S32kx interrupt routing config disabled
Dev15
Hello Team,
I'm trying to configure pwm module and build the project. The build is getting failed due to below
/main/main.c:112:5: error: implicit declaration of function 'IntCtrl_Ip_ConfigIrqRouting' [-Werror=implicit-function-declaration]
112 | IntCtrl_Ip_ConfigIrqRouting(&IntCtrlConfig_0);
SDK used is 3.0.0
Please help to resolve it
Robin_Shen
Function 'IntCtrl_Ip_ConfigIrqRouting' does not exist in RTD3.0.0, please call IntCtrl_Ip_Init.
Robin
Dev15
hi @Robin_Shen ,
Thank you for your response.
We are already calling IntCtrl_Ip_Init(), but the ISR is not getting invoked. We are trying to test UART and PWM modules through ISR.
Please guide us here
Thank you
Robin_Shen
Dev15
hi @Robin_Shen ,
The file is not available to download from the link.
Please share the project if you have it.
Thank you
Dev15
@Senlent , Can please clarify on this interrupt configuration ?
Thank you
