C%9F%E7%9A%84%E7%94%A8%E4%BB%A5%E4%B8%8B%E9%80%89%E9%A1%B9%E9%87%8D%E5%BB%BA%E4%BA%86%20MW%20%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EPTMW_%20SE05X_%20Ver%20%3D%2003_XX%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EPTMW_SE05X_Auth%20%3D%20PlatfSCP03%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E4%BB%8E%E6%97%A5%E5%BF%97%E6%9D%A5%E7%9C%8B%EF%BC%8C%E5%AD%98%E5%9C%A8%E4%B8%80%E4%BA%9B%E5%86%B2%E7%AA%81%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Esss%20%3AINFO%20%3ACompiled%20for%200x70200.%E5%BE%97%E5%88%B0%E6%9B%B4%E6%96%B0%E7%9A%84%200x70216%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Esss%20%3AWARN%20%3ACommunication%20channel%20is%20Plain.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E8%AF%B7%E4%BA%88%E4%BB%A5%E6%BE%84%E6%B8%85%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2254782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2254782%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%E8%AE%B0%E5%BD%95%E5%A6%82%E4%B8%8B%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E9%9C%80%E8%A6%81%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%E8%BF%9B%E8%A1%8C%E8%BF%9B%E4%B8%80%E6%AD%A5%E5%88%86%E6%9E%90%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3Eflexxon%40raspberrypi%3A~%2FSD%2Fsimw-top_build%2Fraspbian_native_se050_t1oi2c%2Fbin%20%24%20.%2Fse05x_GetInfo%3C%2FSTRONG%3E%3CBR%20%2F%3E%E5%AF%BC%E5%87%BA%E5%90%AF%E7%94%A8%E5%BC%95%E8%84%9A%E5%A4%B1%E8%B4%A5%EF%BC%9A%E5%8F%82%E6%95%B0%E6%97%A0%E6%95%88%3CBR%20%2F%3E%E6%89%93%E5%BC%80%20GPIO%20%E5%80%BC%E6%96%87%E4%BB%B6%E5%A4%B1%E8%B4%A5%EF%BC%9A%E6%97%A0%E6%AD%A4%E7%B1%BB%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3CBR%20%2F%3E%E8%A7%A3%E5%AF%BC%E5%87%BA%20GPIO%20%E5%A4%B1%E8%B4%A5%EF%BC%9A%E5%8F%82%E6%95%B0%E6%97%A0%E6%95%88%3CBR%20%2F%3EApp%20%3AINFO%20%3ARunning%20.%2Fse05x_GetInfo%3CBR%20%2F%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AINFO%20%3A%E5%A6%82%E6%9E%9C%E8%A6%81%E6%9B%B4%E6%94%B9%E9%80%89%E6%8B%A9%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%20ENV%3DEX_SSS_BOOT_SSS_PORT%20%E6%88%96%E4%BC%A0%E9%80%92%E5%91%BD%E4%BB%A4%E8%A1%8C%E5%8F%82%E6%95%B0%E3%80%82%3CBR%20%2F%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AINFO%20%3APlugAndTrust_v04.07.01_20250519%3CBR%20%2F%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AINFO%20%3A%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%9A%84%20PlatfSCP03%20%E9%94%AE%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20ENV%3DEX_SSS_BOOT_SCP03_PATH%3CBR%20%2F%3Esss%20%3AINFO%20%3Aatr%20(Len%3D35)%3CBR%20%2F%3E01%20A0%2000%2000%2003%2096%2004%2003%20E8%2000%20FE%2002%200B%2003%20E8%2000%3CBR%20%2F%3E01%2000%2000%2000%2064%2013%2088%200A%2000%2065%2053%2045%2030%2035%2031%3CBR%20%2F%3E00%2000%3CBR%20%2F%3Escp%20%3AWARN%20%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%20%E5%A4%B1%E8%B4%A5%E3%80%82At%20Line%3A148%20Function%3AnxScp03_AuthenticateChannel%3CBR%20%2F%3Esss%20%3AERROR%3ACould%20not%20set%20SCP03%20Secure%20Channel%3CBR%20%2F%3EApp%20%3AERROR%3Asss_session_open%20failed%3CBR%20%2F%3EApp%20%3AERROR%3Aex_sss_session_open%20Failed%3CBR%20%2F%3EApp%20%3AERROR%3A!ERROR%EF%BC%81ret%20!%3D%200%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3Eflexxon%40raspberrypi%3A~%2FSD%2Fsimw-top_build%2Fraspbian_native_se050_t1oi2c%2Fbin%20%24%20.%2Fse05x_Minimal%3C%2FSTRONG%3E%3CBR%20%2F%3E%E5%AF%BC%E5%87%BA%E5%90%AF%E7%94%A8%E5%BC%95%E8%84%9A%E5%A4%B1%E8%B4%A5%EF%BC%9A%E5%8F%82%E6%95%B0%E6%97%A0%E6%95%88%3CBR%20%2F%3E%E6%89%93%E5%BC%80%20GPIO%20%E5%80%BC%E6%96%87%E4%BB%B6%E5%A4%B1%E8%B4%A5%EF%BC%9A%E6%97%A0%E6%AD%A4%E7%B1%BB%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3CBR%20%2F%3E%E8%A7%A3%E5%AF%BC%E5%87%BA%20GPIO%20%E5%A4%B1%E8%B4%A5%EF%BC%9A%E5%8F%82%E6%95%B0%E6%97%A0%E6%95%88%3CBR%20%2F%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AINFO%20%3ARunning%20.%2Fse05x_Minimal%3CBR%20%2F%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AINFO%20%3A%E5%A6%82%E6%9E%9C%E8%A6%81%E6%9B%B4%E6%94%B9%E9%80%89%E6%8B%A9%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%20ENV%3DEX_SSS_BOOT_SSS_PORT%20%E6%88%96%E4%BC%A0%E9%80%92%E5%91%BD%E4%BB%A4%E8%A1%8C%E5%8F%82%E6%95%B0%E3%80%82%3CBR%20%2F%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AINFO%20%3APlugAndTrust_v04.07.01_20250519%3CBR%20%2F%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AINFO%20%3A%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%9A%84%20PlatfSCP03%20%E9%94%AE%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20ENV%3DEX_SSS_BOOT_SCP03_PATH%20%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84%E9%94%AE%3CBR%20%2F%3Esss%20%3AINFO%20%3Aatr%20(Len%3D35)%3CBR%20%2F%3E01%20A0%2000%2000%2003%2096%2004%2003%20E8%2000%20FE%2002%200B%2003%20E8%2000%3CBR%20%2F%3E01%2000%2000%2000%2064%2013%2088%200A%2000%2065%2053%2045%2030%2035%2031%3CBR%20%2F%3E00%2000%3CBR%20%2F%3Esss%20%3AINFO%20%3A%E5%8F%91%E7%8E%B0%E6%9B%B4%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%20Applet%3CBR%20%2F%3Esss%20%3AINFO%20%3A%E7%BC%96%E8%AF%91%E4%B8%BA%200x30100%E3%80%82%E5%BE%97%E5%88%B0%E6%9B%B4%E6%96%B0%E7%9A%84%200x70216%3CBR%20%2F%3Escp%20%3AWARN%20%3AnxEnsure%3A'status%20%3D%3D%20kStatus_SSS_Success'%E5%A4%B1%E8%B4%A5%E3%80%82At%20Line%3A148%20Function%3AnxScp03_AuthenticateChannel%3CBR%20%2F%3Esss%20%3AERROR%3ACould%20not%20set%20SCP03%20Secure%20Channel%3CBR%20%2F%3EApp%20%3AERROR%3Asss_session_open%20failed%3CBR%20%2F%3EApp%20%3AERROR%3Aex_sss_session_open%20Failed%3CBR%20%2F%3EApp%20%3AERROR%3A!ERROR%EF%BC%81ret%20!