returns HSE_SRV_RSP_INVALID_PARAM
hangwu
S32K314 After integrating "Crypto_43_HSE_TS_T40D34M50I0R0", calling the function "
“Crypto_43_HSE_Exts_FormatKeyCatalogs” “
Crypto_43_HSE_KeyElementSet
returns HSE_SRV_RSP_INVALID_PARAM. What could be the possible causes? Additionally, I confirm that all RAM used by Crypto is configured as non-cacheable.
strofald
I am facing the same Issue with driver Crypto_43_HSE v6.0.0 (Crypto_43_HSE_TS_T40D34M60I0R0) on S32K312 and I am facing the exact same issue.
I successfully formatted the key catalogs, and I can see that after that the HSE Status is reported as 0x0B60 so CUST_DEL should be active.
In the NvM and Ram Key Catalogs I have the following configuration:
but I get
HSE_SRV_RSP_INVALID_PARAM when I try to do KeyElementSet to initialize the key.
strofald
On a side note, I can tell you that I am trying to load the AES key without actually doing anything with the SHE keys.
lukaszadrapa
Hi @hangwu
Is it possible to share some simple project to reproduce the issue?
Lukas
hangwu
Due to project constraints, I cannot provide a complete runnable project. Below are the two main source files. I integrated the "S32K3XX_S32M27x_RTD_R21-11_5.0.0_P08" RTD package. The EB configuration strictly follows:
"\S32K3XX_S32M27x_RTD_R21-11_5.0.0_P08\eclipse\plugins\Crypto_43_HSE_TS_T40D34M50I0R0\examples\EBT\S32K3XX".
I tested random number generation, hash values, UpdateFw, GetFwVersion, and other services – all worked normally. However:
  • "Crypto_43_HSE_Exts_FormatKeyCatalogs"
  • "Crypto_43_HSE_KeyElementSet"
  • "Crypto_43_HSE_KeySetValid"
  • "Crypto_43_HSE_ProcessJob"
    all returned "HSE_SRV_RSP_INVALID_PARAM".
I discovered the ‌HSE_STATUS_INSTALL_OK bit is cleared‌, so I tried calling FormatKey – but it failed.
lukaszadrapa
Hi @hangwu
I'm sorry for delayed response.
Are you still in CUST_DEL life cycle? Easiest option to confirm this - please send me a screenshot of memory at 0x1B00_0220 - 0x1B00_026F.
The catalogs can be formatted only in CUST_DEL life cycle, so this could be the root cause. Next failing commands (keyelementset...) could be just a consequence because the catalogs are not formatted.
Lukas
III
我当前S32K312芯片,HSE版本为255,调用函数Crypto_KeyElementSet也返回HSE_SRV_RSP_INVALID_PARAM,当前lifecycle、catalog和EB配置如下图所示,能帮忙看一下什么原因么,我也确认不是cache的原因
III
hangwu
Thank you for your reply. Based on this memory screenshot, can you identify any issues?
lukaszadrapa
Well, there's no problem with the life cycle. Your device is still in CUST_DEL.
Could you show me how are NVM and RAM catalogs defined?
hangwu
Thank you for your reply; I have attached the EB configuration file and some screenshots
hangwu
Thanks for your help. Problem solved! Much appreciated.
Bhushan1312
Hello @hangwu , Can you please share the details how you resolved it.
I am also facing similar kind of issue while programming the ADKP using HSE Library
hangwu
/* Table containing NVM key catalog entries */
const hseKeyGroupCfgEntry_t aHseNvmKeyCatalog[] =
/* NvmKeyGroup_0 */
{(HSE_MU0_MASK | HSE_MU1_MASK), HSE_KEY_OWNER_CUST, HSE_KEY_TYPE_AES, 10U, 256U, {0U, 0U}},
/* NvmKeyGroup_1 */
{(HSE_MU0_MASK | HSE_MU1_MASK), HSE_KEY_OWNER_CUST, HSE_KEY_TYPE_ECC_PAIR, 10U, 521U, {0U, 0U}},
/* Marker to end the key catalog */
{0U, 0U, 0U, 0U, 0U, {0U, 0U}}
/* Table containing RAM key catalog entries */
const hseKeyGroupCfgEntry_t aHseRamKeyCatalog[] =
/* RamKeyGroup_0 */
{(HSE_MU0_MASK | HSE_MU1_MASK), HSE_KEY_OWNER_ANY, HSE_KEY_TYPE_AES, 10U, 128U, {0U, 0U}},
/* RamKeyGroup_1 */
{(HSE_MU0_MASK | HSE_MU1_MASK), HSE_KEY_OWNER_ANY, HSE_KEY_TYPE_ECC_PAIR, 10U, 521U, {0U, 0U}},
The root cause of my error is the absence of the RAM marker(/* Marker to end the key catalog */)—I simply never configured ramKeyCatalog, and it turns out this entry is mandatory.
