S32K344MINI-EVB: FlexCAN_IP_Example_S32K344 and Can_Example_S32K344 Configuration Errors
Veereshh
Hello Community,
I am currently working with the S32K344MINI-EVB (FRDM Automotive Evaluation Board) and would like to gain hands-on experience with basic peripheral drivers before starting development on a custom project based on the NXP S32K3 family.
Development Environment
  • S32 Design Studio (S32DS) 3.5.8
  • SW32K3_S32M27x_RTD_R21-11_4.0.0_P19_D2403
  • EB tresos 29
Current Status
I successfully imported and ran the following example projects:
  • SIUL2_DIO_IP_Example_S32K344
  • Dio_Example_S32K344
For both AUTOSAR and Non-AUTOSAR configurations, the projects built successfully and produced the expected output on the S32K344MINI-EVB.
Issue
I then imported the following CAN example projects:
  • FlexCAN_IP_Example_S32K344
  • Can_Example_S32K344
While configuring and building these projects, I encountered the errors shown in the attached screenshot.
Request
Could anyone please advise:
  1. Are any board-specific modifications required for the S32K344MINI-EVB?
  2. Are there additional FlexCAN, clock, pin, or EB tresos configurations needed?
  3. Is there a guide for running these CAN examples on the MINI-EVB?
The attached screenshot shows the errors encountered during configuration/build.
Thank you for your support.
Veer
Julián_AragónM
Hello @Veereshh,
Pinout is fairly similar between S32K344 EVB and FRDM-A-S32K344 (formerly S32K344MINI).
1. No
2. Yes. Both FlexCAN_IP_Example_S32K344 & Can_Example_S32K344 projects only configure FlexCAN in "loopback" mode, meaning there are no pins configured, and FlexCAN_0 is listening to its own messages.
Inside the project's MEX, you must:
  • Change FlexCAN 'Loopback' to 'Normal/User mode'
  • Add Siul2_Port (or Port in MCAL), and configure both PTA6 & PTA7 (CAN_H CAN_L in FRDM-A-S32K344).
  • Add port initialization in your project.
FRDM-A-S32K344 also uses TJA1043 CAN transceiver, which must set CAN_EN & CAN_STB to HIGH in order to set the transceiver in normal operation. These are routed to PTC21 & PTC20, as stated in the FRDM's user manual:
These must be set to HIGH inside your project as well. You can use the following examples as reference: [RTD600 MCAL & IP] S32K3X4EVB-T172 FlexCAN Example Interrupt/Polling.
Keep in mind they are based on RTD 6.0.0, not RTD 4.0.0.
After setting this, you can use J15.1 CANH and J15.2 CANL connected to another CAN node (PCAN USB analyzer, another MCU, etc.) to test CAN communication. In the examples I've shared, PCAN-USB analyzer was used.
Julián
Veereshh
Hi @Julián_AragónM,
Thank you for the clarification and continued support.
Following your latest guidance, I:
  • Installed the FlexCAN interrupt handlers in the Platform interrupt configuration.
  • Removed the CanMainFunctionRWPeriods reference from CanHardwareObject > Can MainFunction RW Period Reference, as Interrupt mode is being used.
  • Regenerated the code and the configuration completed successfully without validation errors.
I also referred to the [RTD600 MCAL & IP] S32K3X4EVB-T172 FlexCAN Example Interrupt/Polling example that you shared and applied the equivalent settings to my RTD 4.0.0 P19 project.
However, after the configuration was successfully generated, I encountered the following build/linker errors:
Could you please advise whether any additional CanIf callback configuration or application-level implementation is required when enabling Interrupt mode in the AUTOSAR CAN example?
Veer
Veereshh
Hi Julian,
Thank you for your support. Your guidance helped me successfully resolve the original configuration issues and build the CAN example. I have shared the build steps and screenshots below for the benefit of other users facing the same issue.
I have one additional question. After successfully running the Loopback example, I configured CAN_EN (PTC21) and CAN_STB (PTC20) and then modified the CAN configuration as follows:
  • Disabled Can Loop Back Mode
  • Changed Can Rx Processing Type from Polling to Interrupt
After these changes, validation/build errors are generated.
Could you please advise if any additional FlexCAN, IntCtrl_Ip, NVIC, or RTD-specific settings are required when switching from Polling to Interrupt mode?
Thank you again for your continued support.
Steps to Build CAN Example Successfully
  1. Import Can_Example_S32K344 project.
  2. Open the .mex file.
  3. Enable Pins Tool if not already available.
  4. Rename Functional Group to PortContainer_0_VS_0.
  5. Configure:
    • CAN0_RX → PTA6
    • CAN0_TX → PTA7
  6. Add PORT module under MCAL.
  7. Configure PortPin settings and assign the required MSCR values.
  8. Update code and resolve validation errors.
  9. Generate code and build the project.
  10. Program the board and verify CAN Loopback communication.
Veer
Julián_AragónM
Hello
I'm glad the information has been helpful.
In order to operate FlexCAN through interrupts, you must install the interrupt handler:
Also, the error you are seeing is because when FlexCAN driver uses Polling mode, you must specify the CanMainFunctionRWPeriods for both read and write calls. If Interrupt mode is used, this container must be removed from "CanHardwareObjetc > Can MainFunction RW Period Reference"
Julián
%3CLINGO-SUB%20id%3D%22lingo-sub-2417505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K344MINI-EVB%3A%20FlexCAN_IP_Example_S32K344%20and%20Can_Example_S32K344%20Configuration%20Errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2417505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Community%2C%3C%2FP%3E%3CP%3EI%20am%20currently%20working%20with%20the%20%3CSTRONG%3ES32K344MINI-EVB%3C%2FSTRONG%3E%26nbsp%3B(FRDM%20Automotive%20Evaluation%20Board)%20and%20would%20like%20to%20gain%20hands-on%20experience%20with%20basic%20peripheral%20drivers%20before%20starting%20development%20on%20a%20custom%20project%20based%20on%20the%20%3CSTRONG%3ENXP%20S32K3%20family%3C%2FSTRONG%3E.%3C%2FP%3E%3CH3%20id%3D%22toc-hId-2056077555%22%20id%3D%22toc-hId-2056079635%22%20id%3D%22toc-hId-2056079635%22%20id%3D%22toc-hId-2056079635%22%3EDevelopment%20Environment%3C%2FH3%3E%3CUL%3E%3CLI%3ES32%20Design%20Studio%20(S32DS)%203.5.8%3C%2FLI%3E%3CLI%3ESW32K3_S32M27x_RTD_R21-11_4.0.0_P19_D2403%3C%2FLI%3E%3CLI%3EEB%20tresos%2029%3C%2FLI%3E%3C%2FUL%3E%3CH3%20id%3D%22toc-hId-248623092%22%20id%3D%22toc-hId-248625172%22%20id%3D%22toc-hId-248625172%22%20id%3D%22toc-hId-248625172%22%3ECurrent%20Status%3C%2FH3%3E%3CP%3EI%20successfully%20imported%20and%20ran%20the%20following%20example%20projects%3A%3C%2FP%3E%3CUL%3E%3CLI%3ESIUL2_DIO_IP_Example_S32K344%3C%2FLI%3E%3CLI%3EDio_Example_S32K344%3C%2FLI%3E%3C%2FUL%3E%3CP%3EFor%20both%20AUTOSAR%20and%20Non-AUTOSAR%20configurations%2C%20the%20projects%20built%20successfully%20and%20produced%20the%20expected%20output%20on%20the%20S32K344MINI-EVB.%3C%2FP%3E%3CH3%20id%3D%22toc-hId--1558831371%22%20id%3D%22toc-hId--1558829291%22%20id%3D%22toc-hId--1558829291%22%20id%3D%22toc-hId--1558829291%22%3EIssue%3C%2FH3%3E%3CP%3EI%20then%20imported%20the%20following%20CAN%20example%20projects%3A%3C%2FP%3E%3CUL%3E%3CLI%3EFlexCAN_IP_Example_S32K344%3C%2FLI%3E%3CLI%3ECan_Example_S32K344%3C%2FLI%3E%3C%2FUL%3E%3CP%3EWhile%20configuring%20and%20building%20these%20projects%2C%20I%20encountered%20the%20errors%20shown%20in%20the%20attached%20screenshot.%3C%2FP%3E%3CH3%20id%3D%22toc-hId-928681462%22%20id%3D%22toc-hId-928683542%22%20id%3D%22toc-hId-928683542%22%20id%3D%22toc-hId-928683542%22%3ERequest%3C%2FH3%3E%3CP%3ECould%20anyone%20please%20advise%3A%3C%2FP%3E%3CDIV%3E%3COL%3E%3CLI%3EAre%20any%20board-specific%20modifications%20required%20for%20the%20S32K344MINI-EVB%3F%3C%2FLI%3E%3CLI%3EAre%20there%20additional%20FlexCAN%2C%20clock%2C%20pin%2C%20or%20EB%20tresos%20configurations%20needed%3F%3C%2FLI%3E%3CLI%3EIs%20there%20a%20guide%20for%20running%20these%20CAN%20examples%20on%20the%20MINI-EVB%3F%3C%2FLI%3E%3C%2FOL%3E%3C%2FDIV%3E%3CP%3EThe%20attached%20screenshot%20shows%20the%20errors%20encountered%20during%20configuration%2Fbuild.%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20support.%3C%2FP%3E%3CP%3ERegards%2C%3CBR%20%2F%3E%3CSTRONG%3EVeer%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2417608%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344MINI-EVB%3A%20FlexCAN_IP_Example_S32K344%20and%20Can_Example_S32K344%20Configuration%20Errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2417608%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258635%22%20target%3D%22_blank%22%3E%40Veereshh%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EPinout%20is%20fairly%20similar%20between%20S32K344%20EVB%20and%20FRDM-A-S32K344%20(formerly%20S32K344MINI).%26nbsp%3B%3C%2FP%3E%0A%3CP%3E1.%20No%3C%2FP%3E%0A%3CP%3E2.%20Yes.%20Both%20FlexCAN_IP_Example_S32K344%20%26amp%3B%20Can_Example_S32K344%20projects%20only%20configure%20FlexCAN%20in%20%22loopback%22%20mode%2C%20meaning%20there%20are%20no%20pins%20configured%2C%20and%20FlexCAN_0%20is%20listening%20to%20its%20own%20messages.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EInside%20the%20project's%20MEX%2C%20you%20must%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3EChange%20FlexCAN%20'Loopback'%20to%20'Normal%2FUser%20mode'%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EAdd%20Siul2_Port%20(or%20Port%20in%20MCAL)%2C%20and%20configure%20both%20PTA6%20%26amp%3B%20PTA7%20(CAN_H%20CAN_L%20in%20FRDM-A-S32K344).%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3EAdd%20port%20initialization%20in%20your%20project.%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%3EFRDM-A-S32K344%20also%20uses%20TJA1043%20CAN%20transceiver%2C%20which%20must%20set%20CAN_EN%20%26amp%3B%20CAN_STB%20to%20HIGH%20in%20order%20to%20set%20the%20transceiver%20in%20normal%20operation.%20These%20are%20routed%20to%20PTC21%20%26amp%3B%20PTC20%2C%20as%20stated%20in%20the%20FRDM's%20user%20manual%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Julin_AragnM_0-1790804627123.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_0-1790804627123.png%22%20style%3D%22width%3A%20772px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_0-1790804627123.png%22%20style%3D%22width%3A%20772px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_0-1790804627123.png%22%20style%3D%22width%3A%20772px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397110iFAAAF94926CE7E3A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Julin_AragnM_0-1790804627123.png%22%20alt%3D%22Julin_AragnM_0-1790804627123.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThese%20must%20be%20set%20to%20HIGH%20inside%20your%20project%20as%20well.%20You%20can%20use%20the%20following%20examples%20as%20reference%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FRTD600-MCAL-amp-IP-S32K3X4EVB-T172-FlexCAN-Example-Interrupt%2Fta-p%2F2142069%22%20target%3D%22_blank%22%3E%5BRTD600%20MCAL%20%26amp%3B%20IP%5D%20S32K3X4EVB-T172%20FlexCAN%20Example%20Interrupt%2FPolling%3C%2FA%3E.%3C%2FP%3E%0A%3CP%3EKeep%20in%20mind%20they%20are%20based%20on%20RTD%206.0.0%2C%20not%20RTD%204.0.0.%3C%2FP%3E%0A%3CP%3EAfter%20setting%20this%2C%20you%20can%20use%26nbsp%3BJ15.1%20CANH%20and%20J15.2%20CANL%20connected%20to%20another%20CAN%20node%20(PCAN%20USB%20analyzer%2C%20another%20MCU%2C%20etc.)%20to%20test%20CAN%20communication.%20In%20the%20examples%20I've%20shared%2C%20PCAN-USB%20analyzer%20was%20used.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EJuli%C3%A1n%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2417877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344MINI-EVB%3A%20FlexCAN_IP_Example_S32K344%20and%20Can_Example_S32K344%20Configuration%20Errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2417877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI'm%20glad%20the%20information%20has%20been%20helpful.%3C%2FP%3E%0A%3CP%3EIn%20order%20to%20operate%20FlexCAN%20through%20interrupts%2C%20you%20must%20install%20the%20interrupt%20handler%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Julin_AragnM_2-1790873249024.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_2-1790873249024.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_2-1790873249024.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397170i1B4281A441128D24%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Julin_AragnM_2-1790873249024.png%22%20alt%3D%22Julin_AragnM_2-1790873249024.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EAlso%2C%20the%20error%20you%20are%20seeing%20is%20because%20when%20FlexCAN%20driver%20uses%20Polling%20mode%2C%20you%20must%20specify%20the%20CanMainFunctionRWPeriods%20for%20both%20read%20and%20write%20calls.%20If%20Interrupt%20mode%20is%20used%2C%20this%20container%20must%20be%20removed%20from%20%22CanHardwareObjetc%20%26gt%3B%20Can%20MainFunction%20RW%20Period%20Reference%22%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Julin_AragnM_3-1790873263975.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_3-1790873263975.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_3-1790873263975.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397171i5F2F71562E5FC175%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Julin_AragnM_3-1790873263975.png%22%20alt%3D%22Julin_AragnM_3-1790873263975.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EJuli%C3%A1n%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2417853%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344MINI-EVB%3A%20FlexCAN_IP_Example_S32K344%20and%20Can_Example_S32K344%20Configuration%20Errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2417853%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Julian%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you%20for%20your%20support.%20Your%20guidance%20helped%20me%20successfully%20resolve%20the%20original%20configuration%20issues%20and%20build%20the%20CAN%20example.%20I%20have%20shared%20the%20build%20steps%20and%20screenshots%20below%20for%20the%20benefit%20of%20other%20users%20facing%20the%20same%20issue.%3C%2FP%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3EI%20have%20one%20additional%20question.%20After%20successfully%20running%20the%20Loopback%20example%2C%20I%20configured%20%3CSTRONG%3ECAN_EN%20(PTC21)%3C%2FSTRONG%3E%20and%20%3CSTRONG%3ECAN_STB%20(PTC20)%3C%2FSTRONG%3E%20and%20then%20modified%20the%20CAN%20configuration%20as%20follows%3A%3C%2FP%3E%3CUL%3E%3CLI%3EDisabled%20%3CSTRONG%3ECan%20Loop%20Back%20Mode%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3EChanged%20%3CSTRONG%3ECan%20Rx%20Processing%20Type%3C%2FSTRONG%3E%20from%20%3CSTRONG%3EPolling%3C%2FSTRONG%3E%20to%20%3CSTRONG%3EInterrupt%3C%2FSTRONG%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EAfter%20these%20changes%2C%20validation%2Fbuild%20errors%20are%20generated.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Veereshh_11-1790862778793.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Veereshh_11-1790862778793.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397164i3516B52B8DE5D475%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Veereshh_11-1790862778793.png%22%20alt%3D%22Veereshh_11-1790862778793.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Veereshh_0-1790862453855.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Veereshh_0-1790862453855.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397153iC073069D664C970F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Veereshh_0-1790862453855.png%22%20alt%3D%22Veereshh_0-1790862453855.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3ECould%20you%20please%20advise%20if%20any%20additional%20FlexCAN%2C%20IntCtrl_Ip%2C%20NVIC%2C%20or%20RTD-specific%20settings%20are%20required%20when%20switching%20from%20Polling%20to%20Interrupt%20mode%3F%3C%2FP%3E%3CP%3EThank%20you%20again%20for%20your%20continued%20support.