S32K344 Lock step core
5,011件の閲覧回数
nirmal_masilamani
Contributor V
Hello Team,
I am currently working on S32K344, we want to know, how to enable lockstep core in S32K344.
I have referred below community post,
Solved: S32K344 Lock-step kernel - NXP Community.
One thing is not clear, how to know, address for UTEST_MISC to enable/ disable lockstep.?
タグ(2)
11 返答(返信)
4,992件の閲覧回数
petervlna
There is no fixed address of UTEST_MISC. It is not a register, it is a DCF (device configuration record) which is during reset phase copied to corresponding register/ registers.
You will program UTEST_MISC record into the UTEST memory in user area to the first available space.
It is in this area:
First available space is filled with 0xFFFF_FFFF_FFFF_FFFF which is stop record. So load you DCF record here.
Peter
3,535件の閲覧回数
yanyanwang
How can I erase the UTEST records, exit lockstep mode, and test the lockstep functionality?
Could you help me check if my current records are correct?
Thanks.@petervlna
4,982件の閲覧回数
nirmal_masilamani
Contributor V
Hello @petervlna ,
Thanks for your reply.
Can you show me an example DCF record for enabling lockstep in S32K344,
タグ(2)
4,977件の閲覧回数
nirmal_masilamani
Contributor V
Hi @petervlna ,
Below image id the data available in 0x1B000700, so i need to copy my DCF record in 0x1B000770?
Can you give me an example for DCF Records, to enable Lockstep
Is there any document for DCF details?
タグ(2)
4,955件の閲覧回数
petervlna
Yes, that is correct.
Here is how the record should looks like:
at address  0x1B000770 you will load: 0x0010000400000101
So you will modify the example here:
The example code for UTEST programming is here:
https://community.nxp.com/t5/S32K/S32K344-Lock-step-kernel/m-p/1930030
Here is DCF configurator:
https://community.nxp.com/t5/S32K-Knowledge-Base/S32K344-DCF-Configurator/ta-p/1986243
For lauterbach debugger:
data.set 0x1B000790 %QUAD 0x0010000400000101 ;dcf_client_utest_misc
and in S3 record for PE Micro and other:
S30D1B00077001010000040010005A
Peter
4,947件の閲覧回数
nirmal_masilamani
Contributor V
Hello @petervlna ,
Thank you for your reply.
S30D1B00077001010000040010005A,
We are using PE Micro, how can i use this S record?
And is it mandatory to use S record or can i program DCF record directly using the example program?
タグ(2)
4,895件の閲覧回数
petervlna
I am not familiar with PE debuggers, but looking at documentation:
Using S32 Design Studio + PE Micro Plugin
  1. Prepare your DCF record:
    • Identify the next available address in UTEST (look for the first double-word filled with 0xFF).
  2. Create a .srec file:
    • Format the DCF record into an S-record file.
  3. Configure Debugger in S32DS:
    • Use PE Micro’s plugin to set up a debugger configuration.
    • Load the .srec file as the application.
    • Use the correct flash algorithm (e.g., nxp_s32k344_1x32x1012k_hse_disabled.arp).
  4. Flash the DCF Record:
    • Start the debug session.
    • Verify the record in Memory View.
Using PE Micro’s PROG-HL-ARM Tool
  • This standalone tool supports flashing via JTAG/SWD.
  • You can load .srec or binary files and program them directly.
  • Ideal for production environments using Cyclone programmers.
More info: PE Micro S32K344 Support Page
As UTEST is just standard flash, with OTP enabled, you can use SW to program it, like I have shared. For example C40 driver example.
Peter
4,886件の閲覧回数
nirmal_masilamani
Contributor V
Hello @petervlna ,
But i am unable to debug, debugging failed with .srec files.
タグ(2)
4,832件の閲覧回数
petervlna
I am confused here.
Why you are using extension srec? The debugger states that is not an object file.
When using PE Micro tools to program devices using S-record (.srec) files, the type of S-record format you use—such as S1, S2, or S3—depends on the address range of the target device's memory.
Here’s a quick breakdown:
  • S1 records: Use 16-bit addresses (up to 64 KB). Suitable for small memory ranges.
  • S2 records: Use 24-bit addresses (up to 16 MB). Less common, but used for mid-range addressing.
  • S3 records: Use 32-bit addresses (up to 4 GB). Most commonly used for modern microcontrollers and flash programming.
For PE Micro programming:
  • If you're targeting a 32-bit MCU or using a memory map that goes beyond 64 KB, you should use S3 records.
  • PE Micro tools like PROG or Cyclone programmers typically support S3 format for flash programming.
Maybe I am wrong, but use S3 extension instead of srec.
Peter
4,749件の閲覧回数
nirmal_masilamani
Contributor V
hello @petervlna ,
I have referred the below community post for debugging using .srec file.
HOWTO: Program DCF record into UTEST flash in S32 Design Studio for Power - NXP Community
.s3 extension also not working
WIth S32DS and PEMICRO,
Is there a way to program DCF record using .srec file?
If yes, can you share any refer documents?
タグ(2)
4,622件の閲覧回数
petervlna
Yes, you can program DCF records into UTEST flash on the S32K344 using a .srec file with S32 Design Studio (S32DS) and PEMICRO tools. Here's a summary of how to do it and where to find supporting documentation:
Steps to Program DCF Record Using .srec File
  1. Prepare the DCF Record:
    • Use the S32K344 DCF Configurator tool to calculate the correct DCF record values. [community.nxp.com]
    • Identify the next available address in UTEST flash (e.g., starting from 0x1B000700) by checking for the first double-word filled with 0xFF.
  2. Create the .srec File:
    • Format the DCF record into an S3 record line.
    • Example: S30D1B00077001010000040010005A
    • This line represents a DCF record at address 0x1B000770. [community.nxp.com]
  3. Configure S32DS Debugger:
    • Create a new debug configuration in S32DS.
    • Set the .srec file as the application to load.
    • In the debugger tab, enable "Use Alternative Algorithm" and point to the correct PEMICRO flash algorithm (nxp_s32k344_1x32x980k_hse_enabled.arp).
    • Disable "Load Symbols" and "Run on Reset" since this session is only for programming.
  4. Program the Flash:
    • Start the debug session. The .srec file will be loaded into the UTEST flash.
    • After programming, verify the memory content in the Memory View.
nxp_s32k344_1x32x980k_hse_enabled.arp algorithm supports HSE-enabled devices and is suitable for UTEST flash programming.
I have never tried it by using PEMicro so I can't verify the steps from my experience.
Peter
%3CLINGO-SUB%20id%3D%22lingo-sub-2182742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K344%20%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%B3%E3%82%A2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AE%E7%9A%86%E3%81%95%E3%82%93%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81S32K344%20%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82S32K344%20%E3%81%A7%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%20%E3%82%B3%E3%82%A2%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E6%8A%95%E7%A8%BF%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K344-Lock-step-kernel%2Fm-p%2F1930030%22%20target%3D%22_blank%22%3E%E8%A7%A3%E6%B1%BA%E6%B8%88%E3%81%BF%3A%20S32K344%20%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20-%20NXP%20%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CP%3E1%20%E3%81%A4%E4%B8%8D%E6%98%8E%E3%81%AA%E7%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E3%80%81%3CSPAN%3E%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%92%E6%9C%89%E5%8A%B9%2F%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%20UTEST_MISC%20%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E7%9F%A5%E3%82%8B%E3%81%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2189094%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189094%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81.srec%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6S32K344%E3%81%AEUTEST%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%ABDCF%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0CAN%E3%80%82S32%20Design%20Studio%20(S32DS)%20%E3%81%8A%E3%82%88%E3%81%B3%20PEMICRO%20%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AB%E3%80%81%E3%81%9D%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A8%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E5%85%A5%E6%89%8B%E5%85%88%E3%81%AE%E6%A6%82%E8%A6%81%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CH5%20id%3D%22toc-hId--1617192914%22%20id%3D%22toc-hId--1594249038%22%20id%3D%22toc-hId--1594249038%22%3E.srec%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6DCF%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FH5%3E%0A%3COL%3E%0A%3CLI%3E%0A%3CP%3EDCF%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%BA%96%E5%82%99%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CA%20tabindex%3D%220%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K344-DCF-Configurator%2Fta-p%2F1986243%22%20target%3D%22_blank%22%20data-tabster%3D%22%7B%22%20restorer%3D%22%22%3ES32K344%20DCF%20%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%20%E3%83%84%E3%83%BC%E3%83%AB%3C%2FA%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%20DCF%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E5%80%A4%E3%82%92%E8%A8%88%E7%AE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K344-DCF-Configurator%2Fta-p%2F1986243%22%20target%3D%22_blank%22%3E%5Bcommunity.nxp.com%5D%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E0xFF%20%E3%81%A7%E5%9F%8B%E3%82%81%E3%82%89%E3%82%8C%E3%81%9F%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%80%E3%83%96%E3%83%AB%E3%83%AF%E3%83%BC%E3%83%89%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%81UTEST%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%86%85%E3%81%AE%E6%AC%A1%E3%81%AE%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20(%E4%BE%8B%3A%200x1B000700%20%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%8B)%20%E3%82%92%E8%AD%98%E5%88%A5%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E.srec%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EDCF%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%20S3%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E4%BE%8B%3A%20%3CSTRONG%3ES30D1B00077001010000040010005A%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3CLI%3E%E3%81%93%E3%81%AE%E8%A1%8C%E3%81%AF%E3%80%81%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x1B000770%20%E3%81%AE%20DCF%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%A1%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K344-Lock-step-core%2Fm-p%2F2184716%22%20target%3D%22_blank%22%3E%5Bcommunity.nxp.com%5D%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3ES32DS%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3ES32DS%20%E3%81%A7%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%A7%8B%E6%88%90%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E.srec%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%20%E3%82%BF%E3%83%96%E3%81%A7%E3%80%81%E3%80%8C%3CSTRONG%3E%E4%BB%A3%E6%9B%BF%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FSTRONG%3E%E3%80%8D%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%20PEMICRO%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%20(%20%3CSTRONG%3Enxp_s32k344_1x32x980k_hse_enabled.arp%3C%2FSTRONG%3E%20)%20%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E3%81%93%E3%81%AE%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E5%B0%82%E7%94%A8%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E3%80%8C%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%80%8D%E3%81%A8%E3%80%8C%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E6%99%82%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%80%8D%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82.srec%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%20UTEST%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E5%BE%8C%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%93%E3%83%A5%E3%83%BC%E3%81%A7%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E5%86%85%E5%AE%B9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CBR%20%2F%3E%0A%3CP%3Enxp_s32k344_1x32x980k_hse_enabled.arp%20%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%AF%E3%80%81HSE%20%E5%AF%BE%E5%BF%9C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%80%81UTEST%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AB%E9%81%A9%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AF%20PEMicro%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A9%A6%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E7%B5%8C%E9%A8%93%E3%81%8B%E3%82%89%E6%89%8B%E9%A0%86%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2187462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2187462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F13836%22%20target%3D%22_blank%22%3E%40petervlna%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E.srec%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%9F%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E6%8A%95%E7%A8%BF%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio-Knowledge-Base%2FHOWTO-Program-DCF-record-into-UTEST-flash-in-S32-Design-Studio%2Fta-p%2F1099436%22%20target%3D%22_blank%22%3EHOWTO%3A%20S32%20Design%20Studio%20for%20Power%E3%81%A7UTEST%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%ABDCF%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%20-%20NXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%3C%2FP%3E%3CP%3E.s3%E6%8B%A1%E5%BC%B5%E5%AD%90%E3%82%82%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%3C%2FP%3E%3CP%3ES32DS%E3%81%A8PEMICRO%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%3C%2FP%3E%3CP%3E.srec%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6DCF%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E5%8F%82%E8%80%83%E8%B3%87%E6%96%99%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2185367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2185367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E6%B7%B7%E4%B9%B1%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%8B%A1%E5%BC%B5%E6%A9%9F%E8%83%BD%20srec%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E7%90%86%E7%94%B1%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%8C%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EPE%20Micro%3C%2FSTRONG%3E%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%3CSTRONG%3ES%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%20(.srec)%3C%2FSTRONG%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20S%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E5%BD%A2%E5%BC%8F%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97%20(%20%3CSTRONG%3ES1%3C%2FSTRONG%3E%20%E3%80%81%20%3CSTRONG%3ES2%3C%2FSTRONG%3E%20%E3%80%81%20%3CSTRONG%3ES3%3C%2FSTRONG%3E%E3%81%AA%E3%81%A9)%20%E3%81%AF%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%3CSTRONG%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E7%AF%84%E5%9B%B2%3C%2FSTRONG%3E%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%B0%A1%E5%8D%98%E3%81%AB%E8%AA%AC%E6%98%8E%E3%81%99%E3%82%8B%E3%81%A8%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3ES1%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%3A%20%3CSTRONG%3E16%20%E3%83%93%E3%83%83%E3%83%88%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FSTRONG%3E(%E6%9C%80%E5%A4%A7%2064%20KB)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%B0%8F%E3%81%95%E3%81%AA%E3%83%A1%E3%83%A2%E3%83%AA%E7%AF%84%E5%9B%B2%E3%81%AB%E9%81%A9%