S32K312 boot with HSE enabled
2,038 次查看
strofald
I have flashed HSE FW on my S32K312 microcontroller, and I have enabled the HSE FW Feature flag in UTEST.
Anyway I experience the following: whenever I flash a new application FW, right after flashing if I step with the debugger (without executing any instruction, just the first one from the startup code), an Hard Fault is triggered. If instead, after flashing, I perform a reset with the debugger, the Hard Fault does not happen.
How is this possible?
May this be related with the IVT configuration?
I am using the standard linker and startup files that are provided with the Platform module in RTD v5.0.0, I attached them below (renamed in .s.c due to update policies)
I also uploaded the .map file of the application.
标记 (4)
1,935 次查看
strofald
I solved the issue by updating my debugger client (PLS UDE) to version 2024.05
1,936 次查看
strofald
2,007 次查看
lukaszadrapa
Hi @strofald
I have never seen such behavior and I can't see a reason for that.
What kind of debugger do you use? It sound like problem of debugger...
Lukas
%3CLINGO-SUB%20id%3D%22lingo-sub-2085758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%90%AF%E7%94%A8%20HSE%20%E7%9A%84%20S32K312%20%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2085758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%9C%A8%E6%88%91%E7%9A%84%20S32K312%20%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E4%B8%8A%E5%88%B7%E5%85%A5%E4%BA%86%20HSE%20FW%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%B7%B2%E7%BB%8F%E5%9C%A8%20UTEST%20%E4%B8%AD%E5%90%AF%E7%94%A8%E4%BA%86%20HSE%20FW%20%E5%8A%9F%E8%83%BD%E6%A0%87%E5%BF%97%E3%80%82%3CBR%20%2F%3E%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%EF%BC%8C%E6%88%91%E7%BB%8F%E5%8E%86%E4%BA%86%E4%BB%A5%E4%B8%8B%E6%83%85%E5%86%B5%EF%BC%9A%E6%AF%8F%E5%BD%93%E6%88%91%E5%88%B7%E6%96%B0%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%20FW%20%E6%97%B6%EF%BC%8C%E5%88%B7%E6%96%B0%E5%90%8E%E5%A6%82%E6%9E%9C%E6%88%91%E4%BD%BF%E7%94%A8%E8%B0%83%E8%AF%95%E5%99%A8%E8%BF%9B%E8%A1%8C%E5%8D%95%E6%AD%A5%E6%89%A7%E8%A1%8C%EF%BC%88%E4%B8%8D%E6%89%A7%E8%A1%8C%E4%BB%BB%E4%BD%95%E6%8C%87%E4%BB%A4%EF%BC%8C%E5%8F%AA%E6%89%A7%E8%A1%8C%E5%90%AF%E5%8A%A8%E4%BB%A3%E7%A0%81%E4%B8%AD%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E6%8C%87%E4%BB%A4%EF%BC%89%EF%BC%8C%E5%B0%B1%E4%BC%9A%E8%A7%A6%E5%8F%91%E7%A1%AC%E6%95%85%E9%9A%9C%E3%80%82%E7%9B%B8%E5%8F%8D%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%9C%A8%E9%97%AA%E7%83%81%E4%B9%8B%E5%90%8E%E6%88%91%E4%BD%BF%E7%94%A8%E8%B0%83%E8%AF%95%E5%99%A8%E6%89%A7%E8%A1%8C%E9%87%8D%E7%BD%AE%EF%BC%8C%E5%88%99%E4%B8%8D%E4%BC%9A%E5%8F%91%E7%94%9F%E7%A1%AC%E6%95%85%E9%9A%9C%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E6%80%8E%E4%B9%88%E5%8F%AF%E8%83%BD%E5%91%A2%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%BF%99%E5%8F%AF%E8%83%BD%E4%B8%8E%20IVT%20%E9%85%8D%E7%BD%AE%E6%9C%89%E5%85%B3%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20RTD%20v5.0.0%20%E4%B8%AD%E7%9A%84%E5%B9%B3%E5%8F%B0%E6%A8%A1%E5%9D%97%E6%8F%90%E4%BE%9B%E7%9A%84%E6%A0%87%E5%87%86%E9%93%BE%E6%8E%A5%E5%99%A8%E5%92%8C%E5%90%AF%E5%8A%A8%E6%96%87%E4%BB%B6%EF%BC%8C%E6%88%91%E5%B0%86%E5%AE%83%E4%BB%AC%E9%99%84%E5%8A%A0%E5%9C%A8%E4%B8%8B%E9%9D%A2%EF%BC%88%E7%94%B1%E4%BA%8E%E6%9B%B4%E6%96%B0%E6%94%BF%E7%AD%96%EF%BC%8C%E5%9C%A8%20.sc%20%E4%B8%AD%E9%87%8D%E5%91%BD%E5%90%8D%EF%BC%89%3CBR%20%2F%3E%E6%88%91%E8%BF%98%E4%B8%8A%E4%BC%A0%E4%BA%86.map%E7%94%B3%E8%AF%B7%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2089135%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%90%AF%E7%94%A8%20HSE%20%E7%9A%84%20S32K312%20%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2089135%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E9%80%9A%E8%BF%87%E5%B0%86%E8%B0%83%E8%AF%95%E5%99%A8%E5%AE%A2%E6%88%B7%E7%AB%AF%EF%BC%88PLS%20UDE%EF%BC%89%E6%9B%B4%E6%96%B0%E5%88%B0%E7%89%88%E6%9C%AC%202024.05%20%E8%A7%A3%E5%86%B3%E4%BA%86%E8%AF%A5%E9%97%AE%E9%A2%98%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2086491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%90%AF%E7%94%A8%20HSE%20%E7%9A%84%20S32K312%20%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2086491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229151%22%20target%3D%22_blank%22%3E%40strofald%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%8E%E6%9C%AA%E8%A7%81%E8%BF%87%E8%BF%99%E6%A0%B7%E7%9A%84%E8%A1%8C%E4%B8%BA%EF%BC%8C%E4%B9%9F%E4%B8%8D%E6%98%8E%E7%99%BD%E5%85%B6%E4%B8%AD%E7%9A%84%E5%8E%9F%E5%9B%A0%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E4%BB%80%E4%B9%88%E6%A0%B7%E7%9A%84%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%9F%E8%BF%99%E5%90%AC%E8%B5%B7%E6%9D%A5%E5%83%8F%E6%98%AF%E8%B0%83%E8%AF%95%E5%99%A8%E7%9A%84%E9%97%AE%E9%A2%98......%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E
