S32K344 Lock step core
4,966 次查看
nirmal_masilamani
Contributor V
Hello Team,
I am currently working on S32K344, we want to know, how to enable lockstep core in S32K344.
I have referred below community post,
Solved: S32K344 Lock-step kernel - NXP Community.
One thing is not clear, how to know, address for UTEST_MISC to enable/ disable lockstep.?
标记 (2)
11 回复数
4,947 次查看
petervlna
There is no fixed address of UTEST_MISC. It is not a register, it is a DCF (device configuration record) which is during reset phase copied to corresponding register/ registers.
You will program UTEST_MISC record into the UTEST memory in user area to the first available space.
It is in this area:
First available space is filled with 0xFFFF_FFFF_FFFF_FFFF which is stop record. So load you DCF record here.
Peter
3,490 次查看
yanyanwang
How can I erase the UTEST records, exit lockstep mode, and test the lockstep functionality?
Could you help me check if my current records are correct?
Thanks.@petervlna
4,937 次查看
nirmal_masilamani
Contributor V
Hello @petervlna ,
Thanks for your reply.
Can you show me an example DCF record for enabling lockstep in S32K344,
标记 (2)
4,932 次查看
nirmal_masilamani
Contributor V
Hi @petervlna ,
Below image id the data available in 0x1B000700, so i need to copy my DCF record in 0x1B000770?
Can you give me an example for DCF Records, to enable Lockstep
Is there any document for DCF details?
标记 (2)
4,910 次查看
petervlna
Yes, that is correct.
Here is how the record should looks like:
at address  0x1B000770 you will load: 0x0010000400000101
So you will modify the example here:
The example code for UTEST programming is here:
https://community.nxp.com/t5/S32K/S32K344-Lock-step-kernel/m-p/1930030
Here is DCF configurator:
https://community.nxp.com/t5/S32K-Knowledge-Base/S32K344-DCF-Configurator/ta-p/1986243
For lauterbach debugger:
data.set 0x1B000790 %QUAD 0x0010000400000101 ;dcf_client_utest_misc
and in S3 record for PE Micro and other:
S30D1B00077001010000040010005A
Peter
4,902 次查看
nirmal_masilamani
Contributor V
Hello @petervlna ,
Thank you for your reply.
S30D1B00077001010000040010005A,
We are using PE Micro, how can i use this S record?
And is it mandatory to use S record or can i program DCF record directly using the example program?
标记 (2)
4,850 次查看
petervlna
I am not familiar with PE debuggers, but looking at documentation:
Using S32 Design Studio + PE Micro Plugin
  1. Prepare your DCF record:
    • Identify the next available address in UTEST (look for the first double-word filled with 0xFF).
  2. Create a .srec file:
    • Format the DCF record into an S-record file.
  3. Configure Debugger in S32DS:
    • Use PE Micro’s plugin to set up a debugger configuration.
    • Load the .srec file as the application.
    • Use the correct flash algorithm (e.g., nxp_s32k344_1x32x1012k_hse_disabled.arp).
  4. Flash the DCF Record:
    • Start the debug session.
    • Verify the record in Memory View.
Using PE Micro’s PROG-HL-ARM Tool
  • This standalone tool supports flashing via JTAG/SWD.
  • You can load .srec or binary files and program them directly.
  • Ideal for production environments using Cyclone programmers.
More info: PE Micro S32K344 Support Page
As UTEST is just standard flash, with OTP enabled, you can use SW to program it, like I have shared. For example C40 driver example.
Peter
4,841 次查看
nirmal_masilamani
Contributor V
Hello @petervlna ,
But i am unable to debug, debugging failed with .srec files.
标记 (2)
4,787 次查看
petervlna
I am confused here.
Why you are using extension srec? The debugger states that is not an object file.
When using PE Micro tools to program devices using S-record (.srec) files, the type of S-record format you use—such as S1, S2, or S3—depends on the address range of the target device's memory.
Here’s a quick breakdown:
  • S1 records: Use 16-bit addresses (up to 64 KB). Suitable for small memory ranges.
  • S2 records: Use 24-bit addresses (up to 16 MB). Less common, but used for mid-range addressing.
  • S3 records: Use 32-bit addresses (up to 4 GB). Most commonly used for modern microcontrollers and flash programming.
For PE Micro programming:
  • If you're targeting a 32-bit MCU or using a memory map that goes beyond 64 KB, you should use S3 records.
  • PE Micro tools like PROG or Cyclone programmers typically support S3 format for flash programming.
Maybe I am wrong, but use S3 extension instead of srec.
Peter
4,704 次查看
nirmal_masilamani
Contributor V
hello @petervlna ,
I have referred the below community post for debugging using .srec file.
HOWTO: Program DCF record into UTEST flash in S32 Design Studio for Power - NXP Community
.s3 extension also not working
WIth S32DS and PEMICRO,
Is there a way to program DCF record using .srec file?
If yes, can you share any refer documents?
