problem installation s32k3 FreeRTOS
michelet1
i have s32ds 3.5 and i'm using the board MCTPTX1AK324(and follow step provided to get started) with installation RTD 4.4 2.0.0,  IPCF 4.0.0.
I have tried to install sw32k3_FreeRTOS_10.4.6_2.0.0_D2204 and i following these steps on s32ds 3.5:
1)Open Window->Preferences. From next windows, select S32 Design Studio for S32 Platform-> S32DS Extensions and Updates, click Add All and select zip archive sw32k3_FreeRTOS_10.4.6_2.0.0_D2204
2)Help -> S32DS Extensions and Updates. At this point a window appears indicating unsuitable package(i have include image in the attachment) . The question is: which version of FreeRTOS should i download to be compatible with RTD 2.0.0 and s32ds3.5?
Thanks in advance for any help and info
VaneB
Hi @michelet1
Could you validate if the following works for you?
You need to accept all the terms and conditions, and if the package is correctly installed S32DS will ask you to restart.
B.R.
VaneB
VaneB
Hi @michelet1
B.R.
VaneB
michelet1
Thanks for the reply. I tried to follow the steps you indicated and i actually managed to install freertos.
As a next step i tried to allocate a static task and the related scheduler function(vTaskStartScheduler).
I modified FreeRTOSConfig.h to have static allocation etc.. but when I start the code and debug with PE micro it generates hardFault() when it executes prvPortStartFirstTask(void) function in vTaskStartScheduler.
I can't figure out if it's due to a FreeRTOS installation problem that creare conflict in the code or have i configured the FreeRTOSConfig part incorrectly? In the attachment i report the configuration of FreeRTOSConfig.h and the part of the code in the main in which i instantiate a static task and call vTaskStartScheduler.
 Thank you in advance for your help and availability
Michele
michelet1
Hello @VaneB,
anyway the installation of FreeRTOS on s32ds3.5 was successfull following your steps.
I decided to open a new post for the HardFault problem generated by prvPortStartFirstTask(void).
thanks for your help and availability.
AmyHuang666
Hi @michelet1
Did you solve the problem about task you describled uplow? I'm suffering the same issue as yours. Could you please tell how you fix it? Thank you so mcuh~
%3CLINGO-SUB%20id%3D%22lingo-sub-1756325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eproblem%20installation%20s32k3%20FreeRTOS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1756325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3Ei%20have%20s32ds%203.5%20and%20i'm%20using%20the%20board%20MCTPTX1AK324(and%20follow%20step%20provided%20to%20get%20started)%20with%20installation%20RTD%204.4%202.0.0%2C%26nbsp%3B%20IPCF%204.0.0.%3C%2FP%3E%3CP%3EI%20have%20tried%20to%20install%20sw32k3_FreeRTOS_10.4.6_2.0.0_D2204%20and%20i%20following%20these%20steps%20on%20s32ds%203.5%3A%3C%2FP%3E%3CP%3E1)Open%20Window-%26gt%3BPreferences.%20From%20next%20windows%2C%20select%20S32%20Design%20Studio%20for%20S32%20Platform-%26gt%3B%20S32DS%20Extensions%20and%20Updates%2C%20click%20Add%20All%20and%20select%20zip%20archive%26nbsp%3Bsw32k3_FreeRTOS_10.4.6_2.0.0_D2204%3C%2FP%3E%3CP%3E2)Help%20-%26gt%3B%20S32DS%20Extensions%20and%20Updates.%20At%20this%20point%20a%20window%20appears%20indicating%20unsuitable%20package(i%20have%20include%20image%20in%20the%20attachment)%20.%20The%20question%20is%3A%20which%20version%20of%20FreeRTOS%20should%20i%20download%20to%20be%20compatible%20with%20RTD%202.0.0%20and%20s32ds3.5%3F%3C%2FP%3E%3CP%3EThanks%20in%20advance%20for%20any%20help%20and%20info%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140608%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20problem%20installation%20s32k3%20FreeRTOS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140608%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F181154%22%20target%3D%22_blank%22%3E%40michelet1%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EDid%20you%20solve%20the%20problem%20about%20task%20you%20describled%20uplow%3F%20I'm%20suffering%20the%20same%20issue%20as%20yours.%20Could%20you%20please%20tell%20how%20you%20fix%20it%3F%20Thank%20you%20so%20mcuh~%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1757392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20problem%20installation%20s32k3%20FreeRTOS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1757392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHello%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F201913%22%20target%3D%22_blank%22%3E%40VaneB%3C%2FA%3E%2C%3CBR%20%2F%3Eanyway%20the%20installation%20of%20FreeRTOS%20on%20s32ds3.5%20was%20successfull%20following%20your%20steps.