Bhushan1312
Thank you for the Information..
%3CLINGO-SUB%20id%3D%22lingo-sub-2119302%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ereturns%20HSE_SRV_RSP_INVALID_PARAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2119302%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ES32K314%20After%20integrating%20%22Crypto_43_HSE_TS_T40D34M50I0R0%22%2C%20calling%20the%20function%20%22%3C%2FP%3E%3CDIV%3E%3CSPAN%3E%3CSPAN%3E%E2%80%9CCrypto_43_HSE_Exts_FormatKeyCatalogs%E2%80%9D%20%E2%80%9C%3C%2FSPAN%3E%3C%2FSPAN%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3ECrypto_43_HSE_KeyElementSet%3C%2FSPAN%3E%3CSPAN%3E%E2%80%9D%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3Ereturns%20HSE_SRV_RSP_INVALID_PARAM.%20What%20could%20be%20the%20possible%20causes%3F%20Additionally%2C%20I%20confirm%20that%20all%20RAM%20used%20by%20Crypto%20is%20configured%20as%20non-cacheable.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2166586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20returns%20HSE_SRV_RSP_INVALID_PARAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2166586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EOn%20a%20side%20note%2C%20I%20can%20tell%20you%20that%20I%20am%20trying%20to%20load%20the%20AES%20key%20without%20actually%20doing%20anything%20with%20the%20SHE%20keys.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2166501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20returns%20HSE_SRV_RSP_INVALID_PARAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2166501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3CBR%20%2F%3EI%20am%20facing%20the%20same%20Issue%20with%20driver%20Crypto_43_HSE%20v6.0.0%20(Crypto_43_HSE_TS_T40D34M60I0R0)%20on%20S32K312%20and%20I%20am%20facing%20the%20exact%20same%20issue.%3CBR%20%2F%3EI%20successfully%20formatted%20the%20key%20catalogs%2C%20and%20I%20can%20see%20that%20after%20that%20the%26nbsp%3BHSE%20Status%20is%20reported%20as%200x0B60%20so%20CUST_DEL%20should%20be%20active.%3CBR%20%2F%3EIn%20the%20NvM%20and%20Ram%20Key%20Catalogs%20I%20have%20the%20following%20configuration%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22strofald_0-1757495619663.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22strofald_0-1757495619663.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22strofald_0-1757495619663.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22strofald_0-1757495619663.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22strofald_0-1757495619663.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22strofald_0-1757495619663.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22strofald_0-1757495619663.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F356223i8BB364F44070EF26%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22strofald_0-1757495619663.png%22%20alt%3D%22strofald_0-1757495619663.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Estrofald_0-1757495619663.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Ebut%20I%20get%26nbsp%3B%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3EHSE_SRV_RSP_INVALID_PARAM%20when%20I%20try%20to%20do%20KeyElementSet%20to%20initialize%20the%20key.%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2126158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20returns%20HSE_SRV_RSP_INVALID_PARAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2126158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E2%80%8C%3C%2FSPAN%3E%3CSTRONG%3EThanks%20for%20your%20help.%20Problem%20solved!%20Much%20appreciated.%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2125222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20returns%20HSE_SRV_RSP_INVALID_PARAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2125222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CEM%3EThank%20you%20for%20your%20reply%3B%20I%20have%20attached%20the%20EB%20configuration%20file%20and%20some%20screenshots%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2124717%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20returns%20HSE_SRV_RSP_INVALID_PARAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2124717%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWell%2C%20there's%20no%20problem%20with%20the%20life%20cycle.%20Your%20device%20is%20still%20in%20CUST_DEL.