Missing compiler S32 Studio
873件の閲覧回数
Greavesinator85
I can't find a compiler in S32 Studio 3.6.4 for S32K3x8 EVB.
arm-none-eabi-gcc "@board/Siul2_Port_Ip_Cfg.args" -MMD -MP -MF"board/Siul2_Port_Ip_Cfg.d" -MT"board/Siul2_Port_Ip_Cfg.o" -o "board/Siul2_Port_Ip_Cfg.o" "../board/Siul2_Port_Ip_Cfg.c"
make: *** [generate/src/subdir.mk:26: generate/src/Igf_Port_Ip_Cfg.o] Error 127
/bin/sh: line 1: arm-none-eabi-gcc: command not found
make: *** [generate/src/subdir.mk:26: generate/src/OsIf_Cfg.o] Error 127
make: *** [board/subdir.mk:23: board/Tspc_Port_Ip_Cfg.o] Error 127
make: *** [board/subdir.mk:23: board/Siul2_Port_Ip_Cfg.o] Error 127
846件の閲覧回数
Julián_AragónM
Hi @Greavesinator85,
Which RTD version are you using? It seems that the toolchain is not selected within your project.
Does this happen with example projects as well? When creating the project, have you selected the "Create new S32DS application project" option?
You can try manually adding the toolchain path to your project properties, however, I suggest creating a new project to avoid any other configuration issues related to this.
Julián
%3CLINGO-SUB%20id%3D%22lingo-sub-2198426%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9S32%20Studio%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198426%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ES32%20Studio%203.6.4%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93S32K3x8%20EVB%E7%94%A8%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc%20%22%40board%2FSiul2_Port_Ip_Cfg.args%22-MMD%20-MP%20-MF%22%E3%83%9C%E3%83%BC%E3%83%89%2FSiul2_Port_Ip_Cfg.d%22-MT%22%E3%83%9C%E3%83%BC%E3%83%89%2FSiul2_Port_Ip_Cfg.o%22-o%20%22%E3%83%9C%E3%83%BC%E3%83%89%2FSiul2_Port_Ip_Cfg.o%22%E3%80%8C..%2Fboard%2FSiul2_Port_Ip_Cfg.c%E3%80%8D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%A1%E3%82%A4%E3%82%AF%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A26%3A%20generate%2Fsrc%2FIgf_Port_Ip_Cfg.o%5D%E3%82%A8%E3%83%A9%E3%83%BC127%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2Fbin%2Fsh%3A%20%E8%A1%8C%201%3A%20arm-none-eabi-gcc%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%A1%E3%82%A4%E3%82%AF%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A26%3A%20generate%2Fsrc%2FOsIf_Cfg.o%5D%E3%82%A8%E3%83%A9%E3%83%BC127%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2Fbin%2Fsh%3A%20%E8%A1%8C%201%3A%20arm-none-eabi-gcc%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%A1%E3%82%A4%E3%82%AF%3A%20***%20%5Bboard%2Fsubdir.mk%3A23%3A%E3%83%9C%E3%83%BC%E3%83%89%2FTspc_Port_Ip_Cfg.o%5D%20%E3%82%A8%E3%83%A9%E3%83%BC127%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2Fbin%2Fsh%3A%20%E8%A1%8C%201%3A%20arm-none-eabi-gcc%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%A1%E3%82%A4%E3%82%AF%3A%20***%20%5Bboard%2Fsubdir.mk%3A23%3A%E3%83%9C%E3%83%BC%E3%83%89%2FSiul2_Port_Ip_Cfg.o%5D%20%E3%82%A8%E3%83%A9%E3%83%BC127%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Missing%20compiler%20S32%20Studio%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198552%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256454%22%20target%3D%22_blank%22%3E%40Greavesinator85%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%A9%E3%81%AE%20RTD%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E5%86%85%E3%81%A7%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%82%82%E5%90%8C%E6%A7%98%E3%81%AE%E7%8F%BE%E8%B1%A1%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81%E3%80%8C%E6%96%B0%E3%81%97%E3%81%84%20S32DS%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%80%8D%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%20%E3%83%91%E3%82%B9%E3%82%92%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%AB%E6%89%8B%E5%8B%95%E3%81%A7%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82CAN%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%9B%9E%E9%81%BF%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%82%B8%E3%83%A5%E3%83%AA%E3%82%A2%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E
