S32K344 Messaging Unit
4,143 次查看
1260784871
1、According to the above description, MU Reset can trigger an interrupt, but the corresponding interrupt service function was not found?
2、Help to tell the corresponding interrupt service function
5 回复数
4,121 次查看
VaneB
Hi @1260784871
The MU has 9 interrupt sources on each side. There are 1 general-purpose interrupt and 8 RX/TX interrupt sources.
The reset has a different function from the MU or system perspective. Please refer to section 39.3.3 Resets of S32K3xx Reference Manual, Rev. 5.
B.R.
VaneB
4,104 次查看
1260784871
MUB_CR【MURIE】的作用是什么?使能后不是应该触发中断吗?触发的是哪个中断呢?
4,098 次查看
VaneB
Hi @1260784871
Setting the MUR bit to 1 and enabled with the MURIE bit resets both the MUA-side and MUB-side, forcing all control and status registers to return to their default values.
4,074 次查看
1260784871
我问的是中断!文档里面不是说会触发中断吗?触发哪个中断
4,059 次查看
VaneB
Hi @1260784871
Sorry for the misunderstanding. It seems I am losing information due to the translation. Could you help me keep the conversation going in English?
