Unit Testing With Ceedling
ajain33555
I am attempting to use Ceedling to test modules of a S32146 test project (in this case the project is the hello_world example). I am stuck in running the ceedling project because the production code of the s32 requires additional header files that were internally configured within the S32 Development Studio. How do I account for this configuration when attempting to run a ceedling project with that code. Thanks!
Djuric
@ajain33555 Did you finally manage to set up Ceedling in the S32DS project?
ajain33555
Hey Lukas,
Thank you so much for the help. Do you also know how to configure the ceedling plugin for the S32DS or know how to run configure a ceedling project with the s32 code and run from the command line? Thank you!
Best,
Aarush Jain
lukaszadrapa
S32DS officially does not support ceedling plugin, so I'm afraid I cannot help in this matter.
Regads,
Lukas
ajain33555
Hi Lukas,
Do you know if ceedling can test S32 code from the command line? Thanks!
Best,
Aarush
lukaszadrapa
I'm sorry but since it's not supported by S32DS, I do not have experience with this at all.
Lukas
lukaszadrapa
Hi @ajain33555
if my understanding is correct, you need to have all the RTD or SDK files included directly in your project and not just linked, right?
If so, please follow this if you have older version of S32DS with Processor Expert:
https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/HOWTO-Use-SDK-based-example-code-as-st...
If you have S32DS 3.4 and higher, it can be configured like this:
Lukas
%3CLINGO-SUB%20id%3D%22lingo-sub-1817837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUnit%20Testing%20With%20Ceedling%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20am%20attempting%20to%20use%20Ceedling%20to%20test%20modules%20of%20a%20S32146%20test%20project%20(in%20this%20case%20the%20project%20is%20the%20hello_world%20example).%20I%20am%20stuck%20in%20running%20the%20ceedling%20project%20because%20the%20production%20code%20of%20the%20s32%20requires%20additional%20header%20files%20that%20were%20internally%20configured%20within%20the%20S32%20Development%20Studio.%20How%20do%20I%20account%20for%20this%20configuration%20when%20attempting%20to%20run%20a%20ceedling%20project%20with%20that%20code.%20Thanks!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unit%20Testing%20With%20Ceedling%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229863%22%20target%3D%22_blank%22%3E%40ajain33555%3C%2FA%3E%26nbsp%3BDid%20you%20finally%20manage%20to%20set%20up%20Ceedling%20in%20the%20S32DS%20project%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1822163%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unit%20Testing%20With%20Ceedling%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1822163%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI'm%20sorry%20but%20since%20it's%20not%20supported%20by%20S32DS%2C%20I%20do%20not%20have%20experience%20with%20this%20at%20all.%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1821637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unit%20Testing%20With%20Ceedling%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1821637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Lukas%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EDo%20you%20know%20if%20ceedling%20can%20test%20S32%20code%20from%20the%20command%20line%3F%20Thanks!%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBest%2C%3C%2FP%3E%3CP%3EAarush%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1821152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unit%20Testing%20With%20Ceedling%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1821152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ES32DS%20officially%20does%20not%20support%20ceedling%20plugin%2C%20so%20I'm%20afraid%20I%20cannot%20help%20in%20this%20matter.%20%3C%2FP%3E%0A%3CP%3ERegads%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1820597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unit%20Testing%20With%20Ceedling%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1820597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHey%20Lukas%2C%3C%2FP%3E%3CP%3EThank%20you%20so%20much%20for%20the%20help.%20Do%20you%20also%20know%20how%20to%20configure%20the%20ceedling%20plugin%20for%20the%20S32DS%20or%20know%20how%20to%20run%20configure%20a%20ceedling%20project%20with%20the%20s32%20code%20and%20run%20from%20the%20command%20line%3F%20Thank%20you!%3C%2FP%3E%3CP%3EBest%2C%3C%2FP%3E%3CP%3EAarush%20Jain%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1820533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unit%20Testing%20With%20Ceedling%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1820533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229863%22%20target%3D%22_blank%22%3E%40ajain33555%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3Eif%20my%20understanding%20is%20correct%2C%20you%20need%20to%20have%20all%20the%20RTD%20or%20SDK%20files%20included%20directly%20in%20your%20project%20and%20not%20just%20linked%2C%20right%3F%3C%2FP%3E%0A%3CP%3EIf%20so%2C%20please%20follow%20this%20if%20you%20have%20older%20version%20of%20S32DS%20with%20Processor%20Expert%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio-Knowledge-Base%2FHOWTO-Use-SDK-based-example-code-as-standalone-usable-for-GIT%2Fta-p%2F1108204%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio-Knowledge-Base%2FHOWTO-Use-SDK-based-example-code-as-standalone-usable-for-GIT%2Fta-p%2F1108204%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EIf%20you%20have%20S32DS%203.4%20and%20higher%2C%20it%20can%20be%20configured%20like%20this%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_0-1709554324119.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709554324119.png%22%20style%3D%22width%3A%20357px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F266284iC26C06B40EA25ABD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_0-1709554324119.png%22%20alt%3D%22lukaszadrapa_0-1709554324119.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Elukaszadrapa_0-1709554324119.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_1-1709554355757.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_1-1709554355757.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F266285i8AD5E07290A2984D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_1-1709554355757.png%22%20alt%3D%22lukaszadrapa_1-1709554355757.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Elukaszadrapa_1-1709554355757.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E
