TCM Backdoor-Addressing on same core [S32K3]
1,466 次查看
Daimon
Hi NXP-Team,
concerning your TCM-Ram (TightlyCoupledMemory) Regions defined in your MemoryMap available on the S32K388 Controller:
The Memory Map shows that all of these (whether ITCM or DTCM) are located at the same address respectively (see attached screenshot).
1) Can you clarify if addressing a TCM from its local core via the backdoor address leads to performance loss? (.e.g. Core0 accessing ITCM0 at 0x11000000 instead of 0x0)
1.1) If yes: How much loss is expected?
In my project we are using GNU Style LD-Files (GHS).
2) Is there a way to address (via sections in LD File) the TCMs exclusively for same core access unambiguously in a single LD File?
Best Regards
Daimon
标记 (3)
2 回复数
1,416 次查看
Daimon
Hello Peter,
thanks for the answer - this magnitude estimation is sufficient for me (but too high for my usecase).
concerning the direct address region - in case of ITCM: are you talking about 0x0 - 0xFFFF?
Is there a unique address available to differentiate between them, that does not map to the backdoor path?
In Code addressing them is no problem, but If I want to create dedicated sections in my LD File and place objects there the addresses are ambiguous.
Is there a path forward to handle that?
Thanks!
Daimon
1,441 次查看
petervlna
YES — backdoor access is slower.
Because the backdoor accesses the TCM via the System Bus, it is subject to arbitration with other masters trying to access the same memory, which can introduce variable delays.
AN13388
We do nothave published cycle‑accurate numbers for backdoor TCM performance on S32K3
I can only reason based on the M7 architecture:
Architectural expectation: ~4–6× slower for typical code fetch or load/store.
Yes — as long as each TCM’s direct addresses are unique per core.
On S32K388, each core has its own ITCM and DTCM direct address region.
Peter
%3CLINGO-SUB%20id%3D%22lingo-sub-2339842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%B8%AD%E5%8C%BB%E5%90%8E%E9%97%A8-%E5%9C%A8%E5%90%8C%E4%B8%80%E5%86%85%E6%A0%B8%E4%B8%8A%E5%AF%BB%E5%9D%80%20%5BS32K3%5D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E5%9B%A2%E9%98%9F%E3%80%81%3C%2FP%3E%3CP%3E%E5%85%B3%E4%BA%8E%E6%82%A8%E5%9C%A8%20S32K388%20%E6%8E%A7%E5%88%B6%E5%99%A8%E4%B8%8A%E6%8F%90%E4%BE%9B%E7%9A%84%20MemoryMap%20%E4%B8%AD%E5%AE%9A%E4%B9%89%E7%9A%84%20TCM-Ram%EF%BC%88TightlyCoupledMemory%EF%BC%89%E5%8C%BA%E5%9F%9F%EF%BC%9A%3CBR%20%2F%3EMemory%20Map%20%E6%98%BE%E7%A4%BA%EF%BC%8C%E6%89%80%E6%9C%89%E8%BF%99%E4%BA%9B%EF%BC%88%E6%97%A0%E8%AE%BA%E6%98%AF%20ITCM%20%E8%BF%98%E6%98%AF%20DTCM%EF%BC%89%E9%83%BD%E5%88%86%E5%88%AB%E4%BD%8D%E4%BA%8E%E7%9B%B8%E5%90%8C%E7%9A%84%E5%9C%B0%E5%9D%80%EF%BC%88%E8%A7%81%E6%89%80%E9%99%84%E6%88%AA%E5%9B%BE%EF%BC%89%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E1)%20%E8%83%BD%E5%90%A6%E8%AF%B4%E6%98%8E%E9%80%9A%E8%BF%87%E5%90%8E%E9%97%A8%E5%9C%B0%E5%9D%80%E4%BB%8E%E6%9C%AC%E5%9C%B0%E5%86%85%E6%A0%B8%E5%AF%BB%E5%9D%80%20TCM%20%E6%98%AF%E5%90%A6%E4%BC%9A%E5%AF%BC%E8%87%B4%E6%80%A7%E8%83%BD%E6%8D%9F%E5%A4%B1%EF%BC%9F%E4%BE%8B%E5%A6%82Core0%20%