MWCT2016 HSE 2.40.0 Secure Boot Configuration Failure- ImportPlainSymKeyReqMuChannel
107件の閲覧回数
ShrikantM
Environment
  • MCU: MWCT2016S based Wireless Charging Controller
  • Working Setup (Legacy):
    • HSE FW Version: 2.6.0
    • (Application + Secure Boot) merge hex.
  • New Setup (Failing):
    • HSE FW Version: 2.40.0
We are migrating from HSE FW v2.6.0 to HSE FW v2.40.0 while maintaining the same Qi key provisioning and Secure Boot flow.
Problem Statement
With HSE FW v2.6.0, the complete provisioning sequence executes successfully:
  1. HSE installation
  2. Erase Keys
  3. S2TP key slot provisioning
  4. Qi key programming
  5. Secure Boot configuration
  6. Application boots successfully
With HSE FW v2.40.0, all provisioning steps complete successfully until Secure Boot configuration is started.
During Secure Boot configuration the following API fails:
ImportPlainSymKeyReqMuChannel() in secure boot code.
return HSE response: 0x55A5A399 which corresponds to:
#define HSE_SRV_RSP_INVALID_PARAM ((hseSrvResponse_t)0x55A5A399UL)
After this failure, Secure Boot configuration cannot be completed, and the ECU remains stuck in the Secure Boot code.
Provisioning Sequence
Working Configuration (HSE 2.6.0)
00_Blank_MWCT2016_CodeFlash_DataFlash.hex
Power Reset
01_HSE_flash.srec  version 2.6.0
Power Reset
02_EraseKeysSW.hex
Power Reset
03_S2TP_KeySlotsAligned.srec  S2TP SW Version: 1.1.1
Power Reset
Write Qi Keys via UART
Power Reset
Application+SecureBoot.hex
Power Reset
HSE response after merge hex flashing from UART log:
 HseStatus : 2848
        bit 0   : 0 RFU
        bit 1   : 0 HSE_SHE_STATUS_SECURE_BOOT
        bit 2   : 0 HSE_SHE_STATUS_SECURE_BOOT_INIT
        bit 3   : 0 HSE_SHE_STATUS_SECURE_BOOT_FINISHED
        bit 4   : 0 HSE_SHE_STATUS_SECURE_BOOT_OK
        bit 5   : 1 HSE_STATUS_RNG_INIT_OK
        bit 6   : 0 HSE_STATUS_HOST_DEBUGGER_ACTIVE
        bit 7   : 0 HSE_STATUS_HSE_DEBUGGER_ACTIVE
        bit 8   : 1 HSE_STATUS_INIT_OK
        bit 9   : 1 HSE_STATUS_INSTALL_OK
        bit 10  : 0 HSE_STATUS_BOOT_OK
        bit 11  : 1 HSE_STATUS_CUST_SUPER_USER
        bit 12  : 0 HSE_STATUS_OEM_SUPER_USER
        bit 13  : 0 HSE_STATUS_FW_UPDATE_IN_PROGRESS
        bit 14  : 0 RFU
        bit 15  : 0 RFU
 smrCoreStatus_Get :
 smrCoreStatus[1] : 0 , smrCoreStatus[0] : 0
 smrStatus[1] : 0 , smrStatus[0] : 0
Code debug log HSE response:
 ImportPlainSymKeyReqMuChannel-hseResp: 0x55a5aa33
 LoadBootMacKey-hseResp: 0x55a5aa33
 Generic_ImportKeys-hseResp: 0x55a5aa33
 KeyProvisioningForJTAG-status: 1
 SecureBootConfiguration-hseResp: 0x55a5aa33
 KeyProvisioningToHseNVM-status: 1
 NON_SECURE_IVT-BLOCK1-hseResp: 0x55a5aa33
 SECURE_IVT-BLOCK0-hseResp: 0x55a5aa33
 writeDefaultData
 Running Secure Boot CFG program
 Hse-FW Version : 0.13.0.2.6.0 , full mem
 using interface version : 0.13.0.2.6.0