%3D%200%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22krsuresh_0-1764819353609.png%22%20style%3D%22width%3A%20342px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368516i18C82D85B7A1BBF5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22krsuresh_0-1764819353609.png%22%20alt%3D%22krsuresh_0-1764819353609.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ekrsuresh_0-1764819353609.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3ESureshkumar%20R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2253841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2253841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F210184%22%20target%3D%22_blank%22%3E%40krsuresh%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%97%A2%E7%84%B6%E6%82%A8%E5%9C%A8%20Raspberry%20Pi%20%E4%B8%8A%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%EF%BC%8C%E9%82%A3%E4%B9%88%E6%82%A8%E6%98%AF%E5%90%A6%E4%B9%9F%E7%94%A8%E5%AE%8C%E6%95%B4%E7%89%88%E7%9A%84%20MW%20%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%EF%BC%9F%E5%AE%83%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E5%90%97%EF%BC%9F%E8%AF%B7%E4%BA%88%E4%BB%A5%E6%BE%84%E6%B8%85%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2253992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2253992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BF%AB%E9%80%9F%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%20simw_top%20%E7%89%88%E6%9C%AC%E6%9C%9F%E9%97%B4%E4%BD%BF%E7%94%A8%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%85%8D%E7%BD%AE%EF%BC%8C%E8%99%BD%E7%84%B6%20se05x_GetInfo%20%E6%88%90%E5%8A%9F%E8%BF%90%E8%A1%8C%EF%BC%8C%E4%BD%86%20se05x_minimal%20%E5%A4%B1%E8%B4%A5%E4%BA%86%EF%BC%9B%E6%97%A5%E5%BF%97%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%E3%80%82%3C%2FP%3E%3CP%3EPTMW_%20Applet%20%3D%20SE05X_C%3CBR%20%2F%3EPTMW_%20FIPS%20%3D%20None%3CBR%20%2F%3EPTMW_%20SE05X_%20Ver%20%3D%2003_XX%3CBR%20%2F%3EPTMW_SE05X_Auth%20%3D%20PlatfSCP03%3CBR%20%2F%3EPTMW_%20SCP%20%3D%20SCP03_SSS%3CBR%20%2F%3ESSSFTR_%20SE05X_%20RSA%20%3D%20%E7%A6%81%E7%94%A8%2F%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3E%3CSTRONG%3E.%2Fse05x_GetInfo%3C%2FSTRONG%3E%3CBR%20%2F%3E%E5%AF%BC%E5%87%BA%E5%90%AF%E7%94%A8%E5%BC%95%E8%84%9A%E5%A4%B1%E8%B4%A5%EF%BC%9A%E5%8F%82%E6%95%B0%E6%97%A0%E6%95%88%3CBR%20%2F%3E%E6%89%93%E5%BC%80%20GPIO%20%E5%80%BC%E6%96%87%E4%BB%B6%E5%A4%B1%E8%B4%A5%EF%BC%9A%E6%97%A0%E6%AD%A4%E7%B1%BB%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3CBR%20%2F%3E%E8%A7%A3%E5%AF%BC%E5%87%BA%20GPIO%20%E5%A4%B1%E8%B4%A5%EF%BC%9A%E5%8F%82%E6%95%B0%E6%97%A0%E6%95%88%3CBR%20%2F%3EApp%20%3AINFO%20%3ARunning%20.%2Fse05x_GetInfo%3CBR%20%2F%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AINFO%20%3A%E5%A6%82%E6%9E%9C%E8%A6%81%E6%9B%B4%E6%94%B9%E9%80%89%E6%8B%A9%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%20ENV%3DEX_SSS_BOOT_SSS_PORT%20%E6%88%96%E4%BC%A0%E9%80%92%E5%91%BD%E4%BB%A4%E8%A1%8C%E5%8F%82%E6%95%B0%E3%80%82%3CBR%20%2F%3EApp%20%3AINFO%20%3APlugAndTrust_v04.07.01_20250519%3CBR%20%2F%3Esss%20%3AINFO%20%3Aatr%20(Len%3D35)%3CBR%20%2F%3E01%20A0%2000%2000%2003%2096%2004%2003%20E8%2000%20FE%2002%200B%2003%20E8%2000%3CBR%20%2F%3E01%2000%2000%2000%2064%2013%2088%200A%2000%2065%2053%2045%2030%2035%2031%3CBR%20%2F%3E00%2000%3CBR%20%2F%3EApp%20%3AWARN%20%3A%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3CBR%20%2F%3EApp%20%3AINFO%20%3Auid%20(Len%3D18)%3CBR%20%2F%3E04%2000%2050%2001%2039%2097%207A%20C3%20BF%2057%2052%2004%2026%201F%2032%200A%3CBR%20%2F%3E1D%2090%3CBR%20%2F%3EApp%20%3AINFO%20%3ARunning%20.%2Fse05x_GetInfo%3CBR%20%2F%3EApp%20%3AINFO%20%3AIf%20you%20want%20to%20over-ride%20the%20selection%2C%20use%20ENV%3DEX_SSS_BOOT_SSS_PORT%20or%20pass%20in%20command%20line%20arguments.%3CBR%20%2F%3Esss%20%3AINFO%20%3Aatr%20(Len%3D35)%3CBR%20%2F%3E01%20A0%2000%2000%2003%2096%2004%2003%20E8%2000%20FE%2002%200B%2003%20E8%2000%3CBR%20%2F%3E01%2000%2000%2000%2000%2064%2013%2088%200A%2000%2065%2053%2045%2030%2035%2031%3CBR%20%2F%3E00%2000%2000%3CBR%20%2F%3Esss%20%3AINFO%20%3ANewer%20version%20of%20Applet%20Found%3CBR%20%2F%3Esss%20%3AINFO%20%3ACompiled%20for%200x70200.%20Got%20newer%200x70216%3CBR%20%2F%3Esss%20%3AWARN%20%3ACommunication%20channel%20is%20Plain.%3CBR%20%2F%3Esss%20%3AWARN%20%3A!!!Not%20recommended%20for%20production%20use.!!!