S32M244LC high-voltage detect threshold
YAN3
     I have a question about high voltage threshold Settings,S32M244LC‘s GDU will be closed when VSUP over 22.6V,Where can I set this value(such as set to 28V),No description of this section is found in the RM &datasheet.
     thanks
PavelL
Hi Yan,
there is a possibility to set bit HDHVDCFG to 1 , in GDU/CFG register (S32M24x RM rev2, page 1165).  With this bit set, thresholds VHVHDHA and VHVHDHD will be used for overvoltage detector. Thresholds VHVHDHA (min-typ-max: 30.65-32.5-34.6V) and VHVHDHD (min-typ-max: 29.65-31.5-33.6V) are defined in S32M2xx DS rev3, page 38/39
Pavel
PavelL
Hi Yan,
Pavel
YAN3
hi Pavel,
   Thank you and regards,
%3CLINGO-SUB%20id%3D%22lingo-sub-1945802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32M244LC%20high-voltage%20detect%20threshold%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1945802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BI%20have%20a%20question%20about%20high%20voltage%20threshold%20Settings%EF%BC%8CS32M244LC%E2%80%98s%20GDU%20will%20be%20closed%20when%20VSUP%20over%2022.6V%EF%BC%8CWhere%20can%20I%20set%20this%20value(such%20as%20set%20to%2028V)%EF%BC%8CNo%20description%20of%20this%20section%20is%20found%20in%20the%20RM%20%26amp%3Bdatasheet.%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bthanks%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1946718%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32M244LC%20high-voltage%20detect%20threshold%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1946718%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%26nbsp%3B%3CSPAN%3EPavel%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3EThank%20you%20and%20regards%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1946192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32M244LC%20high-voltage%20detect%20threshold%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1946192%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Yan%2C%3C%2FP%3E%0A%3CP%3Ethere%20is%20a%20possibility%20to%20set%20bit%26nbsp%3BHDHVDCFG%20to%201%20%2C%20in%20GDU%2FCFG%20register%20(S32M24x%20RM%20rev2%2C%20page%201165).%26nbsp%3B%20With%20this%20bit%20set%2C%20thresholds%20VHVHDHA%20and%20VHVHDHD%20will%20be%20used%20for%20overvoltage%20detector.%20Thresholds%20VHVHDHA%20(min-typ-max%3A%2030.65-32.5-34.6V)%20and%20VHVHDHD%20(min-typ-max%3A%2029.65-31.5-33.6V)%20are%20defined%20in%20S32M2xx%20DS%20rev3%2C%20page%2038%2F39%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E
