S32K3 CAN-FD RX interrupt not occuring
9,105 次查看
Kazarian
We try to implement CAN-FD in interrupt mode based on the example “FlexCAN_Ip_Example_S32K344” which is not that useful since it use loopback and no interrupts.
What we tried to do is :
Create interrupt in IntCtrl_IP : FlexCAN0_1_IRQn , handler : CAN0_ORED_0_31_MB_IRQHandler
In FlexCan modul add callback function : flexcan0_Callback
Install the interrupts (please refere to attached file function FlexCan_Init_Config)
Implement the Callback function :  flexcan0_Callback
Modul can send the frames, but the reception is not triggering, can you please verify attached code and let me know what is you thought.
We want to receive Ids from 0x100 to 0x7FF. only STD ids not extended ones
const Flexcan_Ip_EnhancedIdTableType CAN0_EnhanceFIFO_IdFilterTable[1] =
			.filterType = FLEXCAN_IP_ENHANCED_RX_FIFO_RANGE_ID_FILTER,
			.isExtendedFrame = false,
			.id1 = 0x7FF ,	// STD ID From
			.id2 = 0x100, 	// STD ID To
			.rtr2 = FALSE,	// RTR filter
			.rtr1 = FALSE,	// RTR mask
 Best regards.
标记 (1)
8,894 次查看
Senlent
Hi@Kazarian
Please Copy Flexcan.c to your project and try agian, this should be an error caused by accessing temporary variables.
9 回复数
9,072 次查看
Kazarian
The hardfault comes if i set the payload in my Can frame to 64 byte , if i set it to whatever other smaller value (32-24-16..) the program run and i can receive frames correctly.
Flexcan_Ip_DataInfoType rx_info = {
	        .msg_id_type = FLEXCAN_MSG_ID_STD,
	        .data_length = 64u,
	        .is_polling  = FALSE,
	        .is_remote   = FALSE,
			.fd_enable   = TRUE,
Where should i change so can be able to receive a payload of 64bytes without hardfault ?
Regards.
8,895 次查看
Senlent
Hi@Kazarian
8,881 次查看
Kazarian
@Senlent Thanks a lot this works.
I'm looking to set a range of Standard CAN IDs, for example, from 0x100 to 0x300, without using the enhanced RX FIFO, which only supports 20 CAN FD messages.
Is there a method to achieve this? Alternatively, if that’s not possible, a global mask that would allow the device to accept all IDs would also work for my application.
8,877 次查看
Senlent
Hi@Kazarian
Please refer to this article which is also same with S32K3 mask settings.
https://community.nxp.com/t5/S32K-Knowledge-Base/S32K1xx-FlexCAN-Mask-Setting-Demo/ta-p/1519753
9,067 次查看
Kazarian
Register view
Kazarian_0-1732202037182.pngKazarian_0-1732202037182.pngKazarian_1-1732202074231.pngKazarian_1-1732202074231.png
9,044 次查看
Senlent
Hi@Kazarian
This may be related to the number of MB settings you have.
Please provide a complete demo if you encounter problems.
8,986 次查看
Kazarian
Hello @Senlent
i emailed you the code in private message.
Number of MB is 2, below is the configuration.
Thank you.
9,086 次查看
Senlent
Hi@Kazarian
Please see attached, this is a demo I made a while ago.
9,077 次查看
Kazarian
Hello @Senlent
Thanks a lot for your answer,
The MCU goes to hardfault when i send a can frame from my CAN-Case into the MCU.
i can however send frames from MCU to my Canoe.
i want to set a range of ids not only 1, and im using CAN-FD with 64 bytes, here is init function, can you please update the RX filter and also why the MCU hard fault ?
between im using Freertos i dont know how usefull this info can be !