%3CBR%20%2F%3EApp%20%3AWARN%20%3A%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3CBR%20%2F%3EApp%20%3AINFO%20%3AApplet%20Major%20%3D%207%3CBR%20%2F%3EApp%20%3AINFO%20%3AApplet%20Minor%20%3D%202%3CBR%20%2F%3EApp%20%3AINFO%20%3AApplet%20patch%20%3D%2022%3CBR%20%2F%3EApp%20%3AINFO%20%3AAppletConfig%20%3D%2026F2%3CBR%20%2F%3EApp%20%3AINFO%20%3AWith%20ECDSA_ECDH_ECDHE%3CBR%20%2F%3EApp%20%3AINFO%20%3AWithOut%20EDDSA%3CBR%20%2F%3EApp%20%3AINFO%20%3AWithOut%20DH_MONT%3CBR%20%2F%3EApp%20%3AINFO%20%3AWith%20HMAC%3CBR%20%2F%3EApp%20%3AINFO%20%3AWith%20RSA_PLAIN%3CBR%20%2F%3EApp%20%3AINFO%20%3AWith%20RSA_CRT%3CBR%20%2F%3EApp%20%3AINFO%20%3AWith%20AES%3CBR%20%2F%3EApp%20%3AINFO%20%3AWithOut%20DES%3CBR%20%2F%3EApp%20%3AINFO%20%3AWith%20PBKDF%3CBR%20%2F%3EApp%20%3AINFO%20%3AWith%20TLS%3CBR%20%2F%3EApp%20%3AINFO%20%3AWithOut%20MIFARE%3CBR%20%2F%3EApp%20%3AINFO%20%3AWith%20I2CM%3CBR%20%2F%3EApp%20%3AINFO%20%3AInternal%20%3D%20FFFF%3CBR%20%2F%3EApp%20%3AWARN%20%3A%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3CBR%20%2F%3EApp%20%3AINFO%20%3ATag%20value%20-%20proprietary%20data%200xFE%20%3D%200xFE%3CBR%20%2F%3EApp%20%3AINFO%20%3ALength%20of%20following%20data%200x45%20%3D%200x4F%3CBR%20%2F%3EApp%20%3AINFO%20%3ATag%20card%20identification%20data%20(Len%3D2)%3CBR%20%2F%3EDF%2028%3CBR%20%2F%3EApp%20%3AINFO%20%3ALength%20of%20card%20identification%20data%20%3D%200x4C%3CBR%20%2F%3EApp%20%3AINFO%20%3ATag%20configuration%20ID%20(Must%20be%200x01)%20%3D%200x01%3CBR%20%2F%3EApp%20%3AINFO%20%3AConfiguration%20ID%20(Len%3D12)%3CBR%20%2F%3E00%2005%20B5%2001%201B%207D%20B8%201B%2089%2099%20D0%205D%3CBR%20%2F%3EApp%20%3AINFO%20%3AOEF%20ID%20(Len%3D2)%3CBR%20%2F%3EB5%2001%3CBR%20%2F%3EApp%20%3AINFO%20%3ATag%20patch%20ID%20(Must%20be%200x02)%20%3D%200x02%3CBR%20%2F%3EApp%20%3AINFO%20%3APatch%20ID%20(Len%3D8)%3CBR%20%2F%3E00%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3EApp%20%3AINFO%20%3ATag%20platform%20build%20ID1%20(Must%20be%200x03)%20%3D%200x03%3CBR%20%2F%3EApp%20%3AINFO%20%3APlatform%20build%20ID%20(Len%3D24)%3CBR%20%2F%3E4A%2033%2052%2036%2030%2030%2030%2033%2037%2033%2031%2038%2031%2032%2030%2030%3CBR%20%2F%3E6D%2020%20B6%2019%207D%2063%205E%207C%3CBR%20%2F%3EApp%20%3AINFO%20%3AJCOP%20Platform%20ID%20%3D%20J3R6000373181200%3CBR%20%2F%3EApp%20%3AINFO%20%3ATag%20FIPS%20mode%20(Must%20be%200x05)%20%3D%200x05%3CBR%20%2F%3EApp%20%3AINFO%20%3AFIPS%20mode%20var%20%3D%200x01%3CBR%20%2F%3EApp%20%3AINFO%20%3ATag%20pre-perso%20state%20(Must%20be%200x07)%20%3D%200x07%3CBR%20%2F%3EApp%20%3AINFO%20%3ABit%20mask%20of%20pre-perso%20state%20var%20%3D%200x00%3CBR%20%2F%3EApp%20%3AINFO%20%3ATag%20ROM%20ID%20(Must%20be%200x08)%20%3D%200x08%3CBR%20%2F%3EApp%20%3AINFO%20%3AROM%20ID%20(Len%3D8)%3CBR%20%2F%3EB3%2037%205F%20E9%20B5%2050%208B%20C4%3CBR%20%2F%3EApp%20%3AINFO%20%3ATag%20JCOP%20OS%20Core%20ID%20(Must%20be%200x0A)%20%3D%200x0A%3CBR%20%2F%3EApp%20%3AINFO%20%3AJCOP%20OS%20Core%20(Len%3D8)%3CBR%20%2F%3E55%2060%206F%20D4%20BE%20EC%20F3%20CD%3CBR%20%2F%3EApp%20%3AINFO%20%3AStatus%20Word%20(SW)%20(Len%3D2)%3CBR%20%2F%3E90%2000%3CBR%20%2F%3EApp%20%3AINFO%20%3Ase05x_GetInfoPlainApplet%20Example%20Success%20!!!...%3CBR%20%2F%3EApp%20%3AWARN%20%3A%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3CBR%20%2F%3EApp%20%3AINFO%20%3Acplc_data.IC_fabricator%20(Len%3D2)%3CBR%20%2F%3E47%2090%3CBR%20%2F%3EApp%20%3AINFO%20%3Acplc_data.IC_type1%20(Len%3D2)%3CBR%20%2F%3ED6%2000%3CBR%20%2F%3EApp%20%3AINFO%20%3Acplc_data.Operating_system_identifier%20(Len%3D2)%3CBR%20%2F%3E47%2000%3CBR%20%2F%3EApp%20%3AINFO%20%3Acplc_data.Operating_system_identifier%20(Len%3D2)%2047%2000%20App%20%3AINFO%20%3Acplc_data.IC_type1%20(Len%3D2)%20D6%2000Operating_system_release_date%20(Len%3D2)%3CBR%20%2F%3E00%2000%3CBR%20%2F%3EApp%20%3AINFO%20%3Acplc_data.Operating_system_release_level%20(Len%3D2)%3CBR%20%2F%3E00%2000%3CBR%20%2F%3EApp%20%3AINFO%20%3Acplc_data.IC_fabrication_date%20(Len%3D2)%3CBR%20%2F%3E41%2002%3CBR%20%2F%3EApp%20%3AINFO%20%3Acplc_data.IC_Serial_number%20(Len%3D4)%3CBR%20%2F%3E38%2051%2087%2021%3CBR%20%2F%3EApp%20%3AINFO%20%3Acplc_data.IC_Batch_identifier%20(Len%3D2)%3CBR%20%2F%3E02%2067%3CBR%20%2F%3EApp%20%3AINFO%20%3Acplc_data.IC_module_fabricator%20(Len%3D2)%3CBR%20%2F%3E00%2000%3CBR%20%2F%3EApp%20%3AINFO%20%3Acplc_data.IC_module_packaging_date%20(Len%3D2)%3CBR%20%2F%3E00%2000%3CBR%20%2F%3EApp%20%3AINFO%20%3Acplc_data.ICC_manufacturer%20(Len%3D2)%3CBR%20%2F%3E00%2000%3CBR%20%2F%3EApp%20%3AINFO%20%3Acplc_data.IC_embedding_date%20(Len%3D3)IC_embedding_date%20(Len%3D2)%3CBR%20%2F%3E00%2000%3CBR%20%2F%3EApp%20%3AINFO%20%3Acplc_data.IC_OS_initializer%20(Len%3D2)%3CBR%20%2F%3E19%2026%3CBR%20%2F%3EApp%20%3AINFO%20%3Acplc_data.IC_OS_initialization_date%20(Len%3D2)%3CBR%20%2F%3E1F%2038%3CBR%20%2F%3EApp%20%3AINFO%20%EF%BC%9Acplc_data.IC_OS_initialization_equipment%20(Len%3D4)%3CBR%20%2F%3E35%2031%2038%2037%3CBR%20%2F%3EApp%20%3AINFO%20%3Acplc_data.IC_personalizer%20(Len%3D2)%3CBR%20%2F%3E00%2000%3CBR%20%2F%3EApp%20%3AINFO%20%3Acplc_data.IC_personalization_date%20(Len%3D2)%3CBR%20%2F%3E00%2000%3CBR%20%2F%3EApp%20%3AINFO%20%3Acplc_data.IC_personalization_equipment_ID%20(Len%3D4)%2000%2000%2000%20App%20%3AINFO%20%3Acplc_data.SW%20(Len%3D2)%2090%2000%20App%20%3AINFO%20%3Acplc_data.IC_personalization_date%20(Len%3D4)IC_personalization_equipment_ID%20(Len%3D4)%3CBR%20%2F%3E00%2000%2000%3CBR%20%2F%3EApp%20%3AINFO%20%3Acplc_data.SW%20(Len%3D2)%3CBR%20%2F%3E90%2000%3CBR%20%2F%3EApp%20%3AINFO%20%3Aex_sss%20Finished%3CBR%20%2F%3EFailed%20to%20open%20GPIO%20value%20file%20%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3EFailed%20to%20unexport%20GPIO%20%3A%20Invalid%20argument%3CBR%20%2F%3EFailed%20to%20unexport%20GPIO%20%3A%20Invalid%20argument%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3Eflexxon%40raspberrypi%3A~%2FSD%2Fsimw-top_build%2Fraspbian_native_se050_t1oi2c%2Fbin%20%24%20.