S32K312 Fault Injection without SAF
linxianti
Hello team
    If SAF and SPD aren't used in the application, is it possible to inject a fault in FCCU in order to test the reactions for these kind of faults?
    I found the Non-critical Fault Fake(NCFF) register in the Reference Manual. Will fault be injected if write a value in this register?
Thanks. & Regards.
Xianti
Tags (2)
danielmartynek
Hello @linxianti,
SAF and SPD inject faults into peripheral hardware via the EIM (Error Injection Module).
In contrast, the NCFF register injects faults directly into the FCCU, without affecting peripheral hardware.
If your goal is to test FCCU fault handling independently of peripheral fault sources, using NCFF is appropriate.
danielmartynek
Hello @linxianti,
linxianti
Hello Daniel
    Thanks for your reply.
    Regarding the EIM, does EIM only used to inject fault related with memory. Because i found this description in the Reference Manual. It doesn't apply for the other fault injection, e.g. clock fault or voltage fault, right?
    If yes, how can we inject this kind of fault except writing NCFF. Because writing NCFF can only verify the handling of fault, doesn't cover the detection of fault.
Thanks.& Regards.
 Xianti
danielmartynek
Hi @linxianti,
The CMU is not connected to the FCCU, and only a few VLD sources are linked.
For reference, here is a simple CMU example that uses the RTD MCAL MCU driver:
https://community.nxp.com/t5/S32K-Knowledge-Base/Example-S32K344-MCAL-MCU-ClockMonitor-v1-0-S32DS36-...
To test LVD functionality, you can manipulate the power supply voltage.
By the way, SPD/SAF also use the NCFF injection:
Any support, information, and technology (“Materials”) provided by NXP are provided AS IS, without any warranty express or implied, and NXP disclaims all direct and indirect liability and damages in connection with the Material to the maximum extent permitted by the applicable law.
NXP accepts no liability for any assistance with applications or product design. Materials may only be used in connection with NXP products. Any feedback provided to NXP regarding the Materials may be used by NXP without restriction.
%3CLINGO-SUB%20id%3D%22lingo-sub-2193239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K312%20Fault%20Injection%20without%20SAF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20team%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20If%20SAF%20and%20SPD%20aren't%20used%20in%20the%20application%2C%20is%20it%20possible%20to%20inject%20a%20fault%20in%20FCCU%20in%20order%20to%20test%20the%20reactions%20for%20these%20kind%20of%20faults%3F%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20I%20found%20the%20Non-critical%20Fault%20Fake(NCFF)%20register%20in%20the%20Reference%20Manual.%20Will%20fault%20be%20injected%20if%20write%20a%20value%20in%20this%20register%3F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22linxianti_0-1761548104306.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22linxianti_0-1761548104306.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362625i1EA9FB97027845A3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22linxianti_0-1761548104306.png%22%20alt%3D%22linxianti_0-1761548104306.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThanks.%20%26amp%3B%20Regards.%3C%2FP%3E%3CP%3EXianti%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195094%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K312%20Fault%20Injection%20without%20SAF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195094%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F211029%22%20target%3D%22_blank%22%3E%40linxianti%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThe%20CMU%20is%20not%20connected%20to%20the%20FCCU%2C%20and%20only%20a%20few%20VLD%20sources%20are%20linked.%3CBR%20%2F%3EFor%20reference%2C%20here%20is%20a%20simple%20CMU%20example%20that%20uses%20the%20RTD%20MCAL%20MCU%20driver%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FExample-S32K344-MCAL-MCU-ClockMonitor-v1-0-S32DS36-RTD600%2Fta-p%2F2179976%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FExample-S32K344-MCAL-MCU-ClockMonitor-v1-0-S32DS36-RTD600%2Fta-p%2F2179976%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3ETo%20test%20LVD%20functionality%2C%20you%20can%20manipulate%20the%20power%20supply%20voltage.