Flexcan_Ip_StatusType FlexCan_Init_Config(void)
	Flexcan_Ip_StatusType retVal = E_NOT_OK;
	Flexcan_Ip_MsgBuffType rxData;
	        .data_length = 64u,
	        .is_remote   = FALSE,
			.fd_enable   = TRUE,
	/* Enable interrupt on CAN 0 */
	IntCtrl_Ip_EnableIrq(FlexCAN0_0_IRQn);
	IntCtrl_Ip_EnableIrq(FlexCAN0_1_IRQn);
	IntCtrl_Ip_EnableIrq(FlexCAN0_2_IRQn);
	retVal = FlexCAN_Ip_Init(INST_BOARD_INITPERIPHERALS_FLEXCAN_0, &FlexCAN_BOARD_InitPeripherals_State0, &FlexCAN_Config0_BOARD_InitPeripherals);
	retVal |= FlexCAN_Ip_SetRxIndividualMask(INST_BOARD_INITPERIPHERALS_FLEXCAN_0,RX_MB_IDX,0xFFFFFFFF);
	retVal |= FlexCAN_Ip_ConfigRxMb(INST_BOARD_INITPERIPHERALS_FLEXCAN_0, RX_MB_IDX, &rx_info, Rx_MSG_ID);
    /* Set the FlexCAN instance in START mode */
	retVal |= retVal |= FlexCAN_Ip_SetStartMode(INST_BOARD_INITPERIPHERALS_FLEXCAN_0);
	retVal |= FlexCAN_Ip_Receive(INST_BOARD_INITPERIPHERALS_FLEXCAN_0,RX_MB_IDX,&rxData,FALSE);
    return retVal;
Thank you.
标记 (1)
%3CLINGO-SUB%20id%3D%22lingo-sub-1997970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K3%20CAN-FD%20RX%E4%B8%AD%E6%96%AD%E6%9C%AA%E5%8F%91%E7%94%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1997970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B0%9D%E8%AF%95%E5%9F%BA%E4%BA%8E%E7%A4%BA%E4%BE%8B%E2%80%9CFlexCAN_Ip_Example_S32K344%E2%80%9D%E4%BB%A5%E4%B8%AD%E6%96%AD%E6%A8%A1%E5%BC%8F%E5%AE%9E%E7%8E%B0%20CAN-FD%EF%BC%8C%E4%BD%86%E7%94%B1%E4%BA%8E%E5%AE%83%E4%BD%BF%E7%94%A8%E7%8E%AF%E5%9B%9E%E8%80%8C%E6%B2%A1%E6%9C%89%E4%B8%AD%E6%96%AD%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%B8%8D%E5%A4%AA%E6%9C%89%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B0%9D%E8%AF%95%E5%81%9A%E7%9A%84%E6%98%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%9C%A8%20IntCtrl_IP%20%E4%B8%AD%E5%88%9B%E5%BB%BA%E4%B8%AD%E6%96%AD%EF%BC%9AFlexCAN0_1_IRQn%EF%BC%8C%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%EF%BC%9ACAN0_ORED_0_31_MB_IRQHandler%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kazarian_0-1732099187138.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kazarian_0-1732099187138.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311449iA347F212DB379603%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Kazarian_0-1732099187138.png%22%20alt%3D%22Kazarian_0-1732099187138.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKazarian_0-1732099187138.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%20FlexCan%20%E6%A8%A1%E5%9D%97%E4%B8%AD%E6%B7%BB%E5%8A%A0%E5%9B%9E%E8%B0%83%E5%87%BD%E6%95%B0%EF%BC%9Aflexcan0_Callback%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kazarian_1-1732099200155.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kazarian_1-1732099200155.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311450iEDD1D751D2DE2482%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Kazarian_1-1732099200155.png%22%20alt%3D%22Kazarian_1-1732099200155.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKazarian_1-1732099200155.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%AE%89%E8%A3%85%E4%B8%AD%E6%96%AD%EF%BC%88%E8%AF%B7%E5%8F%82%E8%80%83%E9%99%84%E4%BB%B6%E5%87%BD%E6%95%B0%3CSTRONG%3EFlexCan_Init_Config%3C%2FSTRONG%3E%20%EF%BC%89%3C%2FP%3E%3CP%3E%E5%AE%9E%E7%8E%B0%E5%9B%9E%E8%B0%83%E5%87%BD%E6%95%B0%EF%BC%9A%20%3CSTRONG%3E%3CU%3Eflexcan0_Callback%3C%2FU%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%A8%A1%E5%9D%97%E5%8F%AF%E4%BB%A5%E5%8F%91%E9%80%81%E5%B8%A7%EF%BC%8C%E4%BD%86%E6%8E%A5%E6%94%B6%E6%9C%AA%E8%A7%A6%E5%8F%91%EF%BC%8C%E6%82%A8%E8%83%BD%E5%90%A6%E9%AA%8C%E8%AF%81%E9%99%84%E5%8A%A0%E7%9A%84%E4%BB%A3%E7%A0%81%E5%B9%B6%E8%AE%A9%E6%88%91%E7%9F%A5%E9%81%93%E6%82%A8%E7%9A%84%E6%83%B3%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B8%8C%E6%9C%9B%E6%8E%A5%E6%94%B6%E4%BB%8E%200x100%20%E5%88%B0%200x7FF%20%E7%9A%84%20ID%E3%80%82%E4%BB%85%E9%99%90%20STD%20ID%EF%BC%8C%E4%B8%8D%E5%8C%85%E6%8B%AC%E6%89%A9%E5%B1%95%20ID%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Econst%20Flexcan_Ip_EnhancedIdTableType%20CAN0_EnhanceFIFO_IdFilterTable%5B1%5D%20%3D%0A%7B%0A%09%09%7B%0A%09%09%09.filterType%20%3D%20FLEXCAN_IP_ENHANCED_RX_FIFO_RANGE_ID_FILTER%2C%0A%09%09%09.isExtendedFrame%20%3D%20false%2C%0A%09%09%09.id1%20%3D%200x7FF%20%2C%09%2F%2F%20STD%20ID%20From%0A%09%09%09.id2%20%3D%200x100%2C%20%09%2F%2F%20STD%20ID%20To%0A%09%09%09.rtr2%20%3D%20FALSE%2C%09%2F%2F%20RTR%20filter%0A%09%09%09.rtr1%20%3D%20FALSE%2C%09%2F%2F%20RTR%20mask%0A%09%09%7D%2C%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E8%87%B4%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2000884%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K3%20CAN-FD%20RX%E4%B8%AD%E6%96%AD%E6%9C%AA%E5%8F%91%E7%94%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2000884%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%40%3CSPAN%3E%E5%8D%A1%E6%89%8E%E9%87%8C%E5%AE%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%E6%9C%AC%E6%96%87%EF%BC%8C%E5%AE%83%E4%B9%9F%E4%B8%8E%20S32K3%20%E6%8E%A9%E7%A0%81%E8%AE%BE%E7%BD%AE%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K1xx-FlexCAN-Mask-Setting-Demo%2Fta-p%2F1519753%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K1xx-FlexCAN-Mask-Setting-Demo%2Fta-p%2F1519753%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2000868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K3%20CAN-FD%20RX%E4%B8%AD%E6%96%AD%E6%9C%AA%E5%8F%91%E7%94%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2000868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F188029%22%20target%3D%22_blank%22%3E%40Senlent%3C%2FA%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%8C%E8%BF%99%E4%B8%AA%E6%96%B9%E6%B3%95%E6%9C%89%E6%95%88%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B8%8C%E6%9C%9B%E8%AE%BE%E7%BD%AE%E4%B8%80%E7%B3%BB%E5%88%97%E6%A0%87%E5%87%86%20CAN%20ID%EF%BC%8C%E4%BE%8B%E5%A6%82%E4%BB%8E%200x100%20%E5%88%B0%200x300%EF%BC%8C%E8%80%8C%E4%B8%8D%E4%BD%BF%E7%94%A8%E4%BB%85%E6%94%AF%E6%8C%81%2020%20%E4%B8%AA%20CAN%20FD%20%E6%B6%88%E6%81%AF%E7%9A%84%E5%A2%9E%E5%BC%BA%E5%9E%8B%20RX%20FIFO%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E4%BB%80%E4%B9%88%E6%96%B9%E6%B3%95%E5%8F%AF%E4%BB%A5%E5%AE%9E%E7%8E%B0%E8%BF%99%E4%B8%AA%E7%9B%AE%E7%9A%84%EF%BC%9F%E6%88%96%E8%80%85%EF%BC%8C%E5%A6%82%E6%9E%9C%E8%BF%99%E4%B8%8D%E5%8F%AF%E8%83%BD%E7%9A%84%E8%AF%9D%EF%BC%8C%E5%85%81%E8%AE%B8%E8%AE%BE%E5%A4%87%E6%8E%A5%E5%8F%97%E6%89%80%E6%9C%89%20ID%20%E7%9A%84%E5%85%A8%E5%B1%80%E6%8E%A9%E7%A0%81%E4%B9%9F%E9%80%82%E7%94%A8%E4%BA%8E%E6%88%91%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2000739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K3%20CAN-FD%20RX%E4%B8%AD%E6%96%AD%E6%9C%AA%E5%8F%91%E7%94%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