%2Fse05x_Minimal%3C%2FSTRONG%3E%3CBR%20%2F%3E%E5%AF%BC%E5%87%BA%E5%90%AF%E7%94%A8%E5%BC%95%E8%84%9A%E5%A4%B1%E8%B4%A5%EF%BC%9A%E5%8F%82%E6%95%B0%E6%97%A0%E6%95%88%3CBR%20%2F%3E%E6%89%93%E5%BC%80%20GPIO%20%E5%80%BC%E6%96%87%E4%BB%B6%E5%A4%B1%E8%B4%A5%EF%BC%9A%E6%97%A0%E6%AD%A4%E7%B1%BB%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3CBR%20%2F%3E%E8%A7%A3%E5%AF%BC%E5%87%BA%20GPIO%20%E5%A4%B1%E8%B4%A5%EF%BC%9A%E5%8F%82%E6%95%B0%E6%97%A0%E6%95%88%3CBR%20%2F%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AINFO%20%3ARunning%20.%2Fse05x_Minimal%3CBR%20%2F%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AINFO%20%3A%E5%A6%82%E6%9E%9C%E8%A6%81%E6%9B%B4%E6%94%B9%E9%80%89%E6%8B%A9%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%20ENV%3DEX_SSS_BOOT_SSS_PORT%20%E6%88%96%E4%BC%A0%E9%80%92%E5%91%BD%E4%BB%A4%E8%A1%8C%E5%8F%82%E6%95%B0%E3%80%82%3CBR%20%2F%3EApp%20%3AINFO%20%3APlugAndTrust_v04.07.01_20250519%3CBR%20%2F%3Esss%20%3AINFO%20%3Aatr%20(Len%3D35)%3CBR%20%2F%3E01%20A0%2000%2000%2003%2096%2004%2003%20E8%2000%20FE%2002%200B%2003%20E8%2000%3CBR%20%2F%3E01%2000%2000%2000%2064%2013%2088%200A%2000%2065%2053%2045%2030%2035%2031%3CBR%20%2F%3E00%2000%3CBR%20%2F%3Esss%20%3AINFO%20%3A%E5%8F%91%E7%8E%B0%E6%9B%B4%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%20Applet%3CBR%20%2F%3Esss%20%3AINFO%20%3ACompiled%20for%200x70200.%E5%BE%97%E5%88%B0%E6%9B%B4%E6%96%B0%200x70216%3CBR%20%2F%3Esss%20%3AWARN%20%3ACommunication%20channel%20is%20Plain.%3CBR%20%2F%3Esss%20%3AWARN%20%3A!!!Not%20recommended%20for%20production%20use.!!%3CBR%20%2F%3Esss%20%3AWARN%20%3AnxEnsure%3A'ret%20%3D%3D%20SM_OK'%20%E5%A4%B1%E8%B4%A5%E3%80%82At%20Line%3A%207839%20%E5%87%BD%E6%95%B0%3ASSS_SE05x_txN%20SSS%3A%20Warn%3A%20APDU%20%E4%BA%A4%E6%98%93%E9%94%99%E8%AF%AF%EF%BC%9A%E6%9D%A1%E4%BB%B6%E4%B8%8D%E6%BB%A1%E8%B6%B3%20(0x6%20%3CBR%20%2F%3E%20985)%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AERROR%3ASe05x_API_GetFreeMemory%20%E5%A4%B1%E8%B4%A5%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AINFO%20%3Amem%3D0%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AERROR%3Ase05x_Minimal%20Example%20%E5%A4%B1%E8%B4%A5%20!!!..%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AINFO%20%3Aex_sss%20%E5%B7%B2%E5%AE%8C%E6%88%90%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AERROR%3Aex_sss_entry%20%E5%A4%B1%E8%B4%A5%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20%3AERROR%3A%EF%BC%81ERROR%EF%BC%81%20ret%20!%3D%200.%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3ESureshkumar%20R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2254906%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2254906%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%9B%B4%E6%96%B0%E3%80%82%E6%98%AF%E7%9A%84%EF%BC%8C%E5%9C%A8%E9%85%8D%E7%BD%AE%E4%BA%86%E6%AD%A3%E7%A1%AE%E7%9A%84%20PlatformSCP%20%E5%AF%86%E9%92%A5%E5%90%8E%EF%BC%8CMW%20%E7%8E%B0%E5%9C%A8%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E4%B8%8D%E5%AF%BB%E5%B8%B8%E7%9A%84%E4%BA%8B%E6%83%85%EF%BC%9APlug%20%26amp%3B%20Trust%20Nano%20%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%A4%BA%E4%BE%8B%E7%8E%B0%E5%9C%A8%E4%B9%9F%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E4%BB%A3%E7%A0%81%E6%9B%B4%E6%94%B9%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E8%BF%90%E8%A1%8C%EF%BC%8C%E5%B0%BD%E7%AE%A1%E5%AE%83%E4%BB%AC%E4%B9%8B%E5%89%8D%E5%A4%B1%E8%B4%A5%E4%BA%86%E3%80%82%E6%88%91%E4%B8%8D%E6%98%8E%E7%99%BD%E4%BB%96%E4%BB%AC%E6%80%8E%E4%B9%88%E4%BC%9A%E7%AA%81%E7%84%B6%E5%BC%80%E5%A7%8B%E5%B7%A5%E4%BD%9C%E3%80%82%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E6%98%AF%E4%BB%80%E4%B9%88%E5%8E%9F%E5%9B%A0%E5%AF%BC%E8%87%B4%E4%BA%86%E8%BF%99%E7%A7%8D%E8%A1%8C%E4%B8%BA%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3Eflexxon%20%40raspberrypi%EF%BC%9A~%2Fse050%2Fnew-nano%2Fse052f%2Fnano-package%2Fexamples%2Fse05x_crypto%2FLinux%2FBuild%20%24%E3%80%82%2Fex_%3C%2FSTRONG%3E%20se05x_crypto%20%3CBR%20%2F%3ESE05x%20%E5%8A%A0%E5%AF%86%E7%A4%BA%E4%BE%8B%EF%BC%81%3CBR%20%2F%3EPlug%20and%20Trust%20nano%20%E8%BD%AF%E4%BB%B6%E5%8C%85-%E7%89%88%E6%9C%AC%EF%BC%9A1.5.4%20%3CBR%20%2F%3EI2C%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%94%AF%E6%8C%81%E6%99%AE%E9%80%9A%20i2c%20%E7%BA%A7%E5%91%BD%E4%BB%A4%E3%80%82%3CBR%20%2F%3E%E5%BB%BA%E7%AB%8B%E5%88%B0%20SE05x%20%E7%9A%84%E5%AE%89%E5%85%A8%E9%80%9A%E9%81%93%20!%3CBR%20%2F%3E%E5%88%9B%E5%BB%BA%20scp03%20%E4%BC%9A%E8%AF%9D%3CBR%20%2F%3E%E8%8E%B7%E5%8F%96%E7%89%88%E6%9C%AC%20%3D%3D%26gt%3B%3CBR%20%2F%3E%20%E5%B0%8F%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%207.2.22%3CBR%20%2F%3Eex_get_version%E3%80%81%E5%B7%B2%E9%80%9A%E8%BF%87%20ex_generate_nist256_key%E3%80%81%E5%B7%B2%E9%80%9A%E8%BF%87%20%3CBR%20%2F%3E%20ex_set_get_nist256_key%E3%80%81%E5%B7%B2%E9%80%9A%E8%BF%87%20ex_nist256_sign_verify%E3%80%81%E5%B7%B2%E9%80%9A%E8%BF%87%20ex_generate_nist384_key%E3%80%81%E9%80%9A%E8%BF%87%20%3CBR%20%2F%3E%20ex_nist384_sign_verify%E3%80%81%E9%80%9A%E8%BF%87%20ex_set_certificate%E3%80%81%E9%80%9A%E8%BF%87%20ex_set_certificate%E3%80%81%E5%B7%B2%E9%80%9A%E8%BF%87%20ex_set_nist_certificate%E3%80%81%E5%B7%B2%E9%80%9A%E8%BF%87%20ex_set_nist_certificate%E3%80%81%E9%80%9A%E8%BF%87%20ex_set_nist_cert%20%3CBR%20%2F%3E%20ificate%E3%80%81%E9%80%9A%E8%BF%87%20ex_dh%EF%BC%8C%E9%80%9A%E8%BF%87%E4%BA%86%20ex_AES_ECB_NOPAD%EF%BC%8C%E9%80%9A%E8%BF%87%E4%BA%86%20ex_AES_CBC_NOPAD%EF%BC%8C%E9%80%9A%E8%BF%87%E4%BA%86%20ex_AES_CTR%EF%BC%8C%E9%80%9A%E8%BF%87%E4%BA%86%20ex