Unified Bootloader Flow Control Issue
1,923 次查看
pratikkul26
Dear Sir/Ma'am,
PFA Log & functions
I'm working on UDS using unified_bootloader_demo_v2.1. I'm using S32K146 controller.
library porting & integration was successful I was able to test services such as session control, read & write data by identifier.
but when I tried to execute security access service. following happened
1)security access request  sent using GUI/UI "NXP Open Bus" or "ECU Bus".
2)First frame received from the hardware.
then UI/GUI didn't send the Flow control frame.
also I would like to understand how to use can_tp.c functions for receiving & transmitting first frame, flow control frame, consecutive frame etc. does TP maintains the status if transmitted data is more than 8 bytes?
Pratik
0 回复数
