[Security] D-Flash CSE driver encryption/decryption interface limitations
4,912 次查看
Gideon
Dear NXPs:
Bootloader- D-Flash-32K
Are there any restrictions if I call CSEC_DRV_EncryptCBC/CSEC_DRV_DecryptCBC interfaces of the CSEc driver on D-Flash?
4,628 次查看
lukaszadrapa
I haven't met this use-case yet but I can see in the manual that you are right. It explicitly says:
 If your code is running from data flash, solution is to put the function to RAM memory.
5 回复数
4,876 次查看
lukaszadrapa
Hi @Gideon
If we are talking about CSEc commands CMD_ENC_CBC and CMD_DEC_CBC, there are no limitations because it is up to software to load plain/encrypted data to CSEc via PRAM interface and then read encrypted/plain data from PRAM. So, software can read the data from anywhere. Mentioned SDK function do not check the addresses, so it can read the data from whole memory map. Just the output buffer needs to be in RAM, of course, so the driver can write the result to the buffer.
Lukas
4,770 次查看
Gideon
Dear lukaszadrapa:
@lukaszadrapa
NXP S32K142 executes CSEC_CMD_ENC_CBC command in D-Flash, but PUBWEAK HardFault_Handler occurs
SECTION .text:CODE:REORDER:NOROOT(1)
HardFault_Handler
B. Error. There is no problem with IAR Debug single-step execution, but the above HardFault will occur when F5 is executed at full speed, which is very strange.
4,744 次查看
lukaszadrapa
Hi @Gideon
not sure what's going on.
First step - did you try to disable interrupts? Second step - you can try to find out what is the reason of the fault exactly:
https://community.nxp.com/t5/S32K-Knowledge-Base/Fault-handling-on-S32K14x/ta-p/1114447
https://www.nxp.com/docs/en/application-note/AN12201.pdf
Lukas
4,685 次查看
Gideon
Dear lukaszadrapa:
@lukaszadrapa
A1:Disabling interrupts has no effect.The interface I use is
INT_SYS_DisableIRQGlobal();
INT_SYS_EnableIRQGlobal();
A2: IBUSSERR
By the way Viewed the manual S32K-RM.pdf Table 37-7. Allowed simultaneous memory operations,
There are limitations in operating CSE PRAM on D-Flash,Could IBUSSERR be related to this?
4,629 次查看
lukaszadrapa
%3CLINGO-SUB%20id%3D%22lingo-sub-1848763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5B%E5%AE%89%E5%85%A8%5D%20D-Flash%20CSE%20%E9%A9%B1%E5%8A%A8%E5%8A%A0%E5%AF%86%2F%E8%A7%A3%E5%AF%86%E6%8E%A5%E5%8F%A3%E9%99%90%E5%88%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1848763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20NXPs%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F-D-Flash-32K%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%9C%A8D-Flash%E4%B8%8A%E8%B0%83%E7%94%A8CSEc%E9%A9%B1%E5%8A%A8%E7%9A%84CSEC_DRV_EncryptCBC%2FCSEC_DRV_DecryptCBC%E6%8E%A5%E5%8F%A3%E6%9C%89%E4%BB%80%E4%B9%88%E9%99%90%E5%88%B6%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1866056%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%5B%E5%AE%89%E5%85%A8%5D%20D-Flash%20CSE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%8A%A0%E5%AF%86%2F%E8%A7%A3%E5%AF%86%E6%8E%A5%E5%8F%A3%E9%99%90%E5%88%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1866056%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E8%BF%98%E6%B2%A1%E6%9C%89%E9%81%87%E5%88%B0%E8%BF%87%E8%BF%99%E4%B8%AA%E7%94%A8%E4%BE%8B%EF%BC%8C%E4%BD%86%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BB%8E%E6%89%8B%E5%86%8C%E4%B8%AD%E7%9C%8B%E5%88%B0%E4%BD%A0%E6%98%AF%E5%AF%B9%E7%9A%84%E3%80%82%E5%AE%83%E6%98%8E%E7%A1%AE%E6%8C%87%E5%87%BA%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_0-1715759187636.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1715759187636.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F278855iB81FB27914B2065C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_0-1715759187636.png%22%20alt%3D%22lukaszadrapa_0-1715759187636.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Elukaszadrapa_0-1715759187636.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E7%9A%84%E4%BB%A3%E7%A0%81%E4%BB%8E%E6%95%B0%E6%8D%AE%E9%97%AA%E5%AD%98%E8%BF%90%E8%A1%8C%EF%BC%8C%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E6%98%AF%E5%B0%86%E5%87%BD%E6%95%B0%E6%94%BE%E5%85%A5%20RAM%20%E5%86%85%E5%AD%98%E4%B8%AD%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1863445%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%5B%E5%AE%89%E5%85%A8%5D%20D-Flash%20CSE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%8A%A0%E5%AF%86%2F%E8%A7%A3%E5%AF%86%E6%8E%A5%E5%8F%A3%E9%99%90%E5%88%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1863445%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EDear%20lukaszadrapa%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37795%22%20target%3D%22_