s32ds spi intterupt request
707件の閲覧回数
rlaxortn
hello.
i am using s32k314 mcu, and s32ds 3.6.1 version. RTD is 4.0.0
and i don't use mcal, and autosar. i only can use low drivers.
1. To use SPI interrupts, do I need to add Dma_Ip to the drivers in S32DS Peripherals? Can I use it by adding only Intctrl_Ip without Dma_Ip?
2. if i can use spi interrupt without Dma_Ip, how i can find callback function? and how i set callback function name?
thanks.
タグ(2)
679件の閲覧回数
Robin_Shen
I checked the non-AUTOSAR MCAL version of Lpspi, and it seems the S32 Configuration Tool does not support configuring callback of LPSPI.
I suggest referring to the following sections in RTD_SPI_UM.pdf:
6.4.4.1 Lpspi_Ip_CallbackType
6.4.5.1 Lpspi_Ip_EventType
6.4.6.4 Lpspi_Ip_AsyncTransmit
The Handler's name needs to be filled in IntCtrl_Ip, for example, Lpspi_Ip_LPSPI_0_IRQHandler. The name can be found in /RTD/src/Lpspi_Ip_Irq.c.
The name of the LPSPI callback is mentioned in "6.3 Calls to Notification Functions, Callbacks, Callouts" of RTD_SPI_IM.pdf:
RTD_SPI_UM.pdf and RTD_SPI_IM.pdf are located at: C:\NXP\S32DS.3.5\S32DS\software\PlatformSDK_S32K3\RTD\Spi_TS_T40D34M40I0R0\doc\
Robin
- If this post answers your question, please click the "ACCEPT AS SOLUTION" button. Thank you!
%3CLINGO-SUB%20id%3D%22lingo-sub-2333152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Es32ds%20SPI%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E8%A6%81%E6%B1%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2333152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFS32K314%20MCU%E3%81%A8S32DS%203.6.1%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82RTD%E3%81%AF4.0.0%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFmcal%E3%82%82autosar%E3%82%82%E4%BD%BF%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AF%E4%BD%8E%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%97%E3%81%8B%E4%BD%BF%E3%81%88%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E1.%20SPI%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81S32DS%20%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%ABDma_Ip%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9FDma_Ip%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%9B%E3%81%9A%E3%81%AB%20Intctrl_Ip%20%E3%81%A0%E3%81%91%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2.%20Dma_Ip%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%9B%E3%81%9A%E3%81%ABSPI%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E9%96%A2%E6%95%B0%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E9%96%A2%E6%95%B0%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2333332%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32ds%20spi%20intterupt%20request%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2333332%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%8F%E3%82%A4%3C%2FP%3E%0A%3CP%3EAUTOSAR%E9%9D%9E%E5%AF%BE%E5%BF%9C%E3%81%AEMCAL%E7%89%88%3CSTRONG%3ELPSPI%3C%2FSTRONG%3E%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%20%3CSTRONG%3ES32%E6%A7%8B%E6%88%90%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AF%3C%2FSTRONG%3ELPSPI%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E6%A7%8B%E6%88%90%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3ERTD_SPI_UM.pdf%3C%2FSTRONG%3E%E3%81%AE%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CSTRONG%3E%3CEM%3E6.4.4.1%20Lpspi_Ip_CallbackType%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E%3CEM%3E6.4.5.1%20Lpspi_Ip_EventType%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E%3CEM%3E6.4.6.4%20Lpspi_Ip_AsyncTransmit%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%AF%3CSTRONG%3EIntCtrl_Ip%3C%2FSTRONG%3E%E3%81%AB%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%20%3CSTRONG%3ELpspi_Ip_LPSPI_0_IRQHandler%20%E3%81%AA%E3%81%A9%3C%2FSTRONG%3E%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%AF%20%2FRTD%2Fsrc%2FLpspi_Ip_Irq.c%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ELPSPI%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%AF%E3%80%81%20%3CSTRONG%3ERTD_SPI_IM.pdf%E3%81%AE%3C%2FSTRONG%3E%E3%80%8C%20%3CSTRONG%3E6.3%20%E9%80%9A%E7%9F%A5%E9%96%A2%E6%95%B0%E3%80%81%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%80%81%E3%82%B3%E3%83%BC%E3%83%AB%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%3C%2FSTRONG%3E%E3%80%8D%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%226.3%20Calls%20to%20Notification%20Functions%2C%20Callbacks%2C%20Callouts%20RTD_SPI_IM.png%22%20style%3D%22width%3A%20822px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%226.3%20Calls%20to%20Notification%20Functions%2C%20Callbacks%2C%20Callouts%20RTD_SPI_IM.png%22%20style%3D%22width%3A%20822px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F379344i070B718EBB392D29%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%226.3%20Calls%20to%20Notification%20Functions%2C%20Callbacks%2C%20Callouts%20RTD_SPI_IM.png%22%20alt%3D%226.3%20Calls%20to%20Notification%20Functions%2C%20Callbacks%2C%20Callouts%20RTD_SPI_IM.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3ERTD_SPI_UM.pdf%3C%2FSTRONG%3E%E3%81%8A%E3%82%88%E3%81%B3%3CSTRONG%3ERTD_SPI_IM.pdf%3C%2FSTRONG%3E%E3%81%AF%E3%80%81C%3A%5CNXP%5CS32DS.3.5%5CS32DS%5Csoftware%5CPlatformSDK_S32K3%5CRTD%5CSpi_TS_T40D34M40I0R0%5Cdoc%5C%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%83%AD%E3%83%93%E3%83%B3%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%A8%E3%81%97%E3%81%A6%E6%89%BF%E8%AA%8D%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3C%2FP%3E%0A%3CP%3E-%20%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%81%AFThread%E3%82%92%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E6%97%A5%E3%80%81%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E9%96%89%E3%81%98%E3%82%89%E3%82%8C%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
