S32K344 Temperature Sensor
liyongfeng
The IC temperature value was obtained from the ADC0-19 channel and calculated using the code shown in the figure below. However, the temperature value fluctuates severely. What is the reason for this? How to solve it?
Senlent
Hi@liyongfeng
RTD 2.0.0 and test result, very stable.
Senlent
Hi@liyongfeng
We have provided you with API functions to calculate temperature sensor conversions
please test the function below:
Adc_Sar_Ip_TempSenseCalculateTemp();
liyongfeng
I used this API, but there was no improvement. The temperature value is still jumping
According to parameter TS-ACC2, Is it allowed for temperature fluctuations to occur within the range of ±10 ℃?
Senlent
Hi@liyongfeng
Could you please provided your project and i will help you to check it agian.
The temperature sensor will have errors, but there will not be such a large fluctuation
liyongfeng
Because this is the project code, we cannot provide it to you. Can you provide me with a good demo of S32K344?
Senlent
Hi@liyongfeng
no problem, so which version the RTD you're using?
liyongfeng
Is there any other way to send my code to you?
Senlent
Hi@liyongfeng
Senlent
Hi@liyongfeng
you can sent me a private message.
liyongfeng
RTD_4.4_2.0.0_D2203