%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3E%3CH3%20id%3D%22toc-hId-2056080591%22%20id%3D%22toc-hId--878770921%22%3ESteps%20to%20Build%20CAN%20Example%20Successfully%3C%2FH3%3E%3COL%3E%3CLI%3EImport%20%3CSTRONG%3ECan_Example_S32K344%3C%2FSTRONG%3E%20project.%3C%2FLI%3E%3CLI%3EOpen%20the%20.mex%20file.%3C%2FLI%3E%3CLI%3EEnable%20%3CSTRONG%3EPins%20Tool%3C%2FSTRONG%3E%20if%20not%20already%20available.%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Veereshh_2-1790863062579.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Veereshh_2-1790863062579.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397167iB32D66BF44D23384%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Veereshh_2-1790863062579.png%22%20alt%3D%22Veereshh_2-1790863062579.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLI%3E%3CLI%3ERename%20Functional%20Group%20to%20%3CSTRONG%3EPortContainer_0_VS_0%3C%2FSTRONG%3E.%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Veereshh_1-1790863039288.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Veereshh_1-1790863039288.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397166i4A463208A69F4C83%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Veereshh_1-1790863039288.png%22%20alt%3D%22Veereshh_1-1790863039288.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Veereshh_3-1790862581274.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Veereshh_3-1790862581274.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397156i0B2DFFFCA57FD131%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Veereshh_3-1790862581274.png%22%20alt%3D%22Veereshh_3-1790862581274.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FLI%3E%3CLI%3EConfigure%3A%3CUL%3E%3CLI%3ECAN0_RX%20%E2%86%92%20PTA6%3C%2FLI%3E%3CLI%3ECAN0_TX%20%E2%86%92%20PTA7%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Veereshh_5-1790862609099.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Veereshh_5-1790862609099.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397158i2894C3731519CF93%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Veereshh_5-1790862609099.png%22%20alt%3D%22Veereshh_5-1790862609099.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3EAdd%20%3CSTRONG%3EPORT%3C%2FSTRONG%3E%20module%20under%20MCAL.%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Veereshh_8-1790862684481.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Veereshh_8-1790862684481.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397161iFBEB01B7E87E2385%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Veereshh_8-1790862684481.png%22%20alt%3D%22Veereshh_8-1790862684481.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FLI%3E%3CLI%3EConfigure%20PortPin%20settings%20and%20assign%20the%20required%20MSCR%20values.%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Veereshh_9-1790862726874.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Veereshh_9-1790862726874.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397162iC7E4795E06271B49%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Veereshh_9-1790862726874.png%22%20alt%3D%22Veereshh_9-1790862726874.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FLI%3E%3CLI%3EUpdate%20code%20and%20resolve%20validation%20errors.%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Veereshh_10-1790862736318.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Veereshh_10-1790862736318.png%22%20style%3D%22width%3A%20291px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397163i94301BEFEF5EFEA3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Veereshh_10-1790862736318.png%22%20alt%3D%22Veereshh_10-1790862736318.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FLI%3E%3CLI%3EGenerate%20code%20and%20build%20the%20project.%3C%2FLI%3E%3CLI%3EProgram%20the%20board%20and%20verify%20CAN%20Loopback%20communication.%3C%2FLI%3E%3C%2FOL%3E%3CBR%20%2F%3E%3CP%3EBest%20regards%2C%3CBR%20%2F%3EVeer%3C%2FP%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