 HseStatus : 2862
        bit 0   : 0 RFU
        bit 1   : 1 HSE_SHE_STATUS_SECURE_BOOT
        bit 2   : 1 HSE_SHE_STATUS_SECURE_BOOT_INIT
        bit 3   : 1 HSE_SHE_STATUS_SECURE_BOOT_FINISHED
        bit 14  : 0 RFU
        bit 15  : 0 RFU
 smrCoreStatus_Get :
 smrStatus[1] : 1 , smrStatus[0] : 1
Failing Configuration-HSE FW 2.40.0 reports:
Power Reset
01_S32K344_HSE_FW_UPDATE_v2_40_0.srec
Power Reset
02_M210WLCUMBCD00A_WSB00.31_EraseKeySW_UART_ENABLE.hex
Power Reset
03_S2TP_2_1_0_KeySlotsAligned.srec
Power Reset
Power Reset
Power Reset
 HseStatus : 2912
        bit 0   : 0 RFU
        bit 6   : 1 HSE_STATUS_HOST_DEBUGGER_ACTIVE
        bit 14  : 0 RFU
        bit 15  : 0 RFU
 smrCoreStatus_Get :
ImportPlainSymKeyReqMuChannel-hseResp: 0x55A5A399
after Power reset:
 UML SW Version : WSB00.3B_UART_ENABLE
 Hse-FW Version : 0.13.0.2.40.0 , full mem
 using interface version : 0.13.0.2.40.0
 HseStatus : 2848
        bit 0   : 0 RFU
        bit 14  : 0 RFU
        bit 15  : 0 RFU
 smrCoreStatus_Get :
 ImportPlainSymKeyReqMuChannel-hseResp: 0x55a5a399
ECU getting stuck in secure boot only
2 返答(返信)
75件の閲覧回数
VaneB
Hi @ShrikantM
Could you please share your key catalogs as well as the parameters used in the ImportPlainSymKeyReqMuChannel() function call? The reported error indicates that one or more HSE request parameters are invalid.
BR, VaneB
16件の閲覧回数
SwapnilGawade
Hi @VaneB ,
We are using below key catalogs:
/* Table containing NVM key catalog entries */
const hseKeyGroupCfgEntry_t aHseNvmKeyCatalog[] =
    /* NvmKeyGroup_0 */
    {(HSE_MU0_MASK), HSE_KEY_OWNER_CUST, HSE_KEY_TYPE_SHE, 1U, 128U, {0U, 0U}},
    /* NvmKeyGroup_1 */
    {(HSE_MU0_MASK), HSE_KEY_OWNER_CUST, HSE_KEY_TYPE_ECC_PAIR, 1U, 256U, {0U, 0U}},
    /* NvmKeyGroup_2 */
    {(HSE_MU0_MASK), HSE_KEY_OWNER_CUST, HSE_KEY_TYPE_AES, 1U, 256U, {0U, 0U}},
    /* Marker to end the key catalog */
    {0U, 0U, 0U, 0U, 0U, {0U, 0U}}
/* Table containing RAM key catalog entries */
const hseKeyGroupCfgEntry_t aHseRamKeyCatalog[] =
    /* RamKeyGroup_0 */
For below function we receive HSE_SRV_RSP_INVALID_PARAM
hseSrvResponse_t Generic_ImportKeys(void)
    hseSrvResponse_t srvResponse = HSE_SRV_RSP_GENERAL_ERROR;
    /*Import key linked with SMR#0*/
    srvResponse = ImportPlainSymKeyReqMuChannel(
            MU0,
            1U,
            NVM_AES128_BOOT_KEY,
            HSE_KEY_TYPE_AES,
            ( HSE_KF_USAGE_VERIFY ),
            0U,
            aesEcbKeyLength,
            aesEcbKey,
            TRUE
    ASSERT(HSE_SRV_RSP_OK == srvResponse );
    if(HSE_SRV_RSP_OK != srvResponse)
            goto exit;
    /* load keys for SHE secure boot */
    srvResponse = LoadBootMacKey();
            goto exit;
exit:
    return srvResponse;
Please check attached global_defs.h for more details about the parameters.