2000739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%40%3CSPAN%3E%E5%8D%A1%E6%89%8E%E9%87%8C%E5%AE%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%B0%86%20Flexcan.c%20%E5%A4%8D%E5%88%B6%E5%88%B0%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%B9%B6%E9%87%8D%E8%AF%95%EF%BC%8C%E8%BF%99%E5%BA%94%E8%AF%A5%E6%98%AF%E8%AE%BF%E9%97%AE%E4%B8%B4%E6%97%B6%E5%8F%98%E9%87%8F%E5%AF%BC%E8%87%B4%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_0-1732514338430.png%22%20style%3D%22width%3A%20674px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1732514338430.png%22%20style%3D%22width%3A%20674px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F312212iBA2589440172CFE6%2Fimage-dimensions%2F674x206%3Fv%3Dv2%22%20width%3D%22674%22%20height%3D%22206%22%20role%3D%22button%22%20title%3D%22Senlent_0-1732514338430.png%22%20alt%3D%22Senlent_0-1732514338430.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESenlent_0-1732514338430.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1999877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K3%20CAN-FD%20RX%E4%B8%AD%E6%96%AD%E6%9C%AA%E5%8F%91%E7%94%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1999877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F188029%22%20target%3D%22_blank%22%3E%40Senlent%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%88%91%E9%80%9A%E8%BF%87%E7%A7%81%E4%BA%BA%E6%B6%88%E6%81%AF%E5%B0%86%E4%BB%A3%E7%A0%81%E9%80%9A%E8%BF%87%E7%94%B5%E5%AD%90%E9%82%AE%E4%BB%B6%E5%8F%91%E9%80%81%E7%BB%99%E6%82%A8%E3%80%82%3C%2FP%3E%3CP%3EMB%E6%95%B0%E4%B8%BA2%EF%BC%8C%E4%BB%A5%E4%B8%8B%E6%98%AF%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kazarian_0-1732261935128.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kazarian_0-1732261935128.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311950i82D97A7570E608B5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Kazarian_0-1732261935128.png%22%20alt%3D%22Kazarian_0-1732261935128.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKazarian_0-1732261935128.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kazarian_1-1732261954422.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kazarian_1-1732261954422.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311952iB59F9A1241659871%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Kazarian_1-1732261954422.png%22%20alt%3D%22Kazarian_1-1732261954422.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKazarian_1-1732261954422.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1999609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K3%20CAN-FD%20RX%E4%B8%AD%E6%96%AD%E6%9C%AA%E5%8F%91%E7%94%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1999609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%40%3CSPAN%3E%E5%8D%A1%E6%89%8E%E9%87%8C%E5%AE%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E5%8F%AF%E8%83%BD%E4%B8%8E%E6%82%A8%E7%9A%84%3CSTRONG%3EMB%20%E8%AE%BE%E7%BD%AE%E6%95%B0%E9%87%8F%3C%2FSTRONG%3E%E6%9C%89%E5%85%B3%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E9%81%87%E5%88%B0%E9%97%AE%E9%A2%98%E8%AF%B7%E6%8F%90%E4%BE%9B%E5%AE%8C%E6%95%B4%E7%9A%84demo%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1998972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K3%20CAN-FD%20RX%E4%B8%AD%E6%96%AD%E6%9C%AA%E5%8F%91%E7%94%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1998972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%B3%A8%E5%86%8C%E8%A7%86%E5%9B%BE%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kazarian_0-1732202037182.