S32K312 Secure Boot Fail
Lizijunasdasd
软件环境为:S32K312 ,HSE固件为2.40.0,A/B分区
开启安全启动后存在一个问题:
如果当前运行分区是低地址区域0x400000,这个时候切换分区后就无法正常运行,只能重新上下电才行。 如果当前运行分区是高地址区域0x500000,这个时候切换分区就可以正常运行。
lukaszadrapa
Hi @Lizijunasdasd
Could you please create new ticket here?
https://support.nxp.com/s/?language=en_US
Then it will be moved to regional FAE team assigned to support your company.
Thanks for understanding.
Lukas