Thanks and Regards,
Swapnil Gawade
タグ(1)
%3CLINGO-SUB%20id%3D%22lingo-sub-2416358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMWCT2016%20HSE%202.40.0%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E6%A7%8B%E6%88%90%E3%82%A8%E3%83%A9%E3%83%BC%20-%20ImportPlainSymKeyReqMuChannel%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2416358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH2%20id%3D%22toc-hId--441969937%22%20id%3D%22toc-hId--441968980%22%3E%E7%92%B0%E5%A2%83%3C%2FH2%3E%3CUL%3E%3CLI%3EMCU%3AMWCT2016S%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%AF%E3%82%A4%E3%83%A4%E3%83%AC%E3%82%B9%E5%85%85%E9%9B%BB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E5%8B%95%E4%BD%9C%E7%92%B0%E5%A2%83%E8%A8%AD%E5%AE%9A%EF%BC%88%E5%BE%93%E6%9D%A5%E5%9E%8B%EF%BC%89%3C%2FSTRONG%3E%20%EF%BC%9A%3CUL%3E%3CLI%3EHSE%20FW%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%202.6.0%3C%2FLI%3E%3CLI%3E(%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2B%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88)16%E9%80%B2%E3%82%92%E3%83%9E%E3%83%BC%E3%82%B8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E6%96%B0%E8%A6%8F%E8%A8%AD%E5%AE%9A%EF%BC%88%E5%A4%B1%E6%95%97%EF%BC%89%3C%2FSTRONG%3E%20%3A%3CUL%3E%3CLI%3EHSE%20FW%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%202.40.0%3C%2FLI%3E%3CLI%3E(%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2B%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88)16%E9%80%B2%E3%82%92%E3%83%9E%E3%83%BC%E3%82%B8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EQi%E3%82%AD%E3%83%BC%E3%81%AE%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%A8%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%81%AE%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AF%E3%81%9D%E3%81%AE%E3%81%BE%E3%81%BE%E7%B6%AD%E6%8C%81%E3%81%97%E3%81%A4%E3%81%A4%E3%80%81HSE%20FW%20v2.6.0%E3%81%8B%E3%82%89HSE%20FW%20v2.40.0%E3%81%B8%E3%81%AE%E7%A7%BB%E8%A1%8C%E3%82%92%E9%80%B2%E3%82%81%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%3E%3CH2%20id%3D%22toc-hId-2045542896%22%20id%3D%22toc-hId-2045543853%22%3E%E5%95%8F%E9%A1%8C%E6%8F%90%E8%B5%B7%3C%2FH2%3E%3CP%3EHSE%20FW%20v2.6.0%E3%81%A7%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E5%85%A8%E4%BD%93%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3COL%3E%3CLI%3EHSE%E8%A8%AD%E5%82%99%3C%2FLI%3E%3CLI%3E%E3%82%AD%E3%83%BC%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%99%E3%82%8B%3C%2FLI%3E%3CLI%3ES2TP%E3%82%AD%E3%83%BC%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%AE%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FLI%3E%3CLI%3EQi%E3%82%AD%E3%83%BC%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%3C%2FLI%3E%3CLI%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E6%A7%8B%E6%88%90%3C%2FLI%3E%3CLI%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3C%2FOL%3E%3CBR%20%2F%3E%3CDIV%3E%3CP%3E%3CSTRONG%3EHSE%20FW%20v2.40.0%3C%2FSTRONG%3E%E3%81%A7%E3%81%AF%E3%80%81%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E6%A7%8B%E6%88%90%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%82%8B%E3%81%BE%E3%81%A7%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%E6%89%8B%E9%A0%86%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%81%AE%E8%A8%AD%E5%AE%9A%E4%B8%AD%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%3CSTRONG%3EAPI%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CDIV%3EImportPlainSymKeyReqMuChannel()%20%E3%81%AF%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3EHSE%E5%BF%9C%E7%AD%94%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3A%3C%2FSTRONG%3E%20%3CSPAN%3E%3CSPAN%3E%3CSTRONG%3E0x55A5A399%3C%2FSTRONG%3E%E3%81%93%E3%82%8C%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%BE%E3%81%99%3A%3C%2FSPAN%3E%3C%2FSPAN%3E%3CDIV%3E%3CSTRONG%3E%23define%20HSE_SRV_RSP_INVALID_PARAM%20((hseSrvResponse_t)0x55A5A399UL)%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CSTRONG%3E%E3%81%93%E3%81%AE%E5%A4%B1%E6%95%97%E5%BE%8C%E3%80%81%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81ECU%E3%81%AF%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E9%96%89%E3%81%98%E8%BE%BC%E3%82%81%E3%82%89%E3%82%8C%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CH2%20id%3D%22toc-hId-238088433%22%20id%3D%22toc-hId-238089390%22%3E%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%3C%2FH2%3E%3CH3%20id%3D%22toc-hId-928649907%22%20id%3D%22toc-hId-928650864%22%3E%E5%8B%95%E4%BD%9C%E6%A7%8B%E6%88%90%EF%BC%88HSE%202.6.0%EF%BC%89%3C%2FH3%3E%3CDIV%3E%3CDIV%20class%3D%22%22%3E00_Blank_MWCT2016_CodeFlash_DataFlash.hex%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E9%9B%BB%E6%BA%90%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E01_HSE_flash.srec%