标记 (2)
4,577 次查看
petervlna
Yes, you can program DCF records into UTEST flash on the S32K344 using a .srec file with S32 Design Studio (S32DS) and PEMICRO tools. Here's a summary of how to do it and where to find supporting documentation:
Steps to Program DCF Record Using .srec File
  1. Prepare the DCF Record:
    • Use the S32K344 DCF Configurator tool to calculate the correct DCF record values. [community.nxp.com]
    • Identify the next available address in UTEST flash (e.g., starting from 0x1B000700) by checking for the first double-word filled with 0xFF.
  2. Create the .srec File:
    • Format the DCF record into an S3 record line.
    • Example: S30D1B00077001010000040010005A
    • This line represents a DCF record at address 0x1B000770. [community.nxp.com]
  3. Configure S32DS Debugger:
    • Create a new debug configuration in S32DS.
    • Set the .srec file as the application to load.
    • In the debugger tab, enable "Use Alternative Algorithm" and point to the correct PEMICRO flash algorithm (nxp_s32k344_1x32x980k_hse_enabled.arp).
    • Disable "Load Symbols" and "Run on Reset" since this session is only for programming.
  4. Program the Flash:
    • Start the debug session. The .srec file will be loaded into the UTEST flash.
    • After programming, verify the memory content in the Memory View.
nxp_s32k344_1x32x980k_hse_enabled.arp algorithm supports HSE-enabled devices and is suitable for UTEST flash programming.
I have never tried it by using PEMicro so I can't verify the steps from my experience.
Peter
%3CLINGO-SUB%20id%3D%22lingo-sub-2182742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K344%20%E9%94%81%E6%AD%A5%E8%8A%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%9B%A2%E9%98%9F%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%83%B3%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E5%9C%A8%20S32K344%20%E4%B8%AD%E5%90%AF%E7%94%A8%E9%94%81%E6%AD%A5%E5%86%85%E6%A0%B8%EF%BC%8C%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E7%A0%94%E7%A9%B6%20S32K344%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%82%E8%80%83%E4%BA%86%E4%B8%8B%E9%9D%A2%E7%9A%84%E7%A4%BE%E5%8C%BA%E5%B8%96%E5%AD%90%E3%80%81%20%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K344-Lock-step-kernel%2Fm-p%2F1930030%22%20target%3D%22_blank%22%3E%E5%B7%B2%E8%A7%A3%E5%86%B3%EF%BC%9AS32K344%20Lock-step%20kernel%20-%20NXP%20Community%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E4%B8%80%E7%82%B9%E4%B8%8D%E6%B8%85%E6%A5%9A%EF%BC%8C%E5%A6%82%E4%BD%95%E7%9F%A5%E9%81%93%3CSPAN%3EUTEST_MISC%20%E5%90%AF%E7%94%A8%2F%E7%A6%81%E7%94%A8%E9%94%81%E6%AD%A5%3C%2FSPAN%3E%E7%9A%84%E5%9C%B0%E5%9D%80%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2189094%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189094%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20.srec%20%E6%96%87%E4%BB%B6%E5%B0%86%20DCF%20%E8%AE%B0%E5%BD%95%E7%BC%96%E7%A8%8B%E5%88%B0%20S32K344%20%E7%9A%84%20UTEST%20%E9%97%AA%E5%AD%98%E4%B8%AD%E3%80%82%E4%BD%BF%E7%94%A8%20S32%20Design%20Studio%20(S32DS)%20%E5%92%8C%20PEMICRO%20%E5%B7%A5%E5%85%B7%E7%94%9F%E6%88%90%E6%96%87%E4%BB%B6%E3%80%82%E4%B8%8B%E9%9D%A2%E6%80%BB%E7%BB%93%E4%BA%86%E5%A6%82%E4%BD%95%E6%93%8D%E4%BD%9C%E4%BB%A5%E5%8F%8A%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E8%AF%81%E6%98%8E%E6%96%87%E4%BB%B6%EF%BC%9A%3C%2FP%3E%0A%3CH5%20id%3D%22toc-hId--1617192914%22%20id%3D%22toc-hId--1594248358%22%20id%3D%22toc-hId--1594248358%22%3E%E4%BD%BF%E7%94%A8%20.srec%20%E5%AF%B9%20DCF%20%E8%AE%B0%E5%BD%95%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E7%9A%84%E6%AD%A5%E9%AA%A4%E6%96%87%E4%BB%B6%3C%2FH5%3E%0A%3COL%3E%0A%3CLI%3E%0A%3CP%3E%E5%87%86%E5%A4%87%20DCF%20%E8%AE%B0%E5%BD%95%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E4%BD%BF%E7%94%A8%3CA%20tabindex%3D%220%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K344-DCF-Configurator%2Fta-p%2F1986243%22%20target%3D%22_blank%22%20data-tabster%3D%22%7B%22%20restorer%3D%22%22%3ES32K344%20DCF%20%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%3C%2FA%3E%E8%AE%A1%E7%AE%97%E6%AD%A3%E7%A1%AE%E7%9A%84%20DCF%20%E8%AE%B0%E5%BD%95%E5%80%BC%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K344-DCF-Configurator%2Fta-p%2F1986243%22%20target%3D%22_blank%22%3E%5Bcommunity.nxp.com%5D%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%E9%80%9A%E8%BF%87%E6%A3%80%E6%9F%A5%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%A1%AB%E5%85%A5%200xFF%20%E7%9A%84%E5%8F%8C%E5%AD%97%EF%BC%8C%E8%AF%86%E5%88%AB%20UTEST%20%E9%97%AA%E5%AD%98%E4%B8%AD%E7%9A%84%E4%B8%8B%E4%B8%80%E4%B8%AA%E5%8F%AF%E7%94%A8%E5%9C%B0%E5%9D%80%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E4%BB%8E%200x1B000700%20%E5%BC%80%E5%A7%8B%EF%BC%89%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E5%88%9B%E5%BB%BA%20.srec%E6%96%87%E4%BB%B6%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%B0%86%20DCF%20%E8%AE%B0%E5%BD%95%E6%A0%BC%E5%BC%8F%E5%8C%96%E4%B8%BA%20S3%20%E8%AE%B0%E5%BD%95%E8%A1%8C%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E4%BE%8B%E5%A6%82%EF%BC%9AS30D1B00077001010000040010005A%3CSTRONG%3ES30D1B00077001010000040010005A%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3CLI%3E%E8%BF%99%E4%B8%80%E8%A1%8C%E4%BB%A3%E8%A1%A8%E5%9C%B0%E5%9D%80%E4%B8%BA%200x1B000770%20%E7%9A%84%20DCF%20%E8%AE%B0%E5%BD%95%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K344-Lock-step-core%2Fm-p%2F2184716%22%20target%3D%22_blank%22%3E%5Bcommunity.nxp.com%5D%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E9%85%8D%E7%BD%AE%20S32DS%20%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%9C%A8%20S32DS%20%E4%B8%AD%E5%88%9B%E5%BB%BA%E6%96%B0%E7%9A%84%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E8%AE%BE%E7%BD%AE%20.srec%E6%96%87%E4%BB%B6%E4%BD%9C%E4%B8%BA%E8%A6%81%E5%8A%A0%E8%BD%BD%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E5%9C%A8%E8%B0%83%E8%AF%95%E5%99%A8%E7%A8%8E%E5%8A%A1%E6%91%8A%E9%94%80%E6%94%B6%E7%9B%8A%E4%B8%AD%EF%BC%8C%E5%90%AF%E7%94%A8%20%22%3CSTRONG%3E%E4%BD%BF%E7%94%A8%E6%9B%BF%E4%BB%A3%E7%AE%97%E6%B3%95%3C%2FSTRONG%3E%22%20%E5%B9%B6%E6%8C%87%E5%90%91%E6%AD%A3%E7%A1%AE%E7%9A%84%20PEMICRO%20%E9%97%AA%E5%AD%98%E7%AE%97%E6%B3%95%EF%BC%88%3CSTRONG%3Enxp_s32k344_1x32x980k_hse_enabled.arp%3C%2FSTRONG%3E%EF%BC%89%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E7%A6%81%E7%94%A8%20%22%20%E5%8A%A0%E8%BD%BD%E7%AC%A6%E5%8F%B7%20%22%20%E5%92%8C%20%22%20%E5%9C%A8%20RESET%20%E6%97%B6%E8%BF%90%E8%A1%8C%20%22%20%E5%9B%A0%E4%B8%BA%E6%AD%A4%E4%BC%9A%E8%AF%9D%E4%BB%85%E7%94%A8%E4%BA%8E%E7%BC%96%E7%A8%8B%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E5%AF%B9%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%90%AF%E5%8A%A8%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E3%80%82.srec%E6%96%87%E4%BB%B6%E5%B0%86%E8%A2%AB%E5%8A%A0%E8%BD%BD%E5%88%B0UTEST%E9%97%AA%E5%AD%98%E4%B8%AD%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E7%BC%96%E7%A8%8B%E5%AE%8C%E6%88%90%E5%90%8E%EF%BC%8C%E5%9C%A8%E5%86%85%E5%AD%98%E8%A7%86%E5%9B%BE%E4%B8%AD%E9%AA%8C%E8%AF%81%E5%86%85%E5%AD%98%E5%86%85%E5%AE%B9%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CBR%20%2F%3E%0A%3CP%3Enxp_s32k344_1x32x980k_hse_enabled.arp%20%E7%AE%97%E6%B3%95%E6%94%AF%E6%8C%81%E6%94%AF%E6%8C%81%20HSE%20%E7%9A%84%E8%AE%BE%E5%A4%87%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20UTEST%20%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%8E%E6%9C%AA%E5%B0%9D%E8%AF%95%E8%BF%87%E4%BD%BF%E7%94%A8%20PEMicro%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%97%A0%E6%B3%95%E9%AA%8C%E8%AF%81%E6%88%91%E7%9A%84%E7%BB%8F%E9%AA%8C%E6%AD%A5%E9%AA%A4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2187462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2187462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F13836%22%20target%3D%22_blank%22%3E%40petervlna%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%82%E8%80%83%E4%BA%86%E4%BB%A5%E4%B8%8B%E7%A4%BE%E5%8C%BA%E5%B8%96%E5%AD%90%EF%BC%8C%E4%BA%86%E8%A7%A3%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20.srec%20%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%E9%94%89%E5%88%80%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio-Knowledge-Base%2FHOWTO-Program-DCF-record-into-UTEST-flash-in-S32-Design-Studio%2Fta-p%2