Synchronizing multiple EMIOS instances
3,888件の閲覧回数
RChatterjee
Is it possible to synchronize multiple EMIOS instances together? Currently, I am running EMIOS 1 and EMIOS 0 together to generate some PWMs, but there is a phase difference,which is variable and i cannot get rid of.
From the following answer: https://community.nxp.com/t5/S32K/Synchronizing-eMIOS-instances/td-p/1423858, I see GTBE bit sets it for one emios instance, which I have done and works well. Can I do this somehow across multiple instances?
タグ(2)
3,841件の閲覧回数
Senlent
Hi@RChatterjee
Sorry for the first reply and I made some modification according to the demo your provided:
1.Clean all eMIOSn->MCR.GTBE at beginning.
2.Enable eMIOSn->MCR.GTBE after init eMIOS_MCL
IP_EMIOS_1->MCR |= eMIOS_MCR_GTBE_MASK;
3.Test Result:
PTD20 & PTB17
3 返答(返信)
3,864件の閲覧回数
Senlent
Hi@RChatterjee
yes,it can be done by enable the emios_mcl->globatimebase feature.
3,851件の閲覧回数
RChatterjee
Hi @Senlent ,
This is my config. I have it enabled for EMIOS 0 and EMIOS 1. However, the phase difference exists.
Should this not happen then?
PFA design files. The phase difference is between any of the emios 0 and emios 1 channels.
Rounak Chatterjee.
3,842件の閲覧回数
Senlent
Hi@RChatterjee
3.Test Result:
PTD20 & PTB17
%3CLINGO-SUB%20id%3D%22lingo-sub-1876462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%A4%87%E6%95%B0%E3%81%AE%20EMIOS%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%AE%E5%90%8C%E6%9C%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1876462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A4%87%E6%95%B0%E3%81%AEEMIOS%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%82%92%E4%B8%80%E7%B7%92%E3%81%AB%E5%90%8C%E6%9C%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%E7%8F%BE%E5%9C%A8%E3%80%81EMIOS%201%E3%81%A8EMIOS%200%E3%82%92%E4%B8%80%E7%B7%92%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E4%B8%80%E9%83%A8%E3%81%AEPWM%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BD%8D%E7%9B%B8%E5%B7%AE%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E5%8F%AF%E5%A4%89%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E5%8F%96%E3%82%8A%E9%99%A4%E3%81%8F%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E7%AD%94%E3%81%88%E3%81%8B%E3%82%89%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FSynchronizing-eMIOS-instances%2Ftd-p%2F1423858%2C%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FSynchronizing-eMIOS-instances%2Ftd-p%2F1423858%E3%80%81%3C%2FA%3EGTBE%E3%83%93%E3%83%83%E3%83%88%E3%81%8C1%E3%81%A4%E3%81%AEemis%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%8C%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%86%E3%81%BE%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E8%A4%87%E6%95%B0%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%A7%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
