hse fw Activation
hse fw Activation
youxi
hello:
I successfully installed the firmware, but when I sent the instruction to HSE, HSE did not return the data, please ask if the installed HSE FW still needs to be activated. If activation is required, how? Can you provide a section of the active code?
youxi
hello:
Thanks for your support, I have successfully installed on it. The hse _ ab _ swap needs to be installed in both partitions, and the hse _ full _ mem does not
petervlna
Please rise the ticket at NXP.com
https://community.nxp.com/t5/HomeTest-Knowledge-Base/How-to-submit-a-new-question-for-NXP-Support/ta...
Security sensitive questions are not discussed on public community.
No activation is required after install. Please refer to installation package documentation
HSE FW install for S32K3xx -
chapter 4.1.1. How to install HSE FW(FULL_MEM) within IVT
Peter
youxi
hello:
