Some issues encountered during Flash driver development on S32K344 under the RTD 4.0.0 environment
yunaidejiezi
Hi everyone,
I'm currently working on a Flash driver that runs in SRAM (specifically, in DTCM without cache enabled for convenience). I've run into some issues and would appreciate your insights.
Project background:
I have two projects: one includes the C40 driver, and the other (which I'll call fls_drv_demo) does not. My goal is to compile the driver in the C40-enabled project, place it at address 0x00500000 via the AT linker directive, and then in fls_drv_demo, use memcpy to copy it to the intended DTCM address. After that, I hardcode the function addresses and call them to observe Flash behavior changes for verification.
What I've done so far:
  • In the C40-enabled project, I placed all C40 IP-layer functions into the .ramcode section and collected them in the flash_driver section.
  • Custom functions for initialization and programming are placed in the .Fls_Api_Tab section, also collected into flash_driver.
  • Linker scripts have been modified accordingly.
The current problem:
In the fls_drv_demo project, when I call a function pointer—whether it's Fls_Init or a programming function like
((uint32_t (*)(const uint32_t, const uint8_t*, const uint32_t))(0x2000702C | 1))(0x00540000, flswritearray, 16);
—the execution always jumps to 0x00406764 after some internal IP-layer function completes.
Specifically:
  • Fls_Init executes successfully.
  • However, during the write function, after the internal C40_Ip_MainInterfaceSectorErase finishes and is about to return (pop), the PC pointer ends up at 0x00000000.
My suspicion:
I'm wondering whether some internal functions are still being compiled into .text or .mcal.text sections, causing the program to access the wrong stub area and leading to this behavior. Or is there some additional setup step I'm missing?
I'm completely stuck at this point and would really appreciate any suggestions or guidance.
Apologies if the phrasing is a bit off—this was translated with AI assistance. I've attached some screenshots of the project and the issue for reference.
Thanks in advance!
Linker file configuration in the C40 driver project
The .map file (function and stub region address allocation) generated after modifying the linker in the C40 driver project
The specific contents of the fls_drv_demo project
  1. When running the write function (at 0x2000702C), it goes into the internal RTD library function C40_Ip_MainInterfaceSectorErase (at 0x200074EC). At 0x20007502, it jumps to 0x20007B52, and then the PC points to the address stored at 0x20007B54, which is 0x00406764. Subsequently, when executing the pop instruction at 0x00406778, the value of r3 is as shown in the figure, pointing to 0x2001FFD8. 0x2001FFD8 then points to 0x20007BA8, and the value at 0x7BA8 is 0x00000000, causing the program to crash/run away.
danielmartynek
Hi @yunaidejiezi,
Based on the disassembly, you forgot to move the OsIf_SuspendAllInterrupts() function to DCTM, all the functions called by the C40_Ip driver must be in DCTM.
I would recommend using the Mem_43_InFls MCAL driver, which handles the copy-to-RAM automatically at runtime and avoids all of this manual dependency tracking.
BR, Daniel
yunaidejiezi
Hi, @danielmartynek
    Thank you for your reply.
    The disassembly at 0x00406764 is running in the fls_drv_demo project. The function it actually points to may not be OsIf_SuspendAllInterrupts() from the C40 driver project, but the instructions executed are indeed those for disabling interrupts. I think this function might have been inlined at compile time, since its address is not found in the .map file, so this factor may be irrelevant. Next, I will try to move the functions called internally by c40_ip into the .flash_driver section. In addition, regarding your suggestion to use the Mem_43_InFls MCAL driver, are there any reference examples of making a Flash driver with MCAL? Actually, I have never used MCAL at all.
danielmartynek
Hi @yunaidejiezi,
Yes, you need to place all the functions called from the C40_Ip to SRAM.
In the below example, I had to place functions from SchM_Mem_43_INFLS.h to SRAM too.
https://community.nxp.com/t5/S32K-Knowledge-Base/S32K312-C40-Ip-SRAM-RTD-500-DS35/ta-p/2074245
Yes, there is this example in RTD 4.0.0.
Mem_InFls_Example_S32K344
yunaidejiezi
Hi,@danielmartynek
I have opened two projects: Mem_InFls_Example_S32K344 and S32K312_C40_Ip_SRAM_RTD_500_DS35. Now I have discovered a very serious issue: it seems that the RTD version I imported does not contain the Mem_43_INFLS_Driver component. After opening Mem_InFls_Example_S32K344, I could not find Mem_43_INFLS_Driver in the MCAL layer. Also, in the S32K312_C40_Ip_SRAM_RTD_500_DS35 project, it appears that Mem_43_INFLS_Driver is not used (since I did not see any calls to Mem_FLs layer functions in main). However, the RTD folder in the Project Explorer does contain SchM_Mem_43_INFLS.c/.h. In the .map file, functions like SchM_Enter_Mem_43_INFLS_MEM_EXCLUSIVE_AREA_04 are also placed into the SRAM area.
I would like to know: when using C40, is SchM_Mem_43_INFLS.c/.h mandatory to be included? Does C40 internally call functions like SchM_Enter_Mem_43_INFLS_MEM_EXCLUSIVE_AREA_04?
There is no Mem_43_INFLS_Driver in the Mem_InFls_Example_S32K344 project
This is my RTD version
The RTD version of the Mem_InFls_Example_S32K344 project.
The RTD version of the S32K312_C40_Ip_SRAM_RTD_500_DS35 project
danielmartynek
Hi @yunaidejiezi,
This looks like a compatibility issue. I can see many different RTD versions in the screenshots you posted. Please use a single RTD version per S32DS IDE installation, and the IDE version should match the release notes of the RTD you want to use. You can have multiple S32DS IDE installations if you need to work with more RTD versions.
yunaidejiezi
Hi,@danielmartynek
It's possible that my description wasn't clear enough.
The reason multiple versions appear in the screenshots is that I have several projects open at the same time: FLs_drv_demo, Mem_InFls_Example_S32K344, and S32K312_C40_Ip_SRAM_RTD_500_DS35.
For the project I created, the RTD version is as shown in Figure 2 in the previous post: S32K3_RTD_4_0_0_P24_D2405_ASR_REL_4_4_REV_0000_20240515.
The versions of the two projects you recommended to me are:
  • S32K3_RTD_5_0_0_D2408_ASR_REL_4_7_REV_0000_20241002
  • S32K3_RTD_6_0_0_QLP04_D2508_ASR_REL_4_7_REV_0000_20250822
My question is: due to the RTD version differences, in the fls_drv_demo project, the Mem_43_INFLS_Driver component is not available in Mcal, and the file SchM_Mem_43_INFLS is not generated in my project. This is clearly shown in the project manager comparison between the two projects in the screenshots below.
Overall, my current RTD version likely does not support developing a flash driver based on the Mem_43_INFLS_Driver. Therefore, I would like to know: for a project that uses the C40 component, is it mandatory to generate the following functions and place them in SRAM?
danielmartynek
Hi @yunaidejiezi,
Regardless of the RTD version you use, there must be an MCAL FLS driver in the Flash example added by default. If you do not see it there and it cannot be added, there is a problem with the IDE - probably because you have multiple RTD versions in a single IDE installation.
Yes, you also need the SchM_Mem_43_INFLS.h functions in SRAM.
BR, Daniel
yunaidejiezi
Hi,@danielmartynek
I apologize for the delayed reply.
What I can confirm is that I have never tried installing multiple versions of RTD simultaneously in the IDE. However, it seems that the MCAL FLS driver you mentioned does exist in my setup—just under a different name than Mem_43_INFLS_Driver, so I'm not entirely sure. I've placed it below for reference.
I would like to know whether this component is usable. It does appear to have a built-in feature for automatically placing code into the SRAM region.
danielmartynek
Hi @yunaidejiezi,
I see, thank you.
This is because the RTD releases are based on different AUTOSAR specifications.
AUTOSAR 4.4.0 uses the Fls driver, while AUTOSAR 4.7.0 (R21-11) uses Mem_43_INFLS.
The naming convention changed, but the functionality is very similar.
As you mentioned, there is also the option to Load Access Code On Job Start. The Configuration Tool layout is different - the SRAM address configuration is located on a different tab, but otherwise the configuration is equivalent.
yunaidejiezi
Hi,@danielmartynek
   I'm very sorry for not replying to this thread for so long. Over the past week, I've been trying the previous approach—developing based on the C40 component. However, I still couldn't make it work, and all sorts of issues left me overwhelmed and without the motivation to continue communicating. Over the weekend, I thought it over and decided to temporarily abandon this route and switch to developing with MCAL instead. This might take a lot more time, but I will calm down and focus on solving the problems step by step. I would like to express my most sincere gratitude to you for all the advice and help you have provided.
danielmartynek
Hi @yunaidejiezi,
Thanks for the feedback, sorry to hear about the issues. If you have any problems with the MCAL driver, let me know.
%3CLINGO-SUB%20id%3D%22lingo-sub-2408020%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESome%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environment%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408020%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EHi%20everyone%2C%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EI'm%20currently%20working%20on%20a%20Flash%20driver%20that%20runs%20in%20SRAM%20(specifically%2C%20in%20DTCM%20without%20cache%20enabled%20for%20convenience).%20I've%20run%20into%20some%20issues%20and%20would%20appreciate%20your%20insights.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EProject%20background%3A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EI%20have%20two%20projects%3A%20one%20includes%20the%20C40%20driver%2C%20and%20the%20other%20(which%20I'll%20call%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efls_drv_demo%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E)%20does%20not.%20My%20goal%20is%20to%20compile%20the%20driver%20in%20the%20C40-enabled%20project%2C%20place%20it%20at%20address%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E0x00500000%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20via%20the%20AT%20linker%20directive%2C%20and%20then%20in%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efls_drv_demo%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%2C%20use%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ememcpy%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20to%20copy%20it%20to%20the%20intended%20DTCM%20address.%20After%20that%2C%20I%20hardcode%20the%20function%20addresses%20and%20call%20them%20to%20observe%20Flash%20behavior%20changes%20for%20verification.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EWhat%20I've%20done%20so%20far%3A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CUL%3E%3CLI%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EIn%20the%20C40-enabled%20project%2C%20I%20placed%20all%20C40%20IP-layer%20functions%20into%20the%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E.ramcode%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20section%20and%20collected%20them%20in%20the%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eflash_driver%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20section.%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3ECustom%20functions%20for%20initialization%20and%20programming%20are%20placed%20in%20the%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E.Fls_Api_Tab%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20section%2C%20also%20collected%20into%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eflash_driver%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3ELinker%20scripts%20have%20been%20modified%20accordingly.%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EThe%20current%20problem%3A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EIn%20the%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Efls_drv_demo%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20project%2C%20when%20I%20call%20a%20function%20pointer%E2%80%94whether%20it's%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3EFls_Init%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20or%20a%20programming%20function%20like%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E((uint32_t%20(*)(const%20uint32_t%2C%20const%20uint8_t*%2C%20const%20uint32_t))(0x2000702C%20%7C%201))(0x00540000%2C%20flswritearray%2C%2016)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E2%80%94the%20execution%20always%20jumps%20to%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E0x00406764%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20after%20some%20internal%20IP-layer%20function%20completes.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3ESpecifically%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CUL%3E%3CLI%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EFls_Init%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20executes%20successfully.%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EHowever%2C%20during%20the%20write%20function%2C%20after%20the%20internal%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3EC40_Ip_MainInterfaceSectorErase%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20finishes%20and%20is%20about%20to%20return%20(pop)%2C%20the%20PC%20pointer%20ends%20up%20at%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E0x00000000%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EMy%20suspicion%3A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EI'm%20wondering%20whether%20some%20internal%20functions%20are%20still%20being%20compiled%20into%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E.text%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20or%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E.mcal.text%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20sections%2C%20causing%20the%20program%20to%20access%20the%20wrong%20stub%20area%20and%20leading%20to%20this%20behavior.%20Or%20is%20there%20some%20additional%20setup%20step%20I'm%20missing%3F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EI'm%20completely%20stuck%20at%20this%20point%20and%20would%20really%20appreciate%20any%20suggestions%20or%20guidance.%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EApologies%20if%20the%20phrasing%20is%20a%20bit%20off%E2%80%94this%20was%20translated%20with%20%3CSPAN%20class%3D%22%22%3EAI%3C%2FSPAN%3E%20assistance.%20I've%20attached%20some%20screenshots%20of%20the%20project%20and%20the%20issue%20for%20reference.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EThanks%20in%20advance!%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3ELinker%20file%20configuration%20in%20the%20C40%20driver%20project%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-102549.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395232i8853457E9AEA0A04%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-102549.jpg%22%20alt%3D%2220260825-102549.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-102549.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-102549.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-102549.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-102549.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-102549.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-102549.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-102549.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-102549.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-102549.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EThe%20.map%20file%20(function%20and%20stub%20region%20address%20allocation)%20generated%20after%20modifying%20the%20linker%20in%20the%20C40%20driver%20project%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103800.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395234i9C29C191FA62A7C5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-103800.jpg%22%20alt%3D%2220260825-103800.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103800.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103800.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103800.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103800.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103800.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103800.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103800.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103800.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103800.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103746.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395233i5CFD496A3E0E16B5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-103746.jpg%22%20alt%3D%2220260825-103746.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103746.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103746.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103746.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103746.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103746.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103746.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103746.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103746.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103746.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EThe%20specific%20contents%20of%20the%20%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3Efls_drv_demo%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%20project%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-103909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395235iF5C24491A4CA040D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-103909.jpg%22%20alt%3D%2220260825-103909.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-103909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3COL%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3EWhen%20running%20the%20write%20function%20(at%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x2000702C%3CSPAN%20class%3D%22%22%3E)%2C%20it%20goes%20into%20the%20internal%20RTD%20library%20function%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3EC40_Ip_MainInterfaceSectorErase%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E(at%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x200074EC%3CSPAN%20class%3D%22%22%3E).%20At%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x20007502%3CSPAN%20class%3D%22%22%3E%2C%20it%20jumps%20to%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x20007B52%3CSPAN%20class%3D%22%22%3E%2C%20and%20then%20the%20PC%20points%20to%20the%20address%20stored%20at%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x20007B54%3CSPAN%20class%3D%22%22%3E%2C%20which%20is%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x00406764%3CSPAN%20class%3D%22%22%3E.%20Subsequently%2C%20when%20executing%20the%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3Epop%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Einstruction%20at%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x00406778%3CSPAN%20class%3D%22%22%3E%2C%20the%20value%20of%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3Er3%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eis%20as%20shown%20in%20the%20figure%2C%20pointing%20to%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x2001FFD8%3CSPAN%20class%3D%22%22%3E.%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x2001FFD8%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Ethen%20points%20to%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x20007BA8%3CSPAN%20class%3D%22%22%3E%2C%20and%20the%20value%20at%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x7BA8%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eis%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x00000000%3CSPAN%20class%3D%22%22%3E%2C%20causing%20the%20program%20to%20crash%2Frun%20away.%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-105216.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395237iEA3CD36C200913B5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-105216.jpg%22%20alt%3D%2220260825-105216.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-105216.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-105216.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-105216.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-105216.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-105216.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-105216.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-105216.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-105216.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-105216.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110659.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395242i9A77CD55E3A7EBE1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-110659.jpg%22%20alt%3D%2220260825-110659.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110659.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110659.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110659.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110659.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110659.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110659.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110659.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110659.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110659.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110639.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395250i6C7F0355D381B360%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-110639.jpg%22%20alt%3D%2220260825-110639.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110639.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110639.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110639.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110639.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110639.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110639.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110639.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110639.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110639.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-110710.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395252iF0548463526388C9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-110710.jpg%22%20alt%3D%2220260825-110710.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110710.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110710.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110710.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110710.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110710.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110710.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110710.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110710.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-110710.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395255iF3D5C827D6B6F885%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%221.jpg%22%20alt%3D%221.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395261iFA993FAF64AD8E0E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%222.jpg%22%20alt%3D%222.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-111431.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395269i06F652FA6AD96C46%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-111431.jpg%22%20alt%3D%2220260825-111431.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-111431.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-111431.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-111431.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-111431.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-111431.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-111431.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-111431.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-111431.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-111431.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130859.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395270i3F2E52DBA22584FB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-130859.jpg%22%20alt%3D%2220260825-130859.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130859.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130859.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130859.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130859.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130859.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130859.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130859.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130859.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130859.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260825-130909.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395271i122AC644E35B55AE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260825-130909.jpg%22%20alt%3D%2220260825-130909.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260825-130909.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408416%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408416%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259229%22%20target%3D%22_blank%22%3E%40yunaidejiezi%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EYes%2C%20you%20need%20to%20place%20all%20the%20functions%20called%20from%20the%20C40_Ip%20to%20SRAM.%3C%2FP%3E%0A%3CP%3EIn%20the%20below%20example%2C%20I%20had%20to%20place%20functions%20from%26nbsp%3BSchM_Mem_43_INFLS.h%20to%20SRAM%20too.%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K312-C40-Ip-SRAM-RTD-500-DS35%2Fta-p%2F2074245%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K312-C40-Ip-SRAM-RTD-500-DS35%2Fta-p%2F2074245%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EYes%2C%20there%20is%20this%20example%20in%20RTD%204.0.0.%3C%2FP%3E%0A%3CP%3EMem_InFls_Example_S32K344%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1787734274169.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395357i3F22BF2545A81C85%2Fimage-dimensions%2F536x468%3Fv%3Dv2%22%20width%3D%22536%22%20height%3D%22468%22%20role%3D%22button%22%20title%3D%22danielmartynek_0-1787734274169.png%22%20alt%3D%22danielmartynek_0-1787734274169.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1787734274169.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1787734274169.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1787734274169.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1787734274169.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1787734274169.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1787734274169.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1787734274169.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1787734274169.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1787734274169.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F160001%22%20target%3D%22_blank%22%3E%40danielmartynek%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3E%26nbsp%3B%20%26nbsp%3B%20Thank%20you%20for%20your%20reply.%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20The%20disassembly%20at%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E0x00406764%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eis%20running%20in%20the%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3Efls_drv_demo%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eproject.%20The%20function%20it%20actually%20points%20to%20may%20not%20be%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3EOsIf_SuspendAllInterrupts()%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Efrom%20the%20C40%20driver%20project%2C%20but%20the%20instructions%20executed%20are%20indeed%20those%20for%20disabling%20interrupts.%20I%20think%20this%20function%20might%20have%20been%20inlined%20at%20compile%20time%2C%20since%20its%20address%20is%20not%20found%20in%20the%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E.map%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Efile%2C%20so%20this%20factor%20may%20be%20irrelevant.%20Next%2C%20I%20will%20try%20to%20move%20the%20functions%20called%20internally%20by%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3Ec40_ip%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Einto%20the%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E.flash_driver%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Esection.%20In%20addition%2C%20regarding%20your%20suggestion%20to%20use%20the%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3EMem_43_InFls%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EMCAL%20driver%2C%20are%20there%20any%20reference%20examples%20of%20making%20a%20Flash%20driver%20with%20MCAL%3F%20Actually%2C%20I%20have%20never%20used%20MCAL%20at%20all.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259229%22%20target%3D%22_blank%22%3E%40yunaidejiezi%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EBased%20on%20the%20disassembly%2C%20you%20forgot%20to%20move%20the%26nbsp%3BOsIf_SuspendAllInterrupts()%20function%20to%20DCTM%2C%20all%20the%20functions%20called%20by%20the%20C40_Ip%20driver%20must%20be%20in%20DCTM.%3C%2FP%3E%0A%3CP%3EI%20would%20recommend%20using%20the%20Mem_43_InFls%20MCAL%20driver%2C%20which%20handles%20the%20copy-to-RAM%20automatically%20at%20runtime%20and%20avoids%20all%20of%20this%20manual%20dependency%20tracking.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%2C%20Daniel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408700%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408700%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259229%22%20target%3D%22_blank%22%3E%40yunaidejiezi%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThis%20looks%20like%20a%20compatibility%20issue.%20I%20can%20see%20many%20different%20RTD%20versions%20in%20the%20screenshots%20you%20posted.%20Please%20use%20a%20single%20RTD%20version%20per%20S32DS%20IDE%20installation%2C%20and%20the%20IDE%20version%20should%20match%20the%20release%20notes%20of%20the%20RTD%20you%20want%20to%20use.%20You%20can%20have%20multiple%20S32DS%20IDE%20installations%20if%20you%20need%20to%20work%20with%20more%20RTD%20versions.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F160001%22%20target%3D%22_blank%22%3E%40danielmartynek%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EIt's%20possible%20that%20my%20description%20wasn't%20clear%20enough.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22%22%3EThe%20reason%20multiple%20versions%20appear%20in%20the%20screenshots%20is%20that%20I%20have%20several%20projects%20open%20at%20the%20same%20time%3A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EFLs_drv_demo%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%2C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EMem_InFls_Example_S32K344%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%2C%20and%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3ES32K312_C40_Ip_SRAM_RTD_500_DS35%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EFor%20the%20project%20I%20created%2C%20the%20RTD%20version%20is%20as%20shown%20in%20Figure%202%20in%20the%20previous%20post%3A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3ES32K3_RTD_4_0_0_P24_D2405_ASR_REL_4_4_REV_0000_20240515%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EThe%20versions%20of%20the%20two%20projects%20you%20recommended%20to%20me%20are%3A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3ES32K3_RTD_5_0_0_D2408_ASR_REL_4_7_REV_0000_20241002%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3ES32K3_RTD_6_0_0_QLP04_D2508_ASR_REL_4_7_REV_0000_20250822%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EMy%20question%20is%3A%20due%20to%20the%20RTD%20version%20differences%2C%20in%20the%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3Efls_drv_demo%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eproject%2C%20the%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EMem_43_INFLS_Driver%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Ecomponent%20is%20not%20available%20in%20Mcal%2C%20and%20the%20file%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3ESchM_Mem_43_INFLS%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eis%20not%20generated%20in%20my%20project.%20This%20is%20clearly%20shown%20in%20the%20project%20manager%20comparison%20between%20the%20two%20projects%20in%20the%20screenshots%20below.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260827-163404.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163404.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163404.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163404.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163404.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163404.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163404.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163404.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395421i22637569AC28DE11%2Fimage-size%2Fsmall%3Fv%3Dv2%26amp%3Bpx%3D200%22%20role%3D%22button%22%20title%3D%2220260827-163404.jpg%22%20alt%3D%2220260827-163404.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163404.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163404.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163404.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163404.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163404.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163404.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163404.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260827-163400.jpg%22%20style%3D%22width%3A%20191px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163400.jpg%22%20style%3D%22width%3A%20191px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163400.jpg%22%20style%3D%22width%3A%20191px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163400.jpg%22%20style%3D%22width%3A%20191px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163400.jpg%22%20style%3D%22width%3A%20191px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163400.jpg%22%20style%3D%22width%3A%20191px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163400.jpg%22%20style%3D%22width%3A%20191px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163400.jpg%22%20style%3D%22width%3A%20191px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395422i7E398F025F0EBF23%2Fimage-size%2Fsmall%3Fv%3Dv2%26amp%3Bpx%3D200%22%20role%3D%22button%22%20title%3D%2220260827-163400.jpg%22%20alt%3D%2220260827-163400.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163400.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163400.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163400.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163400.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163400.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163400.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163400.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EOverall%2C%20my%20current%20RTD%20version%20likely%20does%20not%20support%20developing%20a%20flash%20driver%20based%20on%20the%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EMem_43_INFLS_Driver%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E.%20Therefore%2C%20I%20would%20like%20to%20know%3A%20for%20a%20project%20that%20uses%20the%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EC40%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Ecomponent%2C%20is%20it%20mandatory%20to%20generate%20the%20following%20functions%20and%20place%20them%20in%20SRAM%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260827-163521.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163521.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163521.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163521.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163521.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163521.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163521.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-163521.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395423i2364C029419E1E2E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260827-163521.jpg%22%20alt%3D%2220260827-163521.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163521.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163521.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163521.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163521.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163521.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163521.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-163521.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F160001%22%20target%3D%22_blank%22%3E%40danielmartynek%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EThank%20you%20for%20your%20reply.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EI%20have%20opened%20two%20projects%3A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3EMem_InFls_Example_S32K344%3C%2FSPAN%3E%3C%2FEM%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eand%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3ES32K312_C40_Ip_SRAM_RTD_500_DS35%3C%2FSPAN%3E%3C%2FEM%3E%3CSPAN%20class%3D%22%22%3E.%20Now%20I%20have%20discovered%20a%20very%20serious%20issue%3A%20it%20seems%20that%20the%20RTD%20version%20I%20imported%20does%20not%20contain%20the%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3EMem_43_INFLS_Driver%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Ecomponent.%20After%20opening%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3EMem_InFls_Example_S32K344%3C%2FSPAN%3E%3C%2FEM%3E%3CSPAN%20class%3D%22%22%3E%2C%20I%20could%20not%20find%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3EMem_43_INFLS_Driver%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Ein%20the%20MCAL%20layer.%20Also%2C%20in%20the%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CEM%3E%3CSPAN%20class%3D%22%22%3ES32K312_C40_Ip_SRAM_RTD_500_DS35%3C%2FSPAN%3E%3C%2FEM%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eproject%2C%20it%20appears%20that%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3EMem_43_INFLS_Driver%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eis%20not%20used%20(since%20I%20did%20not%20see%20any%20calls%20to%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3EMem_FLs%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Elayer%20functions%20in%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3Emain%3CSPAN%20class%3D%22%22%3E).%20However%2C%20the%20RTD%20folder%20in%20the%20Project%20Explorer%20does%20contain%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3ESchM_Mem_43_INFLS.c%2F.h%3CSPAN%20class%3D%22%22%3E.%20In%20the%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E.map%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Efile%2C%20functions%20like%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3ESchM_Enter_Mem_43_INFLS_MEM_EXCLUSIVE_AREA_04%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Eare%20also%20placed%20into%20the%20SRAM%20area.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EI%20would%20like%20to%20know%3A%20when%20using%20C40%2C%20is%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3ESchM_Mem_43_INFLS.c%2F.h%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Emandatory%20to%20be%20included%3F%20Does%20C40%20internally%20call%20functions%20like%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3ESchM_Enter_Mem_43_INFLS_MEM_EXCLUSIVE_AREA_04%3CSPAN%20class%3D%22%22%3E%3F%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260827-102145.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102145.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102145.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102145.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102145.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102145.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102145.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395398i79613B917A6F1E02%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260827-102145.jpg%22%20alt%3D%2220260827-102145.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102145.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102145.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102145.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102145.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102145.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102145.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EThere%20is%20no%20Mem_43_INFLS_Driver%20in%20the%20Mem_InFls_Example_S32K344%20project%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260827-102152.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102152.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102152.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102152.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102152.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102152.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102152.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395399i03DDCBE7167830FA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260827-102152.jpg%22%20alt%3D%2220260827-102152.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102152.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102152.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102152.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102152.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102152.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102152.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EThis%20is%20my%20RTD%20version%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260827-102157.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102157.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102157.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102157.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102157.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102157.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-102157.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395400iBE0AD1930765F2C0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260827-102157.jpg%22%20alt%3D%2220260827-102157.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102157.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102157.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102157.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102157.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102157.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-102157.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3EThe%20RTD%20version%20of%20the%20Mem_InFls_Example_S32K344%20project.%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260827-103214.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-103214.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-103214.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-103214.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-103214.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-103214.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260827-103214.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395401i6DE76D9BC34C8476%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%2220260827-103214.jpg%22%20alt%3D%2220260827-103214.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-103214.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-103214.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-103214.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-103214.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-103214.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260827-103214.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3EThe%20RTD%20version%20of%20the%20S32K312_C40_Ip_SRAM_RTD_500_DS35%20project%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259229%22%20target%3D%22_blank%22%3E%40yunaidejiezi%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3ERegardless%20of%20the%20RTD%20version%20you%20use%2C%20there%20must%20be%20an%20MCAL%20FLS%20driver%20in%20the%20Flash%20example%20added%20by%20default.%20If%20you%20do%20not%20see%20it%20there%20and%20it%20cannot%20be%20added%2C%20there%20is%20a%20problem%20with%20the%20IDE%20-%20probably%20because%20you%20have%20multiple%20RTD%20versions%20in%20a%20single%20IDE%20installation.%3C%2FP%3E%0A%3CP%3EYes%2C%20you%20also%20need%20the%20SchM_Mem_43_INFLS.h%20functions%20in%20SRAM.%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K312-C40-Ip-SRAM-RTD-500-DS35%2Fta-p%2F2074245%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K312-C40-Ip-SRAM-RTD-500-DS35%2Fta-p%2F2074245%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%2C%20Daniel%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2409043%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2409043%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F160001%22%20target%3D%22_blank%22%3E%40danielmartynek%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EI%20apologize%20for%20the%20delayed%20reply.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EWhat%20I%20can%20confirm%20is%20that%20I%20have%20never%20tried%20installing%20multiple%20versions%20of%20RTD%20simultaneously%20in%20the%20IDE.%20However%2C%20it%20seems%20that%20the%20MCAL%20FLS%20driver%20you%20mentioned%20does%20exist%20in%20my%20setup%E2%80%94just%20under%20a%20different%20name%20than%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3EMem_43_INFLS_Driver%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%20class%3D%22%22%3E%2C%20so%20I'm%20not%20entirely%20sure.%20I've%20placed%20it%20below%20for%20reference.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260828-095254.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260828-095254.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260828-095254.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260828-095254.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260828-095254.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395475i3E771D05FB9BE72B%2Fimage-size%2Fsmall%3Fv%3Dv2%26amp%3Bpx%3D200%22%20role%3D%22button%22%20title%3D%2220260828-095254.jpg%22%20alt%3D%2220260828-095254.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260828-095254.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260828-095254.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260828-095254.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260828-095254.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260828-095249.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260828-095249.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260828-095249.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260828-095249.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260828-095249.jpg%22%20style%3D%22width%3A%20200px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395476iFF4064C20AE1BCEE%2Fimage-size%2Fsmall%3Fv%3Dv2%26amp%3Bpx%3D200%22%20role%3D%22button%22%20title%3D%2220260828-095249.jpg%22%20alt%3D%2220260828-095249.jpg%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260828-095249.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260828-095249.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260828-095249.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260828-095249.jpg%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EI%20would%20like%20to%20know%20whether%20this%20component%20is%20usable.%20It%20does%20appear%20to%20have%20a%20built-in%20feature%20for%20automatically%20placing%20code%20into%20the%20SRAM%20region.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2409097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2409097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259229%22%20target%3D%22_blank%22%3E%40yunaidejiezi%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EI%20see%2C%20thank%20you.%3C%2FP%3E%0A%3CP%3EThis%20is%20because%20the%20RTD%20releases%20are%20based%20on%20different%20AUTOSAR%20specifications.%3C%2FP%3E%0A%3CP%3EAUTOSAR%204.4.0%20uses%20the%20Fls%20driver%2C%20while%20AUTOSAR%204.7.0%20(R21-11)%20uses%20Mem_43_INFLS.%3C%2FP%3E%0A%3CP%3EThe%20naming%20convention%20changed%2C%20but%20the%20functionality%20is%20very%20similar.%3C%2FP%3E%0A%3CP%3EAs%20you%20mentioned%2C%20there%20is%20also%20the%20option%20to%20Load%20Access%20Code%20On%20Job%20Start.%26nbsp%3BThe%20Configuration%20Tool%20layout%20is%20different%20-%20the%20SRAM%20address%20configuration%20is%20located%20on%20a%20different%20tab%2C%20but%20otherwise%20the%20configuration%20is%20equivalent.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411884%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411884%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259229%22%20target%3D%22_blank%22%3E%40yunaidejiezi%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%20the%20feedback%2C%20sorry%20to%20hear%20about%20the%20issues.%20If%20you%20have%20any%20problems%20with%20the%20MCAL%20driver%2C%20let%20me%20know.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411797%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Some%20issues%20encountered%20during%20Flash%20driver%20development%20on%20S32K344%20under%20the%20RTD%204.0.0%20environme%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411797%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F160001%22%20target%3D%22_blank%22%3E%40danielmartynek%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3BI'm%20very%20sorry%20for%20not%20replying%20to%20this%20thread%20for%20so%20long.%20Over%20the%20past%20week%2C%20I've%20been%20trying%20the%20previous%20approach%E2%80%94developing%20based%20on%20the%20C40%20component.%20However%2C%20I%20still%20couldn't%20make%20it%20work%2C%20and%20all%20sorts%20of%20issues%20left%20me%20overwhelmed%20and%20without%20the%20motivation%20to%20continue%20communicating.%20Over%20the%20weekend%2C%20I%20thought%20it%20over%20and%20decided%20to%20temporarily%20abandon%20this%20route%20and%20switch%20to%20developing%20with%20MCAL%20instead.%20This%20might%20take%20a%20lot%20more%20time%2C%20but%20I%20will%20calm%20down%20and%20focus%20on%20solving%20the%20problems%20step%20by%20step.%20I%20would%20like%20to%20express%20my%20most%20sincere%20gratitude%20to%20you%20for%20all%20the%20advice%20and%20help%20you%20have%20provided.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