F1099436%22%20target%3D%22_blank%22%3E%E5%A6%82%E4%BD%95%EF%BC%9A%E5%9C%A8%20S32%20Design%20Studio%20for%20Power%20%E4%B8%AD%E5%B0%86%20DCF%20%E8%AE%B0%E5%BD%95%E7%BC%96%E7%A8%8B%E5%88%B0%20UTEST%20%E9%97%AA%E5%AD%98%20-%20NXP%20Community%3C%2FA%3E%3C%2FP%3E%3CP%3E.s3%20%E6%89%A9%E5%B1%95%E5%90%8D%E4%B9%9F%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%3C%2FP%3E%3CP%3E%E5%8C%85%E6%8B%AC%20S32DS%20%E5%92%8C%20PEMICRO%E3%80%81%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E5%8A%9E%E6%B3%95%E4%BD%BF%E7%94%A8%20.srec%20%E5%AF%B9%20DCF%20%E8%AE%B0%E5%BD%95%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%EF%BC%9F%E6%96%87%E4%BB%B6%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E5%9B%9E%E7%AD%94%E4%B8%BA%20%22%E6%98%AF%22%EF%BC%8C%E6%82%A8%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%E4%BB%BB%E4%BD%95%E5%8F%82%E8%80%83%E6%96%87%E4%BB%B6%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2185367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2185367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%AF%B9%E6%AD%A4%E6%84%9F%E5%88%B0%E5%9B%B0%E6%83%91%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BD%BF%E7%94%A8%E6%89%A9%E5%B1%95%E5%90%8D%20srec%EF%BC%9F%E8%B0%83%E8%AF%95%E5%99%A8%E6%8C%87%E5%87%BA%E8%BF%99%E4%B8%8D%E6%98%AF%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%BF%E7%94%A8%20%3CSTRONG%3EPE%20Micro%3C%2FSTRONG%3E%20%E5%B7%A5%E5%85%B7%E4%BD%BF%E7%94%A8%20%3CSTRONG%3ES%20%E8%AE%B0%E5%BD%95%20(.srec)%3C%2FSTRONG%3E%20%E6%96%87%E4%BB%B6%E5%AF%B9%E8%AE%BE%E5%A4%87%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E6%97%B6%EF%BC%8C%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%20S%20%E8%AE%B0%E5%BD%95%E6%A0%BC%E5%BC%8F%E7%9A%84%E7%B1%BB%E5%9E%8B%EF%BC%88%E4%BE%8B%E5%A6%82%20%3CSTRONG%3ES1%E3%80%81S%3C%2FSTRONG%3E%20%3CSTRONG%3E2%3C%2FSTRONG%3E%20%E6%88%96%20%3CSTRONG%3ES3%3C%2FSTRONG%3E%EF%BC%89%E5%8F%96%E5%86%B3%E4%BA%8E%E7%9B%AE%E6%A0%87%E8%AE%BE%E5%A4%87%E5%86%85%E5%AD%98%3CSTRONG%3E%E7%9A%84%E5%9C%B0%E5%9D%80%3C%2FSTRONG%3E%E8%8C%83%E5%9B%B4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E4%B8%80%E4%B8%AA%E5%BF%AB%E9%80%9F%E5%88%86%E8%A7%A3%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSTRONG%3ES1%20%E8%AE%B0%E5%BD%95%3C%2FSTRONG%3E%EF%BC%9A%E4%BD%BF%E7%94%A8%3CSTRONG%3E16%20%E4%BD%8D%E5%9C%B0%E5%9D%80%3C%2FSTRONG%3E%EF%BC%88%E6%9C%80%E5%A4%9A%2064%20KB%EF%BC%89%E3%80%82%E9%80%82%E7%94%A8%E4%BA%8E%E8%BE%83%E5%B0%8F%E7%9A%84%E5%86%85%E5%AD%98%E8%8C%83%E5%9B%B4%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3ES2%20%E8%AE%B0%E5%BD%95%3C%2FSTRONG%3E%EF%BC%9A%E4%BD%BF%E7%94%A8%3CSTRONG%3E24%20%E4%BD%8D%E5%9C%B0%E5%9D%80%3C%2FSTRONG%3E%EF%BC%88%E6%9C%80%E5%A4%9A%2016%20MB%EF%BC%89%E3%80%82%E4%B8%8D%E5%A4%AA%E5%B8%B8%E8%A7%81%EF%BC%8C%E4%BD%86%E7%94%A8%E4%BA%8E%E4%B8%AD%E7%AB%AF%E5%AF%BB%E5%9D%80%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%3CSTRONG%3ES3%20%E8%AE%B0%E5%BD%95%3C%2FSTRONG%3E%EF%BC%9A%E4%BD%BF%E7%94%A8%3CSTRONG%3E32%20%E4%BD%8D%E5%9C%B0%E5%9D%80%3C%2FSTRONG%3E%EF%BC%88%E6%9C%80%E5%A4%9A%204%20GB%EF%BC%89%E3%80%82%E6%9C%80%E5%B8%B8%E7%94%A8%E4%BA%8E%E7%8E%B0%E4%BB%A3%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E5%92%8C%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CH4%20id%3D%22toc-hId-179642074%22%20id%3D%22toc-hId--1604751462%22%20id%3D%22toc-hId--1604751462%22%3E%E7%94%A8%E4%BA%8E%20PE%20%E5%BE%AE%E5%9E%8B%E7%BC%96%E7%A8%8B%EF%BC%9A%3C%2FH4%3E%0A%3CUL%3E%0A%3CLI%3E%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%3CSTRONG%3E32%20%E4%BD%8D%20MCU%3C%2FSTRONG%3E%E6%88%96%E5%86%85%E5%AD%98%E6%98%A0%E5%B0%84%E8%B6%85%E8%BF%87%2064%20KB%EF%BC%8C%E5%88%99%E5%BA%94%E4%BD%BF%E7%94%A8%3CSTRONG%3ES3%20%E8%AE%B0%E5%BD%95%3C%2FSTRONG%3E%E3%80%82%3C%2FLI%3E%0A%3CLI%3EPE%20Micro%20%E5%B7%A5%E5%85%B7%EF%BC%88%E5%A6%82%3CSTRONG%3EPROG%3C%2FSTRONG%3E%E6%88%96%3CSTRONG%3ECyclone%20%E7%BC%96%E7%A8%8B%E5%99%A8%3C%2FSTRONG%3E%EF%BC%89%E9%80%9A%E5%B8%B8%E6%94%AF%E6%8C%81%20S3%20%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%E6%A0%BC%E5%BC%8F%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E4%B9%9F%E8%AE%B8%E6%88%91%E8%AF%B4%E9%94%99%E4%BA%86%EF%BC%8C%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20S3%20%E6%89%A9%E5%B1%95%E5%90%8D%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20srec%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F13836%22%20target%3D%22_blank%22%3E%40petervlna%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%88%91%E6%97%A0%E6%B3%95%E8%B0%83%E8%AF%95%EF%BC%8C%E4%BD%BF%E7%94%A8%20.srec%20%E8%B0%83%E8%AF%95%E5%A4%B1%E8%B4%A5%E6%96%87%E4%BB%B6%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22nirmal_masilamani_0-1760346979436.