csec error bits
csec error bits
fan1234
    meet some problem when using CSEC with s32k144 , when does csec driver
   1. return  ERC_GENERAL_ERROR (operating "Resetting Flash to the Factory State")
  2. return ERC_KEY_EMPTY,  seems key not  loaded, what's the possible reason?
BR!
Senlent
Hi@fan1234
Before resetting Flash to the Factory State, you should ensure that the CSEc module has loaded the key.
Judging from your error messages, it seems you haven't loaded the key to CSEc or there was an error during the key loading process.
fan1234
my sequence is , load the key after Configure Csec Module, and trigger a software reset. the Csec seems enabled(by check FCNFG bit), what will cause the error during key loading process?
Senlent
Hi@fan1234
Do you have a test project? I cannot give specific possible reasons.
%3CLINGO-SUB%20id%3D%22lingo-sub-2339856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ecsec%20error%20bits%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20meet%20some%20problem%20when%20using%20CSEC%20with%20s32k144%20%2C%20when%20does%20csec%20driver%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B1.%20return%26nbsp%3B%20ERC_GENERAL_ERROR%20(operating%20%22Resetting%20Flash%20to%20the%20Factory%20State%22)%3C%2FP%3E%3CP%3E%26nbsp%3B%202.%26nbsp%3Breturn%26nbsp%3BERC_KEY_EMPTY%2C%26nbsp%3B%20seems%20key%20not%26nbsp%3B%20loaded%2C%20what's%20the%20possible%20reason%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2340810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20csec%20error%20bits%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2340810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%40%3CSPAN%3Efan1234%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EDo%20you%20have%20a%20test%20project%3F%20I%20cannot%20give%20specific%20possible%20reasons.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2340756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20csec%20error%20bits%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2340756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Emy%20sequence%20is%20%2C%20load%20the%20key%20after%20Configure%20Csec%20Module%2C%20and%20trigger%20a%20software%20reset.%20the%20Csec%20seems%20enabled(by%20check%20FCNFG%20bit)%2C%20what%20will%20cause%20the%20error%20during%20key%20loading%20process%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2340669%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20csec%20error%20bits%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2340669%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%40%3CSPAN%3Efan1234%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBefore%20resetting%20Flash%20to%20the%20Factory%20State%2C%20you%20should%20ensure%20that%20the%20CSEc%20module%20has%20loaded%20the%20key.%3C%2FP%3E%0A%3CP%3EJudging%20from%20your%20error%20messages%2C%20it%20seems%20you%20haven't%20loaded%20the%20key%20to%20CSEc%20or%20there%20was%20an%20error%20during%20the%20key%20loading%20process.%3C%2FP%3E%3C%2FLINGO-BODY%3E