_nist256_sign_policy%EF%BC%8C%E9%80%9A%E8%BF%87%E4%BA%86%20%3CBR%20%2F%3E%20ex_read_attst_object%EF%BC%8C%E9%80%9A%E8%BF%87%E5%85%B3%E9%97%AD%20i2c%20%E8%AE%BE%E5%A4%87%203%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3ESE05x%20%E5%8A%A0%E5%AF%86%E7%A4%BA%E4%BE%8B%E6%88%90%E5%8A%9F%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3ESureshkumar%20R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E5%BB%BA%E8%AE%AE%E5%B0%86%20RST%20%E5%BC%95%E8%84%9A%E8%BF%9E%E6%8E%A5%E5%88%B0%20VCC%EF%BC%8C%E5%AF%B9%E8%AE%BE%E7%BD%AE%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%EF%BC%8C%E4%BD%86%E9%97%AE%E9%A2%98%E4%BE%9D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%88%91%E8%A7%82%E5%AF%9F%E5%88%B0%EF%BC%8C%E5%BD%93%E6%88%91%E9%A6%96%E5%85%88%E8%BF%90%E8%A1%8C%E4%B8%AD%E9%97%B4%E4%BB%B6%E7%A4%BA%E4%BE%8B%E6%97%B6%EF%BC%8C%E4%B8%AD%E9%97%B4%E4%BB%B6%E5%92%8C%E7%BA%B3%E7%B1%B3%E4%BB%A3%E7%A0%81%E5%8C%85%E9%83%BD%E8%83%BD%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E6%96%AD%E5%BC%80%E5%B9%B6%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%20SE052F%20%E6%9D%BF%E7%9A%84%E7%94%B5%E6%BA%90%E5%90%8E%EF%BC%8CNano%20%E8%BD%AF%E4%BB%B6%E5%8C%85%E6%97%A0%E6%B3%95%E5%86%8D%E6%AC%A1%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3ESureshkumar%20R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E6%B5%8B%E8%AF%95%E4%B8%A4%E6%AC%BE%E6%96%B0%E7%9A%84%20SE052F%20%E6%9D%BF%E3%80%82%E5%9C%A8%E7%AC%AC%E4%B8%80%E4%B8%AA%E6%9D%BF%E4%B8%8A%EF%BC%8CPlug%20%26amp%3B%20Play%20Nano%20%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%A4%BA%E4%BE%8B%E6%9C%80%E5%88%9D%E5%A4%B1%E8%B4%A5%E4%BA%86%EF%BC%8C%E4%BD%86%E6%98%AF%E5%9C%A8%E4%BD%BF%E7%94%A8%20plain_scp.txt%20%E8%BF%90%E8%A1%8C%E4%B8%80%E6%AC%A1%E4%B8%AD%E9%97%B4%E4%BB%B6%E7%A4%BA%E4%BE%8B%E4%B9%8B%E5%90%8E%EF%BC%8C%E4%B8%AD%E9%97%B4%E4%BB%B6%E5%92%8C%E7%BA%B3%E7%B1%B3%E6%A0%B7%E6%9C%AC%E9%83%BD%E5%BC%80%E5%A7%8B%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E5%88%87%E6%8D%A2%E5%88%B0%E7%AC%AC%E4%BA%8C%E5%9D%97%E6%96%B0%E6%9D%BF%E5%B9%B6%E6%B5%8B%E8%AF%95%20Nano%20%E8%BD%AF%E4%BB%B6%E5%8C%85%E6%97%B6%EF%BC%8C%E5%AE%83%E5%A4%B1%E8%B4%A5%E4%BA%86%E3%80%82%E4%B9%8B%E5%90%8E%EF%BC%8C%E5%BD%93%E6%88%91%E5%88%87%E6%8D%A2%E5%9B%9E%E7%AC%AC%E4%B8%80%E5%9D%97%E6%9D%BF%E6%97%B6%EF%BC%8CNano%20%E4%BB%A3%E7%A0%81%E5%8C%85%E4%B9%9F%E5%86%8D%E6%AC%A1%E5%A4%B1%E6%95%88%E3%80%82%E7%9C%8B%E6%9D%A5%E6%AF%8F%E6%AC%A1%E9%83%BD%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%20plain_scp.txt%20%E8%BF%90%E8%A1%8C%E4%B8%AD%E9%97%B4%E4%BB%B6%E7%A4%BA%E4%BE%8B%E6%89%8D%E8%83%BD%E4%BD%BF%20Nano%20%E8%BD%AF%E4%BB%B6%E5%8C%85%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%83%BD%E5%90%A6%E5%B8%AE%E5%BF%99%E6%BE%84%E6%B8%85%E4%B8%BA%E4%BB%80%E4%B9%88%20Plug%20%26amp%3B%20Play%20Nano%20%E6%A0%B7%E6%9C%AC%E5%9C%A8%E4%B8%8D%E5%90%8C%E7%9A%84%20SE052F%20%E6%9D%BF%E4%B9%8B%E9%97%B4%E5%88%87%E6%8D%A2%E6%97%B6%E8%A1%A8%E7%8E%B0%E4%B8%8D%E4%B8%80%E8%87%B4%EF%BC%9F%E5%9C%A8%E8%BF%90%E8%A1%8C%20Nano%20%E4%BB%A3%E7%A0%81%E5%8C%85%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%AF%B9%E6%AF%8F%E5%9D%97%E6%9D%BF%E8%BF%9B%E8%A1%8C%E4%BB%BB%E4%BD%95%E9%85%8D%E7%BD%AE%E6%88%96%E9%87%8D%E6%96%B0%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3ESureshkumar%20R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F210184%22%20target%3D%22_blank%22%3E%40krsuresh%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%A0%E6%98%AF%E5%A6%82%E4%BD%95%E5%B0%86%20SE05x%20%E4%B8%8E%E6%A0%91%E8%8E%93%E6%9D%BF%E8%BF%9E%E6%8E%A5%E8%B5%B7%E6%9D%A5%E7%9A%84%EF%BC%9F%E5%A6%82%E6%9E%9C%E4%BD%A0%E9%80%9A%E8%BF%87%E7%94%B5%E7%BA%BF%E8%BF%9E%E6%8E%A5%E5%AE%83%E4%BB%AC%EF%BC%8C%E4%B9%9F%E8%AE%B8%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%B0%86RST%E5%BC%95%E8%84%9A%E7%9B%B4%E6%8E%A5%E8%BF%9E%E6%8E%A5%E5%88%B0VCC%EF%BC%8C%E4%BB%A5%E9%81%BF%E5%85%8DRESET%E6%97%B6SE%E4%BF%9D%E6%8C%81%E4%B8%8D%E5%8F%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kan_Li_0-1764910314471.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764910314471.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764910314471.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764910314471.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764910314471.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764910314471.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764910314471.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764910314471.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764910314471.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764910314471.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764910314471.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764910314471.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764910314471.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764910314471.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764910314471.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1764910314471.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368695i3736DE981A301525%2Fimage-dimensions%2F672x391%3Fv%3Dv2%22%20width%3D%22672%22%20height%3D%22391%22%20role%3D%22button%22%20title%3D%22Kan_Li_0-1764910314471.png%22%20alt%3D%22Kan_Li_0-1764910314471.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKan_Li_0-1764910314471.