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_0-1760346979436.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_0-1760346979436.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360444iA111FD0D00E57AC9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22nirmal_masilamani_0-1760346979436.png%22%20alt%3D%22nirmal_masilamani_0-1760346979436.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22nirmal_masilamani_4-1760347171505.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_4-1760347171505.png%22%20style%3D%22width%3A%20331px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_4-1760347171505.png%22%20style%3D%22width%3A%20331px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360449iC2CC62AD7B0204D7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22nirmal_masilamani_4-1760347171505.png%22%20alt%3D%22nirmal_masilamani_4-1760347171505.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22nirmal_masilamani_1-1760347040844.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_1-1760347040844.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_1-1760347040844.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360446i9AC9351138C7C176%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22nirmal_masilamani_1-1760347040844.png%22%20alt%3D%22nirmal_masilamani_1-1760347040844.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22nirmal_masilamani_2-1760347127108.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_2-1760347127108.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_2-1760347127108.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360447i35B2B95DBB07232D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22nirmal_masilamani_2-1760347127108.png%22%20alt%3D%22nirmal_masilamani_2-1760347127108.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22nirmal_masilamani_3-1760347147113.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_3-1760347147113.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_3-1760347147113.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360448iCBAC69E2BC249D1B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22nirmal_masilamani_3-1760347147113.png%22%20alt%3D%22nirmal_masilamani_3-1760347147113.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20PE%20Micro%EF%BC%8C%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E6%AD%A4%20S%20%E8%AE%B0%E5%BD%95%EF%BC%9F%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E6%88%91%E5%AF%B9%20PE%20%E8%B0%83%E8%AF%95%E5%99%A8%E4%B8%8D%E5%A4%AA%E7%86%9F%E6%82%89%EF%BC%8C%E4%BD%86%E6%AD%A3%E5%9C%A8%E6%9F%A5%E9%98%85%E7%9B%B8%E5%85%B3%E6%96%87%E6%A1%A3%EF%BC%9A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%98%AF%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%20S%20%E8%AE%B0%E5%BD%95%EF%BC%8C%E8%BF%98%E6%98%AF%E5%8F%AF%E4%BB%A5%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%E7%A4%BA%E4%BE%8B%E7%A8%8B%E5%BA%8F%E7%BC%96%E5%88%B6%20DCF%20%E8%AE%B0%E5%BD%95%EF%BC%9F%3C%2FP%3E%0A%3CH4%20id%3D%22toc-hId-179614237%22%20id%3D%22toc-hId-882761371%22%20id%3D%22toc-hId-882761371%22%3E%E4%BD%BF%E7%94%A8%20S32%20Design%20Studio%20%2B%20PE%20Micro%20%E6%8F%92%E4%BB%B6%3C%2FH4%3E%0A%3COL%3E%0A%3CLI%3E%0A%3CP%3E%E5%87%86%E5%A4%87%E6%82%A8%E7%9A%84%20DCF%20%E8%AE%B0%E5%BD%95%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E7%A1%AE%E5%AE%9AUTEST%20%E4%B8%AD%E4%B8%8B%E4%B8%80%E4%B8%AA%E5%8F%AF%E7%94%A8%E5%9C%B0%E5%9D%80%EF%BC%88%E6%9F%A5%E6%89%BE%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%A1%AB%E6%9C%89%200xFF%20%E7%9A%84%E5%8F%8C%E5%AD%97%EF%BC%89%