S32k311 Bootloader
S32k311 Bootloader
1,137件の閲覧回数
kiran5
Hi Team,
I am trying to configure Bootloader jump to application in s32k311 MCU but not able to configure it.
Can you please support on this.
Kiran
3 返答(返信)
1,106件の閲覧回数
Senlent
Hi@kiran5
You can take a look at this post:
https://community.nxp.com/t5/S32K-Knowledge-Base/Unified-bootloader-Demo/ta-p/1423099
You can refer to this sample code to learn how to jump from the bootloader to the application.
1,077件の閲覧回数
kiran5
Hi Senlent,
Thanks for Providing the Reference code, but the issue is still not solved.
Please take a look at the code which we are using.
Application Linker File:
Bootloader Linker File:
The Jump to application code used is as per the s32k312 code.
 When i run in Debug mode it is going to Default handler in the bootloader code.
If i add VTOR relocation SCB->VTOR = (0x0044A200 ); then it is not going to default handler, but still Jump to application is not happening.
I have used the offset as per s32k312. Can you please let me know if the offset for s32k311 is different as i am not able to get the information.
Kiran
1,050件の閲覧回数
Senlent
Hi@kiran5
I created a simple example program, based on the S32K311EVB,the RTD version is RTD 6.0.0 P04.
The bootloader program will toggle a red LED 10 times, then jump to the app program, where
the app program will continuously flash a blue LED.
%3CLINGO-SUB%20id%3D%22lingo-sub-2206685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32k311%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2206685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%81%E3%83%BC%E3%83%A0%3C%2FP%3E%3CP%3Es32k311%20MCU%20%E3%81%A7%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%92%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AD%E3%83%A9%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E