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B32.6.0%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E9%9B%BB%E6%BA%90%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E02_EraseKeysSW.hex%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E9%9B%BB%E6%BA%90%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E03_S2TP_KeySlotsAligned.srec%26nbsp%3B%26nbsp%3BS2TP%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%201.1.1%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E9%9B%BB%E6%BA%90%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3EUART%E7%B5%8C%E7%94%B1%E3%81%A7Qi%E3%82%AD%E3%83%BC%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E9%9B%BB%E6%BA%90%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3EApplication%2BSecureBoot.hex%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E9%9B%BB%E6%BA%90%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3EUART%E3%83%AD%E3%82%B0%E3%81%8B%E3%82%89%E3%81%AE%E3%83%9E%E3%83%BC%E3%82%B8%E5%BE%8C%E3%81%AE16%E9%80%B2%E6%95%B0%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%BE%8C%E3%81%AEHSE%E5%BF%9C%E7%AD%94%EF%BC%9A%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CTABLE%20width%3D%22492%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22492%22%3EHseStatus%3A%202848%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%880%EF%BC%9A0%20RFU%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%93%E3%83%83%E3%83%88%201%26nbsp%3B%26nbsp%3B%20%3A%200%20HSE_SHE_STATUS_SECURE_BOOT%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%202%20%3A%200%20HSE_SHE_STATUS_SECURE_BOOT_INIT%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%93%E3%83%83%E3%83%88%203%26nbsp%3B%26nbsp%3B%20%3A%200%20HSE_SHE_STATUS_SECURE_BOOT_FINISHED%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%884%EF%BC%9A0%20HSE_SHE_STATUS_SECURE_BOOT_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%205%20%3A%201%20HSE_STATUS_RNG_INIT_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%206%20%3A%200%20HSE_STATUS_HOST_DEBUGGER_ACTIVE%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%93%E3%83%83%E3%83%88%207%26nbsp%3B%26nbsp%3B%20%3A%200%20HSE_STATUS_HSE_DEBUGGER_ACTIVE%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%208%20%3A%201%20HSE_STATUS_INIT_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%889%EF%BC%9A1%20HSE_STATUS_INSTALL_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%2010%20%3A%200%20HSE_STATUS_BOOT_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%2011%20%3A%201%20HSE_STATUS_CUST_SUPER_USER%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%2012%20%3A%200%20HSE_STATUS_OEM_SUPER_USER%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%93%E3%83%83%E3%83%88%2013%26nbsp%3B%20%3A%200%20HSE_STATUS_FW_UPDATE_IN_PROGRESS%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%8814%EF%BC%9A0%20RFU%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%8815%EF%BC%9A0%20RFU%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EsmrCoreStatus_Get%20%3A%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EsmrCoreStatus%5B1%5D%20%3A%200%20%E3%80%81smrCoreStatus%5B0%5D%20%3A%200%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EsmrStatus%5B1%5D%20%3A%200%20%E3%80%81smrStatus%5B0%5D%20%3A%200%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%AD%E3%82%B0HSE%E5%BF%9C%E7%AD%94%3A%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CTABLE%20width%3D%22492%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22492%22%3E%26nbsp%3BImportPlainSymKeyReqMuChannel-hseResp%3A%200x55a5aa33%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3ELoadBootMacKey-hseResp%3A%200x55a5aa33%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3BGeneric_ImportKeys-hseResp%3A%200x55a5aa33%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EKeyProvisioningForJTAG-status%3A%201%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3ESecureBootConfiguration-hseResp%3A%200x55a5aa33%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EKeyProvisioningToHseNVM-status%3A%201%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3BNON_SECURE_IVT-BLOCK1-hseResp%3A%200x55a5aa33%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3BSECURE_IVT-BLOCK0-hseResp%3A%200x55a5aa33%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EwriteDefaultData%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88CFG%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E5%AE%9F%E8%A1%8C%E4%B8%AD%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EHse-FW%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%200.13.0.2.6.0%E3%80%81%E3%83%95%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E4%BD%BF%E7%94%A8%3A0.13.0.2.6.0%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