S32K322: Watchdog (SWT) interrupt not triggering and no reset after timeout
210件の閲覧回数
yusupkhan241
Hello NXP team,
I’m currently testing the SWT watchdog functionality on multiple S32K3 devices and found differences in behavior across parts.
I’ve attached my full S32 Design Studio workspace for reference, but here’s a summary of what I observed:
Tested Configurations
MCU
EVK
Behavior
S32K311
S32K311 EVK
Watchdog timeout interrupt callback triggered as expected.
Reset on timeout not occurring.
S32K344
S32K344 EVK
S32K322
Custom board (100-pin)
Watchdog timeout  interrupt callback not invoked and Reset on timeout not occurring , even though SWT is initialized and serviced.
Software & Environment
  • MCU: S32K322 (100-pin package)
  • RTD: S32K3_RTD_6_0_0_QLP04_D2508_ASR_REL_4_7_REV_0000_20250822
  • IDE: S32 Design Studio for S32 Platform
  • SDK components used:
    • Swt_Ip
    • Clock_Ip
    • IntCtrl_Ip
    • Pit_Ip
Issue Summary
  1. Reset on timeout is not working on S32K311 and S32K344.
    The watchdog interrupt triggers correctly, but no device reset occurs even when the watchdog is intentionally left unserviced.
  2. SWT interrupt callback is not invoked on S32K322 (100-pin).
    The same code and configuration that worked on S32K311 and S32K344 fails to generate an interrupt here.
    PIT interrupt works fine — so the NVIC setup seems functional.
What I’ve Verified
  • SWT0 interrupt vector is enabled and mapped:
  • IntCtrl_Ip_InstallHandler(SWT0_IRQn, Swt_Ip_Swt0_Isr, NULL_PTR);
  • PIT timer interrupt is firing correctly → confirms interrupt controller setup is working.
  • The watchdog counter appears to be running (checked through debugger).
  • No lock or configuration error bits set in the SWT registers.
  • Tested with and without servicing the watchdog — no interrupt seen on S32K322.
  • Used default RTD Swt_Ip_Cfg0 configuration.
Code Snippet
Here’s a simplified version of my test case:
void Swt_CallbackNotification0(void)
    u32NumOfNotifications++;
int main(void)
    Clock_Ip_InitClock(&Clock_Ip_aClockConfig[0]);
    IntCtrl_Ip_Init(&IntCtrlConfig_0);
    IntCtrl_Ip_InstallHandler(PIT0_IRQn, PIT_0_ISR, NULL_PTR);
    Pit_Ip_Init(PIT_INST_0, &PIT_0_InitConfig_PB_BOARD_InitPeripherals);
    Pit_Ip_InitChannel(PIT_INST_0, PIT_0_CH_0);
    Pit_Ip_EnableChannelInterrupt(PIT_INST_0, CH_0);
    Pit_Ip_StartChannel(PIT_INST_0, CH_0, PIT_PERIOD);
    Swt_Ip_Init(SWT_INST, &Swt_Ip_Cfg0);
    for (uint32_t i = 0; i < NUM_OF_NOTIFICATIONS; i++)
        Swt_Ip_Service(SWT_INST);
        while ((u32NumOfNotifications <= i)) { }
    Swt_Ip_Deinit(SWT_INST);
    DevAssert(TRUE);
Request for Support
  1. Is there any known difference in SWT interrupt routing or configuration on the S32K322 (100-pin) variant compared to S32K311/344?
  2. Are there any SoC-level differences (e.g., reset domains, RSTGEN configuration, or PRAM protection) that prevent SWT reset or interrupt generation?
  3. Could you please confirm whether reset-on-timeout is expected to work with the current RTD (6.0.0) configuration?
  • Full S32 Design Studio workspace (ZIP)
Thank you for your support — looking forward to your feedback so I can resolve this quickly.
Yusup
145件の閲覧回数
VaneB
Hi @yusupkhan241
Since the PIT is functioning as expected, let’s isolate the issue by working only with a project that involves the SWT. Could you please try the following example code?
