[S32K3XX] C40_Ip using for accessing Code flash memory patition
1,529件の閲覧回数
Changhawn
Hi.
I am developing flash access using C40_Ip api in bootloader.
Data memory partition(0x10000000) can be accessed by that API.
But code memory partition(0x500000 ~ 0x007FE000) can not be accessed.
Hard fault assert is happened.
C40_Ip API is located in SRAM like below.
Could you give me some guide or hint for this debugging?
Thank you in advance.
タグ(1)
1,509件の閲覧回数
Changhawn
Basic working is confirmed.
My access region is not wrong.
4 返答(返信)
1,510件の閲覧回数
Changhawn
1,503件の閲覧回数
Senlent
Hi@Changhawn
Is your problem solved?
I see that you have already set your answer as a solution.
1,500件の閲覧回数
Changhawn
Yes.
It's work normally
129件の閲覧回数
NXP开发者
I encountered the same problem as you. When writing to the PFLASH, a hardware fault occurred. Could you please tell me how you solved it?
タグ(1)