CTABLE%20width%3D%22492%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22492%22%3EHseStatus%3A%202862%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%880%EF%BC%9A0%20RFU%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%201%20%3A%201%20HSE_SHE_STATUS_SECURE_BOOT%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%202%20%3A%201%20HSE_SHE_STATUS_SECURE_BOOT_INIT%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%203%20%3A%201%20HSE_SHE_STATUS_SECURE_BOOT_FINISHED%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%884%EF%BC%9A0%20HSE_SHE_STATUS_SECURE_BOOT_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%205%20%3A%201%20HSE_STATUS_RNG_INIT_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%206%20%3A%200%20HSE_STATUS_HOST_DEBUGGER_ACTIVE%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%93%E3%83%83%E3%83%88%207%26nbsp%3B%26nbsp%3B%20%3A%200%20HSE_STATUS_HSE_DEBUGGER_ACTIVE%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%208%20%3A%201%20HSE_STATUS_INIT_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%889%EF%BC%9A1%20HSE_STATUS_INSTALL_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%2010%20%3A%200%20HSE_STATUS_BOOT_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%2011%20%3A%201%20HSE_STATUS_CUST_SUPER_USER%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%2012%20%3A%200%20HSE_STATUS_OEM_SUPER_USER%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%93%E3%83%83%E3%83%88%2013%26nbsp%3B%20%3A%200%20HSE_STATUS_FW_UPDATE_IN_PROGRESS%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%8814%EF%BC%9A0%20RFU%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%8815%EF%BC%9A0%20RFU%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EsmrCoreStatus_Get%20%3A%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EsmrCoreStatus%5B1%5D%20%3A%200%20%E3%80%81smrCoreStatus%5B0%5D%20%3A%200%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EsmrStatus%5B1%5D%20%3A%201%20%E3%80%81smrStatus%5B0%5D%20%3A%201%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CDIV%3E%3CSTRONG%3E%E6%A7%8B%E6%88%90%E3%82%A8%E3%83%A9%E3%83%BC%20-%20HSE%20FW%202.40.0%20%E3%81%AE%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%3A%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E00_Blank_MWCT2016_CodeFlash_DataFlash.hex%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E9%9B%BB%E6%BA%90%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E01_S32K344_HSE_FW_UPDATE_v2_40_0.srec%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E9%9B%BB%E6%BA%90%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E02_M210WLCUMBCD00A_WSB00.31_EraseKeySW_UART_ENABLE.hex%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E9%9B%BB%E6%BA%90%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E03_S2TP_2_1_0_KeySlotsAligned.srec%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E9%9B%BB%E6%BA%90%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3EUART%E7%B5%8C%E7%94%B1%E3%81%A7Qi%E3%82%AD%E3%83%BC%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E9%9B%BB%E6%BA%90%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3EApplication%2BSecureBoot.hex%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%E9%9B%BB%E6%BA%90%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CTABLE%20width%3D%22492%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22492%22%3EHseStatus%3A%202912%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%880%EF%BC%9A0%20RFU%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%93%E3%83%83%E3%83%88%201%26nbsp%3B%26nbsp%3B%20%3A%200%20HSE_SHE_STATUS_SECURE_BOOT%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%202%20%3A%200%20HSE_SHE_STATUS_SECURE_BOOT_INIT%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%93%E3%83%83%E3%83%88%203%26nbsp%3B%26nbsp%3B%20%3A%200%20HSE_SHE_STATUS_SECURE_BOOT_FINISHED%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%884%EF%BC%9A0%20HSE_SHE_STATUS_SECURE_BOOT_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%205%20%3A%201%20HSE_STATUS_RNG_INIT_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%206%20%3A%201%20HSE_STATUS_HOST_DEBUGGER_ACTIVE%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%93%E3%83%83%E3%83%88%207%26nbsp%3B%26nbsp%3B%20%3A%200%20HSE_STATUS_HSE_DEBUGGER_ACTIVE%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%208%20%3A%201%20HSE_STATUS_INIT_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%889%EF%BC%9A1%20HSE_STATUS_INSTALL_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%2010%20%3A%200%20HSE_STATUS_BOOT_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%2011%20%3A%201%20HSE_STATUS_CUST_SUPER_USER%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%2012%20%3A%200%20HSE_