%3C%2FP%3E%0A%3CP%3EBy%20the%20way%2C%20SPD%2FSAF%20also%20use%20the%20NCFF%20injection%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielmartynek_0-1761738678816.png%22%20style%3D%22width%3A%20490px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1761738678816.png%22%20style%3D%22width%3A%20490px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363081i0B6B99DEAC05C21B%2Fimage-dimensions%2F490x345%3Fv%3Dv2%22%20width%3D%22490%22%20height%3D%22345%22%20role%3D%22button%22%20title%3D%22danielmartynek_0-1761738678816.png%22%20alt%3D%22danielmartynek_0-1761738678816.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%0A%3CPRE%3E%3CFONT%20size%3D%221%202%203%204%205%206%207%22%3EAny%20support%2C%20information%2C%20and%20technology%20(%E2%80%9CMaterials%E2%80%9D)%20provided%20by%20NXP%20are%20provided%20AS%20IS%2C%20%3C%2FFONT%3E%3CFONT%20size%3D%221%202%203%204%205%206%207%22%3Ewithout%20any%20warranty%20express%20or%20implied%2C%20and%20NXP%20disclaims%20all%20direct%20and%20indirect%20liability%20%3C%2FFONT%3E%3CFONT%20size%3D%221%202%203%204%205%206%207%22%3Eand%20damages%20in%20connection%20with%20the%20Material%20to%20the%20maximum%20extent%20permitted%20by%20the%20applicable%20law.%20%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%221%202%203%204%205%206%207%22%3ENXP%20accepts%20no%20liability%20for%20any%20assistance%20with%20applications%20or%20product%20design.%20%3C%2FFONT%3E%3CFONT%20size%3D%221%202%203%204%205%206%207%22%3EMaterials%20may%20only%20be%20used%20in%20connection%20with%20NXP%20products.%20%3C%2FFONT%3E%3CFONT%20size%3D%221%202%203%204%205%206%207%22%3EAny%20feedback%20provided%20to%20NXP%20regarding%20the%20Materials%20may%20be%20used%20by%20NXP%20without%20restriction.%3C%2FFONT%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K312%20Fault%20Injection%20without%20SAF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CSPAN%3EDaniel%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20Thanks%20for%20your%20reply.%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20Regarding%20the%20EIM%2C%20does%20EIM%20only%20used%20to%20inject%20fault%20related%20with%20memory.%20Because%20i%20found%20this%20description%20in%20the%20Reference%20Manual.%20It%20doesn't%20apply%20for%20the%20other%20fault%20injection%2C%20e.g.%20clock%20fault%20or%20voltage%20fault%2C%20right%3F%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20If%20yes%2C%20how%20can%20we%20inject%20this%20kind%20of%20fault%20except%20writing%20NCFF.%20Because%20writing%20NCFF%20can%20only%20verify%20the%20handling%20of%20fault%2C%20doesn't%20cover%20the%20detection%20of%20fault.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22linxianti_0-1761556271778.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22linxianti_0-1761556271778.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362665iF4F315A8FF64B51E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22linxianti_0-1761556271778.png%22%20alt%3D%22linxianti_0-1761556271778.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks.%26amp%3B%20Regards.%3C%2FP%3E%3CP%3E%26nbsp%3BXianti%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K312%20Fault%20Injection%20without%20SAF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F211029%22%20target%3D%22_blank%22%3E%40linxianti%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3ESAF%20and%20SPD%20inject%20faults%20into%20peripheral%20hardware%20via%20the%20EIM%20(Error%20Injection%20Module).%3CBR%20%2F%3EIn%20contrast%2C%20the%20NCFF%20register%20injects%20faults%20directly%20into%20the%20FCCU%2C%20without%20affecting%20peripheral%20hardware.%3CBR%20%2F%3EIf%20your%20goal%20is%20to%20test%20FCCU%20fault%20handling%20independently%20of%20peripheral%20fault%20sources%2C%20using%20NCFF%20is%20appropriate.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