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3ES2%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%3A%20%3CSTRONG%3E24%20%E3%83%93%E3%83%83%E3%83%88%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FSTRONG%3E(%E6%9C%80%E5%A4%A7%2016%20MB)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%81%BE%E3%82%8A%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E4%B8%AD%E8%B7%9D%E9%9B%A2%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E6%8C%87%E5%AE%9A%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3ES3%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%3A%20%3CSTRONG%3E32%20%E3%83%93%E3%83%83%E3%83%88%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FSTRONG%3E(%E6%9C%80%E5%A4%A7%204%20GB)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E6%96%B0%E3%81%AE%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%8A%E3%82%88%E3%81%B3%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%A7%E6%9C%80%E3%82%82%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CH4%20id%3D%22toc-hId-179642074%22%20id%3D%22toc-hId--1604752142%22%20id%3D%22toc-hId--1604752142%22%3EPE%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AE%E5%A0%B4%E5%90%88%3A%3C%2FH4%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3E32%20%E3%83%93%E3%83%83%E3%83%88%20MCU%20%E3%82%92%3C%2FSTRONG%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%2064%20KB%20%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%20%3CSTRONG%3ES3%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%3C%2FSTRONG%3E%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3EPROG%3C%2FSTRONG%3E%E3%82%84%3CSTRONG%3ECyclone%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%83%BC%3C%2FSTRONG%3E%E3%81%AA%E3%81%A9%E3%81%AE%20PE%20Micro%20%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AF%E9%80%9A%E5%B8%B8%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E7%94%A8%E3%81%AE%20S3%20%E5%BD%A2%E5%BC%8F%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81srec%20%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20S3%20%E6%8B%A1%E5%BC%B5%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F13836%22%20target%3D%22_blank%22%3E%40petervlna%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82.srec%E3%81%A7%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22nirmal_masilamani_0-1760346979436.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_0-1760346979436.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_0-1760346979436.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360444iA111FD0D00E57AC9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22nirmal_masilamani_0-1760346979436.png%22%20alt%3D%22nirmal_masilamani_0-1760346979436.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22nirmal_masilamani_4-1760347171505.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_4-1760347171505.png%22%20style%3D%22width%3A%20331px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_4-1760347171505.png%22%20style%3D%22width%3A%20331px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360449iC2CC62AD7B0204D7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22nirmal_masilamani_4-1760347171505.png%22%20alt%3D%22nirmal_masilamani_4-1760347171505.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22nirmal_masilamani_1-1760347040844.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_1-1760347040844.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_1-1760347040844.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360446i9AC9351138C7C176%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22nirmal_masilamani_1-1760347040844.png%22%20alt%3D%22nirmal_masilamani_1-1760347040844.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22nirmal_masilamani_2-1760347127108.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_2-1760347127108.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_2-1760347127108.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360447i35B2B95DBB07232D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22nirmal_masilamani_2-1760347127108.png%22%20alt%3D%22nirmal_masilamani_2-1760347127108.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22nirmal_masilamani_3-1760347147113.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_3-1760347147113.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_3-1760347147113.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360448iCBAC69E2BC249D1B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22nirmal_masilamani_3-1760347147113.png%22%20alt%3D%22nirmal_masilamani_3-1760347147113.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3EPE%20Micro%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AES%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%ABCAN%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E7%A7%81%E3%81%AF%20PE%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%AB%E8%A9%B3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ES%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AF%E5%BF%85%E9%A0%88%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20DCF%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%9B%B4%E6%8E%A5%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CH4%20id%3D%22toc-hId-179614237%22%20id%3D%22toc-hId-882760691%22%20id%3D%22toc-hId-882760691%22%3ES32%20Design%20Studio%20%2B%20PE%20Micro%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FH4%3E%0A%3COL%3E%0A%3CLI%3E%0A%3CP%3EDCF%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%BA%96%E5%82%99%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EUTEST%20%E3%81%A7%E6%AC%A1%E3%81%AB%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%AD%98%E5%88%A5%E3%81%97%E3%81%BE%E3%81%99%20(0xFF%20%E3%81%A7%E5