Example S32K312 SWT DS3.5 RTD300
Related to Reset on Timeout, the SWT can be configured to generate either a reset or an interrupt when a timeout occurs. For details, refer to sections 66.5.1.2, 66.5.1.2.1, and 66.5.1.2.2 of the S32K3xx Reference Manual, Rev. 11.
In ConfigTools → Peripheral Tool, these timeout responses can be configured using the following parameters:
  • Operation Mode → SWT->CR[ITR]
  • Reset on Invalid Access → SWT->CR[RIA]
BR, VaneB
%3CLINGO-SUB%20id%3D%22lingo-sub-2203460%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K322%3A%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%20(SWT)%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E5%BE%8C%E3%81%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2203460%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AE%E7%9A%86%E6%A7%98%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E8%A4%87%E6%95%B0%E3%81%AE%20S32K3%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%3CSTRONG%3ESWT%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E6%A9%9F%E8%83%BD%3C%2FSTRONG%3E%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E9%83%A8%E5%93%81%E9%96%93%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%AB%E9%81%95%E3%81%84%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81%20%3CSTRONG%3ES32%20Design%20Studio%20%E3%81%AE%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%3C%2FSTRONG%3E%E5%85%A8%E4%BD%93%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E7%A7%81%E3%81%8C%E8%A6%B3%E5%AF%9F%E3%81%97%E3%81%9F%E5%86%85%E5%AE%B9%E3%81%AE%E6%A6%82%E8%A6%81%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%86%E3%82%B9%E3%83%88%E6%B8%88%E3%81%BF%E3%81%AE%E6%A7%8B%E6%88%90%3C%2FSTRONG%3E%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%3CP%3E%3CSTRONG%3EMCU%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%3E%3CP%3E%3CSTRONG%3EEVK%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%3E%3CP%3E%3CSTRONG%3E%E5%8B%95%E4%BD%9C%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CP%3E%3CSTRONG%3ES32K311%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%3E%3CP%3ES32K311%20EVK%3C%2FP%3E%3C%2FTD%3E%3CTD%3E%3CP%3E%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%8C%E6%9C%9F%E5%BE%85%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E6%99%82%E3%81%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%AF%3CSTRONG%3E%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CP%3E%3CSTRONG%3ES32K344%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%3E%3CP%3ES32K344%20EVK%3C%2FP%3E%3C%2FTD%3E%3CTD%3E%3CP%3E%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%8C%E6%9C%9F%E5%BE%85%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E6%99%82%E3%81%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%AF%3CSTRONG%3E%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CP%3E%3CSTRONG%3ES32K322%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%3E%3CP%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%EF%BC%88100%E3%83%94%E3%83%B3%EF%BC%89%3C%2FP%3E%3C%2FTD%3E%3CTD%3E%3CP%3ESWT%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%80%81%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%3CSTRONG%3E%E3%81%8C%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%9A%3C%2FSTRONG%3E%E3%80%81%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E6%99%82%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%AF%3CSTRONG%3E%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E7%92%B0%E5%A2%83%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3EMCU%3A%3C%2FSTRONG%3E%20S32K322%20(100%E3%83%94%E3%83%B3%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8)%3C%2FLI%3E%3CLI%3E%3CSTRONG%3ERTD%3A%3C%2FSTRONG%3E%20S32K3_RTD_6_0_0_QLP04_D2508_ASR_REL_4_7_REV_0000_20250822%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EIDE%3A%3C%2FSTRONG%3E%20S32%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E7%94%A8%20S32%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%82%B8%E3%82%AA%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%20SDK%20%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