blank%22%3E%40lukaszadrapa%3C%2FA%3E%3C%2FP%3E%3CP%3EA1%EF%BC%9A%3CSPAN%3E%E7%A6%81%E7%94%A8%E4%B8%AD%E6%96%AD%E6%B2%A1%E6%9C%89%E6%95%88%E6%9E%9C%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%8E%A5%E5%8F%A3%E6%98%AF%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3EINT_SYS_DisableIRQGlobal%3C%2FSPAN%3E%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3EINT_SYS_EnableIRQGlobal%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%88%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EA2%3A%20IBUSSERR%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CBR%20%2F%3E%3CP%3E%E9%A1%BA%E4%BE%BF%E6%9F%A5%E7%9C%8B%E4%BA%86%E6%89%8B%E5%86%8CS32K-RM.pdf%E8%A1%A837-7%E3%80%82%E5%85%81%E8%AE%B8%E5%90%8C%E6%97%B6%E8%BF%9B%E8%A1%8C%E5%86%85%E5%AD%98%E6%93%8D%E4%BD%9C%EF%BC%8C%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%9C%A8%20D-Flash%20%E4%B8%8A%E8%BF%90%E8%A1%8C%20CSE%20PRAM%20%E5%AD%98%E5%9C%A8%E9%99%90%E5%88%B6%EF%BC%8C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EIBUSSERR%20%E6%98%AF%E5%90%A6%E4%B8%8E%E6%AD%A4%E6%9C%89%E5%85%B3%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Gideon_1-1715340768594.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Gideon_1-1715340768594.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F278229i1B574313A6D13877%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Gideon_1-1715340768594.png%22%20alt%3D%22Gideon_1-1715340768594.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EGideon_1-1715340768594.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1858751%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%5B%E5%AE%89%E5%85%A8%5D%20D-Flash%20CSE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%8A%A0%E5%AF%86%2F%E8%A7%A3%E5%AF%86%E6%8E%A5%E5%8F%A3%E9%99%90%E5%88%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1858751%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F218898%22%20target%3D%22_blank%22%3E%40Gideon%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E4%B8%8D%E7%A1%AE%E5%AE%9A%E5%8F%91%E7%94%9F%E4%BA%86%E4%BB%80%E4%B9%88%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%AC%AC%E4%B8%80%E6%AD%A5%20-%20%E6%82%A8%E6%98%AF%E5%90%A6%E5%B0%9D%E8%AF%95%E8%BF%87%E7%A6%81%E7%94%A8%E4%B8%AD%E6%96%AD%EF%BC%9F%E7%AC%AC%E4%BA%8C%E6%AD%A5%20-%20%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E6%89%BE%E5%87%BA%E6%95%85%E9%9A%9C%E7%9A%84%E7%A1%AE%E5%88%87%E5%8E%9F%E5%9B%A0%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FFault-handling-on-S32K14x%2Fta-p%2F1114447%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FFault-handling-on-S32K14x%2Fta-p%2F1114447%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12201.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12201.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1850844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%5B%E5%AE%89%E5%85%A8%5D%20D-Flash%20CSE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%8A%A0%E5%AF%86%2F%E8%A7%A3%E5%AF%86%E6%8E%A5%E5%8F%A3%E9%99%90%E5%88%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1850844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F218898%22%20target%3D%22_blank%22%3E%40Gideon%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E4%BB%AC%E8%B0%88%E8%AE%BA%E7%9A%84%E6%98%AF%20CSEc%20%E5%91%BD%E4%BB%A4%20CMD_ENC_CBC%20%E5%92%8C%20CMD_DEC_CBC%EF%BC%8C%E5%88%99%E6%B2%A1%E6%9C%89%E9%99%90%E5%88%B6%EF%BC%8C%E5%9B%A0%E4%B8%BA%E7%94%B1%E8%BD%AF%E4%BB%B6%E9%80%9A%E8%BF%87%20PRAM%20%E6%8E%A5%E5%8F%A3%E5%B0%86%E7%BA%AF%E6%96%87%E6%9C%AC%2F%E5%8A%A0%E5%AF%86%E6%95%B0%E6%8D%AE%E5%8A%A0%E8%BD%BD%E5%88%B0%20CSEc%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BB%8E%20PRAM%20%E8%AF%BB%E5%8F%96%E5%8A%A0%E5%AF%86%2F%E7%BA%AF%E6%96%87%E6%9C%AC%E6%95%B0%E6%8D%AE%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E8%BD%AF%E4%BB%B6%E5%8F%AF%E4%BB%A5%E4%BB%8E%E4%BB%BB%E4%BD%95%E5%9C%B0%E6%96%B9%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%E3%80%82%E6%8F%90%E5%88%B0%E7%9A%84%20SDK%20%E5%87%BD%E6%95%B0%E4%B8%8D%E6%A3%80%E6%9F%A5%E5%9C%B0%E5%9D%80%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%AE%83%E5%8F%AF%E4%BB%A5%E4%BB%8E%E6%95%B4%E4%B8%AA%E5%86%85%E5%AD%98%E6%98%A0%E5%B0%84%E4%B8%AD%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%E3%80%82%E5%BD%93%E7%84%B6%EF%BC%8C%E5%8F%AA%E9%9C%80%E8%A6%81%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA%E4%BD%8D%E4%BA%8E%20RAM%20%E4%B8%AD%EF%BC%8C%E8%BF%99%E6%A0%B7%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B0%B1%E5%8F%AF%E4%BB%A5%E5%B0%86%E7%BB%93%E6%9E%9C%E5%86%99%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E
