S32K312 Wakeup using RTC timer
4,835 次查看
Akhil1
Hello
I am working on S32K312 and I want to make S32K312 to go to standby mode and need to wakeup using RTC timer for 5 sec.
after going to standby mode...need to wakeup after 5 sec automatically.
can you please help me regarding this and share any project examples.
Akhil
9 回复数
4,823 次查看
Senlent
Hi@Akhil1
Here is some demo you can refer to:
https://community.nxp.com/t5/S32K-Knowledge-Base/S32K3-Low-Power-Management-AN-and-demos/ta-p/152772...
be note, these demo based on RTD 2.0.0 and S32 DS V3.4
4,816 次查看
Akhil1
Hi @Senlent ,
Can you send me the RTD 3.0.0 version of S32K312 with RTC wakeup timer.
4,804 次查看
Senlent
Hi@Akhil1
Sorry, that's all we have, you can port it to new RTD version by yourself.
4,745 次查看
Akhil1
Hi @Senlent ,
I am trying to port into 3.0.0....but I am not getting the output.
Controller is going to sleep mode, but it is not wakeup after 5 sec.
I cannot share the project file because of some reasons. can you please help me.
Akhil
4,741 次查看
Senlent
Hi@Akhil1
The demo in the linker which i provided to you is working or not?
There is no big difference in RTD 2.0.0 vs RTD 3.0.0, It must a problem that something wrong with your porting.
4,738 次查看
Akhil1
Hi @Senlent ,
I have made all the configurations...but what is the mistake...i cant find it
Controller is going to sleep mode...but it is not getting wakeup.
Can you please help me.
4,736 次查看
Senlent
Hi@Akhil1
test RTC is working as expected or not,
If yes, check is RTC have set as wake up source or not.
4,734 次查看
Akhil1
Hi @Senlent ,
How can I check it?
4,727 次查看
Senlent
Hi@Akhil1
use debuger tool to see the RTC interrupt or other behavior is expected or not.
