lin_connect
lin_connect
kalajiao
Since I have been unsuccessful in using Lin, I put the code of the instance program into the project created by myself, but it still doesn't work, so is there anything I haven't configured? The keys are bound to the lights, and do you only need to bind the following images?
QQ截图20210803111128.pngQQ截图20210803111128.pngQQ截图20210803111201.pngQQ截图20210803111201.png
Robin_Shen
Hi kalajiao,
There are several LIN examples in SDK. Would you please test it by follow the example documentation:
Robin