%26nbsp%3B%3C%2FP%3E%0A%3CP%3ECould%20you%20show%20me%20how%20are%20NVM%20and%20RAM%20catalogs%20defined%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2124627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20returns%20HSE_SRV_RSP_INVALID_PARAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2124627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3EThank%20you%20for%20your%20reply.%20Based%20on%20this%20memory%20screenshot%2C%20can%20you%20identify%20any%20issues%3F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2124454%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20returns%20HSE_SRV_RSP_INVALID_PARAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2124454%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251754%22%20target%3D%22_blank%22%3E%40hangwu%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI'm%20sorry%20for%20delayed%20response.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAre%20you%20still%20in%20CUST_DEL%20life%20cycle%3F%20Easiest%20option%20to%20confirm%20this%20-%20please%20send%20me%20a%20screenshot%20of%20memory%20at%200x1B00_0220%20-%200x1B00_026F.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThe%20catalogs%20can%20be%20formatted%20only%20in%20CUST_DEL%20life%20cycle%2C%20so%20this%20could%20be%20the%20root%20cause.%20Next%20failing%20commands%20(keyelementset...)%20could%20be%20just%20a%20consequence%20because%20the%20catalogs%20are%20not%20formatted.%26nbsp%3B%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2122023%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3Ereturns%20HSE_SRV_RSP_INVALID_PARAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2122023%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3EDue%20to%20project%20constraints%2C%20I%20cannot%20provide%20a%20complete%20runnable%20project.%20Below%20are%20the%20two%20main%20source%20files.%20I%20integrated%20the%20%22S32K3XX_S32M27x_RTD_R21-11_5.0.0_P08%22%20RTD%20package.%20The%20EB%20configuration%20strictly%20follows%3A%3CBR%20%2F%3E%22%5CS32K3XX_S32M27x_RTD_R21-11_5.0.0_P08%5Ceclipse%5Cplugins%5CCrypto_43_HSE_TS_T40D34M50I0R0%5Cexamples%5CEBT%5CS32K3XX%22.%3C%2FP%3E%3CP%20class%3D%22%22%3EI%20tested%20random%20number%20generation%2C%20hash%20values%2C%20UpdateFw%2C%20GetFwVersion%2C%20and%20other%20services%20%E2%80%93%20all%20worked%20normally.%20However%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%22Crypto_43_HSE_Exts_FormatKeyCatalogs%22%3C%2FLI%3E%3CLI%3E%22Crypto_43_HSE_KeyElementSet%22%3C%2FLI%3E%3CLI%3E%22Crypto_43_HSE_KeySetValid%22%3C%2FLI%3E%3CLI%3E%22Crypto_43_HSE_ProcessJob%22%3CBR%20%2F%3Eall%20returned%20%22HSE_SRV_RSP_INVALID_PARAM%22.%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%3EI%20discovered%20the%20%E2%80%8C%3CSTRONG%3EHSE_STATUS_INSTALL_OK%20bit%20is%20cleared%3C%2FSTRONG%3E%E2%80%8C%2C%20so%20I%20tried%20calling%20FormatKey%20%E2%80%93%20but%20it%20failed.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2121180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20returns%20HSE_SRV_RSP_INVALID_PARAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2121180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251754%22%20target%3D%22_blank%22%3E%40hangwu%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EIs%20it%20possible%20to%20share%20some%20simple%20project%20to%20reproduce%20the%20issue%3F%26nbsp%3B%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2262873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20returns%20HSE_SRV_RSP_INVALID_PARAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2262873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251754%22%20target%3D%22_blank%22%3E%40hangwu%3C%2FA%3E%26nbsp%3B%2C%20Can%20you%20please%20share%20the%20details%20how%20you%20resolved%20it.%3C%2FP%3E%3CP%3EI%20am%20also%20facing%20similar%20kind%20of%20issue%20while%20programming%20the%20ADKP%20using%20HSE%20Library%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2266005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20returns%20HSE_SRV_RSP_INVALID_PARAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2266005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThank%20you%20for%20the%20Information..