Flash Blank Checking
Switcher
Hello sirs, I skimmed the reference manual for S32K3XX microcontroller and I can't seem to find a Flash Blank Checking functionality. Can anyone confirm that this is the case? TIA
Tags (2)
lukaszadrapa
Hi @Switcher
that's correct, there's no hw blank check functionality. If you check RTD drivers, you can find that C40_Ip_EraseVerify function only reads the flash in a loop and compares if the content is 0xFFFF...
Lukas
lukaszadrapa
Hi @Switcher
Lukas
Switcher
ty for the reply sir