%3CBR%20%2F%3EI%20decided%20to%20open%20a%20new%20post%20for%20the%20HardFault%20problem%20generated%20by%20prvPortStartFirstTask(void).%3CBR%20%2F%3Ethanks%20for%20your%20help%20and%20availability.%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1756786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20problem%20installation%20s32k3%20FreeRTOS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1756786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EThanks%20for%20the%20reply.%20I%20tried%20to%20follow%20the%20steps%20you%20indicated%20and%20i%20actually%20managed%20to%20install%20freertos.%3C%2FP%3E%3CP%3EAs%20a%20next%20step%20i%20tried%20to%20allocate%20a%20static%20task%20and%20the%20related%20scheduler%20function(vTaskStartScheduler).%3C%2FP%3E%3CP%3EI%20modified%20FreeRTOSConfig.h%20to%20have%20static%20allocation%20etc..%20but%20when%20I%20start%20the%20code%20and%20debug%20with%20PE%20micro%20it%20generates%20hardFault()%20when%20it%20executes%20prvPortStartFirstTask(void)%20function%20in%20vTaskStartScheduler.%3C%2FP%3E%3CP%3EI%20can't%20figure%20out%20if%20it's%20due%20to%20a%20FreeRTOS%20installation%20problem%20that%20creare%20conflict%20in%20the%20code%20or%20have%20i%20configured%20the%20FreeRTOSConfig%20part%20incorrectly%3F%20In%20the%20attachment%20i%20report%20the%20configuration%20of%20FreeRTOSConfig.h%20and%20the%20part%20of%20the%20code%20in%20the%20main%20in%20which%20i%20instantiate%20a%20static%20task%20and%20call%20vTaskStartScheduler.%3C%2FP%3E%3CP%3E%26nbsp%3BThank%20you%20in%20advance%20for%20your%20help%20and%20availability%3C%2FP%3E%3CP%3EMichele%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1756476%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20problem%20installation%20s32k3%20FreeRTOS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1756476%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F181154%22%20target%3D%22_blank%22%3E%40michelet1%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CDIV%3ECould%20you%20validate%20if%20the%20following%20works%20for%20you%3F%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CDIV%20id%3D%22tinyMceEditorVaneB_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22VaneB_4-1699904487532.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22VaneB_4-1699904487532.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F249619i90537A5F7EFA8D2D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22VaneB_4-1699904487532.png%22%20alt%3D%22VaneB_4-1699904487532.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22VaneB_5-1699904498843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22VaneB_5-1699904498843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F249620iE6C2510E8228B5EC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22VaneB_5-1699904498843.png%22%20alt%3D%22VaneB_5-1699904498843.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22VaneB_6-1699904557577.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22VaneB_6-1699904557577.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F249621iA949F007DF53CCCF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22VaneB_6-1699904557577.png%22%20alt%3D%22VaneB_6-1699904557577.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22VaneB_7-1699904595385.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22VaneB_7-1699904595385.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F249622i2E9D99CA176C496B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22VaneB_7-1699904595385.png%22%20alt%3D%22VaneB_7-1699904595385.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22VaneB_8-1699904643929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22VaneB_8-1699904643929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F249623i77404C5C8D0BE94C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22VaneB_8-1699904643929.png%22%20alt%3D%22VaneB_8-1699904643929.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3EYou%20need%20to%20accept%20all%20the%20terms%20and%20conditions%2C%20and%20if%20the%20package%20is%20correctly%20installed%20S32DS%20will%20ask%20you%20to%20restart.%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3EB.R.%3C%2FDIV%3E%0A%3CDIV%3EVaneB%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
