S32K312-Error impact when entering StandBy process
Simon-Liu
Contributor V
Hello
When calling the function Power_Ip_SetMode to enter the StandBy process, there are several timeouts. For example, after setting the PRTN_PCONF register, it will wait for the status change of the PRTN_STAT register. If these timeouts occur, will the S32K312 be unable to enter StandBy and cannot wake up?
BestRegards
Simon
VaneB
Hi @Simon-Liu
In the following post are provided some examples developed based on RTD/HLD related to low power management, which you can use as a reference.
B.R.
VaneB
