Triggering can interrupt failed
2,206 次查看
shengzhibing
There is no trigger interrupt after sending the message. Is there any problem with my can initialization?
SOFT:  S32DS for ARM 2018 R1.
CHIP:S32K118
send first message(Success):
send second message(Failure):
Thank you for your reply!!!
标记 (1)
2,126 次查看
Robin_Shen
Hi  Zhibing,
Seems that you forgot set the corresponding IMASK1 bit.
Robin
2,127 次查看
Robin_Shen
Hi  Zhibing,
Robin
2,126 次查看
shengzhibing
HI Robin_Shen:
My problem has been solved,I forgot to enable FlexCAN interrupts (^_^) and I did not set imask bit .
Best Wishes
Sheng