%3A%3C%2FSTRONG%3E%3C%2FLI%3E%3CUL%3E%3CLI%3E%E3%82%B9%E3%83%AF%E3%83%83%E3%83%88_%E3%82%A4%E3%83%97%3C%2FLI%3E%3CLI%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF_Ip%3C%2FLI%3E%3CLI%3EIntCtrl_Ip%3C%2FLI%3E%3CLI%3E%E3%83%94%E3%83%83%E3%83%88%E3%83%BB%E3%82%A4%E3%83%97%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E%E5%95%8F%E9%A1%8C%E3%81%AE%E6%A6%82%E8%A6%81%3C%2FSTRONG%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CSTRONG%3E%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E6%99%82%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%AF%20S32K311%20%E3%81%8A%E3%82%88%E3%81%B3%20S32K344%20%E3%81%A7%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSTRONG%3E%E3%80%82%3CBR%20%2F%3E%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%81%8C%E6%84%8F%E5%9B%B3%E7%9A%84%E3%81%AB%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%A7%E3%82%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLI%3E%3CLI%3ES32K322%20(100%20%E3%83%94%E3%83%B3)%20%E3%81%A7%E3%81%AF%3CSTRONG%3ESWT%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%8C%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSTRONG%3E%E3%80%82%3CBR%20%2F%3ES32K311%20%E3%81%8A%E3%82%88%E3%81%B3%20S32K344%20%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%9F%E5%90%8C%E3%81%98%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E6%A7%8B%E6%88%90%E3%81%8C%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E7%94%9F%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3EPIT%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82SO%E3%80%81NVIC%20%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSTRONG%3E%E7%A7%81%E3%81%8C%E6%A4%9C%E8%A8%BC%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3ESWT0%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%80%81%E3%83%9E%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3EIntCtrl_Ip_InstallHandler(SWT0_IRQn%E3%80%81Swt_Ip_Swt0_Isr%E3%80%81NULL_PTR)%3B%3C%2FLI%3E%3CLI%3EPIT%20%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%E2%86%92%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AF%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%20(%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%A7%E7%A2%BA%E8%AA%8D%E6%B8%88%E3%81%BF)%E3%80%82%3C%2FLI%3E%3CLI%3ESWT%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E3%83%AD%E3%83%83%E3%82%AF%E3%81%BE%E3%81%9F%E3%81%AF%E6%A7%8B%E6%88%90%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLI%3E%3CLI%3E%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%81%AE%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%82%E3%82%8A%E3%81%A8%E3%81%AA%E3%81%97%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20S32K322%20%E3%81%A7%E3%81%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AF%E8%A6%8B%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%20RTD%20Swt_Ip_Cfg0%3C%2FSTRONG%3E%E6%A7%8B%E6%88%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%82%B9%E3%83%8B%E3%83%9A%E3%83%83%E3%83%88%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E7%A7%81%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88CASE%E3%81%AE%E7%B0%A1%E7%95%A5%E7%89%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Evoid%20Swt_CallbackNotification0(void)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3Eu32%E9%80%9A%E7%9F%A5%E6%95%B0%2B%2B%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Eint%20main(void)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3EClock_Ip_InitClock(%26amp%3BClock_Ip_aClockConfig%5B0%5D)%3B%3C%2FP%3E%3CP%3EIntCtrl_Ip_Init(%26amp%3BIntCtrlConfig_0)%3B%3C%2FP%3E%3CP%3EIntCtrl_Ip_InstallHandler(SWT0_IRQn%E3%80%81Swt_Ip_Swt0_Isr%E3%80%81NULL_PTR)%3B%3C%2FP%3E%3CP%3EIntCtrl_Ip_InstallHandler(PIT0_IRQn%E3%80%81PIT_0_ISR%E3%80%81NULL_PTR)%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPit_Ip_Init(PIT_INST_0%E3%80%81%26amp%3BPIT_0_InitConfig_PB_BOARD_InitPeripherals)%3B%3C%2FP%3E%3CP%3EPit_Ip_InitChannel(PIT_INST_0%E3%80%81PIT_0_CH_0)%3B%3C%2FP%3E%3CP%3EPit_Ip_EnableChannelInterrupt(PIT_INST_0%E3%80%81CH_0)%3B%3C%2FP%3E%3CP%3EPit_Ip_StartChannel(PIT_INST_0%E3