freemaster no license
3,302件の閲覧回数
Ahelion
I downloaded freemaster lite for linux, started installing, then it prompted me for a license, but i did not receive any license.
I did receive licenses for s32k studio when downloaded, but not for freemaster, also it is not visible in the software download section where I can see that I downloaded s32k studio.
7 返答(返信)
3,167件の閲覧回数
iulian_stan
Hi @Ahelion,
The are 2 ways to get FreeMASTER license corresponding to your product version:
  1. During the installation, a pop up window should ask you whether you want to get a license:
    If you press "YES" it should redirect you to the corresponding URL (you just need to be logged on NXP.com).
  2. You can also access the link manually. The URL can be found in the "Component selection" view in the description:
    Here's the link for version 1.3: license link.
Hope it helps,
Iulian
3,282件の閲覧回数
petervlna
3,277件の閲覧回数
Ahelion
followed the steps, got a license for 1.0, but....
3,256件の閲覧回数
petervlna
Looks like your are using incorrect installation key, which is for another version.
Best would be to download installation again and along with correct license for that version directly from license tab like presented in installation guide.
Peter
3,251件の閲覧回数
Ahelion
There is only one version for linux, at least that I can find. and there seems to be only the one license website. If you can share the link to directly I would appreciate it.
3,242件の閲覧回数
petervlna
The link to the license is directly in the guide I have posted. If you follow the link you should be able to see the license in license tab:
https://community.nxp.com/t5/FreeMASTER-Knowledge-Base/FreeMASTER-3-0-Installation-Guide/ta-p/110150...
If that do not work for you, let me know.
Peter
3,237件の閲覧回数
Ahelion
i did follow the guide, it brought me to the license I tested and for which I posted above that the tool says it is not good. This is the name of the binary: FMASTERL13.bin, does it help?
