Some issues encountered during Flash driver development on S32K344 under the RTD 4.0.0 environment
1,137 次查看
yunaidejiezi
Hi everyone,
I'm currently working on a Flash driver that runs in SRAM (specifically, in DTCM without cache enabled for convenience). I've run into some issues and would appreciate your insights.
Project background:
I have two projects: one includes the C40 driver, and the other (which I'll call fls_drv_demo) does not. My goal is to compile the driver in the C40-enabled project, place it at address 0x00500000 via the AT linker directive, and then in fls_drv_demo, use memcpy to copy it to the intended DTCM address. After that, I hardcode the function addresses and call them to observe Flash behavior changes for verification.
What I've done so far:
  • In the C40-enabled project, I placed all C40 IP-layer functions into the .ramcode section and collected them in the flash_driver section.
  • Custom functions for initialization and programming are placed in the .Fls_Api_Tab section, also collected into flash_driver.
  • Linker scripts have been modified accordingly.
The current problem:
In the fls_drv_demo project, when I call a function pointer—whether it's Fls_Init or a programming function like
((uint32_t (*)(const uint32_t, const uint8_t*, const uint32_t))(0x2000702C | 1))(0x00540000, flswritearray, 16);
—the execution always jumps to 0x00406764 after some internal IP-layer function completes.
Specifically:
  • Fls_Init executes successfully.
  • However, during the write function, after the internal C40_Ip_MainInterfaceSectorErase finishes and is about to return (pop), the PC pointer ends up at 0x00000000.
My suspicion:
I'm wondering whether some internal functions are still being compiled into .text or .mcal.text sections, causing the program to access the wrong stub area and leading to this behavior. Or is there some additional setup step I'm missing?
I'm completely stuck at this point and would really appreciate any suggestions or guidance.
Apologies if the phrasing is a bit off—this was translated with AI assistance. I've attached some screenshots of the project and the issue for reference.
Thanks in advance!
Linker file configuration in the C40 driver project
The .map file (function and stub region address allocation) generated after modifying the linker in the C40 driver project
The specific contents of the fls_drv_demo project
  1. When running the write function (at 0x2000702C), it goes into the internal RTD library function C40_Ip_MainInterfaceSectorErase (at 0x200074EC). At 0x20007502, it jumps to 0x20007B52, and then the PC points to the address stored at 0x20007B54, which is 0x00406764. Subsequently, when executing the pop instruction at 0x00406778, the value of r3 is as shown in the figure, pointing to 0x2001FFD8. 0x2001FFD8 then points to 0x20007BA8, and the value at 0x7BA8 is 0x00000000, causing the program to crash/run away.
11 回复数
1,103 次查看
danielmartynek
Hi @yunaidejiezi,
Based on the disassembly, you forgot to move the OsIf_SuspendAllInterrupts() function to DCTM, all the functions called by the C40_Ip driver must be in DCTM.
I would recommend using the Mem_43_InFls MCAL driver, which handles the copy-to-RAM automatically at runtime and avoids all of this manual dependency tracking.
BR, Daniel
1,087 次查看
yunaidejiezi
Hi, @danielmartynek
    Thank you for your reply.
    The disassembly at 0x00406764 is running in the fls_drv_demo project. The function it actually points to may not be OsIf_SuspendAllInterrupts() from the C40 driver project, but the instructions executed are indeed those for disabling interrupts. I think this function might have been inlined at compile time, since its address is not found in the .map file, so this factor may be irrelevant. Next, I will try to move the functions called internally by c40_ip into the .flash_driver section. In addition, regarding your suggestion to use the Mem_43_InFls MCAL driver, are there any reference examples of making a Flash driver with MCAL? Actually, I have never used MCAL at all.
1,081 次查看
danielmartynek
Hi @yunaidejiezi,
Yes, you need to place all the functions called from the C40_Ip to SRAM.
In the below example, I had to place functions from SchM_Mem_43_INFLS.h to SRAM too.
https://community.nxp.com/t5/S32K-Knowledge-Base/S32K312-C40-Ip-SRAM-RTD-500-DS35/ta-p/2074245
Yes, there is this example in RTD 4.0.0.
Mem_InFls_Example_S32K344
1,059 次查看
yunaidejiezi
Hi,@danielmartynek
I have opened two projects: Mem_InFls_Example_S32K344 and S32K312_C40_Ip_SRAM_RTD_500_DS35. Now I have discovered a very serious issue: it seems that the RTD version I imported does not contain the Mem_43_INFLS_Driver component. After opening Mem_InFls_Example_S32K344, I could not find Mem_43_INFLS_Driver in the MCAL layer. Also, in the S32K312_C40_Ip_SRAM_RTD_500_DS35 project, it appears that Mem_43_INFLS_Driver is not used (since I did not see any calls to Mem_FLs layer functions in main). However, the RTD folder in the Project Explorer does contain SchM_Mem_43_INFLS.c/.h. In the .map file, functions like SchM_Enter_Mem_43_INFLS_MEM_EXCLUSIVE_AREA_04 are also placed into the SRAM area.
I would like to know: when using C40, is SchM_Mem_43_INFLS.c/.h mandatory to be included? Does C40 internally call functions like SchM_Enter_Mem_43_INFLS_MEM_EXCLUSIVE_AREA_04?
There is no Mem_43_INFLS_Driver in the Mem_InFls_Example_S32K344 project
This is my RTD version
The RTD version of the Mem_InFls_Example_S32K344 project.
The RTD version of the S32K312_C40_Ip_SRAM_RTD_500_DS35 project
1,050 次查看
danielmartynek
Hi @yunaidejiezi,
This looks like a compatibility issue. I can see many different RTD versions in the screenshots you posted. Please use a single RTD version per S32DS IDE installation, and the IDE version should match the release notes of the RTD you want to use. You can have multiple S32DS IDE installations if you need to work with more RTD versions.
1,043 次查看
yunaidejiezi
Hi,@danielmartynek
It's possible that my description wasn't clear enough.
The reason multiple versions appear in the screenshots is that I have several projects open at the same time: FLs_drv_demo, Mem_InFls_Example_S32K344, and S32K312_C40_Ip_SRAM_RTD_500_DS35.
For the project I created, the RTD version is as shown in Figure 2 in the previous post: S32K3_RTD_4_0_0_P24_D2405_ASR_REL_4_4_REV_0000_20240515.
The versions of the two projects you recommended to me are:
  • S32K3_RTD_5_0_0_D2408_ASR_REL_4_7_REV_0000_20241002
  • S32K3_RTD_6_0_0_QLP04_D2508_ASR_REL_4_7_REV_0000_20250822
My question is: due to the RTD version differences, in the fls_drv_demo project, the Mem_43_INFLS_Driver component is not available in Mcal, and the file SchM_Mem_43_INFLS is not generated in my project. This is clearly shown in the project manager comparison between the two projects in the screenshots below.
Overall, my current RTD version likely does not support developing a flash driver based on the Mem_43_INFLS_Driver. Therefore, I would like to know: for a project that uses the C40 component, is it mandatory to generate the following functions and place them in SRAM?
1,035 次查看
danielmartynek
Hi @yunaidejiezi,
Regardless of the RTD version you use, there must be an MCAL FLS driver in the Flash example added by default. If you do not see it there and it cannot be added, there is a problem with the IDE - probably because you have multiple RTD versions in a single IDE installation.
Yes, you also need the SchM_Mem_43_INFLS.h functions in SRAM.
BR, Daniel
1,024 次查看
yunaidejiezi
Hi,@danielmartynek
I apologize for the delayed reply.
What I can confirm is that I have never tried installing multiple versions of RTD simultaneously in the IDE. However, it seems that the MCAL FLS driver you mentioned does exist in my setup—just under a different name than Mem_43_INFLS_Driver, so I'm not entirely sure. I've placed it below for reference.
I would like to know whether this component is usable. It does appear to have a built-in feature for automatically placing code into the SRAM region.
1,015 次查看
danielmartynek
Hi @yunaidejiezi,
I see, thank you.
This is because the RTD releases are based on different AUTOSAR specifications.
AUTOSAR 4.4.0 uses the Fls driver, while AUTOSAR 4.7.0 (R21-11) uses Mem_43_INFLS.
The naming convention changed, but the functionality is very similar.
As you mentioned, there is also the option to Load Access Code On Job Start. The Configuration Tool layout is different - the SRAM address configuration is located on a different tab, but otherwise the configuration is equivalent.
568 次查看
yunaidejiezi
Hi,@danielmartynek
   I'm very sorry for not replying to this thread for so long. Over the past week, I've been trying the previous approach—developing based on the C40 component. However, I still couldn't make it work, and all sorts of issues left me overwhelmed and without the motivation to continue communicating. Over the weekend, I thought it over and decided to temporarily abandon this route and switch to developing with MCAL instead. This might take a lot more time, but I will calm down and focus on solving the problems step by step. I would like to express my most sincere gratitude to you for all the advice and help you have provided.
560 次查看
danielmartynek
Hi @yunaidejiezi,
Thanks for the feedback, sorry to hear about the issues. If you have any problems with the MCAL driver, let me know.
%3CLINGO-SUB%20id%3D%22lingo-sub-2408020%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8RTD%204.0.0%E7%8E%AF%E5%A2%83%E4%B8%8B%E5%AF%B9S32K344%E8%BF%9B%E8%A1%8CFlash%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%BC%80%E5%8F%91%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408020%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E5%BC%80%E5%8F%91%E4%B8%80%E4%B8%AA%E5%9C%A8%20SRAM%20%E4%B8%AD%E8%BF%90%E8%A1%8C%E7%9A%84%20Flash%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%E5%85%B7%E4%BD%93%E6%9D%A5%E8%AF%B4%EF%BC%8C%E4%B8%BA%E4%BA%86%E6%96%B9%E4%BE%BF%E8%B5%B7%E8%A7%81%EF%BC%8C%E5%9C%A8%20DTCM%20%E4%B8%AD%E6%B2%A1%E6%9C%89%E5%90%AF%E7%94%A8%E7%BC%93%E5%AD%98%EF%BC%89%E3%80%82%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%EF%BC%8C%E5%B8%8C%E6%9C%9B%E6%82%A8%E8%83%BD%E6%8F%90%E4%BE%9B%E4%B8%80%E4%BA%9B%E8%A7%81%E8%A7%A3%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%E9%A1%B9%E7%9B%AE%E8%83%8C%E6%99%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E6%9C%89%E4%B8%A4%E4%B8%AA%E9%A1%B9%E7%9B%AE%EF%BC%9A%E4%B8%80%E4%B8%AA%E5%8C%85%E5%90%AB%20C40%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%8F%A6%E4%B8%80%E4%B8%AA%EF%BC%88%E6%88%91%E7%A7%B0%E4%B9%8B%E4%B8%BA%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efls_drv_demo%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%EF%BC%89%E5%88%99%E4%B8%8D%E5%8C%85%E5%90%AB%E3%80%82%E6%88%91%E7%9A%84%E7%9B%AE%E6%A0%87%E6%98%AF%E5%9C%A8%E5%90%AF%E7%94%A8%20C40%20%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%AD%E7%BC%96%E8%AF%91%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%B9%B6%E9%80%9A%E8%BF%87%20AT%20%E9%93%BE%E6%8E%A5%E5%99%A8%E6%8C%87%E4%BB%A4%E5%B0%86%E5%85%B6%E6%94%BE%E7%BD%AE%E5%9C%A8%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E0x00500000%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%EF%BC%8C%E7%84%B6%E5%90%8E%E5%9C%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efls_drv_demo%3C%2FSPAN%3E%E4%B8%AD%3CSPAN%20class%3D%22%22%3E%E4%BD%BF%E7%94%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ememcpy%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%B0%86%E5%85%B6%E5%A4%8D%E5%88%B6%E5%88%B0%E7%9B%AE%E6%A0%87%20DTCM%20%E5%9C%B0%E5%9D%80%E3%80%82%E4%B9%8B%E5%90%8E%EF%BC%8C%E6%88%91%E5%B0%86%E5%87%BD%E6%95%B0%E5%9C%B0%E5%9D%80%E7%A1%AC%E7%BC%96%E7%A0%81%E5%88%B0%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E5%B9%B6%E8%B0%83%E7%94%A8%E5%AE%83%E4%BB%AC%E6%9D%A5%E8%A7%82%E5%AF%9F%20Flash%20%E8%A1%8C%E4%B8%BA%E7%9A%84%E5%8F%98%E5%8C%96%E4%BB%A5%E8%BF%9B%E8%A1%8C%E9%AA%8C%E8%AF%81%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E7%9B%AE%E5%89%8D%E4%B8%BA%E6%AD%A2%E5%AE%8C%E6%88%90%E7%9A%84%E5%B7%A5%E4%BD%9C%EF%BC%9A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CUL%3E%3CLI%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%9C%A8%E5%90%AF%E7%94%A8%20C40%20%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E6%88%91%E5%B0%86%E6%89%80%E6%9C%89%20C40%20IP%20%E5%B1%82%E5%87%BD%E6%95%B0%E6%94%BE%E5%85%A5%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E.ramcode%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E9%83%A8%E5%88%86%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%AE%83%E4%BB%AC%E6%94%B6%E9%9B%86%E5%88%B0%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eflash_driver%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E9%83%A8%E5%88%86%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E7%94%A8%E4%BA%8E%E5%88%9D%E5%A7%8B%E5%8C%96%E5%92%8C%E7%BC%96%E7%A8%8B%E7%9A%84%E8%87%AA%E5%AE%9A%E4%B9%89%E5%87%BD%E6%95%B0%E4%BD%8D%E4%BA%8E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E.Fls_Api_Tab%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E9%83%A8%E5%88%86%EF%BC%8C%E4%B9%9F%E6%94%B6%E9%9B%86%E5%88%B0%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eflash_driver%3C%2FSPAN%3E%E4%B8%AD%3CSPAN%20class%3D%22%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E9%93%BE%E6%8E%A5%E5%99%A8%E8%84%9A%E6%9C%AC%E5%B7%B2%E7%9B%B8%E5%BA%94%E4%BF%AE%E6%94%B9%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%E5%BD%93%E5%89%8D%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%9C%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efls_drv_demo%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E5%BD%93%E6%88%91%E8%B0%83%E7%94%A8%E5%87%BD%E6%95%B0%E6%8C%87%E9%92%88%E6%97%B6%E2%80%94%E2%80%94%E6%97%A0%E8%AE%BA%E6%98%AF%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3EFls_Init%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E8%BF%98%E6%98%AF%E5%85%B6%E4%BB%96%E7%BC%96%E7%A8%8B%E5%87%BD%E6%95%B0%EF%BC%8C%E4%BE%8B%E5%A6%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E((uint32_t%20(*)(const%20uint32_t%2C%20const%20uint8_t*%2C%20const%20uint32_t))(0x2000702C%20%7C%201))(0x00540000%2C%20flswritearray%2C%2016)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%94%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E5%9C%A8%E6%9F%90%E4%BA%9B%E5%86%85%E9%83%A8%20IP%20