%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2265987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20returns%20HSE_SRV_RSP_INVALID_PARAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2265987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%2F*%20Table%20containing%20NVM%20key%20catalog%20entries%20*%2F%3CBR%20%2F%3Econst%20hseKeyGroupCfgEntry_t%20aHseNvmKeyCatalog%5B%5D%20%3D%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%2F*%20NvmKeyGroup_0%20*%2F%3CBR%20%2F%3E%7B(HSE_MU0_MASK%20%7C%20HSE_MU1_MASK)%2C%20HSE_KEY_OWNER_CUST%2C%20HSE_KEY_TYPE_AES%2C%2010U%2C%20256U%2C%20%7B0U%2C%200U%7D%7D%2C%3CBR%20%2F%3E%2F*%20NvmKeyGroup_1%20*%2F%3CBR%20%2F%3E%7B(HSE_MU0_MASK%20%7C%20HSE_MU1_MASK)%2C%20HSE_KEY_OWNER_CUST%2C%20HSE_KEY_TYPE_ECC_PAIR%2C%2010U%2C%20521U%2C%20%7B0U%2C%200U%7D%7D%2C%3CBR%20%2F%3E%2F*%20Marker%20to%20end%20the%20key%20catalog%20*%2F%3CBR%20%2F%3E%7B0U%2C%200U%2C%200U%2C%200U%2C%200U%2C%20%7B0U%2C%200U%7D%7D%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Table%20containing%20RAM%20key%20catalog%20entries%20*%2F%3CBR%20%2F%3Econst%20hseKeyGroupCfgEntry_t%20aHseRamKeyCatalog%5B%5D%20%3D%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%2F*%20RamKeyGroup_0%20*%2F%3CBR%20%2F%3E%7B(HSE_MU0_MASK%20%7C%20HSE_MU1_MASK)%2C%20HSE_KEY_OWNER_ANY%2C%20HSE_KEY_TYPE_AES%2C%2010U%2C%20128U%2C%20%7B0U%2C%200U%7D%7D%2C%3CBR%20%2F%3E%2F*%20RamKeyGroup_1%20*%2F%3CBR%20%2F%3E%7B(HSE_MU0_MASK%20%7C%20HSE_MU1_MASK)%2C%20HSE_KEY_OWNER_ANY%2C%20HSE_KEY_TYPE_ECC_PAIR%2C%2010U%2C%20521U%2C%20%7B0U%2C%200U%7D%7D%2C%3CBR%20%2F%3E%2F*%20Marker%20to%20end%20the%20key%20catalog%20*%2F%3CBR%20%2F%3E%7B0U%2C%200U%2C%200U%2C%200U%2C%200U%2C%20%7B0U%2C%200U%7D%7D%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20root%20cause%20of%20my%20error%20is%20the%20absence%20of%20the%20RAM%20marker%EF%BC%88%2F*%20Marker%20to%20end%20the%20key%20catalog%20*%2F%EF%BC%89%E2%80%94I%20simply%20never%20configured%20ramKeyCatalog%2C%20and%20it%20turns%20out%20this%20entry%20is%20mandatory.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2333320%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20returns%20HSE_SRV_RSP_INVALID_PARAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2333320%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EMy%20current%20S32K312%20chip%2C%20HSE%20version%20255%2C%20call%20function%20%3CSPAN%3ECrypto_KeyElementSet%20also%20return%20HSE_SRV_RSP_INVALID_PARAM%2C%20the%20current%20lifecycle%2C%20catalog%20and%20EB%20configuration%20is%20shown%20in%20the%20following%20figure%2C%20can%20you%20help%20to%20see%20what%20the%20reason%20is%2C%20and%20I%20am%20sure%20that%20it%20is%20not%20the%20cache!%20Can%20you%20help%20me%20to%20see%20what%20is%20the%20reason%2C%20I%20also%20confirm%20that%20it%20is%20not%20the%20reason%20of%20cache.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2333326%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20returns%20HSE_SRV_RSP_INVALID_PARAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2333326%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EMy%20current%20S32K312%20chip%2C%20with%20HSE%20version%20255%2C%20calls%20the%20function%3C%2FSPAN%3E%3CSPAN%3E%20Crypto_KeyElementSet%20also%20returns%20HSE_SRV_RSP_INVALID_PARAM%2C%20and%20the%20current%20lifecycle%2C%20catalog%2C%20and%20EB%20configurations%20are%20as%20shown%20below%2C%20can%20you%20help%20me%20see%20what's%20going%20on%2C%20and%20I'm%20sure%20it's%20not%20the%20cache!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22EB_cfg.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EB_cfg.jpg%22%20style%3D%22width%3A%2060px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F379343iDFC282D9A89D10A9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22EB_cfg.jpg%22%20alt%3D%22EB_cfg.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EEB_cfg.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22LC.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22LC.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F379341iD83C610FDE379AA6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22LC.jpg%22%20alt%3D%22LC.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ELC.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22catalog.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22catalog.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F379342i9AF524DC122A489A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22catalog.jpg%22%20alt%3D%22catalog.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ecatalog.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%E2%80%83%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E