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2260639%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2260639%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F210184%22%20target%3D%22_blank%22%3E%40krsuresh%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%BF%99%E9%87%8C%E9%87%8D%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E7%8E%B0%E5%9C%A8%E6%AD%A3%E5%9C%A8%E4%B8%8E%20MW%20%E5%9B%A2%E9%98%9F%E6%A0%B8%E5%AE%9E%EF%BC%8C%E6%9C%89%E8%BF%9B%E5%B1%95%E6%97%B6%E4%BC%9A%E9%80%9A%E7%9F%A5%E6%82%A8%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E8%80%90%E5%BF%83%E7%AD%89%E5%BE%85%EF%BC%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E5%9D%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2269512%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2269512%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F210184%22%20target%3D%22_blank%22%3E%40krsuresh%3C%2FA%3E%EF%BC%8C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%BE%88%E6%8A%B1%E6%AD%89%EF%BC%8C%E7%94%B1%E4%BA%8E%E5%81%87%E6%9C%9F%E7%9A%84%E5%8E%9F%E5%9B%A0%EF%BC%8CMW%20%E5%9B%A2%E9%98%9F%E8%87%B3%E4%BB%8A%E6%B2%A1%E6%9C%89%E5%81%9A%E5%87%BA%E4%BB%BB%E4%BD%95%E5%9B%9E%E5%BA%94%EF%BC%8C%E8%80%8C%E4%BD%9C%E4%B8%BA%E5%BF%AB%E9%80%9F%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E8%BE%83%E9%95%BF%E7%9A%84%E8%AE%A1%E6%97%B6%E5%99%A8%E9%97%B4%E9%9A%94%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kan_Li_0-1766990511717.png%22%20style%3D%22width%3A%20619px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1766990511717.png%22%20style%3D%22width%3A%20619px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1766990511717.png%22%20style%3D%22width%3A%20619px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1766990511717.png%22%20style%3D%22width%3A%20619px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1766990511717.png%22%20style%3D%22width%3A%20619px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1766990511717.png%22%20style%3D%22width%3A%20619px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1766990511717.png%22%20style%3D%22width%3A%20619px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1766990511717.png%22%20style%3D%22width%3A%20619px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1766990511717.png%22%20style%3D%22width%3A%20619px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1766990511717.png%22%20style%3D%22width%3A%20619px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1766990511717.png%22%20style%3D%22width%3A%20619px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1766990511717.png%22%20style%3D%22width%3A%20619px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1766990511717.png%22%20style%3D%22width%3A%20619px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1766990511717.png%22%20style%3D%22width%3A%20619px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F371299i2F904858FE09CBD4%2Fimage-dimensions%2F619x287%3Fv%3Dv2%22%20width%3D%22619%22%20height%3D%22287%22%20role%3D%22button%22%20title%3D%22Kan_Li_0-1766990511717.png%22%20alt%3D%22Kan_Li_0-1766990511717.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKan_Li_0-1766990511717.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%BA%90%E6%96%87%E4%BB%B6%E5%8F%AF%E4%BB%A5%E5%9C%A8%20nano-package-master%2Flib%2Fplatform%2Flinux%2F%20%E4%B8%AD%E6%89%BE%E5%88%B0%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E4%BD%A0%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2269452%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2269452%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%AA%E6%98%AF%E6%83%B3%E4%BA%86%E8%A7%A3%E4%B8%80%E4%B8%8B%20MW%20%E5%9B%A2%E9%98%9F%E5%9C%A8%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%B8%8A%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E8%BF%9B%E5%B1%95%E6%88%96%E6%9B%B4%E6%96%B0%E3%80%82%3CBR%20%2F%3E%E6%9C%89%E4%BB%BB%E4%BD%95%E4%BF%A1%E6%81%AF%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%3CBR%20%2F%3ESureshkumar%20R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2292481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2292481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E5%BB%BA%E8%AE%AE%EF%BC%8C%E6%88%91%E5%A2%9E%E5%8A%A0%E4%BA%86%E8%AE%A1%E6%97%B6%E5%99%A8%E7%9A%84%E9%97%B4%E9%9A%94%E6%97%B6%E9%97%B4%EF%BC%8C%E4%BD%86%E8%BF%98%E6%98%AF%E5%87%BA%E7%8E%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E6%83%85%E5%86%B5%E3%80%82%3CBR%20%2F%3E%E6%B0%B4%E5%88%A9%E9%83%A8%E5%9B%A2%E9%98%9F%E5%9C%A8%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%B8%8A%E6%9C%89%E4%BB%80%E4%B9%88%E6%96%B0%E8%BF%9B%E5%B1%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3ESureshkumar%20R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2297892%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2297892%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F210184%22%20target%3D%22_blank%22%3E%40krsuresh%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E5%B0%9D%E8%AF%95%E8%BF%87%E7%94%A8%E6%9B%B4%E5%A4%A7%E7%9A%84%E6%95%B0%E5%80%BC%E6%9D%A5%E4%BB%A3%E6%9B%BF%EF%BC%9FMW%20%E5%B7%B2%E7%BB%8F%E5%B0%86%E5%85%B6%E7%BA%B3%E5%85%A5%E4%BA%86%E8%AE%A1%E5%88%92%EF%BC%8C%E4%BD%86%E6%88%91%E9%A2%84%E8%AE%A1%E4%BF%AE%E5%A4%8D%E7%A8%8B%E5%BA%8F%E5%B0%86%E5%9C%A8%E4%B8%8B%