S32K344 UART
S32K344 UART
Zsk
Hi All
   UART with interrupt transceiver, now two MCU single-direction transceiver data with asynchronous no problem, at the same time transceiver will send and receive failure, what will be the reason?
        thank you
VaneB
Hi @Zsk
Please correct me if I understand wrong.
From what I understood, you have the two devices connected to each other and you are trying to send at the same time that you are receiving and vice versa, am I correct?
B.R.
VaneB
VaneB
Hi @Zsk
B.R.
VaneB
Zsk
Found the problem, the status was switched to busy after asynchronous sending, and did not switch back, thank you
wangjiawei
I had the same problem, but I didn't solve it. Could you tell me exactly how you solved it, thank you very much
Zsk
I have changed the judgment condition before sending and receiving in the driver, sending only looks at the sending state, receiving only looks at the receiving state. Problem solved
Zsk
Yes ,and I found another problem :The host needs to send about 10 times before the slave can receive it.After the sending/receiving status is switched once, the data cannot be sent again.
