Some questions about GPIO
4,292 次查看
letseatorange
hi support team:
           Today,when i use GPIO A to read my key signal, i find it can't read it .but when i use GPIO B or C ,they all can read the signal,that's why?My core is v2.0.
               thanks!
Original Attachment has been moved to: ceshi.rar
6 回复数
4,040 次查看
danielmartynek
Can you provide the code?
4,040 次查看
letseatorange
hello
      I have uploaded the attachment
thanks!
4,040 次查看
danielmartynek
I cannot open the file.
Could you check it and attach again?
4,040 次查看
letseatorange
hi
 i'm sorry.new  the attachmen have uploaded!
thanks
4,040 次查看
danielmartynek
Your If statement is not correct,
if(GPIO_HAL_ReadPins(PTA)>> 1 == 0)‍
you should use something like this:
if((GPIO_HAL_ReadPins(PTA)) & (1 << 1))‍
Also, set direction registers:
GPIO_HAL_SetPinDirection(PTA,1,0);
GPIO_HAL_SetPinDirection(PTD,15,1);‍‍
4,040 次查看
letseatorange
hi,
it's work now,Thank you very much.