%E5%B1%82%E5%8A%9F%E8%83%BD%E5%AE%8C%E6%88%90%E5%90%8E%EF%BC%8C%20%E6%89%A7%E8%A1%8C%E6%80%BB%E6%98%AF%E8%B7%B3%E8%BD%AC%E5%88%B0%200x00406764%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%85%B7%E4%BD%93%E6%9D%A5%E8%AF%B4%EF%BC%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CUL%3E%3CLI%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EFls_Init%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E6%89%A7%E8%A1%8C%E6%88%90%E5%8A%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E7%84%B6%E8%80%8C%EF%BC%8C%E5%9C%A8%E5%86%99%E5%85%A5%E5%87%BD%E6%95%B0%E6%89%A7%E8%A1%8C%E6%9C%9F%E9%97%B4%EF%BC%8C%E5%86%85%E9%83%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3EC40_Ip_MainInterfaceSectorErase%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%AE%8C%E6%88%90%E5%B9%B6%E5%8D%B3%E5%B0%86%E8%BF%94%E5%9B%9E%EF%BC%88%E5%BC%B9%E5%87%BA%EF%BC%89%E6%97%B6%EF%BC%8CPC%20%E6%8C%87%E9%92%88%E6%9C%80%E7%BB%88%E4%BD%8D%E4%BA%8E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E0x00000000%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E7%9A%84%E6%80%80%E7%96%91%EF%BC%9A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E6%80%80%E7%96%91%E6%98%AF%E4%B8%8D%E6%98%AF%E6%9F%90%E4%BA%9B%E5%86%85%E9%83%A8%E5%87%BD%E6%95%B0%E4%BB%8D%E7%84%B6%E8%A2%AB%E7%BC%96%E8%AF%91%E5%88%B0%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E.text%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E6%88%96%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E.mcal.text%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E6%AE%B5%E4%B8%AD%EF%BC%8C%E5%AF%BC%E8%87%B4%E7%A8%8B%E5%BA%8F%E8%AE%BF%E9%97%AE%E4%BA%86%E9%94%99%E8%AF%AF%E7%9A%84%E7%9F%AD%E6%88%AA%E7%BA%BF%E5%8C%BA%E5%9F%9F%EF%BC%8C%E4%BB%8E%E8%80%8C%E5%BC%95%E5%8F%91%E4%BA%86%E8%BF%99%E7%A7%8D%E8%A1%8C%E4%B8%BA%E3%80%82%E6%88%96%E8%80%85%E6%98%AF%E4%B8%8D%E6%98%AF%E6%88%91%E6%BC%8F%E6%8E%89%E4%BA%86%E4%B8%80%E4%BA%9B%E9%A2%9D%E5%A4%96%E7%9A%84%E8%AE%BE%E7%BD%AE%E6%AD%A5%E9%AA%A4%EF%BC%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E5%AE%8C%E5%85%A8%E5%8D%A1%E4%BD%8F%E4%BA%86%EF%BC%8C%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BB%BB%E4%BD%95%E5%BB%BA%E8%AE%AE%E6%88%96%E6%8C%87%E5%AF%BC%E3%80%82%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%A6%82%E6%9E%9C%E6%8E%AA%E8%BE%9E%E6%9C%89%E4%BA%9B%E4%B8%8D%E5%A6%A5%EF%BC%8C%E6%95%AC%E8%AF%B7%E8%B0%85%E8%A7%A3%E2%80%94%E2%80%94%E8%BF%99%E6%98%AF%E7%94%B1%3CSPAN%20class%3D%22%22%3E%E4%BA%BA%E5%B7%A5%E6%99%BA%E8%83%BD%3C%2FSPAN%3E%E8%BE%85%E5%8A%A9%E7%BF%BB%E8%AF%91%E7%9A%84%E3%80%82%E6%88%91%E9%99%84%E4%B8%8A%E4%BA%86%E4%B8%80%E4%BA%9B%E9%A1%B9%E7%9B%AE%E5%92%8C%E9%97%AE%E9%A2%98%E7%9A%84%E6%88%AA%E5%9B%BE%E4%BE%9B%E6%82%A8%E5%8F%82%E8%80%83%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EC40%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%A1%B9%E7%9B%AE%E4%B8%AD%E7%9A%84%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395232i8853457E9AEA0A04%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-102549.jpg%22%20alt%3D%2220260825-102549.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-102549.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-102549.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-102549.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-102549.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-102549.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-102549.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-102549.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-102549.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-102549.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%E4%BF%AE%E6%94%B9%20C40%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%A1%B9%E7%9B%AE%E4%B8%AD%E7%9A%84%E9%93%BE%E6%8E%A5%E5%99%A8%E5%90%8E%E7%94%9F%E6%88%90%E7%9A%84%20.map%20%E6%96%87%E4%BB%B6%EF%BC%88%E5%87%BD%E6%95%B0%E5%92%8C%E7%9F%AD%E6%88%AA%E7%BA%BF%E5%8C%BA%E5%9F%9F%E5%9C%B0%E5%9D%80%E5%88%86%E9%85%8D%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395234i9C29C191FA62A7C5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-103800.jpg%22%20alt%3D%2220260825-103800.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103800.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103800.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103800.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103800.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103800.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103800.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103800.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103800.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103800.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395233i5CFD496A3E0E16B5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-103746.jpg%22%20alt%3D%2220260825-103746.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103746.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103746.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103746.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103746.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103746.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103746.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103746.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103746.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103746.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3Efls_drv_demo%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%20%E9%A1%B9%E7%9B%AE%20%E7%9A%84%E5%85%B7%E4%BD%93%E5%86%85%E5%AE%B9%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395235iF5C24491A4CA040D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-103909.jpg%22%20alt%3D%2220260825-103909.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3COL%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%E8%BF%90%E8%A1%8C%E5%86%99%E5%85%A5%E5%87%BD%E6%95%B0%E6%97%B6%EF%BC%88%E5%9C%A8%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x2000702C%20%3CSPAN%20class%3D%22%22%3E%EF%BC%89%EF%BC%8C%E5%AE%83%E8%BF%9B%E5%85%A5%E5%86%85%E9%83%A8%20RTD%20%E5%BA%93%E5%87%BD%E6%95%B0%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3EC40_Ip_MainInterfaceSectorErase%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%EF%BC%88%E5%9C%A8%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x200074EC%20%3CSPAN%20class%3D%22%22%3E%EF%BC%89%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x20007502%20%3CSPAN%20class%3D%22%22%3E%EF%BC%8C%E5%AE%83%E8%B7%B3%E8%BD%AC%E5%88%B0%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x20007B52%20%3CSPAN%20class%3D%22%22%3E%EF%BC%8C%E7%84%B6%E5%90%8E%E7%A8%8B%E5%BA%8F%E8%AE%A1%E6%95%B0%E5%99%A8%E6%8C%87%E5%90%91%E5%AD%98%E5%82%A8%E5%9C%A8%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x20007B54%20%3CSPAN%20class%3D%22%22%3E%EF%BC%8C%E5%8D%B3%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x00406764%20%3CSPAN%20class%3D%22%22%3E%E3%80%82%E9%9A%8F%E5%90%8E%EF%BC%8C%E5%9C%A8%E6%89%A7%E8%A1%8C%E6%97%B6%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%E6%B5%81%E8%A1%8C%E9%9F%B3%E4%B9%90%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%8C%87%E5%AF%BC%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x00406778%20%3CSPAN%20class%3D%22%22%3E%EF%BC%8C%E8%AF%A5%E5%80%BC%E4%B8%BA%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3Er3%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%A6%82%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%8C%E6%8C%87%E5%90%91%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x2001FFD8%20%3CSPAN%20class%3D%22%22%3E%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x2001FFD8%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E7%84%B6%E5%90%8E%E6%8C%87%E5%90%91%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x20007BA8%20%3CSPAN%20class%3D%22%22%3E%EF%BC%8C%E4%BB%A5%E5%8F%8A%E8%AF%A5%E5%80%BC%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x7BA8%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%98%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x00000000%20%3CSPAN%20class%3D%22%22%3E%EF%BC%8C%E5%AF%BC%E8%87%B4%E7%A8%8B%E5%BA%8F%E5%B4%A9%E6%BA%83%2F%E9%80%83%E8%B7%91%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395237iEA3CD36C200913B5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-105216.jpg%22%20alt%3D%2220260825-105216.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-105216.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-105216.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-105216.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-105216.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-105216.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-105216.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-105216.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-105216.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-105216.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395242i9A77CD55E3A7EBE1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-110659.jpg%22%20alt%3D%2220260825-110659.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110659.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110659.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110659.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110659.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110659.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110659.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110659.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110659.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110659.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395250i6C7F0355D381B360%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-110639.jpg%22%20alt%3D%2220260825-110639.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110639.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110639.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110639.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110639.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110639.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110639.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110639.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110639.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110639.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395252iF0548463526388C9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-110710.jpg%22%20alt%3D%2220260825-110710.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110710.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110710.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110710.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110710.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110710.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110710.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110710.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110710.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110710.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395255iF3D5C827D6B6F885%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%221.jpg%22%20alt%3D%221.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395261iFA993FAF64AD8E0E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%222.jpg%22%20alt%3D%222.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395269i06F652FA6AD96C46%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-111431.jpg%22%20alt%3D%2220260825-111431.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-111431.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-111431.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-111431.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-111431.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-111431.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-111431.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-111431.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-111431.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-111431.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395270i3F2E52DBA22584FB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-130859.jpg%22%20alt%3D%2220260825-130859.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130859.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130859.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130859.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130859.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130859.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130859.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130859.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130859.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130859.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395271i122AC644E35B55AE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-130909.jpg%22%20alt%3D%2220260825-130909.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408416%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408416%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259229%22%20target%3D%22_blank%22%3E%40yunaidejiezi%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BD%A0%E9%9C%80%E8%A6%81%E6%8A%8A%E4%BB%8E%20C40_Ip%20%E8%B0%83%E7%94%A8%E7%9A%84%E6%89%80%E6%9C%89%E5%87%BD%E6%95%B0%E9%83%BD%E6%94%BE%E5%88%B0%20SRAM%20%E4%B8%AD%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E4%B8%8B%E9%9D%A2%E7%9A%84%E4%BE%8B%E5%AD%90%E4%B8%AD%EF%BC%8C%E6%88%91%E4%B9%9F%E9%9C%80%E8%A6%81%E5%B0%86%20SchM_Mem_43_INFLS.h%20%E4%B8%AD%E7%9A%84%E5%87%BD%E6%95%B0%E6%94%BE%E5%88%B0%20SRAM%20%E4%B8%AD%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K312-C40-Ip-SRAM-RTD-500-DS35%2Fta-p%2F2074245%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K312-C40-Ip-SRAM-RTD-500-DS35%2Fta-p%2F2074245%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8CRTD%204.0.0%20%E4%B8%AD%E6%9C%89%E8%BF%99%E4%B8%AA%E4%BE%8B%E5%AD%90%E3%80%82%3C%2FP%3E%0A%3CP%3EMem_InFls_Example_S32K344%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395357i3F22BF2545A81C85%2Fimage-dimensions%2F536x468%3Fv%3Dv2%22%20width%3D%22536%22%20height%3D%22468%22%20role%3D%22button%22%20title%3D%22danielmartynek_0-1787734274169.png%22%20alt%3D%22danielmartynek_0-1787734274169.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1787734274169.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1787734274169.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1787734274169.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1787734274169.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1787734274169.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1787734274169.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1787734274169.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1787734274169.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1787734274169.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F160001%22%20target%3D%22_blank%22%3E%40danielmartynek%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3E%20%20%20%20%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E6%8B%86%E5%8D%B8%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x00406764%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3Efls_drv_demo%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E9%A1%B9%E7%9B%AE%E3%80%82%E5%AE%83%E5%AE%9E%E9%99%85%E6%8C%87%E5%90%91%E7%9A%84%E5%87%BD%E6%95%B0%E5%8F%AF%E8%83%BD%E4%B8%8D%E6%98%AF%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3EOsIf_SuspendAllInterrupts()%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E8%99%BD%E7%84%B6%E6%9D%A5%E8%87%AA%20C40%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%A1%B9%E7%9B%AE%EF%BC%8C%E4%BD%86%E6%89%A7%E8%A1%8C%E7%9A%84%E6%8C%87%E4%BB%A4%E7%A1%AE%E5%AE%9E%E6%98%AF%E7%94%A8%E4%BA%8E%E7%A6%81%E7%94%A8%E4%B8%AD%E6%96%AD%E7%9A%84%E6%8C%87%E4%BB%A4%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E4%B8%AA%E5%87%BD%E6%95%B0%E5%8F%AF%E8%83%BD%E6%98%AF%E5%9C%A8%E7%BC%96%E8%AF%91%E6%97%B6%E5%86%85%E8%81%94%E7%9A%84%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E7%9A%84%E5%9C%B0%E5%9D%80%E5%9C%A8%E4%BB%A3%E7%A0%81%E4%B8%AD%E6%89%BE%E4%B8%8D%E5%88%B0%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%E3%80%82%E5%9C%B0%E5%9B%BE%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%96%87%E4%BB%B6%EF%BC%8C%E6%89%80%E4%BB%A5%E8%BF%99%E4%B8%AA%E5%9B%A0%E7%B4%A0%E5%8F%AF%E8%83%BD%E6%97%A0%E5%85%B3%E7%B4%A7%E8%A6%81%E3%80%82%E6%8E%A5%E4%B8%8B%E6%9D%A5%EF%BC%8C%E6%88%91%E5%B0%86%E5%B0%9D%E8%AF%95%E7%A7%BB%E5%8A%A8%E5%86%85%E9%83%A8%E8%B0%83%E7%94%A8%E7%9A%84%E5%87%BD%E6%95%B0%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3Ec40_ip%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E8%BF%9B%E5%85%A5%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E.flash_driver%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E9%83%A8%E5%88%86%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E5%85%B3%E4%BA%8E%E6%82%A8%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%E2%80%A6%E2%80%A6%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3EMem_43_InFls%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EMCAL%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E6%9C%89%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8MCAL%E5%88%B6%E4%BD%9CFlash%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%8F%82%E8%80%83%E7%A4%BA%E4%BE%8B%EF%BC%9F%E5%AE%9E%E9%99%85%E4%B8%8A%EF%BC%8C%E6%88%91%E4%BB%8E%E6%9C%AA%E4%BD%BF%E7%94%A8%E8%BF%87MCAL%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259229%22%20target%3D%22_blank%22%3E%40yunaidejiezi%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%A0%B9%E6%8D%AE%E5%8F%8D%E6%B1%87%E7%BC%96%E7%BB%93%E6%9E%9C%EF%BC%8C%E4%BD%A0%E5%BF%98%E8%AE%B0%E5%B0%86%20OsIf_SuspendAllInterrupts()%20%E5%87%BD%E6%95%B0%E7%A7%BB%E5%88%B0%20DCTM%20%E4%B8%AD%EF%BC%8CC40_Ip%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%B0%83%E7%94%A8%E7%9A%84%E6%89%80%E6%9C%89%E5%87%BD%E6%95%B0%E9%83%BD%E5%BF%85%E9%A1%BB%E5%9C%A8%20DCTM%20%E4%B8%AD%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%20Mem_43_InFls%20MCAL%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%AE%83%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%BF%90%E8%A1%8C%E6%97%B6%E8%87%AA%E5%8A%A8%E5%A4%84%E7%90%86%E5%A4%8D%E5%88%B6%E5%88%B0%20RAM%20%E7%9A%84%E6%93%8D%E4%BD%9C%EF%BC%8C%E9%81%BF%E5%85%8D%E6%89%80%E6%9C%89%E8%BF%99%E4%BA%9B%E6%89%8B%E5%8A%A8%E4%BE%9D%E8%B5%96%E9%A1%B9%E8%B7%9F%E8%B8%AA%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%EF%BC%8C%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F160001%22%20target%3D%22_blank%22%3E%40danielmartynek%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E5%90%AF%E5%8A%A8%E4%BA%86%E4%B8%A4%E4%B8%AA%E9%A1%B9%E7%9B%AE%EF%BC%9A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3EMem_InFls_Example_S32K344%3C%2FSPAN%3E%3C%2FEM%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%92%8C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3ES32K312_C40_Ip_SRAM_RTD_500_DS35%3C%2FSPAN%3E%3C%2FEM%3E%20%3CSPAN%20class%3D%22%22%3E%E3%80%82%E7%8E%B0%E5%9C%A8%E6%88%91%E5%8F%91%E7%8E%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%9D%9E%E5%B8%B8%E4%B8%A5%E9%87%8D%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%9A%E6%88%91%E5%AF%BC%E5%85%A5%E7%9A%84RTD%E7%89%88%E6%9C%AC%E4%BC%BC%E4%B9%8E%E4%B8%8D%E5%8C%85%E5%90%AB%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3EMem_43_INFLS_%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%85%83%E5%99%A8%E4%BB%B6%E3%80%82%E6%89%93%E5%BC%80%E5%90%8E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%3CEM%3E%3CSPAN%20class%3D%22%22%3EMem_InFls_Example_S32K344%3C%2FSPAN%3E%3C%2FEM%3E%20%E3%80%82%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3EMem_43_INFLS_%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%9C%A8%20MCAL%20%E5%B1%82%E4%B8%AD%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E5%9C%A8%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3ES32K312_C40_Ip_SRAM_RTD_500_DS35%3C%2FSPAN%3E%3C%2FEM%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E8%AF%A5%E9%A1%B9%E7%9B%AE%EF%BC%8C%E7%9C%8B%E8%B5%B7%E6%9D%A5%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3EMem_43_INFLS_%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%9C%AA%E4%BD%BF%E7%94%A8%EF%BC%88%E5%9B%A0%E4%B8%BA%E6%88%91%E6%B2%A1%E6%9C%89%E7%9C%8B%E5%88%B0%E4%BB%BB%E4%BD%95%E8%B0%83%E7%94%A8%EF%BC%89%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%E5%86%85%E5%AD%98_FLs%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%B1%82%E5%87%BD%E6%95%B0%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%E4%B8%BB%E6%96%87%E4%BB%B6%E5%A4%B9%3CSPAN%20class%3D%22%22%3E%EF%BC%89%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E9%A1%B9%E7%9B%AE%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E4%B8%AD%E7%9A%84%20RTD%20%E6%96%87%E4%BB%B6%E5%A4%B9%E7%A1%AE%E5%AE%9E%E5%8C%85%E5%90%AB%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3ESchM_Mem_43_INFLS.c%2F.h%20%3CSPAN%20class%3D%22%22%3E%E3%80%82%E5%9C%A8%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%E3%80%82%E5%9C%B0%E5%9B%BE%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%96%87%E4%BB%B6%E3%80%81%E5%87%BD%E6%95%B0%E7%AD%89%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3ESchM_Enter_Mem_43_INFLS_MEM_EXCLUSIVE_AREA_04%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%AE%83%E4%BB%AC%E4%B9%9F%E8%A2%AB%E6%94%BE%E7%BD%AE%E5%9C%A8%20SRAM%20%E5%8C%BA%E5%9F%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%EF%BC%9A%E4%BD%BF%E7%94%A8C40%E6%97%B6%EF%BC%8C%E6%98%AF%E5%90%A6%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3ESchM_Mem_43_INFLS.c%2F.h%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%98%AF%E5%90%A6%E5%BF%85%E9%A1%BB%E5%8C%85%E5%90%AB%E5%9C%A8%E5%86%85%EF%BC%9FC40%20%E5%86%85%E9%83%A8%E6%98%AF%E5%90%A6%E4%BC%9A%E8%B0%83%E7%94%A8%E7%B1%BB%E4%BC%BC%E8%BF%99%E6%A0%B7%E7%9A%84%E5%87%BD%E6%95%B0%EF%BC%9F%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3ESchM_Enter_Mem_43_INFLS_MEM_EXCLUSIVE_AREA_04%20%3CSPAN%20class%3D%22%22%3E%3F%3CBR%20%2F%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260827-102145.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102145.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102145.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102145.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102145.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102145.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102145.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102145.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102145.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395398i79613B917A6F1E02%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260827-102145.jpg%22%20alt%3D%2220260827-102145.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102145.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102145.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102145.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102145.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102145.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102145.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102145.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102145.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EMem_InFls_Example_S32K344%20%E9%A1%B9%E7%9B%AE%E4%B8%AD%E6%B2%A1%E6%9C%89%20Mem_43_INFLS_Driver%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260827-102152.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102152.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102152.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102152.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102152.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102152.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102152.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102152.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102152.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395399i03DDCBE7167830FA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260827-102152.jpg%22%20alt%3D%2220260827-102152.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102152.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102152.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102152.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102152.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102152.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102152.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102152.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102152.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84RTD%E7%89%88%E6%9C%AC%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260827-102157.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102157.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102157.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102157.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102157.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102157.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102157.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102157.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102157.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395400iBE0AD1930765F2C0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260827-102157.jpg%22%20alt%3D%2220260827-102157.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102157.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102157.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102157.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102157.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102157.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102157.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102157.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102157.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3EMem_InFls_Example_S32K344%20%E9%A1%B9%E7%9B%AE%E7%9A%84%20RTD%20%E7%89%88%E6%9C%AC%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260827-103214.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-103214.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-103214.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-103214.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-103214.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-103214.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-103214.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-103214.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-103214.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395401i6DE76D9BC34C8476%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260827-103214.jpg%22%20alt%3D%2220260827-103214.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-103214.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-103214.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-103214.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-103214.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-103214.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-103214.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-103214.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-103214.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3ES32K312_C40_Ip_SRAM_RTD_500_DS35%20%E9%A1%B9%E7%9B%AE%E7%9A%84%20RTD%20%E7%89%88%E6%9C%AC%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408700%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408700%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259229%22%20target%3D%22_blank%22%3E%40yunaidejiezi%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%83%8F%E6%98%AF%E5%85%BC%E5%AE%B9%E6%80%A7%E9%97%AE%E9%A2%98%E3%80%82%E4%BB%8E%E4%BD%A0%E5%8F%91%E7%9A%84%E6%88%AA%E5%9B%BE%E4%B8%AD%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%E4%BA%86%E5%BE%88%E5%A4%9A%E4%B8%8D%E5%90%8C%E7%9A%84RTD%E7%89%88%E6%9C%AC%E3%80%82%E8%AF%B7%E6%AF%8F%E4%B8%AA%20S32DS%20IDE%20%E5%AE%89%E8%A3%85%E4%BD%BF%E7%94%A8%E4%B8%80%E4%B8%AA%20RTD%20%E7%89%88%E6%9C%AC%EF%BC%8C%E5%B9%B6%E4%B8%94%20IDE%20%E7%89%88%E6%9C%AC%E5%BA%94%E4%B8%8E%E6%82%A8%E8%A6%81%E4%BD%BF%E7%94%A8%E7%9A%84%20RTD%20%E7%9A%84%E5%8F%91%E8%A1%8C%E8%AF%B4%E6%98%8E%E7%9B%B8%E5%8C%B9%E9%85%8D%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%E5%A4%9A%E4%B8%AA%20RTD%20%E7%89%88%E6%9C%AC%EF%BC%8C%E5%88%99%E5%8F%AF%E4%BB%A5%E5%AE%89%E8%A3%85%E5%A4%9A%E4%B8%AA%20S32DS%20IDE%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259229%22%20target%3D%22_blank%22%3E%40yunaidejiezi%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%97%A0%E8%AE%BA%E4%BD%A0%E4%BD%BF%E7%94%A8%E5%93%AA%E4%B8%AA%20RTD%20%E7%89%88%E6%9C%AC%EF%BC%8CFlash%20%E7%A4%BA%E4%BE%8B%E4%B8%AD%E9%83%BD%E5%BF%85%E9%A1%BB%E9%BB%98%E8%AE%A4%E6%B7%BB%E5%8A%A0%20MCAL%20FLS%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E5%9C%A8%E9%82%A3%E9%87%8C%E7%9C%8B%E4%B8%8D%E5%88%B0%E5%AE%83%E5%B9%B6%E4%B8%94%E6%97%A0%E6%B3%95%E6%B7%BB%E5%8A%A0%E5%AE%83%EF%BC%8C%E5%88%99%E8%AF%B4%E6%98%8E%20IDE%20%E6%9C%89%E9%97%AE%E9%A2%98%E2%80%94%E2%80%94%E5%8F%AF%E8%83%BD%E6%98%AF%E5%9B%A0%E4%B8%BA%E6%82%A8%E5%9C%A8%E5%8D%95%E4%B8%AA%20IDE%20%E5%AE%89%E8%A3%85%E4%B8%AD%E6%9C%89%E5%A4%9A%E4%B8%AA%20RTD%20%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%82%A8%E8%BF%98%E9%9C%80%E8%A6%81%20SchM_Mem_43_INFLS.h%20%E6%96%87%E4%BB%B6%E3%80%82SRAM%20%E4%B8%AD%E7%9A%84%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K312-C40-Ip-SRAM-RTD-500-DS35%2Fta-p%2F2074245%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K312-C40-Ip-SRAM-RTD-500-DS35%2Fta-p%2F2074245%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%EF%BC%8C%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F160001%22%20target%3D%22_blank%22%3E%40danielmartynek%3C%2FA%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%8F%AF%E8%83%BD%E6%98%AF%E6%88%91%E7%9A%84%E6%8F%8F%E8%BF%B0%E4%B8%8D%E5%A4%9F%E6%B8%85%E6%A5%9A%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3E%E6%88%AA%E5%9B%BE%E4%B8%AD%E5%87%BA%E7%8E%B0%E5%A4%9A%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84%E5%8E%9F%E5%9B%A0%E6%98%AF%EF%BC%8C%E6%88%91%E5%90%8C%E6%97%B6%E6%89%93%E5%BC%80%E4%BA%86%E5%A4%9A%E4%B8%AA%E9%A1%B9%E7%9B%AE%EF%BC%9A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EFLs_drv_demo%3C%2FSPAN%3E%3C%2FSTRONG%3E%20%3CSPAN%20class%3D%22%22%3E%EF%BC%8C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EMem_InFls_Example_S32K344%3C%2FSPAN%3E%3C%2FSTRONG%3E%20%3CSPAN%20class%3D%22%22%3E%EF%BC%8C%E4%BB%A5%E5%8F%8A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3ES32K312_C40_Ip_SRAM_RTD_500_DS35%3C%2FSPAN%3E%3C%2FSTRONG%3E%20%3CSPAN%20class%3D%22%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%AF%B9%E4%BA%8E%E6%88%91%E5%88%9B%E5%BB%BA%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8CRTD%20%E7%89%88%E6%9C%AC%E5%A6%82%E5%9B%BE%202%20%E6%89%80%E7%A4%BA%EF%BC%88%E8%A7%81%E4%B8%8A%E4%B8%80%E7%AF%87%E6%96%87%E7%AB%A0%EF%BC%89%EF%BC%9A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3ES32K3_RTD_4_0_0_P24_D2405_ASR_REL_4_4_REV_0000_20240515%3C%2FSPAN%3E%3C%2FSTRONG%3E%20%3CSPAN%20class%3D%22%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%82%A8%E6%8E%A8%E8%8D%90%E7%BB%99%E6%88%91%E7%9A%84%E4%B8%A4%E4%B8%AA%E9%A1%B9%E7%9B%AE%E7%9A%84%E7%89%88%E6%9C%AC%E5%88%86%E5%88%AB%E6%98%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3ES32K3_RTD_5_0_0_D2408_ASR_REL_4_7_REV_0000_20241002%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3ES32K3_RTD_6_0_0_QLP04_D2508_ASR_REL_4_7_REV_0000_20250822%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%9A%E7%94%B1%E4%BA%8ERTD%E7%89%88%E6%9C%AC%E5%B7%AE%E5%BC%82%EF%BC%8C%E5%9C%A8%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3Efls_drv_demo%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E9%A1%B9%E7%9B%AE%EF%BC%8C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EMem_43_INFLS_%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EMcal%20%E4%B8%AD%E6%B2%A1%E6%9C%89%E8%AF%A5%E5%85%83%E5%99%A8%E4%BB%B6%EF%BC%8C%E5%B9%B6%E4%B8%94%E8%AF%A5%E6%96%87%E4%BB%B6%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3ESchM_Mem_43_INFLS%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%88%91%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%AD%E6%B2%A1%E6%9C%89%E7%94%9F%E6%88%90%E8%AF%A5%E9%A1%B9%E3%80%82%E8%BF%99%E4%B8%80%E7%82%B9%E5%9C%A8%E4%B8%8B%E6%96%B9%E6%88%AA%E5%9B%BE%E4%B8%AD%E4%B8%A4%E4%B8%AA%E9%A1%B9%E7%9B%AE%E7%9A%84%E9%A1%B9%E7%9B%AE%E7%AE%A1%E7%90%86%E5%99%A8%E5%AF%B9%E6%AF%94%E4%B8%AD%E5%8F%AF%E4%BB%A5%E6%98%8E%E6%98%BE%E7%9C%8B%E5%87%BA%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260827-163404.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163404.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163404.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163404.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163404.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163404.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395421i22637569AC28DE11%2Fimage-size%2Fsmall%3Fv%3Dv2%26amp%3Bpx%3D200%22%20role%3D%22button%22%20title%3D%2220260827-163404.jpg%22%20alt%3D%2220260827-163404.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163404.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163404.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163404.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163404.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163404.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260827-163400.jpg%22%20style%3D%22width%3A%20191px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163400.jpg%22%20style%3D%22width%3A%20191px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163400.jpg%22%20style%3D%22width%3A%20191px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163400.jpg%22%20style%3D%22width%3A%20191px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163400.jpg%22%20style%3D%22width%3A%20191px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163400.jpg%22%20style%3D%22width%3A%20191px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395422i7E398F025F0EBF23%2Fimage-size%2Fsmall%3Fv%3Dv2%26amp%3Bpx%3D200%22%20role%3D%22button%22%20title%3D%2220260827-163400.jpg%22%20alt%3D%2220260827-163400.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163400.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163400.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163400.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163400.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163400.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%80%BB%E7%9A%84%E6%9D%A5%E8%AF%B4%EF%BC%8C%E6%88%91%E5%BD%93%E5%89%8D%E7%9A%84RTD%E7%89%88%E6%9C%AC%E5%8F%AF%E8%83%BD%E4%B8%8D%E6%94%AF%E6%8C%81%E5%9F%BA%E4%BA%8E%E6%AD%A4%E5%BC%80%E5%8F%91%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EMem_43_INFLS_Driver%3C%2FSPAN%3E%3C%2FSTRONG%3E%20%3CSPAN%20class%3D%22%22%3E%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%EF%BC%9A%E5%AF%B9%E4%BA%8E%E4%BD%BF%E7%94%A8%20Mem_43_INFLS_Driver%20%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EC40%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%AF%B9%E4%BA%8E%E8%AF%A5%E5%85%83%E5%99%A8%E4%BB%B6%EF%BC%8C%E6%98%AF%E5%90%A6%E5%BF%85%E9%A1%BB%E7%94%9F%E6%88%90%E4%BB%A5%E4%B8%8B%E5%87%BD%E6%95%B0%E5%B9%B6%E5%B0%86%E5%85%B6%E6%94%BE%E7%BD%AE%E5%9C%A8%20SRAM%20%E4%B8%AD%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260827-163521.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163521.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163521.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163521.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163521.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163521.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395423i2364C029419E1E2E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260827-163521.jpg%22%20alt%3D%2220260827-163521.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163521.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163521.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163521.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163521.