S32k312 UART Reception using interrupt
kamleshv
I need to implement interrupt-based UART reception on the S32K312. Please find the attached code for your reference. My goal is to receive incoming data byte by byte and assemble it to form the complete response received on the UART channel.
However, the UART receive callback is triggered only once (the first time) and does not trigger for subsequent data receptions.
Thank you.
Julián_AragónM
Hi @kamleshv,
After finishing the reception, you must call Lpuart_Uart_Ip_AsyncReceive() again to prepare for next reception. You can use the following community example as reference: [RTD600 IP] S32K312-EVB Lpuart interrupt echo - NXP Community.
Julián
%3CLINGO-SUB%20id%3D%22lingo-sub-2198196%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32k312%20UART%20Reception%20using%20interrupt%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198196%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI%20need%20to%20implement%20interrupt-based%20UART%20reception%20on%20the%20S32K312.%20Please%20find%20the%20attached%20code%20for%20your%20reference.%20My%20goal%20is%20to%20receive%20incoming%20data%20%3CSTRONG%3Ebyte%20by%20byte%3C%2FSTRONG%3E%20and%20assemble%20it%20to%20form%20the%20complete%20response%20received%20on%20the%20UART%20channel.%3C%2FP%3E%3CP%3EHowever%2C%20the%20%3CSTRONG%3EUART%20receive%20callback%20is%20triggered%20only%20once%3C%2FSTRONG%3E%20(the%20first%20time)%20and%20does%20not%20trigger%20for%20subsequent%20data%20receptions.%3C%2FP%3E%3CP%3EThank%20you.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32k312%20UART%20Reception%20using%20interrupt%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195950%22%20target%3D%22_blank%22%3E%40kamleshv%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EAfter%20finishing%20the%20reception%2C%20you%20must%20call%20Lpuart_Uart_Ip_AsyncReceive()%20again%20to%20prepare%20for%20next%20reception.%20You%20can%20use%20the%20following%20community%20example%20as%20reference%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FRTD600-IP-S32K312-EVB-Lpuart-interrupt-echo%2Fta-p%2F2141060%22%20target%3D%22_blank%22%3E%5BRTD600%20IP%5D%20S32K312-EVB%20Lpuart%20interrupt%20echo%20-%20NXP%20Community%3C%2FA%3E.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EJuli%C3%A1n%3C%2FP%3E%3C%2FLINGO-BODY%3E
