S32K312 - a MCAL pointer variable point to a self-defined variable
1,667件の閲覧回数
yumi
Hi, I am using s32k312 and MCAL version is 5.0.0, the startup and linker files is based on MCAL package.
I defined a bool variable named LibDiagCom_Initialized, and I found in the LiveWatch and memory it was changed unexpectedly. I set a data breakpoint and found a struct variable with a pointer was changing the memory.
So is this pointer a wilder pointer?
3 返答(返信)
1,577件の閲覧回数
Senlent
Hi@yumi
From the screenshot you provided, I don't see any relationship between "LibDiagCom_Initialized" and "Lpspi_Ip_axStateStructure". Is there a problem?
My understanding of a "dangling pointer"(野指针) is usually that it points to an unknown, random location. I don't see that problem here.
1,476件の閲覧回数
yumi
Hi Selent,
From the Live Watch, you can see the location of 'LibDiagCom_Initialized' is 0x2040 37df, and the pointer RxBuffer in Lpspi_Ip_axStateStructure point to 0x204037DC.
I set a data breakpoint for LibDiagCom_Initialized, the scenery is LibDiagCom_Initialized value is changed by the RxBuffer at the data breakpoint, as shows in another picture.
So my question is:
Shouldn't the RxBuffer in Lpspi_Ip_axStateStructure point to somewhere at initialization? If not, is it a dangling pointer?
1,452件の閲覧回数
Senlent
Hi@yumi
In the image you provided, I did not see that the value of "LibDiagCom_Initialized" had changed.
You'd better provide me with your test routine, because I still don't understand it. I don't see any problems in the images you provided.
%3CLINGO-SUB%20id%3D%22lingo-sub-2245903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K312%20-%20MCAL%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E5%A4%89%E6%95%B0%E3%81%AF%E8%87%AA%E5%B7%B1%E5%AE%9A%E7%BE%A9%E5%A4%89%E6%95%B0%E3%82%92%E6%8C%87%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2245903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E7%A7%81%E3%81%AF%20s32k312%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81MCAL%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%205.0.0%20%E3%81%A7%E3%81%99%E3%80%82%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%20MCAL%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ELibDiagCom_Initialized%20%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%20bool%20%E5%A4%89%E6%95%B0%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81LiveWatch%20%E3%81%A8%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%A7%E4%BA%88%E6%9C%9F%E3%81%9B%E3%81%9A%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E3%82%92%E6%8C%81%E3%81%A4%E6%A7%8B%E9%80%A0%E4%BD%93%E5%A4%89%E6%95%B0%E3%81%8C%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3ESO%E3%80%81%E3%81%93%E3%81%AE%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AF%E3%83%AF%E3%82%A4%E3%83%AB%E3%83%80%E3%83%BC%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2246635%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K312%20-%20a%20MCAL%20pointer%20variable%20point%20to%20a%20self-defined%20variable%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2246635%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F106272%22%20target%3D%22_blank%22%3E%40yumi%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%8B%E3%82%89%E3%81%AF%E3%80%81%E3%80%8CLibDiagCom_Initialized%E3%80%8D%E3%81%A8%E3%80%8CLpspi_Ip_axStateStructure%E3%80%8D%E3%81%AE%E9%96%93%E3%81%AB%E9%96%A2%E4%BF%82%E3%81%8C%E8%A6%8B%E5%BD%93%E3%81%9F%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BD%95%E3%81%8B%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%80%8C%E3%81%B6%E3%82%89%E4%B8%8B%E3%81%8C%E3%81%A3%E3%81%9F%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E3%80%8D%EF%BC%88%E9%87%8E%E6%8C%87%E9%92%88%EF%BC%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E7%A7%81%E3%81%AE%E7%90%86%E8%A7%A3%E3%81%AF%E3%80%81%E9%80%9A%E5%B8%B8%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E6%9C%AA%E7%9F%A5%E3%81%AE%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%81%AA%E5%A0%B4%E6%89%80%E3%82%92%E6%8C%87%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%81%9D%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A6%8B%E5%BD%93%E3%81%9F%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2251607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K312%20-%20a%20MCAL%20pointer%20variable%20point%20to%20a%20self-defined%20variable%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2251607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%BB%E3%83%AC%E3%83%B3%E3%83%88%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%A9%E3%82%A4%E3%83%96%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%81%8B%E3%82%89%E3%80%81%E3%80%8CLibDiagCom_Initialized%E3%80%8D%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%8C%200x2040%2037df%20%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81Lpspi_Ip_axStateStructure%20%E5%86%85%E3%81%AE%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%20RxBuffer%20%E3%81%8C%200x204037DC%20%E3%82%92%E6%8C%87%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ELibDiagCom_Initialized%20%E3%81%AB%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%88%A5%E3%81%AE%E5%9B%B3%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%A7%20RxBuffer%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%20LibDiagCom_Initialized%20%E5%80%A4%E3%81%8C%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESO%E3%80%81%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ELpspi_Ip_axStateStructure%20%E3%81%AE%20RxBuffer%20%E3%81%AF%E5%88%9D%E6%9C%9F%E5%8C%96%E6%99%82%E3%81%AB%E3%81%A9%E3%81%93%E3%81%8B%E3%82%92%E6%8C%87%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E3%83%80%E3%83%B3%E3%82%B0%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%9D%E3%82%A4%E3%83%B3%E3%82%BF%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2252152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K312%20-%20a%20MCAL%20pointer%20variable%20point%20to%20a%20self-defined%20variable%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22mailto%3AHi%40yumi%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%40yumi%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E7%94%BB%E5%83%8F%E3%81%A7%E3%81%AF%E3%80%81%E3%80%8CLibDiagCom_Initialized%E3%80%8D%E3%81%AE%E5%80%A4%E3%81%8C%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AF%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%A0%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E6%96%B9%E3%81%8C%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E7%94%BB%E5%83%8F%E3%81%AB%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A6%8B%E5%BD%93%E3%81%9F%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