E5%9C%A8%200x11000000%20%E8%80%8C%E4%B8%8D%E6%98%AF%200x0%20%E8%AE%BF%E9%97%AE%20ITCM0)%3CBR%20%2F%3E1.1)%E5%A6%82%E6%9E%9C%E5%9B%9E%E7%AD%94%E4%B8%BA%20%22%E6%98%AF%22%EF%BC%9A%E9%A2%84%E8%AE%A1%E6%8D%9F%E5%A4%B1%E5%A4%9A%E5%B0%91%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%9C%A8%E6%88%91%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20GNU%20Style%20LD-Files%20(GHS)%E3%80%82%20%3CBR%20%2F%3E2)%20%E6%98%AF%E5%90%A6%E6%9C%89%E5%8A%9E%E6%B3%95%EF%BC%88%E9%80%9A%E8%BF%87%20LD%20%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84%E7%AB%A0%E8%8A%82%EF%BC%89%E5%9C%A8%E5%8D%95%E4%B8%AA%20LD%20%E6%96%87%E4%BB%B6%E4%B8%AD%3CSPAN%3E%E6%98%8E%E7%A1%AE%3C%2FSPAN%3E%E5%A4%84%E7%90%86%E4%B8%93%E9%97%A8%E7%94%A8%E4%BA%8E%E5%90%8C%E4%B8%80%E5%86%85%E6%A0%B8%E8%AE%BF%E9%97%AE%E7%9A%84%20TCM%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EDaimon%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2340808%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TCM%20Backdoor-Addressing%20on%20same%20core%20%5BS32K3%5D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2340808%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%BD%BC%E5%BE%97%EF%BC%8C%3CBR%20%2F%3E%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E7%AD%94--%E8%BF%99%E4%B8%AA%E4%BC%B0%E8%AE%A1%E5%80%BC%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E5%B7%B2%E7%BB%8F%E8%B6%B3%E5%A4%9F%E4%BA%86%EF%BC%88%E4%BD%86%E5%AF%B9%E6%88%91%E7%9A%84%E4%BD%BF%E7%94%A8%E6%83%85%E5%86%B5%E6%9D%A5%E8%AF%B4%E5%A4%AA%E9%AB%98%E4%BA%86%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%B3%E4%BA%8E%E7%9B%B4%E6%8E%A5%E5%9C%B0%E5%9D%80%E5%8C%BA%E5%9F%9F--%E5%B0%B1%20ITCM%20%E8%80%8C%E8%A8%80%EF%BC%9A%E6%82%A8%E8%AF%B4%E7%9A%84%E6%98%AF%200x0%20-%200xFFFF%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%E6%98%AF%E5%90%A6%E6%9C%89%E5%94%AF%E4%B8%80%E7%9A%84%E5%9C%B0%E5%9D%80%E5%8F%AF%E7%94%A8%E4%BA%8E%E5%8C%BA%E5%88%86%E5%AE%83%E4%BB%AC%EF%BC%8C%E8%80%8C%E4%B8%8D%E4%BC%9A%E6%98%A0%E5%B0%84%E5%88%B0%E5%90%8E%E9%97%A8%E8%B7%AF%E5%BE%84%EF%BC%9F%3CBR%20%2F%3E%3CFONT%3E%E5%9C%A8%E4%BB%A3%E7%A0%81%E4%B8%AD%E8%A7%A3%E5%86%B3%E5%AE%83%E4%BB%AC%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E6%98%AF%E5%A6%82%E6%9E%9C%E6%88%91%E6%83%B3%E5%9C%A8%E6%88%91%E7%9A%84LD%E6%96%87%E4%BB%B6%E4%B8%AD%E5%88%9B%E5%BB%BA%E4%B8%93%E7%94%A8%E7%9A%84%E9%83%A8%E5%88%86%E5%B9%B6%E5%9C%A8%E5%85%B6%E4%B8%AD%E6%94%BE%E7%BD%AE%E5%AF%B9%E8%B1%A1%EF%BC%8C%E5%88%99%E5%9C%B0%E5%9D%80%E6%98%AF%E4%B8%8D%E6%98%8E%E7%A1%AE%E7%9A%84%3C%2FFONT%3E%E3%80%82%3CBR%20%2F%3E%E6%98%AF%E5%90%A6%E6%9C%89%E5%A4%84%E7%90%86%E8%BF%99%E4%B8%80%E9%97%AE%E9%A2%98%E7%9A%84%E9%80%94%E5%BE%84%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%9C%80%E7%BE%8E%E5%A5%BD%E7%9A%84%E7%A5%9D%E6%84%BF%EF%BC%8C%3CBR%20%2F%3EDaimon%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2340347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TCM%20Backdoor-Addressing%20on%20same%20core%20%5BS32K3%5D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2340347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E1)%20%E8%83%BD%E5%