S32k3
3,749件の閲覧回数
luyq
  I had tested the S32K344'wakeup function,and the external I/O can wake up from standby,but the Rtc-API can't .I think there may be a problem with the configuration,so i want the S32k344's RTC wakeup project,could you help me?
thanks.
3,733件の閲覧回数
luyq
Hello
  Thanks your reply.I have found the problem that it is some register not be enable.
4 返答(返信)
3,744件の閲覧回数
danielmartynek
Hello @luyq,
There is no RTC-API Wakeup example yet.
Can you please share your project so that we can test it?
If you don't want to share it here, you can create a ticket.
3,729件の閲覧回数
luyq
Please send your email, I will send the email to you conveniently.
3,731件の閲覧回数
luyq
Besides, I found that sometimes I can wake up, sometimes not.I will send you the project,please check it for me.Thanks very much.
3,734件の閲覧回数
luyq
Hello
