S32K341 QuadSPI
已解决
S32K341 QuadSPI
跳至解决方案
2,551 次查看
Mateusz_K
I want to use external flash with S32K341. I am trying to read id of the external flash memory. When I try to do using IP command, I get stuck waiting for SR[BUSY] flag to become 0. Data, cs, and clk lines quiet. Data lines are in a high state, clk is low. I want to use internal FIRC.
What steps duirng the initialization am i missing?
1. QuadSPI clock enable in MC_ME
2. Pin setup, copied from the example in RTD package, considering S32K342 quad spi.
3. Enable QuadSPI by MCR module
4. Unlocking LUT, writing sequence (cmd(0x9F), read, stop) on 0 index, locking LUT
5. Starting by writing address 0x00 to SFAR and 0 to IPCR[SEQID], 4 to  IDATSZ
Why are the no signal on data lines?
1 解答
2,528 次查看
davidtosenovjan
Why you are not using NXP drivers?
A driver is a part of RTD FLS drivers pack (real-time time flash driver, supporting internal flash as well as QuadSPI):
https://www.nxp.com/design/software/automotive-software-and-tools/real-time-drivers-rtd:AUTOMOTIVE-R...
Otherwise there is an appnote dealing with QuadSPI:
https://www.nxp.com/docs/en/application-note/AN12193.pdf
QuadSPI is highly configurable module because it uses look-up tables for SPI commands what should theoretically allow user to adapt the code to any SPI memory.
在原帖中查看解决方案
2 回复数
2,529 次查看
davidtosenovjan
2,518 次查看
Mateusz_K
Thank you for the answer. I am communicating with the device with through ARM DAP. I am relaying on the drivers but not using them.
I managed to properly initialize the device. Now I want to read the ID of the Ext flash. I am sending proper command, and getting right answer. RBSR register shows that new data appeared in the buffer. But when I read the RDBR register there is no data in them.
%3CLINGO-SUB%20id%3D%22lingo-sub-1865456%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K341%20QuadSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1865456%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%83%B3%E5%B0%86%E5%A4%96%E9%83%A8%E9%97%AA%E5%AD%98%E4%B8%8E%20S32K341%20%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E8%AF%BB%E5%8F%96%E5%A4%96%E9%83%A8%E9%97%AA%E5%AD%98%E7%9A%84%20ID%E3%80%82%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20IP%20%E5%91%BD%E4%BB%A4%E6%97%B6%EF%BC%8C%E6%88%91%E9%99%B7%E5%85%A5%E7%AD%89%E5%BE%85%20SR%5BBUSY%5D%20%E6%A0%87%E5%BF%97%E5%8F%98%E4%B8%BA%200%20%E7%9A%84%E5%9B%B0%E5%A2%83%E3%80%82%E6%95%B0%E6%8D%AE%E3%80%81cs%20%E5%92%8C%20clk%20%E7%BA%BF%E8%B7%AF%E5%AE%89%E9%9D%99%E3%80%82%E6%95%B0%E6%8D%AE%E7%BA%BF%E5%A4%84%E4%BA%8E%E9%AB%98%E7%8A%B6%E6%80%81%EF%BC%8Cclk%E5%A4%84%E4%BA%8E%E4%BD%8E%E7%8A%B6%E6%80%81%E3%80%82%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8%E5%86%85%E9%83%A8%20FIRC%E3%80%82%3C%2FP%3E%3CP%3E%E5%88%9D%E5%A7%8B%E5%8C%96%E8%BF%87%E7%A8%8B%E4%B8%AD%E6%88%91%E9%81%97%E6%BC%8F%E4%BA%86%E5%93%AA%E4%BA%9B%E6%AD%A5%E9%AA%A4%EF%BC%9F%3C%2FP%3E%3CP%3E1.%20MC_ME%20%E4%B8%AD%E7%9A%84%20QuadSPI%20%E6%97%B6%E9%92%9F%E5%90%AF%E7%94%A8%3C%2FP%3E%3CP%3E2.%20%E5%BC%95%E8%84%9A%E8%AE%BE%E7%BD%AE%EF%BC%8C%E4%BB%8E%20RTD%20%E5%8C%85%E4%B8%AD%E7%9A%84%E7%A4%BA%E4%BE%8B%E5%A4%8D%E5%88%B6%EF%BC%8C%E8%80%83%E8%99%91%20S32K342%20%E5%9B%9B%20spi%E3%80%82%3C%2FP%3E%3CP%3E3.%20%E9%80%9A%E8%BF%87MCR%E6%A8%A1%E5%9D%97%E5%90%AF%E7%94%A8QuadSPI%3C%2FP%3E%3CP%3E4.%20%E8%A7%A3%E9%94%81%20LUT%EF%BC%8C%E5%9C%A8%200%20%E7%B4%A2%E5%BC%95%E4%B8%8A%E5%86%99%E5%85%A5%E5%BA%8F%E5%88%97%20(cmd(0x9F)%2C%20read%2C%20stop)%EF%BC%8C%E9%94%81%E5%AE%9A%20LUT%3C%2FP%3E%3CP%3E5.