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E5%88%9B%E5%BB%BA%20.srec%E9%94%89%E5%88%80%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%B0%86%20DCF%20%E8%AE%B0%E5%BD%95%E6%A0%BC%E5%BC%8F%E5%8C%96%E4%B8%BA%20S%20%E8%AE%B0%E5%BD%95%E6%96%87%E4%BB%B6%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E5%9C%A8%20S32DS%20%E4%B8%AD%E9%85%8D%E7%BD%AE%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E4%BD%BF%E7%94%A8%20PE%20Micro%20%E7%9A%84%E6%8F%92%E4%BB%B6%E6%9D%A5%E8%AE%BE%E7%BD%AE%E8%B0%83%E8%AF%95%E5%99%A8%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E5%8A%A0%E8%BD%BD%20.srec%E6%96%87%E4%BB%B6%E4%BD%9C%E4%B8%BA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E4%BD%BF%E7%94%A8%E6%AD%A3%E7%A1%AE%E7%9A%84%E9%97%AA%E5%AD%98%E7%AE%97%E6%B3%95%EF%BC%88%E5%A6%82%20nxp_s32k344_1x32x1012k_hse_disabled.arp%EF%BC%89%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E9%97%AA%E5%AD%98%20DCF%20%E8%AE%B0%E5%BD%95%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%90%AF%E5%8A%A8%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E5%9C%A8%E5%86%85%E5%AD%98%E8%A7%86%E5%9B%BE%E4%B8%AD%E9%AA%8C%E8%AF%81%E8%AE%B0%E5%BD%95%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CH4%20id%3D%22toc-hId--1627840226%22%20id%3D%22toc-hId--924693092%22%20id%3D%22toc-hId--924693092%22%3E%3CSTRONG%3E%E4%BD%BF%E7%94%A8%20PE%20Micro%20%E7%9A%84%20PROG-HL-ARM%20%E5%B7%A5%E5%85%B7%3C%2FSTRONG%3E%3C%2FH4%3E%0A%3CUL%3E%0A%3CLI%3E%E8%BF%99%E4%B8%AA%E7%8B%AC%E7%AB%8B%E7%BB%84%E7%BD%91%20(SA)%20%E5%B7%A5%E5%85%B7%E6%94%AF%E6%8C%81%E9%80%9A%E8%BF%87%20JTAG%2FSWD%20%E8%BF%9B%E8%A1%8C%E5%88%B7%E6%96%B0%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8A%A0%E8%BD%BD%20.srec%E6%88%96%E8%80%85%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%B9%B6%E7%9B%B4%E6%8E%A5%E5%AF%B9%E5%AE%83%E4%BB%AC%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E9%80%82%E7%94%A8%E4%BA%8E%E4%BD%BF%E7%94%A8%20Cyclone%20%E7%BC%96%E7%A8%8B%E5%99%A8%E7%9A%84%E7%94%9F%E4%BA%A7%E7%8E%AF%E5%A2%83%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%9A%3CA%20tabindex%3D%220%22%20href%3D%22https%3A%2F%2Fwww.pemicro.com%2Farm%2Fdevice_support%2FNXP_Automotive%2FS32K3xx%2FS32K344%2Findex.cfm%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%20nofollow%22%20data-tabster%3D%22%7B%22%20restorer%3D%22%22%3EPE%20Micro%20S32K344%20%E6%94%AF%E6%8C%81%E9%A1%B5%E9%9D%A2%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%E6%98%AF%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%20S%20%E8%AE%B0%E5%BD%95%EF%BC%8C%E8%BF%98%E6%98%AF%E5%8F%AF%E4%BB%A5%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%E7%A4%BA%E4%BE%8B%E7%A8%8B%E5%BA%8F%E7%BC%96%E5%88%B6%20DCF%20%E8%AE%B0%E5%BD%95%EF%BC%9F%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E7%94%B1%E4%BA%8EUTEST%20%E5%8F%AA%E6%98%AF%E5%90%AF%E7%94%A8%E4%BA%86%20OTP%20%E7%9A%84%E6%A0%87%E5%87%86%E9%97%AA%E5%AD%98%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20SW%20%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%EF%BC%8C%E5%B0%B1%E5%83%8F%E6%88%91%E5%88%86%E4%BA%AB%E7%9A%84%E9%82%A3%E6%A0%B7%E3%80%82%E4%BE%8B%E5%A6%82%20C40%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%A4%BA%E4%BE%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183851%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183851%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F13836%22%20target%3D%22_blank%22%3E%40petervlna%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E4%BD%93%E8%82%B2%E5%BE%AE%E6%9C%BA%E5%92%8C%E5%85%B6%E4%BB%96%E7%9A%84%20S3%20%E8%AE%B0%E5%BD%95%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ES30D1B00077001010000040010005A%2C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20PE%20Micro%EF%BC%8C%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E6%AD%A4%20S%20%E8%AE%B0%E5%BD%95%EF%BC%9F%20%3C%2FP%3E%3CP%3E%E6%98%AF%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%20S%20%E8%AE%B0%E5%BD%95%EF%BC%8C%E8%BF%98%E6%98%AF%E5%8F%AF%E4%BB%A5%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%E7%A4%BA%E4%BE%8B%E7%A8%8B%E5%BA%8F%E7%BC%96%E5%88%B6%20DCF%20%E8%AE%B0%E5%BD%95%