%80%81CH_0%E3%80%81PIT_PERIOD)%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ESwt_Ip_Init(SWT_INST%2C%20%26amp%3BSwt_Ip_Cfg0)%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E(uint32_t%20i%20%3D%200%3B%20i%20%26lt%3B%20%E9%80%9A%E7%9F%A5%E6%95%B0%3B%20i%2B%2B)%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FP%3E%3CP%3ESwt_Ip_Service(SWT_INST)%3B%3C%2FP%3E%3CP%3Ewhile%20((u32NumOfNotifications%20%26lt%3B%3D%20i))%20%7B%20%7D%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ESwt_Ip_Deinit(SWT_INST)%3B%3C%2FP%3E%3CP%3EDevAssert(TRUE)%3B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%3C%2FSTRONG%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CSTRONG%3ES32K322%20(100%20%E3%83%94%E3%83%B3)%3C%2FSTRONG%3E%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%E3%81%A8%20S32K311%2F344%20%E3%81%AE%3CSTRONG%3ESWT%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%BE%E3%81%9F%E3%81%AF%E6%A7%8B%E6%88%90%E3%81%AB%E4%BD%95%E3%81%8B%E6%97%A2%E7%9F%A5%E3%81%AE%E9%81%95%E3%81%84%3C%2FSTRONG%3E%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3ESWT%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E7%94%9F%E6%88%90%E3%82%92%E5%A6%A8%E3%81%92%E3%82%8B%3CSTRONG%3ESoC%20%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E9%81%95%E3%81%84%3C%2FSTRONG%3E(%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%80%81RSTGEN%20%E6%A7%8B%E6%88%90%E3%80%81PRAM%20%E4%BF%9D%E8%AD%B7%E3%81%AA%E3%81%A9)%20%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%20RTD%20(6.0.0)%20%E6%A7%8B%E6%88%90%E3%81%A7%3CSTRONG%3Ereset-on-timeout%3C%2FSTRONG%3E%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSTRONG%3E%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3ES32%20Design%20Studio%20%E3%81%AE%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%20(ZIP)%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E4%BB%B6%E3%82%92%E8%BF%85%E9%80%9F%E3%81%AB%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%80%81%E7%9A%86%E6%A7%98%E3%81%AE%E3%83%95%E3%82%A3%E3%83%BC%E3%83%89%E3%83%90%E3%83%83%E3%82%AF%E3%82%92%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%3CSTRONG%3E%E3%83%A6%E3%82%B5%E3%83%83%E3%83%97%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K322%3A%20Watchdog%20(SWT)%20interrupt%20not%20triggering%20and%20no%20reset%20after%20timeout%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252570%22%20target%3D%22_blank%22%3E%40yusupkhan241%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EPIT%20%E3%81%AF%E6%9C%9F%E5%BE%85%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81SWT%20%E3%81%8C%E9%96%A2%E4%BF%82%E3%81%99%E3%82%8B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%81%BF%E3%81%A7%E4%BD%9C%E6%A5%AD%E3%81%97%E3%81%A6%E5%95%8F%E9%A1%8C%E3%82%92%E5%88%87%E3%82%8A%E5%88%86%E3%81%91%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FExample-S32K312-SWT-DS3-5-RTD300%2Fta-p%2F1800559%22%20target%3D%22_blank%22%3E%E4%BE%8B%3A%20S32K312%20SWT%20DS3.5%20RTD300%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E6%99%82%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%80%81%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%20SWT%20%E3%82%92%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B366.5.1.2%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82S32K3xx%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%20Rev.%2011%20%E3%81%AE%2066.5.1.2.1%20%E3%81%8A%E3%82%88%E3%81%B3%2066.5.1.2.2%E3%80%82%3C%2FP%3E%0A%3CP%3EConfigTools%20%E2%86%92%20Peripheral%20Tool%20%E3%81%A7%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E5%BF%9C%E7%AD%94%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%8B%95%E4%BD%9C%E3%83%A2%E3%83%BC%E3%83%89%20%E2%86%92%20SWT-%26gt%3BCR%5BITR%5D%3C%2FLI%3E%0A%3CLI%3E%E7%84%A1%E5%8A%B9%E3%81%AA%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E6%99%82%E3%81%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E2%86%92%20SWT-%26gt%3BCR%5BRIA%5D%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%E3%80%81%E3%83%B4%E3%82%A7%E3%82%A4%E3%83%B3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