E4%B8%80%E4%B8%AA%E7%89%88%E6%9C%AC%E4%B8%AD%E5%8F%91%E5%B8%83%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2301777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2301777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%20%E4%BD%A0%E7%9F%A5%E9%81%93%E6%9C%89%E4%BB%BB%E4%BD%95%E5%AE%9A%E6%9C%9F%E5%8F%91%E5%B8%83%E7%9A%84%E9%A2%84%E5%AE%9A%E7%89%88%E6%9C%AC%E5%90%97%EF%BC%8C%E6%88%91%E4%BB%AC%E9%A2%84%E8%AE%A1%E4%BC%9A%E5%9C%A8%E8%BF%99%E6%AE%B5%E6%97%B6%E9%97%B4%E5%86%85%E5%8F%91%E5%B8%83%E8%BF%99%E4%B8%AA%E7%89%88%E6%9C%AC%EF%BC%9F%3C%2FP%3E%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%9C%A8%E6%AF%8F%E4%B8%AA%E5%AD%A3%E5%BA%A6%E5%86%85%EF%BC%8C%E8%BF%98%E6%98%AF%E6%AF%8F%E4%B8%AA%20Q1%26amp%3B%20Q3%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E4%B8%8D%E6%98%AF%E5%BE%88%E5%BF%AB%E5%B0%B1%E4%BC%9A%E5%8F%91%E7%94%9F%E7%9A%84%E4%BA%8B%E6%83%85%EF%BC%8C%E9%82%A3%E4%B9%88%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E7%9F%A5%E9%81%93%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%AF%E8%83%BD%E5%9C%A8%E4%B8%8D%E5%BD%B1%E5%93%8D%E6%88%91%E4%BB%AC%E7%9A%84%E5%BC%80%E5%8F%91%E6%B4%BB%E5%8A%A8%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E8%BF%9B%E8%A1%8C%E9%9D%9E%E5%91%A8%E6%9C%9F%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%90%A6%E5%88%99%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E8%83%BD%E5%BF%85%E9%A1%BB%E8%80%83%E8%99%91%E5%85%B6%E4%BB%96%E9%80%89%E9%A1%B9%EF%BC%8C%E4%BE%8B%E5%A6%82%E9%87%8D%E6%96%B0%E4%BD%BF%E7%94%A8%20SE050%EF%BC%88%E7%94%A8%E4%BA%8E%E6%88%91%E4%BB%AC%E5%8D%B3%E5%B0%86%E6%8E%A8%E5%87%BA%E7%9A%84%E5%8E%9F%E5%9E%8B%E7%89%88%E6%9C%AC%EF%BC%89%EF%BC%8C%E5%B9%B6%E4%BA%86%E8%A7%A3%E8%BF%81%E7%A7%BB%E5%88%B0%20SE052%20%E9%9C%80%E8%A6%81%E4%BB%80%E4%B9%88%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2303462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259272%22%20target%3D%22_blank%22%3E%EF%BC%8C%40Ben-FLX%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E6%BE%84%E6%B8%85%EF%BC%81%E6%88%91%E4%BC%9A%E8%AE%A9%E6%B0%B4%E5%88%A9%E9%83%A8%E5%9B%A2%E9%98%9F%E4%BA%86%E8%A7%A3%E6%AD%A4%E4%BA%8B%E3%80%82%E8%87%B3%E4%BA%8E%E9%80%9A%E7%9F%A5%EF%BC%8C%E6%88%91%E6%83%B3%E4%BD%A0%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20github%20%E4%B8%8A%E7%9A%84%20notify%20%E5%87%BD%E6%95%B0%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kan_Li_0-1769759900876.png%22%20style%3D%22width%3A%20665px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1769759900876.png%22%20style%3D%22width%3A%20665px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1769759900876.png%22%20style%3D%22width%3A%20665px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1769759900876.png%22%20style%3D%22width%3A%20665px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1769759900876.png%22%20style%3D%22width%3A%20665px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1769759900876.png%22%20style%3D%22width%3A%20665px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1769759900876.png%22%20style%3D%22width%3A%20665px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1769759900876.png%22%20style%3D%22width%3A%20665px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1769759900876.png%22%20style%3D%22width%3A%20665px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374920iCA37D3F18182B4BA%2Fimage-dimensions%2F665x270%3Fv%3Dv2%22%20width%3D%22665%22%20height%3D%22270%22%20role%3D%22button%22%20title%3D%22Kan_Li_0-1769759900876.png%22%20alt%3D%22Kan_Li_0-1769759900876.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKan_Li_0-1769759900876.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%80%BB%E4%B9%8B%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E9%9A%8F%E6%97%B6%E8%81%94%E7%B3%BB%E6%88%91%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2303349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259272%22%20target%3D%22_blank%22%3E%EF%BC%8C%40Ben-FLX%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E8%AE%A1%E5%88%92%E5%9C%A8%202026%20%E5%B9%B4%202%20%E6%9C%88%E5%BA%95%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%8E%E4%B8%BB%E8%BD%AF%E4%BB%B6%E5%8C%85%E4%B8%80%E8%B5%B7%E7%89%88%E6%9C%AC%E3%80%82%E5%AE%83%E4%B8%8E%E4%BD%A0%E7%9A%84%E6%97%B6%E9%97%B4%E8%A1%A8%E4%B8%80%E8%87%B4%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%9D%8E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2303454%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303454%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E5%8F%AA%E8%A6%81%E6%88%91%E4%BB%AC%E8%83%BD%E5%A4%9F%E4%BD%BF%E7%94%A8%20SE052%20%E8%AF%84%E4%BC%B0%E6%9D%BF%E6%89%A7%E8%A1%8C%E8%BD%AF%E4%BB%B6%E5%8C%85%E6%8F%90%E4%BE%9B%E7%9A%84%E6%89%80%E6%9C%89%E6%94%AF%E6%8C%81%E7%9A%84%E4%BB%A3%E7%A0%81%2F%E5%8A%9F%E8%83%BD%EF%BC%8C%E4%BA%8C%E6%9C%88%E5%BA%95%E5%B0%B1%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E5%BD%93%E7%84%B6%EF%BC%8C%E8%BF%99%E4%B8%AA%E8%BD%AF%E4%BB%B6%E5%8C%85%E5%8F%AF%E4%BB%A5%E8%B6%8A%E6%97%A9%E6%8F%90%E4%BE%9B%EF%BC%8C%E5%AF%B9%E6%88%91%E4%BB%AC%E8%B6%8A%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E5%90%8E%EF%BC%8C%E5%9C%A8%E6%96%B0%E8%BD%AF%E4%BB%B6%E5%8C%85%E4%B8%8A%E5%B8%82%E6%97%B6%E9%80%9A%E7%9F%A5%E6%88%91%E4%BB%AC%E7%9A%84%E5%A5%BD%E6%96%B9%E6%B3%95%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