%9F%8B%E3%82%81%E3%82%89%E3%82%8C%E3%81%9F%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%80%E3%83%96%E3%83%AB%E3%83%AF%E3%83%BC%E3%83%89%E3%82%92%E6%8E%A2%E3%81%97%E3%81%BE%E3%81%99)%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E.srec%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EDCF%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%20S%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3ES32DS%20%E3%81%A7%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EPE%20Micro%20%E3%81%AE%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E6%A7%8B%E6%88%90%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E.srec%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E6%AD%A3%E3%81%97%E3%81%84%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%20(%E4%BE%8B%3A%20nxp_s32k344_1x32x1012k_hse_disabled.arp)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3EDCF%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%93%E3%83%A5%E3%83%BC%E3%81%A7%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CH4%20id%3D%22toc-hId--1627840226%22%20id%3D%22toc-hId--924693772%22%20id%3D%22toc-hId--924693772%22%3E%3CSTRONG%3EPE%20Micro%E3%81%AEPROG-HL-ARM%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FSTRONG%3E%3C%2FH4%3E%0A%3CUL%3E%0A%3CLI%3E%E3%81%93%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%20%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81JTAG%2FSWD%20%E7%B5%8C%E7%94%B1%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E.srec%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E7%9B%B4%E6%8E%A5%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3ECyclone%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E7%94%9F%E7%94%A3%E7%92%B0%E5%A2%83%E3%81%AB%E6%9C%80%E9%81%A9%E3%81%A7%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E8%A9%B3%E7%B4%B0%E6%83%85%E5%A0%B1%3A%20%3CA%20tabindex%3D%220%22%20href%3D%22https%3A%2F%2Fwww.pemicro.com%2Farm%2Fdevice_support%2FNXP_Automotive%2FS32K3xx%2FS32K344%2Findex.cfm%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%20nofollow%22%20data-tabster%3D%22%7B%22%20restorer%3D%22%22%3EPE%20Micro%20S32K344%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%9A%E3%83%BC%E3%82%B8%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3ES%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AF%E5%BF%85%E9%A0%88%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20DCF%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%9B%B4%E6%8E%A5%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3EUTEST%20%E3%81%AF%20OTP%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E6%A8%99%E6%BA%96%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E7%A7%81%E3%81%8C%E5%85%B1%E6%9C%89%E3%81%97%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81SW%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0CAN%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81C40%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E4%BE%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183851%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183851%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F13836%22%20target%3D%22_blank%22%3E%40petervlna%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3EPE%20Micro%20%E3%81%8A%E3%82%88%E3%81%B3%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%20S3%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ES30D1B00077001010000040010005A%E3%80%81%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EPE%20Micro%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AES%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%ABCAN%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3ES%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AF%E5%BF%85%E9%A0%88%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20DCF%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%9B%B4%E6%8E%A5%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AF%200x1B000700%20%E3%81%A7%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82SO%E3%80%81DCF%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%3CSTRONG%3E0x1B000770%3C%2FSTRONG%3E%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%9D%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x1B000770%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E5%80%A4%E3%81%AF0x0010000400000101%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3ESO%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E4%BE%8B%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_1-1760082759086.png%22%20style%3D%22width%3A%20683px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_1-1760082759086.png%22%20style%3D%22width%3A%20683px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_1-1760082759086.png%22%20style%3D%22width%3A%20683px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360215iEDB7130ABB5F5B5C%2Fimage-dimensions%2F683x422%3Fv%3Dv2%22%20width%3D%22683%22%20height%3D%22422%22%20role%3D%22button%22%20title%3D%22petervlna_1-1760082759086.png%22%20alt%3D%22petervlna_1-1760082759086.