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kazarian_0-1732202037182.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311738i7D5CE8FE48510C25%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Kazarian_0-1732202037182.png%22%20alt%3D%22Kazarian_0-1732202037182.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKazarian_0-1732202037182.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kazarian_1-1732202074231.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kazarian_1-1732202074231.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311739i822B4947A4AAEA2E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Kazarian_1-1732202074231.png%22%20alt%3D%22Kazarian_1-1732202074231.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKazarian_1-1732202074231.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1998761%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K3%20CAN-FD%20RX%E4%B8%AD%E6%96%AD%E6%9C%AA%E5%8F%91%E7%94%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1998761%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%B0%86%20Can%20%E5%B8%A7%E4%B8%AD%E7%9A%84%E6%9C%89%E6%95%88%E8%BD%BD%E8%8D%B7%E8%AE%BE%E7%BD%AE%E4%B8%BA%2064%20%E5%AD%97%E8%8A%82%EF%BC%8C%E5%B0%B1%E4%BC%9A%E5%87%BA%E7%8E%B0%E7%A1%AC%E6%95%85%E9%9A%9C%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E5%B0%86%E5%85%B6%E8%AE%BE%E7%BD%AE%E4%B8%BA%E5%85%B6%E4%BB%96%E8%BE%83%E5%B0%8F%E7%9A%84%E5%80%BC%EF%BC%8832-24-16..%EF%BC%89%EF%BC%8C%E7%A8%8B%E5%BA%8F%E5%B0%B1%E4%BC%9A%E8%BF%90%E8%A1%8C%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%88%91%E5%8F%AF%E4%BB%A5%E6%AD%A3%E7%A1%AE%E6%8E%A5%E6%94%B6%E5%B8%A7%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kazarian_0-1732181623540.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kazarian_0-1732181623540.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F311680iC66D01C27F729BBD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Kazarian_0-1732181623540.png%22%20alt%3D%22Kazarian_0-1732181623540.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKazarian_0-1732181623540.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3EFlexcan_Ip_DataInfoType%20rx_info%20%3D%20%7B%0A%09%20%20%20%20%20%20%20%20.msg_id_type%20%3D%20FLEXCAN_MSG_ID_STD%2C%0A%09%20%20%20%20%20%20%20%20.data_length%20%3D%2064u%2C%0A%09%20%20%20%20%20%20%20%20.is_polling%20%20%3D%20FALSE%2C%0A%09%20%20%20%20%20%20%20%20.is_remote%20%20%20%3D%20FALSE%2C%0A%09%09%09.fd_enable%20%20%20%3D%20TRUE%2C%0A%09%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E5%BA%94%E8%AF%A5%E5%9C%A8%E5%93%AA%E9%87%8C%E8%BF%9B%E8%A1%8C%E6%9B%B4%E6%94%B9%E6%89%8D%E8%83%BD%E6%8E%A5%E6%94%B6%2064%20%E5%AD%97%E8%8A%82%E7%9A%84%E6%9C%89%E6%95%88%E8%BD%BD%E8%8D%B7%E8%80%8C%E4%B8%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E7%A1%AC%E6%95%85%E9%9A%9C%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1998687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K3%20CAN-FD%20RX%E4%B8%AD%E6%96%AD%E6%9C%AA%E5%8F%91%E7%94%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1998687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F188029%22%20target%3D%22_blank%22%3E%40Senlent%3C%2FA%