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%E4%B8%8B%E5%9B%BE%E6%A0%87%E8%AF%86%E4%BA%86%200x1B000700%20%E4%B8%AD%E7%9A%84%E5%8F%AF%E7%94%A8%E6%95%B0%E6%8D%AE%EF%BC%8C%E9%82%A3%E4%B9%88%E6%88%91%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%B0%86%20DCF%20%E8%AE%B0%E5%BD%95%E5%A4%8D%E5%88%B6%E5%88%B0%3CSTRONG%3E0x1B000770%3C%2FSTRONG%3E%20%E4%B8%AD%EF%BC%9F%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%B2%A1%E9%94%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AE%B0%E5%BD%95%E5%BA%94%E8%AF%A5%E6%98%AF%E8%BF%99%E6%A0%B7%E7%9A%84%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E5%9C%B0%E5%9D%80%200x1B000770%20%E5%A4%84%E5%8A%A0%E8%BD%BD%EF%BC%9A0x0010000400000101%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BF%AE%E6%94%B9%E8%BF%99%E9%87%8C%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_1-1760082759086.png%22%20style%3D%22width%3A%20683px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_1-1760082759086.png%22%20style%3D%22width%3A%20683px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_1-1760082759086.png%22%20style%3D%22width%3A%20683px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360215iEDB7130ABB5F5B5C%2Fimage-dimensions%2F683x422%3Fv%3Dv2%22%20width%3D%22683%22%20height%3D%22422%22%20role%3D%22button%22%20title%3D%22petervlna_1-1760082759086.png%22%20alt%3D%22petervlna_1-1760082759086.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EUTEST%E7%BC%96%E7%A8%8B%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E5%9C%A8%E8%BF%99%E9%87%8C%EF%BC%9A%20%3C%2FP%3E%0A%3CDIV%20class%3D%22lia-attachment-row-element%20lia-message-attachment-link-row-element%22%3E%3CSPAN%20class%3D%22lia-link-navigation%20lia-attachment-link-disabled%20lia-link-disabled%22%20aria-disabled%3D%22true%22%3EC40_Ip_Example_S32K344.zip%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lia-attachment-row-element%20lia-media-document%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lia-attachment-row-element%20lia-media-document%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K344-Lock-step-kernel%2Fm-p%2F1930030%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K344-Lock-step-kernel%2Fm-p%2F1930030%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E9%87%8C%E6%98%AF%20DCF%20%E9%85%8D%E7%BD%AE%E5%99%A8%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K344-DCF-Configurator%2Fta-p%2F1986243%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K344-DCF-Configurator%2Fta-p%2F1986243%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E7%94%A8%E4%BA%8E%E5%8A%B3%E7%89%B9%E5%B7%B4%E8%B5%AB%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%9A%20%3C%2FP%3E%0A%3CP%3Edata.set%200x1B000790%25QUAD%200x0010000400000101%20%3Bdcf_client_utest_misc%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E5%8F%8A%20S3%20%E8%AE%B0%E5%BD%95%E4%B8%AD%E7%9A%84%20PE%20Micro%20%E5%92%8C%E5%85%B6%E4%BB%96%EF%BC%9A%3C%2FP%3E%0A%3CP%3ES30D1B00077001010000040010005A%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2182894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F13836%22%20target%3D%22_blank%22%3E%40petervlna%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%B8%8B%E5%9B%BE%E6%A0%87%E8%AF%86%E4%BA%86%200x1B000700%20%E4%B8%AD%E7%9A%84%E5%8F%AF%E7%94%A8%E6%95%B0%E6%8D%AE%EF%BC%8C%E9%82%A3%E4%B9%88%E6%88%91%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%B0%86%20DCF%20%E8%AE%B0%E5%BD%95%E5%A4%8D%E5%88%B6%E5%88%B0%3CSTRONG%3E0x1B000770%3C%2FSTRONG%3E%20%E4%B8%AD%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%83%BD%E5%90%A6%E7%BB%99%E6%88%91%E4%B8%80%E4%B8%AA%20DCF%20%E8%AE%B0%E5%BD%95%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%8C%E4%BB%A5%E5%90%AF%E7%94%A8%20Lockstep%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22nirmal_masilamani_0-1760000995795.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_0-1760000995795.png%22%20style%3D%22width%3A%20375px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_0-1760000995795.png%22%20style%3D%22width%3A%20375px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360029i1FA9D78BB5F04C30%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22nirmal_masilamani_0-1760000995795.png%22%20alt%3D%22nirmal_masilamani_0-1760000995795.