Scrubbing ECC RAM
Scrubbing ECC RAM
durga_choudhury
Contributor V
MCU: S32K148
Driver: RTD 3.0.0
OS: Bare metal
With the above MCU, is there a way of 'scrubbing' the ECC SRAM? 'Scrubbing' means that if a correctable error is detected, the SRAM cell is updated with the correct value if the user configures some appropriate registers. Some competing products such as TI Hercules have this feature.
Tags (2)
davidtosenovjan
S32K1 devices do not support a hardware SRAM scrubbing mechanism that would automatically write corrected data back to memory after a correctable ECC event. A software-based implementation is also not feasible, as single-bit SRAM ECC correction events are not reported by the ERM, so the application cannot identify the affected memory location.
While the S32K3 family also does not provide automatic SRAM scrubbing, it does report single-bit ECC events, which gives the application visibility into these errors and enables implementation of more advanced fault-handling strategies.
davidtosenovjan
durga_choudhury
Contributor V
Thank you very much for the feedback.
%3CLINGO-SUB%20id%3D%22lingo-sub-2403508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EScrubbing%20ECC%20RAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2403508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMCU%3A%20S32K148%3C%2FP%3E%3CP%3EDriver%3A%20RTD%203.0.0%3C%2FP%3E%3CP%3EOS%3A%20Bare%20metal%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EWith%20the%20above%20MCU%2C%20is%20there%20a%20way%20of%20'scrubbing'%20the%20ECC%20SRAM%3F%20'Scrubbing'%20means%20that%20if%20a%20correctable%20error%20is%20detected%2C%20the%20SRAM%20cell%20is%20updated%20with%20the%20correct%20value%20if%20the%20user%20configures%20some%20appropriate%20registers.%20Some%20competing%20products%20such%20as%20TI%20Hercules%20have%20this%20feature.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2403700%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Scrubbing%20ECC%20RAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2403700%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThank%20you%20very%20much%20for%20the%20feedback.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2403570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Scrubbing%20ECC%20RAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2403570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ES32K1%20devices%20do%20not%20support%20a%20hardware%20SRAM%20scrubbing%20mechanism%20that%20would%20automatically%20write%20corrected%20data%20back%20to%20memory%20after%20a%20correctable%20ECC%20event.%20A%20software-based%20implementation%20is%20also%20not%20feasible%2C%20as%20single-bit%20SRAM%20ECC%20correction%20events%20are%20not%20reported%20by%20the%20ERM%2C%20so%20the%20application%20cannot%20identify%20the%20affected%20memory%20location.%3C%2FP%3E%0A%3CP%3EWhile%20the%20S32K3%20family%20also%20does%20not%20provide%20automatic%20SRAM%20scrubbing%2C%20it%20does%20report%20single-bit%20ECC%20events%2C%20which%20gives%20the%20application%20visibility%20into%20these%20errors%20and%20enables%20implementation%20of%20more%20advanced%20fault-handling%20strategies.%3C%2FP%3E%3C%2FLINGO-BODY%3E
