S32K3 Bootloader
S32K3 Bootloader
vinaykl
Hello NXP Team,
We have an S32K312 EVK with us. We want to implement bootloader for our EVK. As you mentioned in S32K144 is it possible to use A/B Swapping technique for S32K3 also? And if you have any bootloader and gateway examples kindly share here.
Thanks and regards
Vinay
lukaszadrapa
Hi @vinaykl
Yes, there's HW support for AB swap on S32K3 devices. You can take a look at "S32K3XX HSE and OTA Advance Training" (pages 59 - 86) which can be found in section Documentation -> Secure files on S32K3 page:
https://www.nxp.com/products/S32K3
The AB swap is performed by HSE service, so it's necessary to have AB swap version of HSE firmware installed. You can take a look at this post how to run the HSE service:
https://community.nxp.com/t5/S32K/s32k3-flash-swap-requirements/m-p/1920123/highlight/true#M38475
Currently there are two OTA Demo applications. You can find it in S32K3 Reference Software package:
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=SW32K3-REFSW-D
Search for "Automotive SW - S32K3 - OTA Demo".
Lukas
