utest nvm user space programming
ソリューションへジャンプ
2,391件の閲覧回数
pasa_kevin_y
is there a way to program utest user space(OTP data) by using jtag direct flashing?
just like how we flash the pflash and dflash?
I
2,364件の閲覧回数
lukaszadrapa
Hi @pasa_kevin_y
Yes, it is possible. It depends on your tools. If you have Lauterbach debugger, you can use simple script which I shared in this post a few days ago:
https://community.nxp.com/t5/S32K/S32K388-HSE-No-Response-Error/m-p/2090937/highlight/true#M48394
Lukas
4 返答(返信)
2,365件の閲覧回数
lukaszadrapa
Hi @pasa_kevin_y
Lukas
2,347件の閲覧回数
pasa_kevin_y
Thanks, it looks like the debugger load a driver to RAM and it plays the magic.
It should also follow the reference manual to program through the registers.
2,366件の閲覧回数
raj12
Hi @pasa_kevin_y,
you can use lauterbach cmm script to write data into UTEST area.
2,345件の閲覧回数
pasa_kevin_y
Thank you for your answer too.