STATUS_OEM_SUPER_USER%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%93%E3%83%83%E3%83%88%2013%26nbsp%3B%20%3A%200%20HSE_STATUS_FW_UPDATE_IN_PROGRESS%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%8814%EF%BC%9A0%20RFU%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%8815%EF%BC%9A0%20RFU%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EsmrCoreStatus_Get%20%3A%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EsmrCoreStatus%5B1%5D%20%3A%200%20%E3%80%81smrCoreStatus%5B0%5D%20%3A%200%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EsmrStatus%5B1%5D%20%3A%200%20%E3%80%81smrStatus%5B0%5D%20%3A%200%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%3EImportPlainSymKeyReqMuChannel-hseResp%3A%200x55A5A399%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E9%9B%BB%E6%BA%90%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%EF%BC%9A%3C%2FDIV%3E%3CDIV%3E%3CTABLE%20width%3D%22492%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22492%22%3EUML%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%EF%BC%9AWSB00.3B_UART_ENABLE%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88CFG%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E5%AE%9F%E8%A1%8C%E4%B8%AD%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EHse-FW%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%200.13.0.2.40.0%E3%80%81%E3%83%95%E3%83%AB%E3%83%A1%E3%83%A2%E3%83%AA%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A0.13.0.2.40.0%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EHseStatus%3A%202848%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%880%EF%BC%9A0%20RFU%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%93%E3%83%83%E3%83%88%201%26nbsp%3B%26nbsp%3B%20%3A%200%20HSE_SHE_STATUS_SECURE_BOOT%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%202%20%3A%200%20HSE_SHE_STATUS_SECURE_BOOT_INIT%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%93%E3%83%83%E3%83%88%203%26nbsp%3B%26nbsp%3B%20%3A%200%20HSE_SHE_STATUS_SECURE_BOOT_FINISHED%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%884%EF%BC%9A0%20HSE_SHE_STATUS_SECURE_BOOT_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%205%20%3A%201%20HSE_STATUS_RNG_INIT_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%206%20%3A%200%20HSE_STATUS_HOST_DEBUGGER_ACTIVE%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%93%E3%83%83%E3%83%88%207%26nbsp%3B%26nbsp%3B%20%3A%200%20HSE_STATUS_HSE_DEBUGGER_ACTIVE%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%208%20%3A%201%20HSE_STATUS_INIT_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%889%EF%BC%9A1%20HSE_STATUS_INSTALL_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%2010%20%3A%200%20HSE_STATUS_BOOT_OK%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%2011%20%3A%201%20HSE_STATUS_CUST_SUPER_USER%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%88%2012%20%3A%200%20HSE_STATUS_OEM_SUPER_USER%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%93%E3%83%83%E3%83%88%2013%26nbsp%3B%20%3A%200%20HSE_STATUS_FW_UPDATE_IN_PROGRESS%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%8814%EF%BC%9A0%20RFU%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%93%E3%83%83%E3%83%8815%EF%BC%9A0%20RFU%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EsmrCoreStatus_Get%20%3A%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EsmrCoreStatus%5B1%5D%20%3A%200%20%E3%80%81smrCoreStatus%5B0%5D%20%3A%200%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3EsmrStatus%5B1%5D%20%3A%200%20%E3%80%81smrStatus%5B0%5D%20%3A%200%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%26nbsp%3BImportPlainSymKeyReqMuChannel-hseResp%3A%200x55a5a399%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3EECU%E3%81%8C%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%81%AE%E3%81%BF%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2416375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MWCT2016%20HSE%202.40.0%20Secure%20Boot%20Configuration%20Failure-%20ImportPlainSymKeyReqMuChannel%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2416375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247788%22%20target%3D%22_blank%22%3E%40ShrikantM%20%E3%81%95%E3%82%93%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSTRONG%3EImportPlainSymKeyReqMuChannel()%3C%2FSTRONG%3E%3C%2FEM%3E%20%E9%96%A2%E6%95%B0%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A7%E4%BD%BF%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%A8%E3%80%81%E3%82%AD%E3%83%BC%E3%82%AB%E3%82%BF%E3%83%AD%E3%82%B0%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%80%811%E3%81%A4%E4%BB%A5%E4%B8%8A%E3%81%AEHSE%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%E3%80%81VaneB%3C%2FP%3E%3C%2FLINGO-BODY%3E