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EUTEST%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CDIV%20class%3D%22lia-attachment-row-element%20lia-message-attachment-link-row-element%22%3E%3CSPAN%20class%3D%22lia-link-navigation%20lia-attachment-link-disabled%20lia-link-disabled%22%20aria-disabled%3D%22true%22%3EC40_Ip_Example_S32K344.zip%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lia-attachment-row-element%20lia-media-document%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lia-attachment-row-element%20lia-media-document%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K344-Lock-step-kernel%2Fm-p%2F1930030%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K344-%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%2Fmp%2F1930030%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EDCF%20%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K344-DCF-Configurator%2Fta-p%2F1986243%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K344-DCF-%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%2Fta-p%2F1986243%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ELauterbach%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%AE%E5%A0%B4%E5%90%88%3A%3C%2FP%3E%0A%3CP%3E%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%BB%E3%83%83%E3%83%88%200x1B000790%20%25QUAD%200x0010000400000101%20%3Bdcf_client_utest_misc%3C%2FP%3E%0A%3CP%3EPE%20Micro%E3%81%AA%E3%81%A9%E3%81%AES3%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ES30D1B00077001010000040010005A%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2182894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F13836%22%20target%3D%22_blank%22%3E%40petervlna%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AF%200x1B000700%20%E3%81%A7%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82SO%E3%80%81DCF%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%3CSTRONG%3E0x1B000770%3C%2FSTRONG%3E%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3EDCF%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E4%BE%8B%E3%82%92%E6%8C%99%E3%81%92%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22nirmal_masilamani_0-1760000995795.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_0-1760000995795.png%22%20style%3D%22width%3A%20375px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_0-1760000995795.png%22%20style%3D%22width%3A%20375px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360029i1FA9D78BB5F04C30%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22nirmal_masilamani_0-1760000995795.png%22%20alt%3D%22nirmal_masilamani_0-1760000995795.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EDCF%20%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%96%87%E6%9B%B8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2182866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F13836%22%20target%3D%22_blank%22%3E%40petervlna%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3ES32K344%E3%81%A7%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AEDCF%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E4%BE%8B%E3%82%92%E8%A6%8B%E3%81%9B%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2182818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E1%20%E3%81%A4%E4%B8%8D%E6%98%8E%E3%81%AA%E7%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E3%80%81%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%92%E6%9C%89%E5%8A%B9%2F%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%20UTEST_MISC%20%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E7%9F%A5%E3%82%8B%E3%81%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3EUTEST_MISC%20%E3%81%AB%E3%81%AF%E5%9B%BA%E5%AE%9A%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E4%B8%AD%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%95%E3%82%8C%E3%82%8B%20DCF%20(%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E6%A7%8B%E6%88%90%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89)%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EUTEST_MISC%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E9%A0%98%E5%9F%9F%E3%81%AE%20UTEST%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%93%E3%81%AE%E3%82%A8%E3%83%AA%E3%82%A2%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_0-1759995633418.png%22%20style%3D%22width%3A%20800px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1759995633418.png%22%20style%3D%22width%3A%20800px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1759995633418.png%22%20style%3D%22width%3A%20800px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360018i8009D21A0207937E%2Fimage-dimensions%2F800x504%3Fv%3Dv2%22%20width%3D%22800%22%20height%3D%22504%22%20role%3D%22button%22%20title%3D%22petervlna_0-1759995633418.png%22%20alt%3D%22petervlna_0-1759995633418.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%9C%80%E5%88%9D%E3%81%AE%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AF%E3%80%81%E5%81%9C%E6%AD%A2%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%82%E3%82%8B%200xFFFF_FFFF_FFFF_FFFF%20%E3%81%A7%E5%9F%8B%E3%82%81%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82SO%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%20DCF%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2293125%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2293125%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%3CEM%3EUTEST%20%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%97%E3%80%81%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%20%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%B5%82%E4%BA%86%E3%81%97%E3%81%A6%E3%80%81%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E6%A9%9F%E8%83%BD%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%E8%A8%98%E9%8C%B2%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22yanyanwang_0-1768382402433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22yanyanwang_0-1768382402433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F372788i9B00E7A2D389DA1E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22yanyanwang_0-1768382402433.png%22%20alt%3D%22yanyanwang_0-1768382402433.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FEM%3E%3C%2FSTRONG%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F13836%22%20target%3D%22_blank%22%3E%40petervlna%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