90%A6%E8%AF%B4%E6%98%8E%E9%80%9A%E8%BF%87%E5%90%8E%E9%97%A8%E5%9C%B0%E5%9D%80%E4%BB%8E%E6%9C%AC%E5%9C%B0%E5%86%85%E6%A0%B8%E5%AF%BB%E5%9D%80%20TCM%20%E6%98%AF%E5%90%A6%E4%BC%9A%E5%AF%BC%E8%87%B4%E6%80%A7%E8%83%BD%E6%8D%9F%E5%A4%B1%EF%BC%9F%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E6%98%AF%20-%20%E5%90%8E%E9%97%A8%E8%AE%BF%E9%97%AE%E9%80%9F%E5%BA%A6%E8%BE%83%E6%85%A2%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%94%B1%E4%BA%8E%E5%90%8E%E9%97%A8%E9%80%9A%E8%BF%87%E7%B3%BB%E7%BB%9F%E6%80%BB%E7%BA%BF%E8%AE%BF%E9%97%AE%20TCM%EF%BC%8C%E5%9B%A0%E6%AD%A4%E9%9C%80%E8%A6%81%E4%B8%8E%E5%85%B6%E4%BB%96%E8%AF%95%E5%9B%BE%E8%AE%BF%E9%97%AE%E7%9B%B8%E5%90%8C%E5%86%85%E5%AD%98%E7%9A%84%E4%B8%BB%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%BF%9B%E8%A1%8C%E4%BB%B2%E8%A3%81%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%B8%A6%E6%9D%A5%E5%8F%AF%E5%8F%98%E7%9A%84%E5%BB%B6%E8%BF%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.google.com%2Furl%3Fsa%3Dt%26amp%3Bsource%3Dweb%26amp%3Brct%3Dj%26amp%3Bopi%3D89978449%26amp%3Burl%3Dhttps%3A%2F%2Fcommunity.nxp.com%2Fpwmxy87654%2Fattachments%2Fpwmxy87654%2FS32K%2F37044%2F2%2FAN13388.pdf%26amp%3Bved%3D2ahUKEwjWkKP2y72TAxVKGxAIHbIPJw4QFnoECBsQAQ%26amp%3Busg%3DAOvVaw2h6Jr5jGQ0YIaWHT5lFRud%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN13388%3C%2FA%3E%20%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E1.1)%20%E5%A6%82%E6%9E%9C%E5%9B%9E%E7%AD%94%E4%B8%BA%20%22%E6%98%AF%22%EF%BC%9A%E9%A2%84%E8%AE%A1%E6%8D%9F%E5%A4%B1%E5%A4%9A%E5%B0%91%EF%BC%9F%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E5%85%AC%E5%B8%83%20S32K3%20%E4%B8%8A%E5%90%8E%E9%97%A8%20TCM%20%E6%80%A7%E8%83%BD%E7%9A%84%E7%B2%BE%E7%A1%AE%E5%91%A8%E6%9C%9F%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%8F%AA%E8%83%BD%E6%A0%B9%E6%8D%AE%20M7%20%E6%9E%B6%E6%9E%84%E8%BF%9B%E8%A1%8C%E6%8E%A8%E7%90%86%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E6%9E%B6%E6%9E%84%E9%A2%84%E6%9C%9F%EF%BC%9A~%E5%AF%B9%E4%BA%8E%E5%85%B8%E5%9E%8B%E7%9A%84%E4%BB%A3%E7%A0%81%E8%8E%B7%E5%8F%96%E6%88%96%E5%8A%A0%E8%BD%BD%2F%E5%AD%98%E5%82%A8%EF%BC%8C%E9%80%9F%E5%BA%A6%E8%A6%81%E6%85%A2%204-6%20%E5%80%8D%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E2)%20%E6%98%AF%E5%90%A6%E6%9C%89%E5%8A%9E%E6%B3%95%EF%BC%88%E9%80%9A%E8%BF%87%20LD%20%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84%E7%AB%A0%E8%8A%82%EF%BC%89%E5%9C%A8%E5%8D%95%E4%B8%AA%20LD%20%E6%96%87%E4%BB%B6%E4%B8%AD%E6%98%8E%E7%A1%AE%E5%A4%84%E7%90%86%E4%B8%93%E9%97%A8%E7%94%A8%E4%BA%8E%E7%9B%B8%E5%90%8C%E5%86%85%E6%A0%B8%E8%AE%BF%E9%97%AE%E7%9A%84%20TCM%EF%BC%9F%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E5%8F%AA%E8%A6%81%E6%AF%8F%E4%B8%AA%E6%A0%B8%E5%BF%83%E7%9A%84%20TCM%20%E7%9B%B4%E6%8E%A5%E5%9C%B0%E5%9D%80%E6%98%AF%E5%94%AF%E4%B8%80%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%20S32K388%20%E4%B8%8A%EF%BC%8C%E6%AF%8F%E4%B8%AA%E5%86%85%E6%A0%B8%E9%83%BD%E6%9C%89%E8%87%AA%E5%B7%B1%E7%9A%84%20ITCM%20%E5%92%8C%20DTCM%20%E7%9B%B4%E6%8E%A5%E5%9C%B0%E5%9D%80%E5%8C%BA%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%3C%2FLINGO-BODY%3E