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163521.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2409043%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2409043%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F160001%22%20target%3D%22_blank%22%3E%40danielmartynek%3C%2FA%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%BE%88%E6%8A%B1%E6%AD%89%E5%9B%9E%E5%A4%8D%E6%99%9A%E4%BA%86%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E7%A1%AE%E8%AE%A4%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E4%BB%8E%E6%9C%AA%E5%B0%9D%E8%AF%95%E5%9C%A8%20IDE%20%E4%B8%AD%E5%90%8C%E6%97%B6%E5%AE%89%E8%A3%85%E5%A4%9A%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84%20RTD%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E6%82%A8%E6%8F%90%E5%88%B0%E7%9A%84%20MCAL%20FLS%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BC%BC%E4%B9%8E%E7%A1%AE%E5%AE%9E%E5%AD%98%E5%9C%A8%E4%BA%8E%E6%88%91%E7%9A%84%E7%B3%BB%E7%BB%9F%E4%B8%AD%E2%80%94%E2%80%94%E5%8F%AA%E6%98%AF%E5%90%8D%E7%A7%B0%E4%B8%8D%E5%90%8C%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EMem_43_INFLS_Driver%3C%2FSPAN%3E%3C%2FSTRONG%3E%20%3CSPAN%20class%3D%22%22%3E%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E4%B8%8D%E5%A4%AA%E7%A1%AE%E5%AE%9A%E3%80%82%E6%88%91%E6%8A%8A%E5%AE%83%E6%94%BE%E5%9C%A8%E4%B8%8B%E9%9D%A2%E4%BE%9B%E5%8F%82%E8%80%83%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260828-095254.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260828-095254.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260828-095254.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260828-095254.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260828-095254.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395475i3E771D05FB9BE72B%2Fimage-size%2Fsmall%3Fv%3Dv2%26amp%3Bpx%3D200%22%20role%3D%22button%22%20title%3D%2220260828-095254.jpg%22%20alt%3D%2220260828-095254.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260828-095254.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260828-095254.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260828-095254.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260828-095254.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260828-095249.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260828-095249.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260828-095249.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260828-095249.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260828-095249.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395476iFF4064C20AE1BCEE%2Fimage-size%2Fsmall%3Fv%3Dv2%26amp%3Bpx%3D200%22%20role%3D%22button%22%20title%3D%2220260828-095249.jpg%22%20alt%3D%2220260828-095249.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260828-095249.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260828-095249.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260828-095249.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260828-095249.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E8%BF%99%E4%B8%AA%E5%85%83%E5%99%A8%E4%BB%B6%E6%98%AF%E5%90%A6%E5%8F%AF%E7%94%A8%E3%80%82%E5%AE%83%E4%BC%BC%E4%B9%8E%E5%86%85%E7%BD%AE%E4%BA%86%E8%87%AA%E5%8A%A8%E5%B0%86%E4%BB%A3%E7%A0%81%E6%94%BE%E5%85%A5%20SRAM%20%E5%8C%BA%E5%9F%9F%E7%9A%84%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2409097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2409097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259229%22%20target%3D%22_blank%22%3E%40yunaidejiezi%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%98%8E%E7%99%BD%E4%BA%86%EF%BC%8C%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%98%AF%E5%9B%A0%E4%B8%BA%20RTD%20%E7%89%88%E6%9C%AC%E5%9F%BA%E4%BA%8E%E4%B8%8D%E5%90%8C%E7%9A%84%20AUTOSAR%20%E8%A7%84%E8%8C%83%E3%80%82%3C%2FP%3E%0A%3CP%3EAUTOSAR%204.4.0%20%E4%BD%BF%E7%94%A8%20Fls%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E8%80%8C%20AUTOSAR%204.7.0%20(R21-11)%20%E4%BD%BF%E7%94%A8%20Mem_43_INFLS%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%91%BD%E5%90%8D%E8%A7%84%E5%88%99%E8%99%BD%E7%84%B6%E6%94%B9%E5%8F%98%E4%BA%86%EF%BC%8C%E4%BD%86%E5%8A%9F%E8%83%BD%E9%9D%9E%E5%B8%B8%E7%9B%B8%E4%BC%BC%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A3%E5%A6%82%E6%82%A8%E6%89%80%E6%8F%90%E5%88%B0%E7%9A%84%EF%BC%8C%E8%BF%98%E5%8F%AF%E4%BB%A5%E9%80%89%E6%8B%A9%E5%9C%A8%E4%BD%9C%E4%B8%9A%E5%90%AF%E5%8A%A8%E6%97%B6%E5%8A%A0%E8%BD%BD%E8%AE%BF%E9%97%AE%E4%BB%A3%E7%A0%81%E3%80%82%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E7%9A%84%E5%B8%83%E5%B1%80%E6%9C%89%E6%89%80%E4%B8%8D%E5%90%8C%E2%80%94%E2%80%94SRAM%20%E5%9C%B0%E5%9D%80%E9%85%8D%E7%BD%AE%E4%BD%8D%E4%BA%8E%E4%B8%8D%E5%90%8C%E7%9A%84%E9%80%89%E9%A1%B9%E5%8D%A1%E4%B8%8A%EF%BC%8C%E4%BD%86%E9%99%A4%E6%AD%A4%E4%B9%8B%E5%A4%96%EF%BC%8C%E9%85%8D%E7%BD%AE%E6%98%AF%E7%9B%B8%E5%90%8C%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411884%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411884%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259229%22%20target%3D%22_blank%22%3E%40yunaidejiezi%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%8F%8D%E9%A6%88%EF%BC%8C%E5%BE%88%E6%8A%B1%E6%AD%89%E5%90%AC%E5%88%B0%E6%82%A8%E9%81%87%E5%88%B0%E8%BF%99%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E5%9C%A8%E4%BD%BF%E7%94%A8%20MCAL%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%97%B6%E9%81%87%E5%88%B0%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411797%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411797%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F160001%22%20target%3D%22_blank%22%3E%40danielmartynek%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%9D%9E%E5%B8%B8%E6%8A%B1%E6%AD%89%E8%BF%99%E4%B9%88%E4%B9%85%E9%83%BD%E6%B2%A1%E8%83%BD%E5%9B%9E%E5%A4%8D%E8%BF%99%E4%B8%AA%E5%B8%96%E5%AD%90%E3%80%82%E8%BF%87%E5%8E%BB%E4%B8%80%E5%91%A8%EF%BC%8C%E6%88%91%E4%B8%80%E7%9B%B4%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%B9%8B%E5%89%8D%E7%9A%84%E6%96%B9%E6%B3%95%E2%80%94%E2%80%94%E5%9F%BA%E4%BA%8E%20C40%20%E5%85%83%E5%99%A8%E4%BB%B6%20%E8%BF%9B%E8%A1%8C%E5%BC%80%E5%8F%91%E3%80%82%E7%84%B6%E8%80%8C%EF%BC%8C%E6%88%91%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E6%88%90%E5%8A%9F%EF%BC%8C%E5%90%84%E7%A7%8D%E5%90%84%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E8%AE%A9%E6%88%91%E6%84%9F%E5%88%B0%E4%B8%8D%E7%9F%A5%E6%89%80%E6%8E%AA%EF%BC%8C%E5%A4%B1%E5%8E%BB%E4%BA%86%E7%BB%A7%E7%BB%AD%E6%B2%9F%E9%80%9A%E7%9A%84%E5%8A%A8%E5%8A%9B%E3%80%82%E5%91%A8%E6%9C%AB%E6%9C%9F%E9%97%B4%EF%BC%8C%E6%88%91%E4%BB%94%E7%BB%86%E8%80%83%E8%99%91%E4%BA%86%E4%B8%80%E4%B8%8B%EF%BC%8C%E5%86%B3%E5%AE%9A%E6%9A%82%E6%97%B6%E6%94%BE%E5%BC%83%E8%BF%99%E6%9D%A1%E8%B7%AF%E7%BA%BF%EF%BC%8C%E8%BD%AC%E8%80%8C%E4%BD%BF%E7%94%A8%20MCAL%20%E8%BF%9B%E8%A1%8C%E5%BC%80%E5%8F%91%E3%80%82%E8%BF%99%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E6%9B%B4%E5%A4%9A%E6%97%B6%E9%97%B4%EF%BC%8C%E4%BD%86%E6%88%91%E4%BC%9A%E5%86%B7%E9%9D%99%E4%B8%8B%E6%9D%A5%EF%BC%8C%E4%B8%80%E6%AD%A5%E4%B8%80%E6%AD%A5%E5%9C%B0%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E8%A1%B7%E5%BF%83%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E6%89%80%E6%9C%89%E5%BB%BA%E8%AE%AE%E5%92%8C%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