%20%E9%A6%96%E5%85%88%E5%B0%86%E5%9C%B0%E5%9D%80%200x00%20%E5%86%99%E5%85%A5%20SFAR%EF%BC%8C%E5%B0%86%200%20%E5%86%99%E5%85%A5%20IPCR%5BSEQID%5D%EF%BC%8C%E5%B0%86%204%20%E5%86%99%E5%85%A5%20IDATSZ%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E6%95%B0%E6%8D%AE%E7%BA%BF%E6%B2%A1%E6%9C%89%E4%BF%A1%E5%8F%B7%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1867156%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K341%20QuadSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1867156%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E7%AD%94%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E9%80%9A%E8%BF%87%20ARM%20DAP%20%E4%B8%8E%E8%AE%BE%E5%A4%87%E9%80%9A%E4%BF%A1%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BE%9D%E8%B5%96%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BD%86%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%E5%AE%83%E4%BB%AC%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%AE%BE%E6%B3%95%E6%AD%A3%E7%A1%AE%E5%88%9D%E5%A7%8B%E5%8C%96%E8%AF%A5%E8%AE%BE%E5%A4%87%E3%80%82%E7%8E%B0%E5%9C%A8%E6%88%91%E6%83%B3%E8%AF%BB%E5%8F%96%20Ext%20flash%20%E7%9A%84%20ID%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E5%8F%91%E9%80%81%E6%AD%A3%E7%A1%AE%E7%9A%84%E5%91%BD%E4%BB%A4%E5%B9%B6%E5%BE%97%E5%88%B0%E6%AD%A3%E7%A1%AE%E7%9A%84%E7%AD%94%E6%A1%88%E3%80%82RBSR%E5%AF%84%E5%AD%98%E5%99%A8%E6%98%BE%E7%A4%BA%E7%BC%93%E5%86%B2%E5%8C%BA%E4%B8%AD%E5%87%BA%E7%8E%B0%E4%BA%86%E6%96%B0%E6%95%B0%E6%8D%AE%E3%80%82%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E8%AF%BB%E5%8F%96%20RDBR%20%E5%AF%84%E5%AD%98%E5%99%A8%E6%97%B6%EF%BC%8C%E5%85%B6%E4%B8%AD%E6%B2%A1%E6%9C%89%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1866312%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K341%20QuadSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1866312%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E6%82%A8%E4%B8%8D%E4%BD%BF%E7%94%A8%20NXP%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%98%AF%20RTD%20FLS%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%8C%85%EF%BC%88%E5%AE%9E%E6%97%B6%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E6%94%AF%E6%8C%81%E5%86%85%E9%83%A8%E9%97%AA%E5%AD%98%E4%BB%A5%E5%8F%8A%20QuadSPI%EF%BC%89%E7%9A%84%E4%B8%80%E9%83%A8%E5%88%86%EF%BC%9A%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fsoftware%2Fautomotive-software-and-tools%2Freal-time-drivers-rtd%3AAUTOMOTIVE-RTD%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fsoftware%2Fautomotive-software-and-tools%2Freal-time-drivers-rtd%3AAUTOMOTIVE-RTD%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%90%A6%E5%88%99%EF%BC%8C%E6%9C%89%E4%B8%80%E4%B8%AA%E5%A4%84%E7%90%86%3CSPAN%3EQuadSPI%20%E7%9A%84%E5%BA%94%E7%94%A8%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12193.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12193.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EQuadSPI%20%E6%98%AF%E4%B8%80%E4%B8%AA%E9%AB%98%E5%BA%A6%E5%8F%AF%E9%85%8D%E7%BD%AE%E7%9A%84%E6%A8%A1%E5%9D%97%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E4%BD%BF%E7%94%A8%E6%9F%A5%E6%89%BE%E8%A1%A8%E6%9D%A5%E6%9F%A5%E6%89%BE%20SPI%20%E5%91%BD%E4%BB%A4%EF%BC%8C%E7%90%86%E8%AE%BA%E4%B8%8A%E5%85%81%E8%AE%B8%E7%94%A8%E6%88%B7%E5%B0%86%E4%BB%A3%E7%A0%81%E9%80%82%E9%85%8D%E5%88%B0%E4%BB%BB%E4%BD%95%20SPI%20%E5%86%85%E5%AD%98%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