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E5%85%B3%E4%BA%8E%20DCF%20%E8%AF%A6%E6%83%85%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2182866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182866%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F13836%22%20target%3D%22_blank%22%3E%40petervlna%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E8%83%BD%E5%90%A6%E7%BB%99%E6%88%91%E7%9C%8B%E4%B8%80%E4%B8%AA%3CSPAN%3E%E5%9C%A8%20S32K344%20%E4%B8%AD%E5%90%AF%E7%94%A8%E9%94%81%E5%AE%9A%E6%AD%A5%E8%BF%9B%E7%9A%84%20DCF%20%E8%AE%B0%E5%BD%95%3C%2FSPAN%3E%E7%A4%BA%E4%BE%8B%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2182818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%E6%9C%89%E4%B8%80%E7%82%B9%E4%B8%8D%E6%B8%85%E6%A5%9A%EF%BC%8C%E5%A6%82%E4%BD%95%E7%9F%A5%E9%81%93%20UTEST_MISC%20%E5%90%AF%E7%94%A8%2F%E7%A6%81%E7%94%A8%E9%94%81%E6%AD%A5%E7%9A%84%E5%9C%B0%E5%9D%80%EF%BC%9F%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3EUTEST_MISC%E6%B2%A1%E6%9C%89%E5%9B%BA%E5%AE%9A%E5%9C%B0%E5%9D%80%E3%80%82%E5%AE%83%E4%B8%8D%E6%98%AF%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E8%80%8C%E6%98%AFDCF%EF%BC%88%E8%AE%BE%E5%A4%87%E9%85%8D%E7%BD%AE%E8%AE%B0%E5%BD%95%EF%BC%89%EF%BC%8C%E5%9C%A8RESET%E9%98%B6%E6%AE%B5%E5%B0%86%E5%85%B6%E5%A4%8D%E5%88%B6%E5%88%B0%E7%9B%B8%E5%BA%94%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%2F%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%B0%86%E6%8A%8A%20UTEST_MISC%20%E8%AE%B0%E5%BD%95%E7%BC%96%E5%85%A5%E7%94%A8%E6%88%B7%E5%8C%BA%E7%9A%84%20UTEST%20%E5%86%85%E5%AD%98%E4%B8%AD%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%8F%AF%E7%94%A8%E7%A9%BA%E9%97%B4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B0%B1%E5%9C%A8%E8%BF%99%E4%B8%AA%E5%8C%BA%E5%9F%9F%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_0-1759995633418.png%22%20style%3D%22width%3A%20800px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1759995633418.png%22%20style%3D%22width%3A%20800px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1759995633418.png%22%20style%3D%22width%3A%20800px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360018i8009D21A0207937E%2Fimage-dimensions%2F800x504%3Fv%3Dv2%22%20width%3D%22800%22%20height%3D%22504%22%20role%3D%22button%22%20title%3D%22petervlna_0-1759995633418.png%22%20alt%3D%22petervlna_0-1759995633418.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%8F%AF%E7%94%A8%E7%A9%BA%E9%97%B4%E5%A1%AB%E5%85%A5%200xFFFF_FFFFF_FFFFF_FFFFF%EF%BC%8C%E5%8D%B3%E5%81%9C%E6%AD%A2%E8%AE%B0%E5%BD%95%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E8%AF%B7%E5%9C%A8%E6%AD%A4%E5%8A%A0%E8%BD%BD%E6%82%A8%E7%9A%84%20DCF%20%E8%AE%B0%E5%BD%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EPeter%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2293125%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Lock%20step%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2293125%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%E5%A6%82%E4%BD%95%E6%B8%85%E9%99%A4UTEST%20%E8%AE%B0%E5%BD%95%E3%80%81%E9%80%80%E5%87%BA%E9%94%81%E6%AD%A5%E6%A8%A1%E5%BC%8F%E5%B9%B6%E6%B5%8B%E8%AF%95%E9%94%81%E6%AD%A5%E5%8A%9F%E8%83%BD%EF%BC%9F%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E6%88%91%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E6%88%91%E7%9B%AE%E5%89%8D%E7%9A%84%E8%AE%B0%E5%BD%95%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E5%90%97%EF%BC%9F%20%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22yanyanwang_0-1768382402433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22yanyanwang_0-1768382402433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F372788i9B00E7A2D389DA1E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22yanyanwang_0-1768382402433.png%22%20alt%3D%22yanyanwang_0-1768382402433.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FEM%3E%3C%2FSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F13836%22%20target%3D%22_blank%22%3E%40petervlna%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