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E7%AD%94%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%B0%86%20CAN%20%E5%B8%A7%E4%BB%8E%E6%88%91%E7%9A%84%20CAN-Case%20%E5%8F%91%E9%80%81%E5%88%B0%20MCU%20%E6%97%B6%EF%BC%8CMCU%20%E8%BF%9B%E5%85%A5%E7%A1%AC%E6%95%85%E9%9A%9C%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E6%88%91%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%B8%A7%E4%BB%8E%20MCU%20%E5%8F%91%E9%80%81%E5%88%B0%E6%88%91%E7%9A%84%20Canoe%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E8%AE%BE%E7%BD%AE%E4%B8%80%E7%B3%BB%E5%88%97%20ID%EF%BC%8C%E4%B8%8D%E4%BB%85%E4%BB%85%E6%98%AF%201%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%2064%20%E5%AD%97%E8%8A%82%E7%9A%84%20CAN-FD%EF%BC%8C%E8%BF%99%E6%98%AF%E5%88%9D%E5%A7%8B%E5%8C%96%E5%87%BD%E6%95%B0%EF%BC%8C%E6%82%A8%E8%83%BD%E5%90%A6%E6%9B%B4%E6%96%B0%20RX%20%E8%BF%87%E6%BB%A4%E5%99%A8%E4%BB%A5%E5%8F%8A%E4%B8%BA%E4%BB%80%E4%B9%88%20MCU%20%E5%87%BA%E7%8E%B0%E7%A1%AC%E6%95%85%E9%9A%9C%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%88%91%E4%BD%BF%E7%94%A8%20Freertos%20%E6%9C%9F%E9%97%B4%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%E6%9C%89%E5%A4%9A%E5%A4%A7%E7%94%A8%E5%A4%84%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3EFlexcan_Ip_StatusType%20FlexCan_Init_Config(void)%0A%7B%0A%09Flexcan_Ip_StatusType%20retVal%20%3D%20E_NOT_OK%3B%0A%0A%09Flexcan_Ip_MsgBuffType%20rxData%3B%0A%0A%09Flexcan_Ip_DataInfoType%20rx_info%20%3D%20%7B%0A%09%20%20%20%20%20%20%20%20.msg_id_type%20%3D%20FLEXCAN_MSG_ID_STD%2C%0A%09%20%20%20%20%20%20%20%20.data_length%20%3D%2064u%2C%0A%09%20%20%20%20%20%20%20%20.is_polling%20%20%3D%20FALSE%2C%0A%09%20%20%20%20%20%20%20%20.is_remote%20%20%20%3D%20FALSE%2C%0A%09%09%09.fd_enable%20%20%20%3D%20TRUE%2C%0A%09%7D%3B%0A%0A%09%2F*%20Enable%20interrupt%20on%20CAN%200%20*%2F%0A%09IntCtrl_Ip_EnableIrq(FlexCAN0_0_IRQn)%3B%0A%09IntCtrl_Ip_EnableIrq(FlexCAN0_1_IRQn)%3B%0A%09IntCtrl_Ip_EnableIrq(FlexCAN0_2_IRQn)%3B%0A%0A%09retVal%20%3D%20FlexCAN_Ip_Init(INST_BOARD_INITPERIPHERALS_FLEXCAN_0%2C%20%26amp%3BFlexCAN_BOARD_InitPeripherals_State0%2C%20%26amp%3BFlexCAN_Config0_BOARD_InitPeripherals)%3B%0A%0A%09retVal%20%7C%3D%20FlexCAN_Ip_SetRxIndividualMask(INST_BOARD_INITPERIPHERALS_FLEXCAN_0%2CRX_MB_IDX%2C0xFFFFFFFF)%3B%0A%0A%09retVal%20%7C%3D%20FlexCAN_Ip_ConfigRxMb(INST_BOARD_INITPERIPHERALS_FLEXCAN_0%2C%20RX_MB_IDX%2C%20%26amp%3Brx_info%2C%20Rx_MSG_ID)%3B%0A%0A%20%20%20%20%2F*%20Set%20the%20FlexCAN%20instance%20in%20START%20mode%20*%2F%0A%09retVal%20%7C%3D%20retVal%20%7C%3D%20FlexCAN_Ip_SetStartMode(INST_BOARD_INITPERIPHERALS_FLEXCAN_0)%3B%0A%0A%0A%09retVal%20%7C%3D%20FlexCAN_Ip_Receive(INST_BOARD_INITPERIPHERALS_FLEXCAN_0%2CRX_MB_IDX%2C%26amp%3BrxData%2CFALSE)%3B%0A%0A%0A%20%20%20%20return%20retVal%3B%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1998498%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K3%20CAN-FD%20RX%E4%B8%AD%E6%96%AD%E6%9C%AA%E5%8F%91%E7%94%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1998498%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%40%3CSPAN%3E%E5%8D%A1%E6%89%8E%E9%87%8C%E5%AE%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%E9%99%84%E4%BB%B6%EF%BC%8C%E8%BF%99%E6%98%AF%E6%88%91%E4%B9%8B%E5%89%8D%E5%88%B6%E4%BD%9C%E7%9A%84%E4%B8%80%E4%B8%AA%E6%BC%94%E7%A4%BA%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