%E6%88%91%E4%B8%8D%E6%B8%85%E6%A5%9A%E4%B8%BA%E4%BB%80%E4%B9%88%E6%88%91%E5%9C%A8%E8%BF%99%E9%87%8C%E6%B2%A1%E6%9C%89%E6%94%B6%E5%88%B0%E7%94%B5%E5%AD%90%E9%82%AE%E4%BB%B6%E9%80%9A%E7%9F%A5%EF%BC%8C%E8%80%8C%E4%B8%94%E6%88%91%E4%B9%9F%E6%B2%A1%E6%9C%89%E6%AF%8F%E5%A4%A9%E5%88%B7%E6%96%B0%E6%81%A9%E6%99%BA%E6%B5%A6%E7%BD%91%E7%AB%99%E6%9F%A5%E7%9C%8B%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2321650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2321650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%20%E5%8F%AA%E6%98%AF%E6%83%B3%E7%9F%A5%E9%81%93%EF%BC%8C%E6%9C%89%E5%85%B3%E4%BA%8E%E8%AE%A1%E5%88%92%E7%9A%84%E7%89%88%E6%9C%AC%E7%9A%84%E6%9B%B4%E6%96%B0%2F%E6%96%B0%E9%97%BB%E5%90%97%EF%BC%9F%E8%BF%9B%E5%B1%95%E9%A1%BA%E5%88%A9%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2322881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2322881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259272%22%20target%3D%22_blank%22%3E%EF%BC%8C%40Ben-FLX%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E5%88%9A%E5%90%91%20MW%20%E5%9B%A2%E9%98%9F%E6%A0%B8%E5%AE%9E%E8%BF%87%EF%BC%8C%E4%BF%AE%E5%A4%8D%E7%A8%8B%E5%BA%8F%3CSPAN%20data-teams%3D%22true%22%3E%E5%B0%86%E4%BA%8E%203%20%E6%9C%88%2031%20%E6%97%A5%E6%8E%A8%E5%87%BA%E3%80%82%E7%94%B1%E4%BA%8E%E5%85%B6%E4%BB%96%E4%BC%98%E5%85%88%E4%BA%8B%E9%A1%B9%EF%BC%8C%E4%BF%AE%E5%A4%8D%E5%B7%A5%E4%BD%9C%E8%A2%AB%E6%8E%A8%E8%BF%9F%E4%BA%86%E3%80%82%E5%BE%88%E6%8A%B1%E6%AD%89%E7%BB%99%E6%82%A8%E5%B8%A6%E6%9D%A5%E4%B8%8D%E4%BE%BF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2324193%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2324193%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E6%96%B0%E7%9A%84%E5%B1%95%E6%9C%9B%E3%80%82%E6%88%91%E4%BB%AC%E6%98%AF%E5%90%A6%E6%9C%89%E5%8A%9E%E6%B3%95%E8%8E%B7%E5%BE%97%E6%81%A9%E6%99%BA%E6%B5%A6%E5%AF%B9%E8%BF%99%E4%B8%80%E6%96%B0%E5%89%8D%E6%99%AF%E7%9A%84%E6%89%BF%E8%AF%BA%EF%BC%8C%E8%80%8C%E4%B8%8D%E4%BB%85%E4%BB%85%E6%98%AF%E5%9C%A8%203%20%E6%9C%88%E5%BA%95%E5%88%B0%E6%9D%A5%E6%97%B6%E6%97%A0%E6%B3%95%E5%AE%9E%E7%8E%B0%E7%9A%84%E6%B5%B7%E5%B8%82%E8%9C%83%E6%A5%BC%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%99%A4%E4%BA%86%E5%8E%9F%E5%B0%81%E4%B8%8D%E5%8A%A8%E5%9C%B0%E5%90%9E%E4%B8%8B%E8%BF%99%E4%B8%AA%E6%B6%88%E6%81%AF%EF%BC%8C%E5%B9%B6%E7%9F%A5%E9%81%93%E6%88%91%E4%BB%AC%E6%97%A0%E6%B3%95%E5%9C%A8%20SE052%20%E4%B8%8A%E5%8F%96%E5%BE%97%E8%BF%9B%E5%B1%95%E4%B9%8B%E5%A4%96%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E8%BF%98%E6%9C%89%E4%BB%80%E4%B9%88%E5%85%B6%E4%BB%96%E5%8A%9E%E6%B3%95%E6%9D%A5%E8%A1%A8%E8%BE%BE%E8%BF%99%E7%A7%8D%E4%BB%A4%E4%BA%BA%E4%B8%8D%E5%BF%AB%E7%9A%84%E4%BD%99%E5%91%B3%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%B9%9F%E8%AE%B8%EF%BC%8C%E6%88%91%E4%BB%AC%E5%BA%94%E8%AF%A5%E8%AE%A4%E7%9C%9F%E8%80%83%E8%99%91%E5%85%B6%E4%BB%96%E4%BE%9B%E5%BA%94%E5%95%86......%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2325962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259272%22%20target%3D%22_blank%22%3E%40Ben-FLX%3C%2FA%3E%EF%BC%8C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3EGitHub%20Nano-PKG%20%E7%8E%B0%E5%9C%A8%E5%B7%B2%E7%BB%8F%E6%9B%B4%E6%96%B0%E4%BA%86%EF%BC%8C%E4%BD%86%E5%AE%83%E8%BF%98%E6%B2%A1%E6%9C%89%E7%89%88%E6%9C%AC%EF%BC%8C%E5%AE%83%E6%98%AF%E4%B8%80%E4%B8%AA%E9%A2%84%E5%8F%91%E8%A1%8C%E7%89%88%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%B9%B2%E8%84%86%E7%94%A8%20git%20%E5%85%8B%E9%9A%86%E5%AE%83%E6%9D%A5%E8%BF%9B%E8%A1%8C%E8%AF%84%E4%BC%B0%E3%80%82%E7%89%88%E6%9C%AC%E8%BF%87%E7%A8%8B%E5%B0%86%E4%B8%8E%E6%9A%82%E5%AE%9A%E4%BA%8E%202026%20%E5%B9%B4%203%20%E6%9C%88%3CSUP%3E%2031%20%E6%97%A5%E5%8F%91%E5%B8%83%E7%9A%84%E7%89%88%E6%9C%AC%E4%B8%80%E8%B5%B7%E5%AE%8C%E6%88%90%E3%80%82%3C%2FSUP%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E4%BD%A0%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2342459%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Failure%20in%20Se05x_API_SessionOpen%20on%20SE052F%20(Raspberry%20Pi%20I2C%20Communication%20Issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2342459%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E6%88%91%E5%81%87%E8%AE%BE%20MW%20%E5%B0%86%E8%BF%9B%E4%B8%80%E6%AD%A5%E5%BB%B6%E8%BF%9F%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-left%22%20image-alt%3D%22Last%20update%20was%206%20months%20ago%20based%20on%2031%2F3%2F2026%2010.16am%20(%2B8GMT%20timestamp)%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Last%20update%20was%206%20months%20ago%20based%20on%2031%2F3%2F2026%2010.16am%20(%2B8GMT%20timestamp)%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F380873i8CB13EAEC3D61741%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22Last%20update%20was%206%20months%20ago%20based%20on%2031%2F3%2F2026%2010.16am%20(%2B8GMT%20timestamp)%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ELast%20update%20was%206%20months%20ago%20based%20on%2031%2F3%2F2026%2010.16am%20(%2B8GMT%20timestamp)%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E4%B8%8A%E6%AC%A1%E6%9B%B4%E6%96%B0%E6%98%AF%206%20%E4%B8%AA%E6%9C%88%E5%89%8D%EF%BC%8C%E5%9F%BA%E4%BA%8E%2031%2F3%2F2026%2010.16am%20(%2B8GMT%20%E6%97%B6%E9%97%B4%E6%88%B3)%3C%2FSPAN%3E%3C%2FSPAN%3Eed%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
